root/radiance/ray/src/px/ra_bn.c
Revision: 1.9
Committed: Mon Nov 11 14:01:48 1991 UTC (33 years, 6 months ago) by greg
Changes since 1.8: +4 -2 lines
1 /* Copyright (c) 1991 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * ra_bn.c - program to convert between RADIANCE and barneyscan picture format.
9 *
10 * 10/12/88
11 */
12
13 #include <stdio.h>
14
15 #include "color.h"
16
17 #include "resolu.h"
18
19 extern double atof(), pow();
20
21 double gamma = 2.0; /* gamma correction */
22
23 int bradj = 0; /* brightness adjustment */
24
25 char *progname;
26
27 char errmsg[128];
28
29 FILE *rafp, *bnfp[3];
30
31 int xmax, ymax;
32
33
34 main(argc, argv)
35 int argc;
36 char *argv[];
37 {
38 int reverse = 0;
39 int i;
40
41 progname = argv[0];
42
43 for (i = 1; i < argc; i++)
44 if (argv[i][0] == '-')
45 switch (argv[i][1]) {
46 case 'g':
47 gamma = atof(argv[++i]);
48 break;
49 case 'r':
50 reverse = !reverse;
51 break;
52 case 'e':
53 if (argv[i+1][0] != '+' && argv[i+1][0] != '-')
54 goto userr;
55 bradj = atoi(argv[++i]);
56 break;
57 default:
58 goto userr;
59 }
60 else
61 break;
62 /* set gamma correction */
63 setcolrgam(gamma);
64
65 if (reverse) {
66 if (i > argc-1 || i < argc-2)
67 goto userr;
68 if (openbarney(argv[i], "r") < 0) {
69 sprintf(errmsg, "cannot open input \"%s\"", argv[i]);
70 quiterr(errmsg);
71 }
72 if (i == argc-1 || !strcmp(argv[i+1], "-"))
73 rafp = stdout;
74 else if ((rafp = fopen(argv[i+1], "w")) == NULL) {
75 sprintf(errmsg, "cannot open output \"%s\"",
76 argv[i+1]);
77 quiterr(errmsg);
78 }
79 /* put header */
80 printargs(i, argv, rafp);
81 fputformat(COLRFMT, rafp);
82 putc('\n', rafp);
83 fprtresolu(xmax, ymax, rafp);
84 /* convert file */
85 bn2ra();
86 } else {
87 if (i != argc-2)
88 goto userr;
89 if (!strcmp(argv[i], "-"))
90 rafp = stdin;
91 else if ((rafp = fopen(argv[i], "r")) == NULL) {
92 sprintf(errmsg, "cannot open input \"%s\"",
93 argv[i]);
94 quiterr(errmsg);
95 }
96 /* get header */
97 if (checkheader(rafp, COLRFMT, NULL) < 0 ||
98 fgetresolu(&xmax, &ymax, rafp) < 0)
99 quiterr("bad RADIANCE format");
100 if (openbarney(argv[i+1], "w") < 0) {
101 sprintf(errmsg, "cannot open output \"%s\"", argv[i+1]);
102 quiterr(errmsg);
103 }
104 /* convert file */
105 ra2bn();
106 }
107 quiterr(NULL);
108 userr:
109 fprintf(stderr, "Usage: %s [-g gamma][-e +/-stops] {input|-} output\n",
110 progname);
111 fprintf(stderr, " or: %s -r [-g gamma][-e +/-stops] input [output|-]\n",
112 progname);
113 exit(1);
114 }
115
116
117 quiterr(err) /* print message and exit */
118 char *err;
119 {
120 if (err != NULL) {
121 fprintf(stderr, "%s: %s\n", progname, err);
122 exit(1);
123 }
124 exit(0);
125 }
126
127
128 openbarney(fname, mode) /* open barneyscan files */
129 char *fname;
130 char *mode;
131 {
132 static char suffix[3][4] = {"red", "grn", "blu"};
133 int i;
134 char file[128];
135
136 for (i = 0; i < 3; i++) {
137 sprintf(file, "%s.%s", fname, suffix[i]);
138 if ((bnfp[i] = fopen(file, mode)) == NULL)
139 return(-1);
140 }
141 if (mode[0] == 'r') { /* get header */
142 xmax = getint(bnfp[0]);
143 ymax = getint(bnfp[0]);
144 for (i = 1; i < 3; i++)
145 if (getint(bnfp[i]) != xmax || getint(bnfp[i]) != ymax)
146 return(-1);
147 } else { /* put header */
148 for (i = 0; i < 3; i++) {
149 putint(xmax, bnfp[i]);
150 putint(ymax, bnfp[i]);
151 }
152 }
153 return(0);
154 }
155
156
157 int
158 getint(fp) /* get short int from barneyscan file */
159 register FILE *fp;
160 {
161 register short val;
162
163 val = getc(fp);
164 val |= getc(fp) << 8;
165
166 return(val);
167 }
168
169
170 putint(val, fp) /* put short int to barneyscan file */
171 register int val;
172 register FILE *fp;
173 {
174 putc(val&0xff, fp);
175 putc((val >> 8)&0xff, fp);
176 }
177
178
179 ra2bn() /* convert radiance to barneyscan */
180 {
181 register int i;
182 register COLR *inl;
183 int j;
184
185 if ((inl = (COLR *)malloc(xmax*sizeof(COLR))) == NULL)
186 quiterr("out of memory");
187 for (j = 0; j < ymax; j++) {
188 if (freadcolrs(inl, xmax, rafp) < 0)
189 quiterr("error reading RADIANCE file");
190 if (bradj)
191 shiftcolrs(inl, xmax, bradj);
192 colrs_gambs(inl, xmax);
193 for (i = 0; i < xmax; i++) {
194 putc(inl[i][RED], bnfp[0]);
195 putc(inl[i][GRN], bnfp[1]);
196 putc(inl[i][BLU], bnfp[2]);
197 }
198 if (ferror(bnfp[0]) || ferror(bnfp[1]) || ferror(bnfp[2]))
199 quiterr("error writing Barney files");
200 }
201 free((char *)inl);
202 }
203
204
205 bn2ra() /* convert barneyscan to radiance */
206 {
207 register int i;
208 register COLR *outline;
209 int j;
210
211 if ((outline = (COLR *)malloc(xmax*sizeof(COLR))) == NULL)
212 quiterr("out of memory");
213 for (j = 0; j < ymax; j++) {
214 for (i = 0; i < xmax; i++) {
215 outline[i][RED] = getc(bnfp[0]);
216 outline[i][GRN] = getc(bnfp[1]);
217 outline[i][BLU] = getc(bnfp[2]);
218 }
219 if (feof(bnfp[0]) || feof(bnfp[1]) || feof(bnfp[2]))
220 quiterr("error reading barney file");
221 gambs_colrs(outline, xmax);
222 if (bradj)
223 shiftcolrs(outline, xmax, bradj);
224 if (fwritecolrs(outline, xmax, rafp) < 0)
225 quiterr("error writing RADIANCE file");
226 }
227 free((char *)outline);
228 }
