root/radiance/ray/src/px/ra_bmp.c
Sat Jun 7 05:09:46 2025 UTC (2 months ago) by greg
CVS Tags: HEAD, rad6R0
Changes since 2.16: +1 -2 lines
Diff to previous 2.16
Revision 2.16 - (view) (download) (annotate) - [selected]
Fri Jun 6 19:11:21 2025 UTC (2 months ago) by greg
Changes since 2.15: +3 -4 lines
Diff to previous 2.15
refactor: Making use of printargs() more consistent with fixargv0()
Tue Sep 10 20:24:42 2024 UTC (10 months, 3 weeks ago) by greg
Changes since 2.14: +12 -2 lines
Diff to previous 2.14 , to selected 2.16
feat(ra_bmp,ra_rgbe,ximage): Added quick conversion of spectral inputs to RGB
Sun Apr 5 19:10:51 2020 UTC (5 years, 4 months ago) by greg
CVS Tags: rad5R3, rad5R4
Changes since 2.13: +5 -4 lines
Diff to previous 2.13 , to selected 2.16
Fixed segmentation error with -b on input with color primaries
Fri Jul 19 17:37:56 2019 UTC (6 years ago) by greg
Changes since 2.12: +2 -3 lines
Diff to previous 2.12 , to selected 2.16
Thu Aug 2 18:33:46 2018 UTC (7 years ago) by greg
Diff to previous 2.11 , to selected 2.16
Fri May 20 02:06:39 2011 UTC (14 years, 2 months ago) by greg
Diff to previous 2.10 , to selected 2.16
Mon Oct 4 17:44:22 2004 UTC (20 years, 10 months ago) by greg
Changes since 2.9: +3 -1 lines
Diff to previous 2.9 , to selected 2.16
Thu Sep 23 18:00:54 2004 UTC (20 years, 10 months ago) by greg
Changes since 2.8: +68 -12 lines
Diff to previous 2.8 , to selected 2.16
Tue Jul 20 03:08:42 2004 UTC (21 years ago) by greg
Changes since 2.7: +3 -9 lines
Diff to previous 2.7 , to selected 2.16
Eliminated unnecessary file chaecking in tmap2bmp()
Fri Apr 30 21:16:58 2004 UTC (21 years, 3 months ago) by greg
Changes since 2.6: +4 -7 lines
Diff to previous 2.6 , to selected 2.16
Fixed inconsistent behavior with inverted Radiance pictures
Fri Apr 30 17:56:06 2004 UTC (21 years, 3 months ago) by greg
Changes since 2.5: +2 -4 lines
Diff to previous 2.5 , to selected 2.16
Fixed - option for reading from stdin
Fri Apr 30 17:30:33 2004 UTC (21 years, 3 months ago) by greg
Changes since 2.4: +3 -2 lines
Diff to previous 2.4 , to selected 2.16
Fixed minor problem with RLE8 output
Fri Apr 30 17:00:29 2004 UTC (21 years, 3 months ago) by greg
Changes since 2.3: +132 -19 lines
Diff to previous 2.3 , to selected 2.16
Sun Mar 28 20:33:14 2004 UTC (21 years, 4 months ago) by schorsch
Changes since 2.2: +10 -8 lines
Diff to previous 2.2 , to selected 2.16
Sat Mar 27 05:43:37 2004 UTC (21 years, 4 months ago) by greg
Changes since 2.1: +14 -7 lines
Diff to previous 2.1 , to selected 2.16
Bug fixes in run-length encoding code
Fri Mar 26 03:11:50 2004 UTC (21 years, 4 months ago) by greg
Diff to selected 2.16
