root/radiance/ray/src/px/ra_bmp.c
Revision: 2.14
Committed: Sun Apr 5 19:10:51 2020 UTC (4 years ago) by greg
CVS Tags: rad5R4, rad5R3, HEAD
Changes since 2.13: +5 -4 lines
Fixed segmentation error with -b on input with color primaries
2 static const char RCSid[] = "$Id: ra_bmp.c,v 2.13 2019/07/19 17:37:56 greg Exp $";
5 * program to convert between RADIANCE and Windows BMP file
6 */
7
8 #include <math.h>
9
10 #include "rtio.h"
11 #include "platform.h"
12 #include "color.h"
13 #include "tonemap.h"
14 #include "resolu.h"
15 #include "bmpfile.h"
16
17 int bradj = 0; /* brightness adjustment */
18
19 double gamcor = 2.2; /* gamma correction value */
20
21 char *progname;
22
23 static void quiterr(const char *err);
24 static void tmap2bmp(char *fnin, char *fnout, char *expec,
25 RGBPRIMP monpri, double gamval);
26 static void rad2bmp(FILE *rfp, BMPWriter *bwr, int inv, RGBPRIMP monpri);
27 static void bmp2rad(BMPReader *brd, FILE *rfp, int inv);
28
29 static RGBPRIMP rgbinp = stdprims; /* RGB input primitives */
30 static RGBPRIMS myinprims; /* custom primitives holder */
31
32 static gethfunc headline;
33
34
35 int
36 main(int argc, char *argv[])
37 {
38 char *inpfile=NULL, *outfile=NULL;
39 char *expec = NULL;
40 int reverse = 0;
41 RGBPRIMP rgbp = stdprims;
42 RGBPRIMS myprims;
43 RESOLU rs;
44 int i;
45
46 progname = argv[0];
47
48 for (i = 1; i < argc; i++)
49 if (argv[i][0] == '-' && argv[i][1])
50 switch (argv[i][1]) {
51 case 'b':
52 rgbp = NULL;
53 break;
54 case 'g':
55 gamcor = atof(argv[++i]);
56 break;
57 case 'e':
58 if (argv[i+1][0] != '+' && argv[i+1][0] != '-')
59 expec = argv[++i];
60 else
61 bradj = atoi(argv[++i]);
62 break;
63 case 'p':
64 if (argc-i < 9)
65 goto userr;
66 myprims[RED][CIEX] = atof(argv[++i]);
67 myprims[RED][CIEY] = atof(argv[++i]);
68 myprims[GRN][CIEX] = atof(argv[++i]);
69 myprims[GRN][CIEY] = atof(argv[++i]);
70 myprims[BLU][CIEX] = atof(argv[++i]);
71 myprims[BLU][CIEY] = atof(argv[++i]);
72 myprims[WHT][CIEX] = atof(argv[++i]);
73 myprims[WHT][CIEY] = atof(argv[++i]);
74 if (rgbp == stdprims)
75 rgbp = myprims;
76 break;
77 case 'r':
78 reverse = !reverse;
79 break;
80 default:
81 goto userr;
82 }
83 else
84 break;
85
86 if (i < argc-2)
87 goto userr;
88
89 SET_FILE_BINARY(stdin);
90 SET_FILE_BINARY(stdout);
91 SET_DEFAULT_BINARY();
92
93 if (i <= argc-1 && strcmp(argv[i], "-"))
94 inpfile = argv[i];
95
96 if (i == argc-2 && strcmp(argv[i+1], "-"))
97 outfile = argv[i+1];
98 /* check for tone-mapping */
99 if (expec != NULL) {
100 if (reverse)
101 goto userr;
102 tmap2bmp(inpfile, outfile, expec, rgbp, gamcor);
103 return(0);
104 }
105
106 setcolrgam(gamcor); /* set up conversion */
107
108 if (reverse) {
109 BMPReader *rdr;
110 /* open BMP file or stream */
111 if (inpfile != NULL)
112 rdr = BMPopenInputFile(inpfile);
113 else
114 rdr = BMPopenInputStream(stdin);
115
116 if (rdr == NULL) {
117 fprintf(stderr, "%s: cannot open or recognize BMP\n",
118 inpfile != NULL ? inpfile : "<stdin>");
119 exit(1);
120 }
121 /* open Radiance output */
122 if (outfile != NULL && freopen(outfile, "w", stdout) == NULL) {
123 fprintf(stderr, "%s: cannot open for output\n",
124 outfile);
125 exit(1);
126 }
127 /* put Radiance header */
128 newheader("RADIANCE", stdout);
129 printargs(i, argv, stdout);
130 fputformat(COLRFMT, stdout);
131 putchar('\n');
132 rs.xr = rdr->hdr->width;
133 rs.yr = rdr->hdr->height;
134 rs.rt = YMAJOR;
135 /* write scans downward if we can */
136 if (rdr->hdr->yIsDown || inpfile != NULL)
137 rs.rt |= YDECR;
138 fputsresolu(&rs, stdout);
139 /* convert file */
140 bmp2rad(rdr, stdout, !rdr->hdr->yIsDown && inpfile!=NULL);
141 /* flush output */
142 BMPcloseInput(rdr);
143 if (fflush(stdout) < 0)
144 quiterr("error writing Radiance output");
145 } else {
146 BMPHeader *hdr;
147 BMPWriter *wtr;
148 /* open Radiance input */
149 if (inpfile != NULL && freopen(inpfile, "r", stdin) == NULL) {
150 fprintf(stderr, "%s: cannot open input file\n",
151 inpfile);
152 exit(1);
153 }
154 /* get header info. */
155 if (getheader(stdin, headline, NULL) < 0 ||
156 !fgetsresolu(&rs, stdin))
157 quiterr("bad Radiance picture format");
158 /* initialize BMP header */
159 if (rgbp == NULL) {
160 hdr = BMPmappedHeader(scanlen(&rs),
161 numscans(&rs), 0, 256);
162 /*
163 if (outfile != NULL)
164 hdr->compr = BI_RLE8;
165 */
166 } else
167 hdr = BMPtruecolorHeader(scanlen(&rs),
168 numscans(&rs), 0);
169 if (hdr == NULL)
170 quiterr("cannot initialize BMP header");
171 /* set up output direction */
172 hdr->yIsDown = ((outfile == NULL) | (hdr->compr == BI_RLE8));
173 /* open BMP output */
174 if (outfile != NULL)
175 wtr = BMPopenOutputFile(outfile, hdr);
176 else
177 wtr = BMPopenOutputStream(stdout, hdr);
178 if (wtr == NULL)
179 quiterr("cannot allocate writer structure");
180 /* convert file */
181 rad2bmp(stdin, wtr, !hdr->yIsDown, rgbp);
182 /* flush output */
183 if (fflush((FILE *)wtr->c_data) < 0)
184 quiterr("error writing BMP output");
185 BMPcloseOutput(wtr);
186 }
187 return(0); /* success */
188 userr:
189 fprintf(stderr,
190 "Usage: %s [-b][-g gamma][-e spec][-p xr yr xg yg xb yb xw yw] [input|- [output]]\n",
191 progname);
192 fprintf(stderr,
193 " or: %s -r [-g gamma][-e +/-stops] [input|- [output]]\n",
194 progname);
195 return(1);
196 }
197
198 /* print message and exit */
199 static void
200 quiterr(const char *err)
201 {
202 if (err != NULL) {
203 fprintf(stderr, "%s: %s\n", progname, err);
204 exit(1);
205 }
206 exit(0);
207 }
208
209 /* process header line (don't echo) */
210 static int
211 headline(char *s, void *p)
212 {
213 char fmt[MAXFMTLEN];
214
215 if (formatval(fmt, s)) { /* check if format string */
216 if (!strcmp(fmt,COLRFMT))
217 return(0);
218 if (!strcmp(fmt,CIEFMT)) {
219 rgbinp = TM_XYZPRIM;
220 return(0);
221 }
222 return(-1);
223 }
224 if (isprims(s)) { /* get input primaries */
225 primsval(myinprims, s);
226 rgbinp = myinprims;
227 return(0);
228 }
229 /* should I grok colcorr also? */
230 return(0);
231 }
232
233
234 /* convert Radiance picture to BMP */
235 static void
236 rad2bmp(FILE *rfp, BMPWriter *bwr, int inv, RGBPRIMP monpri)
237 {
238 int usexfm = 0;
239 COLORMAT xfm;
240 COLR *scanin;
241 COLOR cval;
242 int y, yend, ystp;
243 int x;
244 /* allocate scanline */
245 scanin = (COLR *)malloc(bwr->hdr->width*sizeof(COLR));
246 if (scanin == NULL)
247 quiterr("out of memory in rad2bmp");
248 /* set up color conversion */
249 usexfm = (monpri != NULL ? rgbinp != monpri :
250 rgbinp != TM_XYZPRIM && rgbinp != stdprims);
251 if (usexfm) {
252 RGBPRIMP destpri = monpri != NULL ? monpri : stdprims;
253 double expcomp = pow(2.0, (double)bradj);
254 if (rgbinp == TM_XYZPRIM)
255 compxyz2rgbWBmat(xfm, destpri);
256 else
257 comprgb2rgbWBmat(xfm, rgbinp, destpri);
258 for (y = 0; y < 3; y++)
259 for (x = 0; x < 3; x++)
260 xfm[y][x] *= expcomp;
261 }
262 /* convert image */
263 if (inv) {
264 y = bwr->hdr->height - 1;
265 ystp = -1; yend = -1;
266 } else {
267 y = 0;
268 ystp = 1; yend = bwr->hdr->height;
269 }
270 /* convert each scanline */
271 for ( ; y != yend; y += ystp) {
272 if (freadcolrs(scanin, bwr->hdr->width, rfp) < 0)
273 quiterr("error reading Radiance picture");
274 if (usexfm)
275 for (x = bwr->hdr->width; x--; ) {
276 colr_color(cval, scanin[x]);
277 colortrans(cval, xfm, cval);
278 setcolr(scanin[x], colval(cval,RED),
279 colval(cval,GRN),
280 colval(cval,BLU));
281 }
282 else if (bradj)
283 shiftcolrs(scanin, bwr->hdr->width, bradj);
284 if (monpri == NULL && rgbinp != TM_XYZPRIM)
285 for (x = bwr->hdr->width; x--; )
286 scanin[x][GRN] = normbright(scanin[x]);
287 colrs_gambs(scanin, bwr->hdr->width);
288 if (monpri == NULL)
289 for (x = bwr->hdr->width; x--; )
290 bwr->scanline[x] = scanin[x][GRN];
291 else
292 for (x = bwr->hdr->width; x--; ) {
293 bwr->scanline[3*x] = scanin[x][BLU];
294 bwr->scanline[3*x+1] = scanin[x][GRN];
295 bwr->scanline[3*x+2] = scanin[x][RED];
296 }
297 bwr->yscan = y;
298 x = BMPwriteScanline(bwr);
299 if (x != BIR_OK)
300 quiterr(BMPerrorMessage(x));
301 }
302 /* free scanline */
303 free((void *)scanin);
304 }
305
306 /* convert BMP file to Radiance */
307 static void
308 bmp2rad(BMPReader *brd, FILE *rfp, int inv)
309 {
310 COLR *scanout;
311 int y, yend, ystp;
312 int x;
313 /* allocate scanline */
314 scanout = (COLR *)malloc(brd->hdr->width*sizeof(COLR));
315 if (scanout == NULL)
316 quiterr("out of memory in bmp2rad");
317 /* convert image */
318 if (inv) {
319 y = brd->hdr->height - 1;
320 ystp = -1; yend = -1;
321 } else {
322 y = 0;
323 ystp = 1; yend = brd->hdr->height;
324 }
325 /* convert each scanline */
326 for ( ; y != yend; y += ystp) {
327 x = BMPseekScanline(y, brd);
328 if (x != BIR_OK)
329 quiterr(BMPerrorMessage(x));
330 for (x = brd->hdr->width; x--; ) {
331 RGBquad rgbq = BMPdecodePixel(x, brd);
332 scanout[x][RED] = rgbq.r;
333 scanout[x][GRN] = rgbq.g;
334 scanout[x][BLU] = rgbq.b;
335 }
336 gambs_colrs(scanout, brd->hdr->width);
337 if (bradj)
338 shiftcolrs(scanout, brd->hdr->width, bradj);
339 if (fwritecolrs(scanout, brd->hdr->width, rfp) < 0)
340 quiterr("error writing Radiance picture");
341 }
342 /* clean up */
343 free((void *)scanout);
344 }
345
346 /* Tone-map and convert Radiance picture */
347 static void
348 tmap2bmp(char *fnin, char *fnout, char *expec, RGBPRIMP monpri, double gamval)
349 {
350 int tmflags;
351 BMPHeader *hdr;
352 BMPWriter *wtr;
353 FILE *fp;
354 int xr, yr;
355 uby8 *pa;
356 int i;
357 /* check tone-mapping spec */
358 i = strlen(expec);
359 if (i && !strncmp(expec, "auto", i))
360 tmflags = TM_F_CAMERA;
361 else if (i && !strncmp(expec, "human", i))
362 tmflags = TM_F_HUMAN & ~TM_F_UNIMPL;
363 else if (i && !strncmp(expec, "linear", i))
364 tmflags = TM_F_LINEAR;
365 else
366 quiterr("illegal exposure specification (auto|human|linear)");
367 if (monpri == NULL) {
368 tmflags |= TM_F_BW;
369 monpri = stdprims;
370 }
371 /* open Radiance input */
372 if (fnin == NULL)
373 fp = stdin;
374 else if ((fp = fopen(fnin, "r")) == NULL) {
375 fprintf(stderr, "%s: cannot open\n", fnin);
376 exit(1);
377 }
378 /* tone-map picture */
379 if (tmMapPicture(&pa, &xr, &yr, tmflags, monpri, gamval,
380 0., 0., fnin, fp) != TM_E_OK)
381 exit(1);
382 /* initialize BMP header */
383 if (tmflags & TM_F_BW) {
384 hdr = BMPmappedHeader(xr, yr, 0, 256);
385 if (fnout != NULL)
386 hdr->compr = BI_RLE8;
387 } else
388 hdr = BMPtruecolorHeader(xr, yr, 0);
389 if (hdr == NULL)
390 quiterr("cannot initialize BMP header");
391 /* open BMP output */
392 if (fnout != NULL)
393 wtr = BMPopenOutputFile(fnout, hdr);
394 else
395 wtr = BMPopenOutputStream(stdout, hdr);
396 if (wtr == NULL)
397 quiterr("cannot allocate writer structure");
398 /* write to BMP file */
399 while (wtr->yscan < yr) {
400 uby8 *scn = pa + xr*((tmflags & TM_F_BW) ? 1 : 3)*
401 (yr-1 - wtr->yscan);
402 if (tmflags & TM_F_BW)
403 memcpy((void *)wtr->scanline, (void *)scn, xr);
404 else
405 for (i = xr; i--; ) {
406 wtr->scanline[3*i] = scn[3*i+BLU];
407 wtr->scanline[3*i+1] = scn[3*i+GRN];
408 wtr->scanline[3*i+2] = scn[3*i+RED];
409 }
410 if ((i = BMPwriteScanline(wtr)) != BIR_OK)
411 quiterr(BMPerrorMessage(i));
412 }
413 /* flush output */
414 if (fflush((FILE *)wtr->c_data) < 0)
415 quiterr("error writing BMP output");
416 /* clean up */
417 if (fnin != NULL)
418 fclose(fp);
419 free((void *)pa);
420 BMPcloseOutput(wtr);
421 }
