feat(ra_bmp,ra_rgbe,ximage): Added quick conversion of spectral inputs to RGB
Fixed segmentation error with -b on input with color primaries
Eliminated unnecessary file chaecking in tmap2bmp()
Fixed inconsistent behavior with inverted Radiance pictures
Fixed - option for reading from stdin
Fixed minor problem with RLE8 output
Bug fixes in run-length encoding code
