root/Development/ray/src/px/ra_pfm.csh
Revision: 2.5
Committed: Fri Nov 17 19:14:54 2006 UTC (18 years, 11 months ago) by greg
Content type: application/x-csh
CVS Tags: rad5R4, rad5R2, rad5R3, rad5R0, rad5R1, rad4R2, rad6R0, rad4R1, rad4R0, rad3R9, rad4R2P1, rad4R2P2, HEAD
Corrected Usage: output
1 #!/bin/csh -f
2 # RCSid $Id: ra_pfm.csh,v 2.4 2005/01/14 06:40:54 greg Exp $
3 #
4 # Convert to/from Poskanzer Float Map image format using pvalue
5 #
6 if (`uname -p` == powerpc) then
7 set machend=big
8 else
9 set machend=little
10 endif
11 while ($#argv > 0)
12 if ("$argv[1]" == "-r") then
13 set reverse
14 else if (! $?inp) then
15 set inp="$argv[1]"
16 else if (! $?out) then
17 set out="$argv[1]"
18 else
19 goto userr
20 endif
21 shift argv
22 end
23 if ($?reverse) then
24 if (! $?inp) then
25 goto userr
26 endif
27 set opt=""
28 set hl="`head -3 $inp:q`"
29 if ("$hl[1]" == "Pf") then
30 set opt=($opt -b)
31 else if ("$hl[1]" != "PF") then
32 echo "Input not a Poskanzer Float Map"
33 exit 1
34 endif
35 if (`ev "if($hl[3],1,0)"`) then
36 set filend=big
37 else
38 set filend=little
39 endif
40 if ($filend != $machend) then
41 set opt=($opt -dF)
42 else
43 set opt=($opt -df)
44 endif
45 set res=($hl[2])
46 if ($?out) then
47 tail +4 $inp:q | pvalue -r -h $opt +y $res[2] +x $res[1] > $out:q
48 else
49 tail +4 $inp:q | pvalue -r -h $opt +y $res[2] +x $res[1]
50 endif
51 exit $status
52 endif
53 if (! $?inp) then
54 goto userr
55 endif
56 set res=(`getinfo -d < $inp:q`)
57 if ($?out) then
58 ( echo PF ; echo $res[4] $res[2] ) > $out:q
59 if ($machend == little) then
60 echo "-1.000000" >> $out:q
61 else
62 echo "1.000000" >> $out:q
63 endif
64 if ("$res[1]" == "-Y") then
65 pflip -v $inp:q | pvalue -h -H -df >> $out:q
66 else
67 pvalue -h -H -df $inp:q >> $out:q
68 endif
69 else
70 echo PF
71 echo $res[4] $res[2]
72 if ($machend == little) then
73 echo "-1.000000"
74 else
75 echo "1.000000"
76 endif
77 if ("$res[1]" == "-Y") then
78 pflip -v $inp:q | pvalue -h -H -df
79 else
80 pvalue -h -H -df $inp:q
81 endif
82 endif
83 exit $status
84 userr:
85 echo "Usage: $0 input.hdr [output.pfm]"
86 echo " or: $0 -r input.pfm [output.hdr]"
87 exit 1
