root/radiance/ray/src/px/ra_pfm.csh
Fri Nov 17 19:14:54 2006 UTC (18 years, 8 months ago) by greg
CVS Tags: HEAD, rad3R9, rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0, rad5R1, rad5R2, rad5R3, rad5R4, rad6R0
Corrected Usage: output
Fri Jan 14 06:40:54 2005 UTC (20 years, 6 months ago) by greg
Changes since 2.3: +13 -5 lines
Fixed orientation of PFM to match standard at www.debevec.org/Research/HDR/PFM
Thu Dec 30 18:33:50 2004 UTC (20 years, 7 months ago) by greg
Changes since 2.2: +47 -12 lines
More improvements and bug fixes
Sat Dec 25 04:14:25 2004 UTC (20 years, 7 months ago) by greg
Diff to previous 2.1
Corrected x-y coordinate reversal in -r conversion
Thu Nov 25 14:47:03 2004 UTC (20 years, 8 months ago) by greg
Links to HEAD: (view) (download) (as text) (annotate) Links to rad6R0: (view) (download) (as text) (annotate)
