1 |
/* Copyright (c) 1992 Regents of the University of California */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ LBL"; |
5 |
#endif |
6 |
7 |
8 |
* pvalue.c - program to print pixel values. |
9 |
10 |
* 4/23/86 |
11 |
12 |
13 |
#include "standard.h" |
14 |
15 |
#include "color.h" |
16 |
17 |
#include "resolu.h" |
18 |
19 |
#define min(a,b) ((a)<(b)?(a):(b)) |
20 |
21 |
RESOLU picres; /* resolution of picture */ |
22 |
23 |
int uniq = 0; /* print only unique values? */ |
24 |
25 |
int doexposure = 0; /* exposure change? (>100 to print) */ |
26 |
27 |
int dataonly = 0; /* data only format? */ |
28 |
29 |
int brightonly = 0; /* only brightness values? */ |
30 |
31 |
int reverse = 0; /* reverse conversion? */ |
32 |
33 |
int format = 'a'; /* input/output format */ |
34 |
char *fmtid = "ascii"; /* format identifier for header */ |
35 |
36 |
int header = 1; /* do header? */ |
37 |
38 |
int resolution = 1; /* put/get resolution string? */ |
39 |
40 |
int original = 0; /* convert to original values? */ |
41 |
42 |
int wrongformat = 0; /* wrong input format? */ |
43 |
44 |
double gamcor = 1.0; /* gamma correction */ |
45 |
46 |
int ord[3] = {RED, GRN, BLU}; /* RGB ordering */ |
47 |
int rord[4]; /* reverse ordering */ |
48 |
49 |
COLOR exposure = WHTCOLOR; |
50 |
51 |
char *progname; |
52 |
53 |
FILE *fin; |
54 |
55 |
int (*getval)(), (*putval)(); |
56 |
57 |
58 |
main(argc, argv) |
59 |
int argc; |
60 |
char **argv; |
61 |
62 |
extern int checkhead(); |
63 |
double d, expval = 1.0; |
64 |
int i; |
65 |
66 |
progname = argv[0]; |
67 |
68 |
for (i = 1; i < argc; i++) |
69 |
if (argv[i][0] == '-' || argv[i][0] == '+') |
70 |
switch (argv[i][1]) { |
71 |
case 'h': /* header */ |
72 |
header = argv[i][0] == '+'; |
73 |
break; |
74 |
case 'H': /* resolution string */ |
75 |
resolution = argv[i][0] == '+'; |
76 |
break; |
77 |
case 'u': /* unique values */ |
78 |
uniq = argv[i][0] == '-'; |
79 |
break; |
80 |
case 'o': /* original values */ |
81 |
original = argv[i][0] == '-'; |
82 |
break; |
83 |
case 'g': /* gamma correction */ |
84 |
gamcor = atof(argv[i+1]); |
85 |
if (argv[i][0] == '+') |
86 |
gamcor = 1.0/gamcor; |
87 |
i++; |
88 |
break; |
89 |
case 'e': /* exposure correction */ |
90 |
d = atof(argv[i+1]); |
91 |
if (argv[i+1][0] == '-' || argv[i+1][0] == '+') |
92 |
d = pow(2.0, d); |
93 |
if (argv[i][0] == '-') |
94 |
expval *= d; |
95 |
scalecolor(exposure, d); |
96 |
doexposure++; |
97 |
i++; |
98 |
break; |
99 |
case 'R': /* reverse byte sequence */ |
100 |
if (argv[i][0] == '-') { |
101 |
ord[0]=BLU; ord[1]=GRN; ord[2]=RED; |
102 |
} else { |
103 |
ord[0]=RED; ord[1]=GRN; ord[2]=BLU; |
104 |
105 |
break; |
106 |
case 'r': /* reverse conversion */ |
107 |
reverse = argv[i][0] == '-'; |
108 |
break; |
109 |
case 'b': /* brightness values */ |
110 |
brightonly = argv[i][0] == '-'; |
111 |
break; |
112 |
case 'd': /* data only (no indices) */ |
113 |
dataonly = argv[i][0] == '-'; |
114 |
switch (argv[i][2]) { |
115 |
case '\0': |
116 |
case 'a': /* ascii */ |
117 |
format = 'a'; |
118 |
fmtid = "ascii"; |
119 |
break; |
120 |
case 'i': /* integer */ |
121 |
format = 'i'; |
122 |
fmtid = "ascii"; |
123 |
break; |
124 |
case 'b': /* byte */ |
125 |
dataonly = 1; |
126 |
format = 'b'; |
127 |
fmtid = "byte"; |
128 |
break; |
129 |
case 'f': /* float */ |
130 |
dataonly = 1; |
131 |
format = 'f'; |
132 |
fmtid = "float"; |
133 |
break; |
134 |
case 'd': /* double */ |
135 |
dataonly = 1; |
136 |
format = 'd'; |
137 |
fmtid = "double"; |
138 |
break; |
139 |
default: |
140 |
goto unkopt; |
141 |
142 |
break; |
143 |
case 'x': /* x resolution */ |
144 |
case 'X': /* x resolution */ |
145 |
resolution = 0; |
146 |
147 |
picres.or |= XDECR; |
148 |
picres.xr = atoi(argv[++i]); |
149 |
break; |
150 |
case 'y': /* y resolution */ |
151 |
case 'Y': /* y resolution */ |
152 |
resolution = 0; |
153 |
154 |
picres.or |= YDECR; |
155 |
if (picres.xr == 0) |
156 |
picres.or |= YMAJOR; |
157 |
picres.yr = atoi(argv[++i]); |
158 |
break; |
159 |
default: |
160 |
unkopt: |
161 |
fprintf(stderr, "%s: unknown option: %s\n", |
162 |
progname, argv[i]); |
163 |
quit(1); |
164 |
break; |
165 |
166 |
else |
167 |
break; |
168 |
/* recognize special formats */ |
169 |
if (dataonly && format == 'b') |
170 |
if (brightonly) |
171 |
fmtid = "8-bit_grey"; |
172 |
else |
173 |
fmtid = "24-bit_rgb"; |
174 |
/* assign reverse ordering */ |
175 |
rord[ord[0]] = 0; |
176 |
rord[ord[1]] = 1; |
177 |
rord[ord[2]] = 2; |
178 |
/* get input */ |
179 |
if (i == argc) { |
180 |
fin = stdin; |
181 |
} else if (i == argc-1) { |
182 |
if ((fin = fopen(argv[i], "r")) == NULL) { |
183 |
fprintf(stderr, "%s: can't open file \"%s\"\n", |
184 |
185 |
quit(1); |
186 |
187 |
} else { |
188 |
fprintf(stderr, "%s: bad # file arguments\n", progname); |
189 |
quit(1); |
190 |
191 |
192 |
set_io(); |
193 |
194 |
if (reverse) { |
195 |
#ifdef MSDOS |
196 |
setmode(fileno(stdout), O_BINARY); |
197 |
if (format != 'a' && format != 'i') |
198 |
setmode(fileno(fin), O_BINARY); |
199 |
#endif |
200 |
/* get header */ |
201 |
if (header) { |
202 |
if (checkheader(fin, fmtid, stdout) < 0) { |
203 |
fprintf(stderr, "%s: wrong input format\n", |
204 |
progname); |
205 |
quit(1); |
206 |
207 |
} else |
208 |
newheader("RADIANCE", stdout); |
209 |
/* get resolution */ |
210 |
if ((resolution && !fgetsresolu(&picres, fin)) || |
211 |
picres.xr <= 0 || picres.yr <= 0) { |
212 |
fprintf(stderr, "%s: missing resolution\n", progname); |
213 |
quit(1); |
214 |
215 |
/* add to header */ |
216 |
printargs(i, argv, stdout); |
217 |
if (expval < .99 || expval > 1.01) |
218 |
fputexpos(expval, stdout); |
219 |
fputformat(COLRFMT, stdout); |
220 |
putchar('\n'); |
221 |
fputsresolu(&picres, stdout); /* always put resolution */ |
222 |
valtopix(); |
223 |
} else { |
224 |
#ifdef MSDOS |
225 |
226 |
227 |
228 |
#endif |
229 |
/* get header */ |
230 |
getheader(fin, checkhead, NULL); |
231 |
if (wrongformat) { |
232 |
fprintf(stderr, "%s: input not a Radiance picture\n", |
233 |
progname); |
234 |
quit(1); |
235 |
236 |
if (!fgetsresolu(&picres, fin)) { |
237 |
238 |
quit(1); |
239 |
240 |
if (header) { |
241 |
242 |
243 |
244 |
fputformat(fmtid, stdout); |
245 |
putchar('\n'); |
246 |
247 |
if (resolution) /* put resolution */ |
248 |
fputsresolu(&picres, stdout); |
249 |
pixtoval(); |
250 |
251 |
252 |
quit(0); |
253 |
254 |
255 |
256 |
checkhead(line) /* deal with line from header */ |
257 |
char *line; |
258 |
259 |
char fmt[32]; |
260 |
double d; |
261 |
COLOR ctmp; |
262 |
263 |
if (formatval(fmt, line)) |
264 |
wrongformat = strcmp(fmt, COLRFMT); |
265 |
else if (original && isexpos(line)) { |
266 |
d = 1.0/exposval(line); |
267 |
268 |
doexposure++; |
269 |
} else if (original && iscolcor(line)) { |
270 |
colcorval(ctmp, line); |
271 |
setcolor(exposure, colval(exposure,RED)/colval(ctmp,RED), |
272 |
colval(exposure,GRN)/colval(ctmp,GRN), |
273 |
colval(exposure,BLU)/colval(ctmp,BLU)); |
274 |
doexposure++; |
275 |
} else if (header) |
276 |
fputs(line, stdout); |
277 |
278 |
279 |
280 |
pixtoval() /* convert picture to values */ |
281 |
282 |
register COLOR *scanln; |
283 |
int dogamma; |
284 |
COLOR lastc; |
285 |
FLOAT hv[2]; |
286 |
int y; |
287 |
register int x; |
288 |
289 |
scanln = (COLOR *)malloc(scanlen(&picres)*sizeof(COLOR)); |
290 |
if (scanln == NULL) { |
291 |
fprintf(stderr, "%s: out of memory\n", progname); |
292 |
quit(1); |
293 |
294 |
dogamma = gamcor < .95 || gamcor > 1.05; |
295 |
setcolor(lastc, 0.0, 0.0, 0.0); |
296 |
for (y = 0; y < numscans(&picres); y++) { |
297 |
if (freadscan(scanln, scanlen(&picres), fin) < 0) { |
298 |
fprintf(stderr, "%s: read error\n", progname); |
299 |
quit(1); |
300 |
301 |
for (x = 0; x < scanlen(&picres); x++) { |
302 |
if (uniq) |
303 |
if ( colval(scanln[x],RED) == |
304 |
colval(lastc,RED) && |
305 |
colval(scanln[x],GRN) == |
306 |
colval(lastc,GRN) && |
307 |
colval(scanln[x],BLU) == |
308 |
colval(lastc,BLU) ) |
309 |
continue; |
310 |
else |
311 |
copycolor(lastc, scanln[x]); |
312 |
if (doexposure) |
313 |
multcolor(scanln[x], exposure); |
314 |
if (dogamma) |
315 |
setcolor(scanln[x], |
316 |
pow(colval(scanln[x],RED), 1.0/gamcor), |
317 |
pow(colval(scanln[x],GRN), 1.0/gamcor), |
318 |
pow(colval(scanln[x],BLU), 1.0/gamcor)); |
319 |
if (!dataonly) { |
320 |
pix2loc(hv, &picres, x, y); |
321 |
printf("%7d %7d ", (int)(hv[0]*picres.xr), |
322 |
(int)(hv[1]*picres.yr)); |
323 |
324 |
if ((*putval)(scanln[x], stdout) < 0) { |
325 |
fprintf(stderr, "%s: write error\n", progname); |
326 |
quit(1); |
327 |
328 |
329 |
330 |
free((char *)scanln); |
331 |
332 |
333 |
334 |
valtopix() /* convert values to a pixel file */ |
335 |
336 |
int dogamma; |
337 |
338 |
int y; |
339 |
register int x; |
340 |
341 |
342 |
343 |
344 |
quit(1); |
345 |
346 |
347 |
348 |
349 |
if (!dataonly) |
350 |
fscanf(fin, "%*d %*d"); |
351 |
if ((*getval)(scanln[x], fin) < 0) { |
352 |
353 |
quit(1); |
354 |
355 |
if (dogamma) |
356 |
357 |
pow(colval(scanln[x],RED), gamcor), |
358 |
pow(colval(scanln[x],GRN), gamcor), |
359 |
pow(colval(scanln[x],BLU), gamcor)); |
360 |
if (doexposure) |
361 |
362 |
363 |
if (fwritescan(scanln, scanlen(&picres), stdout) < 0) { |
364 |
365 |
quit(1); |
366 |
367 |
368 |
369 |
370 |
371 |
372 |
quit(code) |
373 |
int code; |
374 |
375 |
exit(code); |
376 |
377 |
378 |
379 |
getcascii(col, fp) /* get an ascii color value from fp */ |
380 |
COLOR col; |
381 |
FILE *fp; |
382 |
383 |
double vd[3]; |
384 |
385 |
if (fscanf(fp, "%lf %lf %lf", &vd[0], &vd[1], &vd[2]) != 3) |
386 |
return(-1); |
387 |
setcolor(col, vd[rord[RED]], vd[rord[GRN]], vd[rord[BLU]]); |
388 |
return(0); |
389 |
390 |
391 |
392 |
getcdouble(col, fp) /* get a double color value from fp */ |
393 |
COLOR col; |
394 |
FILE *fp; |
395 |
396 |
double vd[3]; |
397 |
398 |
if (fread((char *)vd, sizeof(double), 3, fp) != 3) |
399 |
return(-1); |
400 |
401 |
return(0); |
402 |
403 |
404 |
405 |
getcfloat(col, fp) /* get a float color value from fp */ |
406 |
COLOR col; |
407 |
FILE *fp; |
408 |
409 |
float vf[3]; |
410 |
411 |
if (fread((char *)vf, sizeof(float), 3, fp) != 3) |
412 |
return(-1); |
413 |
setcolor(col, vf[rord[RED]], vf[rord[GRN]], vf[rord[BLU]]); |
414 |
return(0); |
415 |
416 |
417 |
418 |
getcint(col, fp) /* get an int color value from fp */ |
419 |
COLOR col; |
420 |
FILE *fp; |
421 |
422 |
int vi[3]; |
423 |
424 |
if (fscanf(fp, "%d %d %d", &vi[0], &vi[1], &vi[2]) != 3) |
425 |
return(-1); |
426 |
setcolor(col, (vi[rord[RED]]+.5)/256., |
427 |
(vi[rord[GRN]]+.5)/256., (vi[rord[BLU]]+.5)/256.); |
428 |
return(0); |
429 |
430 |
431 |
432 |
getcbyte(col, fp) /* get a byte color value from fp */ |
433 |
COLOR col; |
434 |
FILE *fp; |
435 |
436 |
BYTE vb[3]; |
437 |
438 |
if (fread((char *)vb, sizeof(BYTE), 3, fp) != 3) |
439 |
return(-1); |
440 |
setcolor(col, (vb[rord[RED]]+.5)/256., |
441 |
(vb[rord[GRN]]+.5)/256., (vb[rord[BLU]]+.5)/256.); |
442 |
return(0); |
443 |
444 |
445 |
446 |
getbascii(col, fp) /* get an ascii brightness value from fp */ |
447 |
COLOR col; |
448 |
FILE *fp; |
449 |
450 |
double vd; |
451 |
452 |
if (fscanf(fp, "%lf", &vd) != 1) |
453 |
return(-1); |
454 |
setcolor(col, vd, vd, vd); |
455 |
return(0); |
456 |
457 |
458 |
459 |
getbdouble(col, fp) /* get a double brightness value from fp */ |
460 |
COLOR col; |
461 |
FILE *fp; |
462 |
463 |
double vd; |
464 |
465 |
if (fread((char *)&vd, sizeof(double), 1, fp) != 1) |
466 |
return(-1); |
467 |
468 |
return(0); |
469 |
470 |
471 |
472 |
getbfloat(col, fp) /* get a float brightness value from fp */ |
473 |
COLOR col; |
474 |
FILE *fp; |
475 |
476 |
float vf; |
477 |
478 |
if (fread((char *)&vf, sizeof(float), 1, fp) != 1) |
479 |
return(-1); |
480 |
setcolor(col, vf, vf, vf); |
481 |
return(0); |
482 |
483 |
484 |
485 |
getbint(col, fp) /* get an int brightness value from fp */ |
486 |
COLOR col; |
487 |
FILE *fp; |
488 |
489 |
int vi; |
490 |
double d; |
491 |
492 |
if (fscanf(fp, "%d", &vi) != 1) |
493 |
return(-1); |
494 |
d = (vi+.5)/256.; |
495 |
setcolor(col, d, d, d); |
496 |
return(0); |
497 |
498 |
499 |
500 |
getbbyte(col, fp) /* get a byte brightness value from fp */ |
501 |
COLOR col; |
502 |
FILE *fp; |
503 |
504 |
BYTE vb; |
505 |
double d; |
506 |
507 |
if (fread((char *)&vb, sizeof(BYTE), 1, fp) != 1) |
508 |
return(-1); |
509 |
d = (vb+.5)/256.; |
510 |
511 |
return(0); |
512 |
513 |
514 |
515 |
putcascii(col, fp) /* put an ascii color to fp */ |
516 |
COLOR col; |
517 |
FILE *fp; |
518 |
519 |
fprintf(fp, "%15.3e %15.3e %15.3e\n", |
520 |
colval(col,ord[0]), |
521 |
colval(col,ord[1]), |
522 |
colval(col,ord[2])); |
523 |
524 |
return(ferror(fp) ? -1 : 0); |
525 |
526 |
527 |
528 |
putcfloat(col, fp) /* put a float color to fp */ |
529 |
COLOR col; |
530 |
FILE *fp; |
531 |
532 |
float vf[3]; |
533 |
534 |
vf[0] = colval(col,ord[0]); |
535 |
vf[1] = colval(col,ord[1]); |
536 |
vf[2] = colval(col,ord[2]); |
537 |
fwrite((char *)vf, sizeof(float), 3, fp); |
538 |
539 |
540 |
541 |
542 |
543 |
putcdouble(col, fp) /* put a double color to fp */ |
544 |
COLOR col; |
545 |
FILE *fp; |
546 |
547 |
double vd[3]; |
548 |
549 |
vd[0] = colval(col,ord[0]); |
550 |
vd[1] = colval(col,ord[1]); |
551 |
vd[2] = colval(col,ord[2]); |
552 |
fwrite((char *)vd, sizeof(double), 3, fp); |
553 |
554 |
555 |
556 |
557 |
558 |
putcint(col, fp) /* put an int color to fp */ |
559 |
COLOR col; |
560 |
FILE *fp; |
561 |
562 |
fprintf(fp, "%d %d %d\n", |
563 |
(int)(colval(col,ord[0])*256.), |
564 |
(int)(colval(col,ord[1])*256.), |
565 |
(int)(colval(col,ord[2])*256.)); |
566 |
567 |
568 |
569 |
570 |
571 |
putcbyte(col, fp) /* put a byte color to fp */ |
572 |
COLOR col; |
573 |
FILE *fp; |
574 |
575 |
register int i; |
576 |
BYTE vb[3]; |
577 |
578 |
i = colval(col,ord[0])*256.; |
579 |
vb[0] = min(i,255); |
580 |
i = colval(col,ord[1])*256.; |
581 |
vb[1] = min(i,255); |
582 |
i = colval(col,ord[2])*256.; |
583 |
vb[2] = min(i,255); |
584 |
fwrite((char *)vb, sizeof(BYTE), 3, fp); |
585 |
586 |
587 |
588 |
589 |
590 |
putbascii(col, fp) /* put an ascii brightness to fp */ |
591 |
COLOR col; |
592 |
FILE *fp; |
593 |
594 |
fprintf(fp, "%15.3e\n", bright(col)); |
595 |
596 |
597 |
598 |
599 |
600 |
putbfloat(col, fp) /* put a float brightness to fp */ |
601 |
COLOR col; |
602 |
FILE *fp; |
603 |
604 |
float vf; |
605 |
606 |
vf = bright(col); |
607 |
fwrite((char *)&vf, sizeof(float), 1, fp); |
608 |
609 |
610 |
611 |
612 |
613 |
putbdouble(col, fp) /* put a double brightness to fp */ |
614 |
COLOR col; |
615 |
FILE *fp; |
616 |
617 |
double vd; |
618 |
619 |
vd = bright(col); |
620 |
fwrite((char *)&vd, sizeof(double), 1, fp); |
621 |
622 |
623 |
624 |
625 |
626 |
putbint(col, fp) /* put an int brightness to fp */ |
627 |
COLOR col; |
628 |
FILE *fp; |
629 |
630 |
fprintf(fp, "%d\n", (int)(bright(col)*256.)); |
631 |
632 |
633 |
634 |
635 |
636 |
putbbyte(col, fp) /* put a byte brightness to fp */ |
637 |
COLOR col; |
638 |
FILE *fp; |
639 |
640 |
register int i; |
641 |
BYTE vb; |
642 |
643 |
i = bright(col)*256.; |
644 |
vb = min(i,255); |
645 |
fwrite((char *)&vb, sizeof(BYTE), 1, fp); |
646 |
647 |
648 |
649 |
650 |
651 |
set_io() /* set put and get functions */ |
652 |
653 |
switch (format) { |
654 |
655 |
if (brightonly) { |
656 |
getval = getbascii; |
657 |
putval = putbascii; |
658 |
} else { |
659 |
getval = getcascii; |
660 |
putval = putcascii; |
661 |
662 |
return; |
663 |
case 'f': /* binary float */ |
664 |
if (brightonly) { |
665 |
getval = getbfloat; |
666 |
putval = putbfloat; |
667 |
} else { |
668 |
getval = getcfloat; |
669 |
putval = putcfloat; |
670 |
671 |
return; |
672 |
case 'd': /* binary double */ |
673 |
if (brightonly) { |
674 |
getval = getbdouble; |
675 |
putval = putbdouble; |
676 |
} else { |
677 |
getval = getcdouble; |
678 |
putval = putcdouble; |
679 |
680 |
return; |
681 |
682 |
if (brightonly) { |
683 |
getval = getbint; |
684 |
putval = putbint; |
685 |
} else { |
686 |
getval = getcint; |
687 |
putval = putcint; |
688 |
689 |
return; |
690 |
691 |
if (brightonly) { |
692 |
getval = getbbyte; |
693 |
putval = putbbyte; |
694 |
} else { |
695 |
getval = getcbyte; |
696 |
putval = putcbyte; |
697 |
698 |
return; |
699 |
700 |
