root/radiance/ray/src/px/ra_bn.c
Revision: 2.5
Committed: Fri Oct 30 09:11:35 1992 UTC (32 years, 6 months ago) by greg
renamed gamma to avoid conflict with some math libraries
1 /* Copyright (c) 1992 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * ra_bn.c - program to convert between RADIANCE and barneyscan picture format.
9 *
10 * 10/12/88
11 */
12
13 #include <stdio.h>
14
15 #ifdef MSDOS
16 #include <fcntl.h>
17 #endif
18
19 #include <math.h>
20
21 #include "color.h"
22
23 #include "resolu.h"
24
25 extern char *malloc();
26
27 double gamcor = 2.0; /* gamma correction */
28
29 int bradj = 0; /* brightness adjustment */
30
31 char *progname;
32
33 char errmsg[128];
34
35 FILE *rafp, *bnfp[3];
36
37 int xmax, ymax;
38
39
40 main(argc, argv)
41 int argc;
42 char *argv[];
43 {
44 int reverse = 0;
45 int i;
46 #ifdef MSDOS
47 extern int _fmode;
48 _fmode = O_BINARY;
49 setmode(fileno(stdin), O_BINARY);
50 setmode(fileno(stdout), O_BINARY);
51 #endif
52 progname = argv[0];
53
54 for (i = 1; i < argc; i++)
55 if (argv[i][0] == '-')
56 switch (argv[i][1]) {
57 case 'g':
58 gamcor = atof(argv[++i]);
59 break;
60 case 'r':
61 reverse = !reverse;
62 break;
63 case 'e':
64 if (argv[i+1][0] != '+' && argv[i+1][0] != '-')
65 goto userr;
66 bradj = atoi(argv[++i]);
67 break;
68 default:
69 goto userr;
70 }
71 else
72 break;
73 /* set gamma correction */
74 setcolrgam(gamcor);
75
76 if (reverse) {
77 if (i > argc-1 || i < argc-2)
78 goto userr;
79 if (openbarney(argv[i], "r") < 0) {
80 sprintf(errmsg, "cannot open input \"%s\"", argv[i]);
81 quiterr(errmsg);
82 }
83 if (i == argc-1 || !strcmp(argv[i+1], "-"))
84 rafp = stdout;
85 else if ((rafp = fopen(argv[i+1], "w")) == NULL) {
86 sprintf(errmsg, "cannot open output \"%s\"",
87 argv[i+1]);
88 quiterr(errmsg);
89 }
90 /* put header */
91 printargs(i, argv, rafp);
92 fputformat(COLRFMT, rafp);
93 putc('\n', rafp);
94 fprtresolu(xmax, ymax, rafp);
95 /* convert file */
96 bn2ra();
97 } else {
98 if (i != argc-2)
99 goto userr;
100 if (!strcmp(argv[i], "-"))
101 rafp = stdin;
102 else if ((rafp = fopen(argv[i], "r")) == NULL) {
103 sprintf(errmsg, "cannot open input \"%s\"",
104 argv[i]);
105 quiterr(errmsg);
106 }
107 /* get header */
108 if (checkheader(rafp, COLRFMT, NULL) < 0 ||
109 fgetresolu(&xmax, &ymax, rafp) < 0)
110 quiterr("bad RADIANCE format");
111 if (openbarney(argv[i+1], "w") < 0) {
112 sprintf(errmsg, "cannot open output \"%s\"", argv[i+1]);
113 quiterr(errmsg);
114 }
115 /* convert file */
116 ra2bn();
117 }
118 quiterr(NULL);
119 userr:
120 fprintf(stderr, "Usage: %s [-g gamma][-e +/-stops] {input|-} output\n",
121 progname);
122 fprintf(stderr, " or: %s -r [-g gamma][-e +/-stops] input [output|-]\n",
123 progname);
124 exit(1);
125 }
126
127
128 quiterr(err) /* print message and exit */
129 char *err;
130 {
131 if (err != NULL) {
132 fprintf(stderr, "%s: %s\n", progname, err);
133 exit(1);
134 }
135 exit(0);
136 }
137
138
139 openbarney(fname, mode) /* open barneyscan files */
140 char *fname;
141 char *mode;
142 {
143 static char suffix[3][4] = {"red", "grn", "blu"};
144 int i;
145 char file[128];
146
147 for (i = 0; i < 3; i++) {
148 sprintf(file, "%s.%s", fname, suffix[i]);
149 if ((bnfp[i] = fopen(file, mode)) == NULL)
150 return(-1);
151 }
152 if (mode[0] == 'r') { /* get header */
153 xmax = getint(bnfp[0]);
154 ymax = getint(bnfp[0]);
155 for (i = 1; i < 3; i++)
156 if (getint(bnfp[i]) != xmax || getint(bnfp[i]) != ymax)
157 return(-1);
158 } else { /* put header */
159 for (i = 0; i < 3; i++) {
160 putint(xmax, bnfp[i]);
161 putint(ymax, bnfp[i]);
162 }
163 }
164 return(0);
165 }
166
167
168 int
169 getint(fp) /* get short int from barneyscan file */
170 register FILE *fp;
171 {
172 register short val;
173
174 val = getc(fp);
175 val |= getc(fp) << 8;
176
177 return(val);
178 }
179
180
181 putint(val, fp) /* put short int to barneyscan file */
182 register int val;
183 register FILE *fp;
184 {
185 putc(val&0xff, fp);
186 putc((val >> 8)&0xff, fp);
187 }
188
189
190 ra2bn() /* convert radiance to barneyscan */
191 {
192 register int i;
193 register COLR *inl;
194 int j;
195
196 if ((inl = (COLR *)malloc(xmax*sizeof(COLR))) == NULL)
197 quiterr("out of memory");
198 for (j = 0; j < ymax; j++) {
199 if (freadcolrs(inl, xmax, rafp) < 0)
200 quiterr("error reading RADIANCE file");
201 if (bradj)
202 shiftcolrs(inl, xmax, bradj);
203 colrs_gambs(inl, xmax);
204 for (i = 0; i < xmax; i++) {
205 putc(inl[i][RED], bnfp[0]);
206 putc(inl[i][GRN], bnfp[1]);
207 putc(inl[i][BLU], bnfp[2]);
208 }
209 if (ferror(bnfp[0]) || ferror(bnfp[1]) || ferror(bnfp[2]))
210 quiterr("error writing Barney files");
211 }
212 free((char *)inl);
213 }
214
215
216 bn2ra() /* convert barneyscan to radiance */
217 {
218 register int i;
219 register COLR *outline;
220 int j;
221
222 if ((outline = (COLR *)malloc(xmax*sizeof(COLR))) == NULL)
223 quiterr("out of memory");
224 for (j = 0; j < ymax; j++) {
225 for (i = 0; i < xmax; i++) {
226 outline[i][RED] = getc(bnfp[0]);
227 outline[i][GRN] = getc(bnfp[1]);
228 outline[i][BLU] = getc(bnfp[2]);
229 }
230 if (feof(bnfp[0]) || feof(bnfp[1]) || feof(bnfp[2]))
231 quiterr("error reading barney file");
232 gambs_colrs(outline, xmax);
233 if (bradj)
234 shiftcolrs(outline, xmax, bradj);
235 if (fwritecolrs(outline, xmax, rafp) < 0)
236 quiterr("error writing RADIANCE file");
237 }
238 free((char *)outline);
239 }
