root/radiance/ray/src/px/ra_avs.c
Sun Mar 28 20:33:14 2004 UTC (20 years ago) by schorsch
Changes since 2.10: +19 -9 lines
Thu Jun 5 19:29:34 2003 UTC (20 years, 10 months ago) by schorsch
Changes since 2.9: +5 -8 lines
Changes since 2.8: +4 -8 lines
Sun Feb 27 10:17:30 1994 UTC (30 years, 1 month ago) by greg
Wed Dec 1 10:02:15 1993 UTC (30 years, 4 months ago) by greg
fixed detection of empty AVS input file
Thu Nov 18 09:55:29 1993 UTC (30 years, 5 months ago) by greg
minor compiler warning fixes
Wed Oct 27 09:37:37 1993 UTC (30 years, 5 months ago) by greg
Changes since 2.4: +7 -5 lines
fixed missing loop
Mon Jul 12 12:41:13 1993 UTC (30 years, 9 months ago) by greg
renamed gamma to avoid math library conflict
Fri Jun 4 14:45:59 1993 UTC (30 years, 10 months ago) by greg
added math.h for atof() usage
Wed Jun 2 09:41:28 1993 UTC (30 years, 10 months ago) by greg
made AVS header read/write more portable
Tue Jun 1 17:36:55 1993 UTC (30 years, 10 months ago) by greg
