--- ray/src/px/ra_bmp.c 2004/04/30 17:00:29 2.4 +++ ray/src/px/ra_bmp.c 2004/04/30 21:16:58 2.7 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: ra_bmp.c,v 2.4 2004/04/30 17:00:29 greg Exp $"; +static const char RCSid[] = "$Id: ra_bmp.c,v 2.7 2004/04/30 21:16:58 greg Exp $"; #endif /* * program to convert between RADIANCE and Windows BMP file @@ -41,7 +41,7 @@ main(int argc, char *argv[]) progname = argv[0]; for (i = 1; i < argc; i++) - if (argv[i][0] == '-') + if (argv[i][0] == '-' && argv[i][1]) switch (argv[i][1]) { case 'b': rgbp = NULL; @@ -72,8 +72,6 @@ main(int argc, char *argv[]) case 'r': reverse = !reverse; break; - case '\0': - break; default: goto userr; } @@ -164,8 +162,7 @@ main(int argc, char *argv[]) if (hdr == NULL) quiterr("cannot initialize BMP header"); /* set up output direction */ - hdr->yIsDown = (rs.rt & YDECR) && - ((outfile == NULL) | (hdr->compr == BI_RLE8)); + hdr->yIsDown = ((outfile == NULL) | (hdr->compr == BI_RLE8)); /* open BMP output */ if (outfile != NULL) wtr = BMPopenOutputFile(outfile, hdr); @@ -174,7 +171,7 @@ main(int argc, char *argv[]) if (wtr == NULL) quiterr("cannot allocate writer structure"); /* convert file */ - rad2bmp(stdin, wtr, !hdr->yIsDown && rs.rt&YDECR, rgbp==NULL); + rad2bmp(stdin, wtr, !hdr->yIsDown, rgbp==NULL); /* flush output */ if (fflush((FILE *)wtr->c_data) < 0) quiterr("error writing BMP output"); @@ -335,7 +332,8 @@ tmap2bmp(char *fnin, char *fnout, char *expec, RGBPRIM /* initialize BMP header */ if (tmflags & TM_F_BW) { hdr = BMPmappedHeader(xr, yr, 0, 256); - hdr->compr = BI_RLE8; + if (fnout != NULL) + hdr->compr = BI_RLE8; } else hdr = BMPtruecolorHeader(xr, yr, 0); if (hdr == NULL) @@ -350,9 +348,7 @@ tmap2bmp(char *fnin, char *fnout, char *expec, RGBPRIM /* write to BMP file */ while (wtr->yscan < yr) { BYTE *scn = pa + xr*((tmflags & TM_F_BW) ? 1 : 3)* - ((rs.rt & YDECR) ? - (yr-1 - wtr->yscan) : - wtr->yscan); + (yr-1 - wtr->yscan); if (tmflags & TM_F_BW) memcpy((void *)wtr->scanline, (void *)scn, xr); else
