root/radiance/ray/src/px/ra_gif.c
Fri Jul 19 17:37:56 2019 UTC (6 years ago) by greg
CVS Tags: HEAD, rad5R3, rad5R4, rad6R0
Changes since 2.12: +2 -3 lines
Diff to previous 2.12
Fri May 20 02:06:39 2011 UTC (14 years, 2 months ago) by greg
CVS Tags: rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0, rad5R1, rad5R2
Sun Mar 28 20:33:14 2004 UTC (21 years, 4 months ago) by schorsch
Changes since 2.10: +113 -70 lines
Sun Jul 27 22:12:03 2003 UTC (22 years ago) by schorsch
Mon Jul 21 22:30:19 2003 UTC (22 years ago) by schorsch
Changes since 2.8: +3 -2 lines
Thu Jun 5 19:29:34 2003 UTC (22 years, 2 months ago) by schorsch
Changes since 2.7: +6 -15 lines
Sat Feb 22 02:07:27 2003 UTC (22 years, 5 months ago) by greg
Changes since 2.6: +3 -4 lines
Mon Apr 3 15:29:43 1995 UTC (30 years, 4 months ago) by greg
Changes since 2.5: +3 -2 lines
fixed bug in -c option with -b
Mon Nov 21 15:55:59 1994 UTC (30 years, 8 months ago) by greg
fixed Usage message to mention -n option
Fri Jun 10 12:51:27 1994 UTC (31 years, 2 months ago) by greg
Changes since 2.3: +28 -10 lines
Fri May 20 11:44:19 1994 UTC (31 years, 2 months ago) by greg
fixed bug in read error handling
Tue May 3 10:06:32 1994 UTC (31 years, 3 months ago) by greg
Changes since 2.1: +14 -0 lines
added -d option and made dithering the default
Wed Mar 30 14:24:52 1994 UTC (31 years, 4 months ago) by greg
