root/radiance/ray/src/px/ra_gif.c
Sun Mar 28 20:33:14 2004 UTC (21 years, 1 month ago) by schorsch
Changes since 2.10: +113 -70 lines
Sun Jul 27 22:12:03 2003 UTC (21 years, 9 months ago) by schorsch
Mon Jul 21 22:30:19 2003 UTC (21 years, 9 months ago) by schorsch
Changes since 2.8: +3 -2 lines
Thu Jun 5 19:29:34 2003 UTC (21 years, 11 months ago) by schorsch
Changes since 2.7: +6 -15 lines
Sat Feb 22 02:07:27 2003 UTC (22 years, 2 months ago) by greg
Changes since 2.6: +3 -4 lines
Mon Apr 3 15:29:43 1995 UTC (30 years, 1 month ago) by greg
Changes since 2.5: +3 -2 lines
fixed bug in -c option with -b
Mon Nov 21 15:55:59 1994 UTC (30 years, 5 months ago) by greg
fixed Usage message to mention -n option
Fri Jun 10 12:51:27 1994 UTC (30 years, 11 months ago) by greg
Changes since 2.3: +28 -10 lines
Fri May 20 11:44:19 1994 UTC (30 years, 11 months ago) by greg
fixed bug in read error handling
Tue May 3 10:06:32 1994 UTC (31 years ago) by greg
Changes since 2.1: +14 -0 lines
added -d option and made dithering the default
Wed Mar 30 14:24:52 1994 UTC (31 years, 1 month ago) by greg
