root/radiance/ray/src/px/ra_bn.c
Revision: 2.9
Committed: Sun Mar 28 20:33:14 2004 UTC (20 years, 2 months ago) by schorsch
CVS Tags: rad3R6P1, rad3R6
Changes since 2.8: +36 -22 lines
2 static const char RCSid[] = "$Id: ra_bn.c,v 2.8 2003/06/05 19:29:34 schorsch Exp $";
5 * ra_bn.c - program to convert between RADIANCE and barneyscan picture format.
6 *
7 * 10/12/88
8 */
9
10 #include <stdio.h>
11 #include <string.h>
12 #include <time.h>
13 #include <math.h>
14
15 #include "platform.h"
16 #include "color.h"
17 #include "resolu.h"
18
19 double gamcor = 2.0; /* gamma correction */
20 int bradj = 0; /* brightness adjustment */
21 char *progname;
22 char errmsg[128];
23 FILE *rafp, *bnfp[3];
24 int xmax, ymax;
25
26 static void quiterr(char *err);
27 static int openbarney(char *fname, char *mode);
28 static int getint(FILE *fp);
29 static void putint(int val, FILE *fp);
30 static void ra2bn(void);
31 static void bn2ra(void);
32
33
34 int
35 main(
36 int argc,
37 char *argv[]
38 )
39 {
40 int reverse = 0;
41 int i;
42 SET_DEFAULT_BINARY();
43 SET_FILE_BINARY(stdin);
44 SET_FILE_BINARY(stdout);
45 progname = argv[0];
46
47 for (i = 1; i < argc; i++)
48 if (argv[i][0] == '-')
49 switch (argv[i][1]) {
50 case 'g':
51 gamcor = atof(argv[++i]);
52 break;
53 case 'r':
54 reverse = !reverse;
55 break;
56 case 'e':
57 if (argv[i+1][0] != '+' && argv[i+1][0] != '-')
58 goto userr;
59 bradj = atoi(argv[++i]);
60 break;
61 default:
62 goto userr;
63 }
64 else
65 break;
66 /* set gamma correction */
67 setcolrgam(gamcor);
68
69 if (reverse) {
70 if (i > argc-1 || i < argc-2)
71 goto userr;
72 if (openbarney(argv[i], "r") < 0) {
73 sprintf(errmsg, "cannot open input \"%s\"", argv[i]);
74 quiterr(errmsg);
75 }
76 if (i == argc-1 || !strcmp(argv[i+1], "-"))
77 rafp = stdout;
78 else if ((rafp = fopen(argv[i+1], "w")) == NULL) {
79 sprintf(errmsg, "cannot open output \"%s\"",
80 argv[i+1]);
81 quiterr(errmsg);
82 }
83 /* put header */
84 newheader("RADIANCE", stdout);
85 printargs(i, argv, rafp);
86 fputformat(COLRFMT, rafp);
87 putc('\n', rafp);
88 fprtresolu(xmax, ymax, rafp);
89 /* convert file */
90 bn2ra();
91 } else {
92 if (i != argc-2)
93 goto userr;
94 if (!strcmp(argv[i], "-"))
95 rafp = stdin;
96 else if ((rafp = fopen(argv[i], "r")) == NULL) {
97 sprintf(errmsg, "cannot open input \"%s\"",
98 argv[i]);
99 quiterr(errmsg);
100 }
101 /* get header */
102 if (checkheader(rafp, COLRFMT, NULL) < 0 ||
103 fgetresolu(&xmax, &ymax, rafp) < 0)
104 quiterr("bad RADIANCE format");
105 if (openbarney(argv[i+1], "w") < 0) {
106 sprintf(errmsg, "cannot open output \"%s\"", argv[i+1]);
107 quiterr(errmsg);
108 }
109 /* convert file */
110 ra2bn();
111 }
112 quiterr(NULL);
113 userr:
114 fprintf(stderr, "Usage: %s [-g gamma][-e +/-stops] {input|-} output\n",
115 progname);
116 fprintf(stderr, " or: %s -r [-g gamma][-e +/-stops] input [output|-]\n",
117 progname);
118 exit(1);
119 }
120
121
122 static void
123 quiterr( /* print message and exit */
124 char *err
125 )
126 {
127 if (err != NULL) {
128 fprintf(stderr, "%s: %s\n", progname, err);
129 exit(1);
130 }
131 exit(0);
132 }
133
134
135 static int
136 openbarney( /* open barneyscan files */
137 char *fname,
138 char *mode
139 )
140 {
141 static char suffix[3][4] = {"red", "grn", "blu"};
142 int i;
143 char file[128];
144
145 for (i = 0; i < 3; i++) {
146 sprintf(file, "%s.%s", fname, suffix[i]);
147 if ((bnfp[i] = fopen(file, mode)) == NULL)
148 return(-1);
149 }
150 if (mode[0] == 'r') { /* get header */
151 xmax = getint(bnfp[0]);
152 ymax = getint(bnfp[0]);
153 for (i = 1; i < 3; i++)
154 if (getint(bnfp[i]) != xmax || getint(bnfp[i]) != ymax)
155 return(-1);
156 } else { /* put header */
157 for (i = 0; i < 3; i++) {
158 putint(xmax, bnfp[i]);
159 putint(ymax, bnfp[i]);
160 }
161 }
162 return(0);
163 }
164
165
166 static int
167 getint( /* get short int from barneyscan file */
168 register FILE *fp
169 )
170 {
171 register short val;
172
173 val = getc(fp);
174 val |= getc(fp) << 8;
175
176 return(val);
177 }
178
179
180 static void
181 putint( /* put short int to barneyscan file */
182 register int val,
183 register FILE *fp
184 )
185 {
186 putc(val&0xff, fp);
187 putc((val >> 8)&0xff, fp);
188 }
189
190
191 static void
192 ra2bn(void) /* convert radiance to barneyscan */
193 {
194 register int i;
195 register COLR *inl;
196 int j;
197
198 if ((inl = (COLR *)malloc(xmax*sizeof(COLR))) == NULL)
199 quiterr("out of memory");
200 for (j = 0; j < ymax; j++) {
201 if (freadcolrs(inl, xmax, rafp) < 0)
202 quiterr("error reading RADIANCE file");
203 if (bradj)
204 shiftcolrs(inl, xmax, bradj);
205 colrs_gambs(inl, xmax);
206 for (i = 0; i < xmax; i++) {
207 putc(inl[i][RED], bnfp[0]);
208 putc(inl[i][GRN], bnfp[1]);
209 putc(inl[i][BLU], bnfp[2]);
210 }
211 if (ferror(bnfp[0]) || ferror(bnfp[1]) || ferror(bnfp[2]))
212 quiterr("error writing Barney files");
213 }
214 free((void *)inl);
215 }
216
217
218 static void
219 bn2ra(void) /* convert barneyscan to radiance */
220 {
221 register int i;
222 register COLR *outline;
223 int j;
224
225 if ((outline = (COLR *)malloc(xmax*sizeof(COLR))) == NULL)
226 quiterr("out of memory");
227 for (j = 0; j < ymax; j++) {
228 for (i = 0; i < xmax; i++) {
229 outline[i][RED] = getc(bnfp[0]);
230 outline[i][GRN] = getc(bnfp[1]);
231 outline[i][BLU] = getc(bnfp[2]);
232 }
233 if (feof(bnfp[0]) || feof(bnfp[1]) || feof(bnfp[2]))
234 quiterr("error reading barney file");
235 gambs_colrs(outline, xmax);
236 if (bradj)
237 shiftcolrs(outline, xmax, bradj);
238 if (fwritecolrs(outline, xmax, rafp) < 0)
239 quiterr("error writing RADIANCE file");
240 }
241 free((void *)outline);
242 }
