root/radiance/ray/src/px/ra_pict.c
Revision: 2.2
Committed: Thu Nov 21 11:34:10 1991 UTC (33 years, 5 months ago) by greg
Changes since 2.1: +158 -63 lines
bug fixes from second version
2 static char SCCSid[] = "$SunId$ Auckuni";
4
5 /*
6 * rad2pict -
7 * Convert an Radiance image to APPLE pict format.
8 *
9 * Orginally Iris to PICT by Paul Haeberli - 1990
10 * Hacked into Rad to PICT by Russell Street 1990
11 *
12 * History:
13 * V 1 -- Does basic conversion
14 * V 1.1 (2/11/91) -- Added options for Gamma
15 * -- verbose option
16 * -- man page
17 * -- better about allocating buffers
18 * V 1.2 (19/11/91) -- Revised to handle opening "The Radiance Way"
19 * -- Added exposure level adjustment
20 */
21
22 #include <stdio.h>
23 #include <stdlib.h>
24
25 #include "pict.h"
26 #include "color.h"
27 #include "resolu.h"
28
29 int outbytes; /* This had better be 32 bits! */
30 char *progname;
31 int verbose = 0;
32 float gamma = 2.0;
33 int bradj = 0;
34
35 /* First some utility routines */
36
37 putrect(xorg,yorg,xsize,ysize)
38 int xorg, yorg, xsize, ysize;
39 {
40 putashort(yorg);
41 putashort(xorg);
42 putashort(ysize);
43 putashort(xsize);
44 }
45
46 putfprect(xorg,yorg,xsize,ysize)
47 int xorg, yorg, xsize, ysize;
48 {
49 putalong(yorg<<16);
50 putalong(xorg<<16);
51 putalong(ysize<<16);
52 putalong(xsize<<16);
53 }
54
55 putalong(l)
56 long l;
57 {
58 putbyte((l>>24)&0xff);
59 putbyte((l>>16)&0xff);
60 putbyte((l>>8)&0xff);
61 putbyte((l>>0)&0xff);
62 }
63
64 putashort(s)
65 short s;
66 {
67 putbyte((s>>8)&0xff);
68 putbyte((s>>0)&0xff);
69 }
70
71 putbyte(b)
72 int b;
73 {
74 if (putc(b,stdout) == EOF && ferror(stdout)) {
75 fprintf(stderr,"%s: error on write\n", progname);
76 exit(1);
77 }
78 outbytes++;
79 }
80
81 putbytes(buf,n)
82 unsigned char *buf;
83 int n;
84 {
85 if(!fwrite(buf,n,1,stdout)) {
86 fprintf(stderr,"%s: error on write\n", progname);
87 exit(1);
88 }
89 outbytes+=n;
90 }
91
92 main(argc,argv)
93 int argc;
94 char **argv;
95 {
96 int xsize, ysize;
97 int i, picsize;
98 int ssizepos, lsizepos;
99
100 progname = argv[0];
101
102 for (i = 1; i < argc ; i++)
103 if (argv[i][0] == '-')
104 switch (argv[i][1]) {
105 case 'g': gamma = atof(argv[++i]);
106 break;
107
108 case 'e': if (argv[i+1][0] != '+' && argv[i+1][0] != '-')
109 usage();
110 else
111 bradj = atoi(argv[++i]);
112 break;
113
114 case 'v': ;
115 verbose = 1;
116 break;
117
118 case 'r': fprintf(stderr, "Sorry. Get a Macintosh :-)\n");
119 exit(1);
120
121 case '-': i++;
122 goto outofparse;
123 break; /* NOTREACHED */
124
125 otherwise: usage();
126 break;
127 }
128 else
129 break;
130
131 outofparse:
132
133 if (i < argc - 2)
134 usage();
135
136 if (i <= argc - 1 && freopen(argv[i], "r", stdin) == NULL) {
137 fprintf(stderr, "%s: can not open input \"%s\"\n",
138 progname, argv[i]);
139 exit(1);
140 }
141
142 if (i <= argc - 2 && freopen(argv[i+1], "w", stdout) == NULL) {
143 fprintf(stderr, "%s: can not open input \"%s\"\n",
144 progname, argv[i+1]);
145 exit(1);
146 }
147
148 #ifdef DEBUG
149 fprintf(stderr, "Input file: %s\n", i <= argc - 1 ? argv[i] : "stdin");
150 fprintf(stderr, "Outut file: %s\n", i <= argc - 2 ? argv[i+1] : "stdout" );
151 fprintf(stderr, "Gamma: %f\n", gamma);
152 fprintf(stderr, "Brightness adjust: %d\n", bradj);
153 fprintf(stderr, "Verbose: %s\n", verbose ? "on" : "off");
154 #endif
155
156
157 /* OK. Now we read the size of the Radiance picture */
158 if (checkheader(stdin, COLRFMT, NULL) < 0 ||
159 fgetresolu(&xsize, &ysize, stdin) < 0 /* != (YMAJOR|YDECR) */ ) {
160 fprintf(stderr, "%s: not a radiance picture\n", progname);
161 exit(1);
162 }
163
164 /* Set the gamma correction */
165
166 setcolrgam(gamma);
167
168 for(i=0; i<HEADER_SIZE; i++)
169 putbyte(0);
170
171 ssizepos = outbytes;
172 putashort(0); /* low 16 bits of file size less HEADER_SIZE */
173 putrect(0,0,xsize,ysize); /* bounding box of picture */
174 putashort(PICT_picVersion);
175 putashort(0x02ff); /* version 2 pict */
176 putashort(PICT_reservedHeader); /* reserved header opcode */
177
178 lsizepos = outbytes;
179 putalong(0); /* full size of the file */
180 putfprect(0,0,xsize,ysize); /* fixed point bounding box of picture */
181 putalong(0); /* reserved */
182
183 putashort(PICT_clipRgn); /* the clip region */
184 putashort(10);
185 putrect(0,0,xsize,ysize);
186
187 if (verbose)
188 fprintf(stderr, "%s: The picture is %d by %d, with a gamma of %f\n",
189 progname, xsize, ysize, gamma);
190
191
192 putpict(xsize, ysize); /* Here is where all the work is done */
193
194 putashort(PICT_EndOfPicture); /* end of pict */
195
196 picsize = outbytes-HEADER_SIZE;
197 fseek(stdout,ssizepos,0);
198 putashort(picsize&0xffff);
199 fseek(stdout,lsizepos,0);
200 putalong(picsize);
201
202 fclose(stdout);
203 fclose(stdin);
204
205 exit(0);
206 return 0; /* lint fodder */
207 }
208
209 putpict(xsize, ysize)
210 int xsize;
211 int ysize;
212 {
213 int y;
214 int nbytes, rowbytes;
215 char *cbuf, *pbuf;
216
217 cbuf = malloc(4 * xsize);
218
219 if (cbuf == NULL) {
220 fprintf(stderr, "%s: not enough memory\n", progname);
221 exit(1);
222 }
223
224 pbuf = malloc(4 * xsize);
225
226 if (pbuf == NULL) {
227 fprintf(stderr, "%s: not enough memory\n", progname);
228 exit(1);
229 }
230
231 putashort(PICT_Pack32BitsRect); /* 32 bit rgb */
232 rowbytes = 4*xsize;
233 putalong(0x000000ff); /* base address */
234
235
236 if(rowbytes&1)
237 rowbytes++;
238 putashort(rowbytes|0x8000); /* rowbytes */
239 putrect(0,0,xsize,ysize); /* bounds */
240 putashort(0); /* version */
241
242 putashort(4); /* packtype */
243 putalong(0); /* packsize */
244 putalong(72<<16); /* hres */
245 putalong(72<<16); /* vres */
246
247 putashort(16); /* pixeltype */
248 putashort(32); /* pixelsize */
249 putashort(3); /* cmpcount */
250
251
252 putashort(8); /* cmpsize */
253 putalong(0); /* planebytes */
254 putalong(0); /* pmtable */
255 putalong(0); /* pmreserved */
256
257
258 putrect(0,0,xsize,ysize); /* scr rect */
259 putrect(0,0,xsize,ysize); /* dest rect */
260
261
262 putashort(0x40); /* transfer mode */
263
264 for(y=0; y<ysize; y++) {
265 getrow(stdin, cbuf, xsize);
266
267 nbytes = packbits(cbuf,pbuf,24*xsize);
268 if(rowbytes>250)
269 putashort(nbytes);
270 else
271 putbyte(nbytes);
272 putbytes(pbuf,nbytes);
273 }
274
275 if(outbytes&1)
276 putbyte(0);
277
278 free(cbuf);
279 free(pbuf);
280 }
281
282 int getrow(in, cbuf, xsize)
283 FILE *in;
284 char *cbuf;
285 int xsize;
286 {
287 extern char *tempbuffer(); /* defined in color.c */
288 COLR *scanin = NULL;
289 int x;
290
291 if ((scanin = (COLR *)tempbuffer(xsize*sizeof(COLR))) == NULL) {
292 fprintf(stderr, "%s: not enough memory\n", progname);
293 exit(1);
294 }
295
296 if (freadcolrs(scanin, xsize, in) < 0) {
297 fprintf(stderr, "%s: read error\n", progname);
298 exit(1);
299 }
300
301 if (bradj) /* Adjust exposure level */
302 shiftcolrs(scanin, xsize, bradj);
303
304
305 colrs_gambs(scanin, xsize); /* Gamma correct it */
306
307 for (x = 0; x < xsize; x++) {
308 cbuf[x] = scanin[x][RED];
309 cbuf[xsize + x] = scanin[x][GRN];
310 cbuf[2*xsize + x] = scanin[x][BLU];
311 }
312
313 }
314
315
316 packbits(ibits,pbits,nbits)
317 unsigned char *ibits, *pbits;
318 int nbits;
319 {
320 int bytes; /* UNUSED */
321 unsigned char *sptr;
322 unsigned char *ibitsend;
323 unsigned char *optr = pbits;
324 int nbytes, todo, cc, count;
325
326 nbytes = ((nbits-1)/8)+1;
327 ibitsend = ibits+nbytes;
328 while(ibits<ibitsend) {
329 sptr = ibits;
330 ibits += 2;
331 while((ibits<ibitsend)&&((ibits[-2]!=ibits[-1])||(ibits[-1]!=ibits[0])))
332 ibits++;
333 if(ibits != ibitsend) {
334 ibits -= 2;
335 }
336 count = ibits-sptr;
337 while(count) {
338 todo = count>127 ? 127:count;
339 count -= todo;
340 *optr++ = todo-1;
341 while(todo--)
342 *optr++ = *sptr++;
343 }
344 if(ibits == ibitsend)
345 break;
346 sptr = ibits;
347 cc = *ibits++;
348 while( (ibits<ibitsend) && (*ibits == cc) )
349 ibits++;
350 count = ibits-sptr;
351 while(count) {
352 todo = count>128 ? 128:count;
353 count -= todo;
354 *optr++ = 257-todo;
355 *optr++ = cc;
356 }
357 }
358 return optr-pbits;
359 }
360
361 usage()
362 {
363 fprintf(stderr, "Usage: %s [-v] [-g gamma] [infile [outfile]]\n",
364 progname);
365 exit(2);
366 }
