root/radiance/ray/src/px/ra_bmp.c
Sun Apr 5 19:10:51 2020 UTC (4 years, 1 month ago) by greg
Changes since 2.13: +5 -4 lines
Fixed segmentation error with -b on input with color primaries
Fri Jul 19 17:37:56 2019 UTC (4 years, 10 months ago) by greg
Changes since 2.12: +2 -3 lines
Thu Aug 2 18:33:46 2018 UTC (5 years, 9 months ago) by greg
Mon Oct 4 17:44:22 2004 UTC (19 years, 7 months ago) by greg
Changes since 2.9: +3 -1 lines
Thu Sep 23 18:00:54 2004 UTC (19 years, 8 months ago) by greg
Changes since 2.8: +68 -12 lines
Tue Jul 20 03:08:42 2004 UTC (19 years, 10 months ago) by greg
Changes since 2.7: +3 -9 lines
Eliminated unnecessary file chaecking in tmap2bmp()
Fri Apr 30 21:16:58 2004 UTC (20 years, 1 month ago) by greg
Changes since 2.6: +4 -7 lines
Fixed inconsistent behavior with inverted Radiance pictures
Fri Apr 30 17:56:06 2004 UTC (20 years, 1 month ago) by greg
Changes since 2.5: +2 -4 lines
Fixed - option for reading from stdin
Fri Apr 30 17:30:33 2004 UTC (20 years, 1 month ago) by greg
Changes since 2.4: +3 -2 lines
Fixed minor problem with RLE8 output
Fri Apr 30 17:00:29 2004 UTC (20 years, 1 month ago) by greg
Changes since 2.3: +132 -19 lines
Changes since 2.2: +10 -8 lines
Sat Mar 27 05:43:37 2004 UTC (20 years, 2 months ago) by greg
Changes since 2.1: +14 -7 lines
Bug fixes in run-length encoding code
Fri Mar 26 03:11:50 2004 UTC (20 years, 2 months ago) by greg
Diff to selected 2.7
