root/radiance/ray/src/px/ra_gif.c
Fri May 20 02:06:39 2011 UTC (12 years, 11 months ago) by greg
CVS Tags: rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0, rad5R1, rad5R2
Changes since 2.10: +113 -70 lines
Changes since 2.8: +3 -2 lines
Changes since 2.7: +6 -15 lines
Changes since 2.6: +3 -4 lines
Mon Apr 3 15:29:43 1995 UTC (29 years, 1 month ago) by greg
Changes since 2.5: +3 -2 lines
fixed bug in -c option with -b
Mon Nov 21 15:55:59 1994 UTC (29 years, 5 months ago) by greg
fixed Usage message to mention -n option
Fri Jun 10 12:51:27 1994 UTC (29 years, 11 months ago) by greg
Changes since 2.3: +28 -10 lines
Fri May 20 11:44:19 1994 UTC (29 years, 11 months ago) by greg
fixed bug in read error handling
Tue May 3 10:06:32 1994 UTC (30 years ago) by greg
Changes since 2.1: +14 -0 lines
added -d option and made dithering the default
Wed Mar 30 14:24:52 1994 UTC (30 years, 1 month ago) by greg
Diff to selected 2.12
