--- ray/src/px/ra_bmp.c 2004/07/20 03:08:42 2.8 +++ ray/src/px/ra_bmp.c 2024/09/10 20:24:42 2.15 @@ -1,32 +1,37 @@ #ifndef lint -static const char RCSid[] = "$Id: ra_bmp.c,v 2.8 2004/07/20 03:08:42 greg Exp $"; +static const char RCSid[] = "$Id: ra_bmp.c,v 2.15 2024/09/10 20:24:42 greg Exp $"; #endif /* * program to convert between RADIANCE and Windows BMP file */ -#include -#include +#include +#include "rtio.h" #include "platform.h" #include "color.h" #include "tonemap.h" #include "resolu.h" #include "bmpfile.h" -int bradj = 0; /* brightness adjustment */ +int bradj = 0; /* brightness adjustment */ -double gamcor = 2.2; /* gamma correction value */ +double gamcor = 2.2; /* gamma correction value */ -char *progname; +char *progname; static void quiterr(const char *err); static void tmap2bmp(char *fnin, char *fnout, char *expec, RGBPRIMP monpri, double gamval); -static void rad2bmp(FILE *rfp, BMPWriter *bwr, int inv, int gry); +static void rad2bmp(FILE *rfp, BMPWriter *bwr, int inv, RGBPRIMP monpri); static void bmp2rad(BMPReader *brd, FILE *rfp, int inv); +static RGBPRIMP rgbinp = stdprims; /* RGB input primitives */ +static RGBPRIMS myinprims; /* custom primitives holder */ +static gethfunc headline; + + int main(int argc, char *argv[]) { @@ -147,15 +152,17 @@ main(int argc, char *argv[]) exit(1); } /* get header info. */ - if (checkheader(stdin, COLRFMT, NULL) < 0 || + if (getheader(stdin, headline, NULL) < 0 || !fgetsresolu(&rs, stdin)) quiterr("bad Radiance picture format"); /* initialize BMP header */ if (rgbp == NULL) { hdr = BMPmappedHeader(scanlen(&rs), numscans(&rs), 0, 256); + /* if (outfile != NULL) hdr->compr = BI_RLE8; + */ } else hdr = BMPtruecolorHeader(scanlen(&rs), numscans(&rs), 0); @@ -171,7 +178,7 @@ main(int argc, char *argv[]) if (wtr == NULL) quiterr("cannot allocate writer structure"); /* convert file */ - rad2bmp(stdin, wtr, !hdr->yIsDown, rgbp==NULL); + rad2bmp(stdin, wtr, !hdr->yIsDown, rgbp); /* flush output */ if (fflush((FILE *)wtr->c_data) < 0) quiterr("error writing BMP output"); @@ -199,17 +206,69 @@ quiterr(const char *err) exit(0); } +/* process header line (don't echo) */ +static int +headline(char *s, void *p) +{ + char fmt[MAXFMTLEN]; + + if (formatval(fmt, s)) { /* check if format string */ + if (!strcmp(fmt,COLRFMT)) + return(0); + if (!strcmp(fmt,CIEFMT)) { + rgbinp = TM_XYZPRIM; + return(0); + } + if (!strcmp(fmt,SPECFMT)) + return(0); + return(-1); + } + if (isprims(s)) { /* get input primaries */ + primsval(myinprims, s); + rgbinp = myinprims; + return(0); + } + if (isncomp(s)) { + NCSAMP = ncompval(s); + return(0); + } + if (iswlsplit(s)) { + wlsplitval(WLPART, s); + return(0); + } + /* should I grok colcorr also? */ + return(0); +} + + /* convert Radiance picture to BMP */ static void -rad2bmp(FILE *rfp, BMPWriter *bwr, int inv, int gry) +rad2bmp(FILE *rfp, BMPWriter *bwr, int inv, RGBPRIMP monpri) { + int usexfm = 0; + COLORMAT xfm; COLR *scanin; + COLOR cval; int y, yend, ystp; int x; /* allocate scanline */ scanin = (COLR *)malloc(bwr->hdr->width*sizeof(COLR)); if (scanin == NULL) quiterr("out of memory in rad2bmp"); + /* set up color conversion */ + usexfm = (monpri != NULL ? rgbinp != monpri : + rgbinp != TM_XYZPRIM && rgbinp != stdprims); + if (usexfm) { + RGBPRIMP destpri = monpri != NULL ? monpri : stdprims; + double expcomp = pow(2.0, (double)bradj); + if (rgbinp == TM_XYZPRIM) + compxyz2rgbWBmat(xfm, destpri); + else + comprgb2rgbWBmat(xfm, rgbinp, destpri); + for (y = 0; y < 3; y++) + for (x = 0; x < 3; x++) + xfm[y][x] *= expcomp; + } /* convert image */ if (inv) { y = bwr->hdr->height - 1; @@ -220,14 +279,23 @@ rad2bmp(FILE *rfp, BMPWriter *bwr, int inv, int gry) } /* convert each scanline */ for ( ; y != yend; y += ystp) { - if (freadcolrs(scanin, bwr->hdr->width, rfp) < 0) + if (fread2colrs(scanin, bwr->hdr->width, rfp, NCSAMP, WLPART) < 0) quiterr("error reading Radiance picture"); - if (bradj) + if (usexfm) + for (x = bwr->hdr->width; x--; ) { + colr_color(cval, scanin[x]); + colortrans(cval, xfm, cval); + setcolr(scanin[x], colval(cval,RED), + colval(cval,GRN), + colval(cval,BLU)); + } + else if (bradj) shiftcolrs(scanin, bwr->hdr->width, bradj); - for (x = gry ? bwr->hdr->width : 0; x--; ) - scanin[x][GRN] = normbright(scanin[x]); + if (monpri == NULL && rgbinp != TM_XYZPRIM) + for (x = bwr->hdr->width; x--; ) + scanin[x][GRN] = normbright(scanin[x]); colrs_gambs(scanin, bwr->hdr->width); - if (gry) + if (monpri == NULL) for (x = bwr->hdr->width; x--; ) bwr->scanline[x] = scanin[x][GRN]; else @@ -294,7 +362,7 @@ tmap2bmp(char *fnin, char *fnout, char *expec, RGBPRIM BMPWriter *wtr; FILE *fp; int xr, yr; - BYTE *pa; + uby8 *pa; int i; /* check tone-mapping spec */ i = strlen(expec); @@ -339,7 +407,7 @@ tmap2bmp(char *fnin, char *fnout, char *expec, RGBPRIM quiterr("cannot allocate writer structure"); /* write to BMP file */ while (wtr->yscan < yr) { - BYTE *scn = pa + xr*((tmflags & TM_F_BW) ? 1 : 3)* + uby8 *scn = pa + xr*((tmflags & TM_F_BW) ? 1 : 3)* (yr-1 - wtr->yscan); if (tmflags & TM_F_BW) memcpy((void *)wtr->scanline, (void *)scn, xr);
