1 |
/* Copyright (c) 1991 Regents of the University of California */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ LBL"; |
5 |
#endif |
6 |
7 |
8 |
* ra_bn.c - program to convert between RADIANCE and barneyscan picture format. |
9 |
10 |
* 10/12/88 |
11 |
12 |
13 |
#include <stdio.h> |
14 |
15 |
#include "color.h" |
16 |
17 |
extern double atof(), pow(); |
18 |
19 |
double gamma = 2.0; /* gamma correction */ |
20 |
21 |
int bradj = 0; /* brightness adjustment */ |
22 |
23 |
char *progname; |
24 |
25 |
char errmsg[128]; |
26 |
27 |
FILE *rafp, *bnfp[3]; |
28 |
29 |
int xmax, ymax; |
30 |
31 |
32 |
main(argc, argv) |
33 |
int argc; |
34 |
char *argv[]; |
35 |
36 |
int reverse = 0; |
37 |
int i; |
38 |
39 |
progname = argv[0]; |
40 |
41 |
for (i = 1; i < argc; i++) |
42 |
if (argv[i][0] == '-') |
43 |
switch (argv[i][1]) { |
44 |
case 'g': |
45 |
gamma = atof(argv[++i]); |
46 |
break; |
47 |
case 'r': |
48 |
reverse = !reverse; |
49 |
break; |
50 |
case 'e': |
51 |
if (argv[i+1][0] != '+' && argv[i+1][0] != '-') |
52 |
goto userr; |
53 |
bradj = atoi(argv[++i]); |
54 |
break; |
55 |
default: |
56 |
goto userr; |
57 |
58 |
else |
59 |
break; |
60 |
/* set gamma correction */ |
61 |
setcolrgam(gamma); |
62 |
63 |
if (reverse) { |
64 |
if (i > argc-1 || i < argc-2) |
65 |
goto userr; |
66 |
if (openbarney(argv[i], "r") < 0) { |
67 |
sprintf(errmsg, "cannot open input \"%s\"", argv[i]); |
68 |
quiterr(errmsg); |
69 |
70 |
if (i == argc-1 || !strcmp(argv[i+1], "-")) |
71 |
rafp = stdout; |
72 |
else if ((rafp = fopen(argv[i+1], "w")) == NULL) { |
73 |
sprintf(errmsg, "cannot open output \"%s\"", |
74 |
argv[i+1]); |
75 |
quiterr(errmsg); |
76 |
77 |
/* put header */ |
78 |
printargs(i, argv, rafp); |
79 |
fputformat(COLRFMT, rafp); |
80 |
putc('\n', rafp); |
81 |
fputresolu(YMAJOR|YDECR, xmax, ymax, rafp); |
82 |
/* convert file */ |
83 |
bn2ra(); |
84 |
} else { |
85 |
if (i != argc-2) |
86 |
goto userr; |
87 |
if (!strcmp(argv[i], "-")) |
88 |
rafp = stdin; |
89 |
else if ((rafp = fopen(argv[i], "r")) == NULL) { |
90 |
sprintf(errmsg, "cannot open input \"%s\"", |
91 |
argv[i]); |
92 |
quiterr(errmsg); |
93 |
94 |
/* get header */ |
95 |
if (checkheader(rafp, COLRFMT, NULL) < 0 || |
96 |
fgetresolu(&xmax, &ymax, rafp) != (YMAJOR|YDECR)) |
97 |
quiterr("bad RADIANCE format"); |
98 |
if (openbarney(argv[i+1], "w") < 0) { |
99 |
sprintf(errmsg, "cannot open output \"%s\"", argv[i+1]); |
100 |
quiterr(errmsg); |
101 |
102 |
103 |
ra2bn(); |
104 |
105 |
quiterr(NULL); |
106 |
userr: |
107 |
fprintf(stderr, "Usage: %s [-g gamma][-e +/-stops] {input|-} output\n", |
108 |
progname); |
109 |
fprintf(stderr, " or: %s -r [-g gamma][-e +/-stops] input [output|-]\n", |
110 |
progname); |
111 |
exit(1); |
112 |
113 |
114 |
115 |
quiterr(err) /* print message and exit */ |
116 |
char *err; |
117 |
118 |
if (err != NULL) { |
119 |
fprintf(stderr, "%s: %s\n", progname, err); |
120 |
exit(1); |
121 |
122 |
exit(0); |
123 |
124 |
125 |
126 |
openbarney(fname, mode) /* open barneyscan files */ |
127 |
char *fname; |
128 |
char *mode; |
129 |
130 |
static char suffix[3][4] = {"red", "grn", "blu"}; |
131 |
int i; |
132 |
char file[128]; |
133 |
134 |
for (i = 0; i < 3; i++) { |
135 |
sprintf(file, "%s.%s", fname, suffix[i]); |
136 |
if ((bnfp[i] = fopen(file, mode)) == NULL) |
137 |
return(-1); |
138 |
139 |
if (mode[0] == 'r') { /* get header */ |
140 |
xmax = getint(bnfp[0]); |
141 |
ymax = getint(bnfp[0]); |
142 |
for (i = 1; i < 3; i++) |
143 |
if (getint(bnfp[i]) != xmax || getint(bnfp[i]) != ymax) |
144 |
return(-1); |
145 |
} else { /* put header */ |
146 |
147 |
putint(xmax, bnfp[i]); |
148 |
putint(ymax, bnfp[i]); |
149 |
150 |
151 |
return(0); |
152 |
153 |
154 |
155 |
int |
156 |
getint(fp) /* get short int from barneyscan file */ |
157 |
register FILE *fp; |
158 |
159 |
register short val; |
160 |
161 |
val = getc(fp); |
162 |
val |= getc(fp) << 8; |
163 |
164 |
return(val); |
165 |
166 |
167 |
168 |
putint(val, fp) /* put short int to barneyscan file */ |
169 |
register int val; |
170 |
171 |
172 |
putc(val&0xff, fp); |
173 |
putc((val >> 8)&0xff, fp); |
174 |
175 |
176 |
177 |
ra2bn() /* convert radiance to barneyscan */ |
178 |
179 |
register int i; |
180 |
register COLR *inl; |
181 |
int j; |
182 |
183 |
if ((inl = (COLR *)malloc(xmax*sizeof(COLR))) == NULL) |
184 |
quiterr("out of memory"); |
185 |
for (j = 0; j < ymax; j++) { |
186 |
if (freadcolrs(inl, xmax, rafp) < 0) |
187 |
quiterr("error reading RADIANCE file"); |
188 |
if (bradj) |
189 |
shiftcolrs(inl, xmax, bradj); |
190 |
colrs_gambs(inl, xmax); |
191 |
for (i = 0; i < xmax; i++) { |
192 |
putc(inl[i][RED], bnfp[0]); |
193 |
putc(inl[i][GRN], bnfp[1]); |
194 |
putc(inl[i][BLU], bnfp[2]); |
195 |
196 |
if (ferror(bnfp[0]) || ferror(bnfp[1]) || ferror(bnfp[2])) |
197 |
quiterr("error writing Barney files"); |
198 |
199 |
free((char *)inl); |
200 |
201 |
202 |
203 |
bn2ra() /* convert barneyscan to radiance */ |
204 |
205 |
register int i; |
206 |
register COLR *outline; |
207 |
int j; |
208 |
209 |
if ((outline = (COLR *)malloc(xmax*sizeof(COLR))) == NULL) |
210 |
211 |
212 |
213 |
outline[i][RED] = getc(bnfp[0]); |
214 |
outline[i][GRN] = getc(bnfp[1]); |
215 |
outline[i][BLU] = getc(bnfp[2]); |
216 |
217 |
if (feof(bnfp[0]) || feof(bnfp[1]) || feof(bnfp[2])) |
218 |
quiterr("error reading barney file"); |
219 |
gambs_colrs(outline, xmax); |
220 |
if (bradj) |
221 |
shiftcolrs(outline, xmax, bradj); |
222 |
if (fwritecolrs(outline, xmax, rafp) < 0) |
223 |
quiterr("error writing RADIANCE file"); |
224 |
225 |
free((char *)outline); |
226 |
