root/radiance/ray/src/px/ra_bn.c
Sun Mar 28 20:33:14 2004 UTC (21 years, 1 month ago) by schorsch
Changes since 2.8: +36 -22 lines
Diff to previous 2.8 , to selected 1.7
Thu Jun 5 19:29:34 2003 UTC (21 years, 11 months ago) by schorsch
Changes since 2.7: +5 -14 lines
Diff to previous 2.7 , to selected 1.7
Sat Feb 22 02:07:27 2003 UTC (22 years, 2 months ago) by greg
Changes since 2.6: +5 -8 lines
Diff to previous 2.6 , to selected 1.7
Sun Feb 27 10:17:10 1994 UTC (31 years, 2 months ago) by greg
Diff to previous 2.5 , to selected 1.7
Fri Oct 30 09:11:35 1992 UTC (32 years, 6 months ago) by greg
Diff to previous 2.4 , to selected 1.7
renamed gamma to avoid conflict with some math libraries
Fri Oct 2 16:24:56 1992 UTC (32 years, 7 months ago) by greg
Diff to previous 2.3 , to selected 1.7
Mon Sep 21 12:14:44 1992 UTC (32 years, 7 months ago) by greg
Changes since 2.2: +13 -2 lines
Diff to previous 2.2 , to selected 1.7
Changes for PC port
Thu Dec 19 14:52:07 1991 UTC (33 years, 5 months ago) by greg
Diff to previous 2.1 , to selected 1.7
Tue Nov 12 16:05:07 1991 UTC (33 years, 6 months ago) by greg
Diff to previous 1.9 , to selected 1.7
Mon Nov 11 14:01:48 1991 UTC (33 years, 6 months ago) by greg
Changes since 1.8: +4 -2 lines
Diff to previous 1.8 , to selected 1.7
Wed Aug 7 08:36:29 1991 UTC (33 years, 9 months ago) by greg
Changes since 1.7: +15 -3 lines
Diff to previous 1.7
added -e +/-stops option
Revision 1.7 - (view) (download) (annotate) - [selected]
Thu Apr 18 14:35:35 1991 UTC (34 years, 1 month ago) by greg
Diff to previous 1.6
Fri Oct 19 21:44:29 1990 UTC (34 years, 7 months ago) by greg
Changes since 1.5: +26 -27 lines
now uses colrops.c for gamma correction (faster)
Wed Jun 20 09:17:32 1990 UTC (34 years, 11 months ago) by greg
fixed usage message
Mon Mar 12 15:14:37 1990 UTC (35 years, 2 months ago) by greg
Changes since 1.3: +5 -5 lines
changed "inline" to "inl" for compiler compatibility
Fri Feb 9 13:59:17 1990 UTC (35 years, 3 months ago) by greg
changed arguments printed in header
Mon Sep 25 13:22:06 1989 UTC (35 years, 7 months ago) by greg
Thu Feb 2 10:49:32 1989 UTC (36 years, 3 months ago) by greg
Diff to selected 1.7
