1 |
/* Copyright (c) 1991 Regents of the University of California */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ LBL"; |
5 |
#endif |
6 |
7 |
8 |
* pvalue.c - program to print pixel values. |
9 |
10 |
* 4/23/86 |
11 |
12 |
13 |
#include "standard.h" |
14 |
15 |
#include "color.h" |
16 |
17 |
#include "resolu.h" |
18 |
19 |
#define min(a,b) ((a)<(b)?(a):(b)) |
20 |
21 |
RESOLU picres; /* resolution of picture */ |
22 |
23 |
int uniq = 0; /* print only unique values? */ |
24 |
25 |
int original = 0; /* convert back to original values? */ |
26 |
27 |
int dataonly = 0; /* data only format? */ |
28 |
29 |
int brightonly = 0; /* only brightness values? */ |
30 |
31 |
int reverse = 0; /* reverse conversion? */ |
32 |
33 |
int format = 'a'; /* input/output format */ |
34 |
char *fmtid = "ascii"; /* format identifier for header */ |
35 |
36 |
int header = 1; /* do header? */ |
37 |
38 |
int resolution = 1; /* put/get resolution string? */ |
39 |
40 |
int wrongformat = 0; /* wrong input format? */ |
41 |
42 |
double gamcor = 1.0; /* gamma correction */ |
43 |
44 |
int ord[3] = {RED, GRN, BLU}; /* RGB ordering */ |
45 |
int rord[4]; /* reverse ordering */ |
46 |
47 |
COLOR exposure = WHTCOLOR; |
48 |
49 |
char *progname; |
50 |
51 |
FILE *fin; |
52 |
53 |
int (*getval)(), (*putval)(); |
54 |
55 |
56 |
main(argc, argv) |
57 |
int argc; |
58 |
char **argv; |
59 |
60 |
extern int checkhead(); |
61 |
int i; |
62 |
63 |
progname = argv[0]; |
64 |
65 |
for (i = 1; i < argc; i++) |
66 |
if (argv[i][0] == '-' || argv[i][0] == '+') |
67 |
switch (argv[i][1]) { |
68 |
case 'h': /* header */ |
69 |
header = argv[i][0] == '+'; |
70 |
break; |
71 |
case 'H': /* resolution string */ |
72 |
resolution = argv[i][0] == '+'; |
73 |
break; |
74 |
case 'u': /* unique values */ |
75 |
uniq = argv[i][0] == '-'; |
76 |
break; |
77 |
case 'o': /* original values */ |
78 |
original = argv[i][0] == '-'; |
79 |
break; |
80 |
case 'g': /* gamma correction */ |
81 |
gamcor = atof(argv[++i]); |
82 |
if (argv[i][0] == '+') |
83 |
gamcor = 1.0/gamcor; |
84 |
break; |
85 |
case 'R': /* reverse byte sequence */ |
86 |
if (argv[i][0] == '-') { |
87 |
ord[0]=BLU; ord[1]=GRN; ord[2]=RED; |
88 |
} else { |
89 |
ord[0]=RED; ord[1]=GRN; ord[2]=BLU; |
90 |
91 |
break; |
92 |
case 'r': /* reverse conversion */ |
93 |
reverse = argv[i][0] == '-'; |
94 |
break; |
95 |
case 'b': /* brightness values */ |
96 |
brightonly = argv[i][0] == '-'; |
97 |
break; |
98 |
case 'd': /* data only (no indices) */ |
99 |
dataonly = argv[i][0] == '-'; |
100 |
switch (argv[i][2]) { |
101 |
case '\0': |
102 |
case 'a': /* ascii */ |
103 |
format = 'a'; |
104 |
fmtid = "ascii"; |
105 |
break; |
106 |
case 'i': /* integer */ |
107 |
format = 'i'; |
108 |
fmtid = "ascii"; |
109 |
break; |
110 |
case 'b': /* byte */ |
111 |
dataonly = 1; |
112 |
format = 'b'; |
113 |
fmtid = "byte"; |
114 |
break; |
115 |
case 'f': /* float */ |
116 |
dataonly = 1; |
117 |
format = 'f'; |
118 |
fmtid = "float"; |
119 |
break; |
120 |
case 'd': /* double */ |
121 |
dataonly = 1; |
122 |
format = 'd'; |
123 |
fmtid = "double"; |
124 |
break; |
125 |
default: |
126 |
goto unkopt; |
127 |
128 |
break; |
129 |
case 'x': /* x resolution */ |
130 |
resolution = 0; |
131 |
if (argv[i][0] == '-') |
132 |
picres.or |= XDECR; |
133 |
picres.xr = atoi(argv[++i]); |
134 |
break; |
135 |
case 'y': /* y resolution */ |
136 |
resolution = 0; |
137 |
138 |
picres.or |= YDECR; |
139 |
if (picres.xr == 0) |
140 |
picres.or |= YMAJOR; |
141 |
picres.yr = atoi(argv[++i]); |
142 |
break; |
143 |
default: |
144 |
unkopt: |
145 |
fprintf(stderr, "%s: unknown option: %s\n", |
146 |
progname, argv[i]); |
147 |
quit(1); |
148 |
break; |
149 |
150 |
else |
151 |
break; |
152 |
/* recognize special formats */ |
153 |
if (dataonly && format == 'b') |
154 |
if (brightonly) |
155 |
fmtid = "8-bit_grey"; |
156 |
else |
157 |
fmtid = "24-bit_rgb"; |
158 |
/* assign reverse ordering */ |
159 |
rord[ord[0]] = 0; |
160 |
rord[ord[1]] = 1; |
161 |
rord[ord[2]] = 2; |
162 |
/* get input */ |
163 |
if (i == argc) { |
164 |
fin = stdin; |
165 |
} else if (i == argc-1) { |
166 |
if ((fin = fopen(argv[i], "r")) == NULL) { |
167 |
fprintf(stderr, "%s: can't open file \"%s\"\n", |
168 |
169 |
quit(1); |
170 |
171 |
} else { |
172 |
fprintf(stderr, "%s: bad # file arguments\n", progname); |
173 |
quit(1); |
174 |
175 |
176 |
set_io(); |
177 |
178 |
if (reverse) { |
179 |
/* get header */ |
180 |
if (header && checkheader(fin, fmtid, stdout) < 0) { |
181 |
fprintf(stderr, "%s: wrong input format\n", progname); |
182 |
quit(1); |
183 |
184 |
/* get resolution */ |
185 |
if ((resolution && !fgetsresolu(&picres, fin)) || |
186 |
picres.xr <= 0 || picres.yr <= 0) { |
187 |
fprintf(stderr, "%s: missing resolution\n", progname); |
188 |
quit(1); |
189 |
190 |
/* add to header */ |
191 |
printargs(i, argv, stdout); |
192 |
fputformat(COLRFMT, stdout); |
193 |
putchar('\n'); |
194 |
fputsresolu(&picres, stdout); /* always put resolution */ |
195 |
valtopix(); |
196 |
} else { |
197 |
/* get header */ |
198 |
getheader(fin, checkhead, NULL); |
199 |
if (wrongformat) { |
200 |
fprintf(stderr, "%s: input not a Radiance picture\n", |
201 |
progname); |
202 |
quit(1); |
203 |
204 |
if (!fgetsresolu(&picres, fin)) { |
205 |
206 |
quit(1); |
207 |
208 |
if (header) { |
209 |
210 |
fputformat(fmtid, stdout); |
211 |
putchar('\n'); |
212 |
213 |
if (resolution) /* put resolution */ |
214 |
fputsresolu(&picres, stdout); |
215 |
pixtoval(); |
216 |
217 |
218 |
quit(0); |
219 |
220 |
221 |
222 |
checkhead(line) /* deal with line from header */ |
223 |
char *line; |
224 |
225 |
char fmt[32]; |
226 |
double d; |
227 |
COLOR ctmp; |
228 |
229 |
if (isformat(line)) { |
230 |
formatval(fmt, line); |
231 |
wrongformat = strcmp(fmt, COLRFMT); |
232 |
} else if (original && isexpos(line)) { |
233 |
d = 1.0/exposval(line); |
234 |
scalecolor(exposure, d); |
235 |
} else if (original && iscolcor(line)) { |
236 |
colcorval(ctmp, line); |
237 |
setcolor(exposure, colval(exposure,RED)/colval(ctmp,RED), |
238 |
colval(exposure,GRN)/colval(ctmp,GRN), |
239 |
colval(exposure,BLU)/colval(ctmp,BLU)); |
240 |
} else if (header) |
241 |
fputs(line, stdout); |
242 |
243 |
244 |
245 |
pixtoval() /* convert picture to values */ |
246 |
247 |
register COLOR *scanln; |
248 |
int dogamma; |
249 |
COLOR lastc; |
250 |
FLOAT hv[2]; |
251 |
int y; |
252 |
register int x; |
253 |
254 |
scanln = (COLOR *)malloc(scanlen(&picres)*sizeof(COLOR)); |
255 |
if (scanln == NULL) { |
256 |
fprintf(stderr, "%s: out of memory\n", progname); |
257 |
quit(1); |
258 |
259 |
dogamma = gamcor < .95 || gamcor > 1.05; |
260 |
setcolor(lastc, 0.0, 0.0, 0.0); |
261 |
for (y = 0; y < numscans(&picres); y++) { |
262 |
if (freadscan(scanln, scanlen(&picres), fin) < 0) { |
263 |
fprintf(stderr, "%s: read error\n", progname); |
264 |
quit(1); |
265 |
266 |
for (x = 0; x < scanlen(&picres); x++) { |
267 |
if (uniq) |
268 |
if ( colval(scanln[x],RED) == |
269 |
colval(lastc,RED) && |
270 |
colval(scanln[x],GRN) == |
271 |
colval(lastc,GRN) && |
272 |
colval(scanln[x],BLU) == |
273 |
colval(lastc,BLU) ) |
274 |
continue; |
275 |
else |
276 |
copycolor(lastc, scanln[x]); |
277 |
if (original) |
278 |
multcolor(scanln[x], exposure); |
279 |
if (dogamma) |
280 |
setcolor(scanln[x], |
281 |
pow(colval(scanln[x],RED), 1.0/gamcor), |
282 |
pow(colval(scanln[x],GRN), 1.0/gamcor), |
283 |
pow(colval(scanln[x],BLU), 1.0/gamcor)); |
284 |
if (!dataonly) { |
285 |
pix2loc(hv, &picres, x, y); |
286 |
printf("%7d %7d ", (int)(hv[0]*picres.xr), |
287 |
(int)(hv[1]*picres.yr)); |
288 |
289 |
if ((*putval)(scanln[x], stdout) < 0) { |
290 |
fprintf(stderr, "%s: write error\n", progname); |
291 |
quit(1); |
292 |
293 |
294 |
295 |
free((char *)scanln); |
296 |
297 |
298 |
299 |
valtopix() /* convert values to a pixel file */ |
300 |
301 |
int dogamma; |
302 |
303 |
int y; |
304 |
register int x; |
305 |
306 |
307 |
308 |
309 |
quit(1); |
310 |
311 |
312 |
313 |
314 |
if (!dataonly) |
315 |
fscanf(fin, "%*d %*d"); |
316 |
if ((*getval)(scanln[x], fin) < 0) { |
317 |
318 |
quit(1); |
319 |
320 |
if (dogamma) |
321 |
322 |
pow(colval(scanln[x],RED), gamcor), |
323 |
pow(colval(scanln[x],GRN), gamcor), |
324 |
pow(colval(scanln[x],BLU), gamcor)); |
325 |
326 |
if (fwritescan(scanln, scanlen(&picres), stdout) < 0) { |
327 |
328 |
quit(1); |
329 |
330 |
331 |
332 |
333 |
334 |
335 |
quit(code) |
336 |
int code; |
337 |
338 |
exit(code); |
339 |
340 |
341 |
342 |
getcascii(col, fp) /* get an ascii color value from fp */ |
343 |
COLOR col; |
344 |
FILE *fp; |
345 |
346 |
double vd[3]; |
347 |
348 |
if (fscanf(fp, "%lf %lf %lf", &vd[0], &vd[1], &vd[2]) != 3) |
349 |
return(-1); |
350 |
setcolor(col, vd[rord[RED]], vd[rord[GRN]], vd[rord[BLU]]); |
351 |
return(0); |
352 |
353 |
354 |
355 |
getcdouble(col, fp) /* get a double color value from fp */ |
356 |
COLOR col; |
357 |
FILE *fp; |
358 |
359 |
double vd[3]; |
360 |
361 |
if (fread((char *)vd, sizeof(double), 3, fp) != 3) |
362 |
return(-1); |
363 |
364 |
return(0); |
365 |
366 |
367 |
368 |
getcfloat(col, fp) /* get a float color value from fp */ |
369 |
COLOR col; |
370 |
FILE *fp; |
371 |
372 |
float vf[3]; |
373 |
374 |
if (fread((char *)vf, sizeof(float), 3, fp) != 3) |
375 |
return(-1); |
376 |
setcolor(col, vf[rord[RED]], vf[rord[GRN]], vf[rord[BLU]]); |
377 |
return(0); |
378 |
379 |
380 |
381 |
getcint(col, fp) /* get an int color value from fp */ |
382 |
COLOR col; |
383 |
FILE *fp; |
384 |
385 |
int vi[3]; |
386 |
387 |
if (fscanf(fp, "%d %d %d", &vi[0], &vi[1], &vi[2]) != 3) |
388 |
return(-1); |
389 |
setcolor(col, (vi[rord[RED]]+.5)/256., |
390 |
(vi[rord[GRN]]+.5)/256., (vi[rord[BLU]]+.5)/256.); |
391 |
return(0); |
392 |
393 |
394 |
395 |
getcbyte(col, fp) /* get a byte color value from fp */ |
396 |
COLOR col; |
397 |
FILE *fp; |
398 |
399 |
BYTE vb[3]; |
400 |
401 |
if (fread((char *)vb, sizeof(BYTE), 3, fp) != 3) |
402 |
return(-1); |
403 |
setcolor(col, (vb[rord[RED]]+.5)/256., |
404 |
(vb[rord[GRN]]+.5)/256., (vb[rord[BLU]]+.5)/256.); |
405 |
return(0); |
406 |
407 |
408 |
409 |
getbascii(col, fp) /* get an ascii brightness value from fp */ |
410 |
COLOR col; |
411 |
FILE *fp; |
412 |
413 |
double vd; |
414 |
415 |
if (fscanf(fp, "%lf", &vd) != 1) |
416 |
return(-1); |
417 |
setcolor(col, vd, vd, vd); |
418 |
return(0); |
419 |
420 |
421 |
422 |
getbdouble(col, fp) /* get a double brightness value from fp */ |
423 |
COLOR col; |
424 |
FILE *fp; |
425 |
426 |
double vd; |
427 |
428 |
if (fread((char *)&vd, sizeof(double), 1, fp) != 1) |
429 |
return(-1); |
430 |
431 |
return(0); |
432 |
433 |
434 |
435 |
getbfloat(col, fp) /* get a float brightness value from fp */ |
436 |
COLOR col; |
437 |
FILE *fp; |
438 |
439 |
float vf; |
440 |
441 |
if (fread((char *)&vf, sizeof(float), 1, fp) != 1) |
442 |
return(-1); |
443 |
setcolor(col, vf, vf, vf); |
444 |
return(0); |
445 |
446 |
447 |
448 |
getbint(col, fp) /* get an int brightness value from fp */ |
449 |
COLOR col; |
450 |
FILE *fp; |
451 |
452 |
int vi; |
453 |
double d; |
454 |
455 |
if (fscanf(fp, "%d", &vi) != 1) |
456 |
return(-1); |
457 |
d = (vi+.5)/256.; |
458 |
setcolor(col, d, d, d); |
459 |
return(0); |
460 |
461 |
462 |
463 |
getbbyte(col, fp) /* get a byte brightness value from fp */ |
464 |
COLOR col; |
465 |
FILE *fp; |
466 |
467 |
BYTE vb; |
468 |
double d; |
469 |
470 |
if (fread((char *)&vb, sizeof(BYTE), 1, fp) != 1) |
471 |
return(-1); |
472 |
d = (vb+.5)/256.; |
473 |
474 |
return(0); |
475 |
476 |
477 |
478 |
putcascii(col, fp) /* put an ascii color to fp */ |
479 |
COLOR col; |
480 |
FILE *fp; |
481 |
482 |
fprintf(fp, "%15.3e %15.3e %15.3e\n", |
483 |
colval(col,ord[0]), |
484 |
colval(col,ord[1]), |
485 |
colval(col,ord[2])); |
486 |
487 |
return(ferror(fp) ? -1 : 0); |
488 |
489 |
490 |
491 |
putcfloat(col, fp) /* put a float color to fp */ |
492 |
COLOR col; |
493 |
FILE *fp; |
494 |
495 |
float vf[3]; |
496 |
497 |
vf[0] = colval(col,ord[0]); |
498 |
vf[1] = colval(col,ord[1]); |
499 |
vf[2] = colval(col,ord[2]); |
500 |
fwrite((char *)vf, sizeof(float), 3, fp); |
501 |
502 |
503 |
504 |
505 |
506 |
putcdouble(col, fp) /* put a double color to fp */ |
507 |
COLOR col; |
508 |
FILE *fp; |
509 |
510 |
double vd[3]; |
511 |
512 |
vd[0] = colval(col,ord[0]); |
513 |
vd[1] = colval(col,ord[1]); |
514 |
vd[2] = colval(col,ord[2]); |
515 |
fwrite((char *)vd, sizeof(double), 3, fp); |
516 |
517 |
518 |
519 |
520 |
521 |
putcint(col, fp) /* put an int color to fp */ |
522 |
COLOR col; |
523 |
FILE *fp; |
524 |
525 |
fprintf(fp, "%d %d %d\n", |
526 |
(int)(colval(col,ord[0])*256.), |
527 |
(int)(colval(col,ord[1])*256.), |
528 |
(int)(colval(col,ord[2])*256.)); |
529 |
530 |
531 |
532 |
533 |
534 |
putcbyte(col, fp) /* put a byte color to fp */ |
535 |
COLOR col; |
536 |
FILE *fp; |
537 |
538 |
register int i; |
539 |
BYTE vb[3]; |
540 |
541 |
i = colval(col,ord[0])*256.; |
542 |
vb[0] = min(i,255); |
543 |
i = colval(col,ord[1])*256.; |
544 |
vb[1] = min(i,255); |
545 |
i = colval(col,ord[2])*256.; |
546 |
vb[2] = min(i,255); |
547 |
fwrite((char *)vb, sizeof(BYTE), 3, fp); |
548 |
549 |
550 |
551 |
552 |
553 |
putbascii(col, fp) /* put an ascii brightness to fp */ |
554 |
COLOR col; |
555 |
FILE *fp; |
556 |
557 |
fprintf(fp, "%15.3e\n", bright(col)); |
558 |
559 |
560 |
561 |
562 |
563 |
putbfloat(col, fp) /* put a float brightness to fp */ |
564 |
COLOR col; |
565 |
FILE *fp; |
566 |
567 |
float vf; |
568 |
569 |
vf = bright(col); |
570 |
fwrite((char *)&vf, sizeof(float), 1, fp); |
571 |
572 |
573 |
574 |
575 |
576 |
putbdouble(col, fp) /* put a double brightness to fp */ |
577 |
COLOR col; |
578 |
FILE *fp; |
579 |
580 |
double vd; |
581 |
582 |
vd = bright(col); |
583 |
fwrite((char *)&vd, sizeof(double), 1, fp); |
584 |
585 |
586 |
587 |
588 |
589 |
putbint(col, fp) /* put an int brightness to fp */ |
590 |
COLOR col; |
591 |
FILE *fp; |
592 |
593 |
fprintf(fp, "%d\n", (int)(bright(col)*256.)); |
594 |
595 |
596 |
597 |
598 |
599 |
putbbyte(col, fp) /* put a byte brightness to fp */ |
600 |
COLOR col; |
601 |
FILE *fp; |
602 |
603 |
register int i; |
604 |
BYTE vb; |
605 |
606 |
i = bright(col)*256.; |
607 |
vb = min(i,255); |
608 |
fwrite((char *)&vb, sizeof(BYTE), 1, fp); |
609 |
610 |
611 |
612 |
613 |
614 |
set_io() /* set put and get functions */ |
615 |
616 |
switch (format) { |
617 |
618 |
if (brightonly) { |
619 |
getval = getbascii; |
620 |
putval = putbascii; |
621 |
} else { |
622 |
getval = getcascii; |
623 |
putval = putcascii; |
624 |
625 |
return; |
626 |
case 'f': /* binary float */ |
627 |
if (brightonly) { |
628 |
getval = getbfloat; |
629 |
putval = putbfloat; |
630 |
} else { |
631 |
getval = getcfloat; |
632 |
putval = putcfloat; |
633 |
634 |
return; |
635 |
case 'd': /* binary double */ |
636 |
if (brightonly) { |
637 |
getval = getbdouble; |
638 |
putval = putbdouble; |
639 |
} else { |
640 |
getval = getcdouble; |
641 |
putval = putcdouble; |
642 |
643 |
return; |
644 |
645 |
if (brightonly) { |
646 |
getval = getbint; |
647 |
putval = putbint; |
648 |
} else { |
649 |
getval = getcint; |
650 |
putval = putcint; |
651 |
652 |
return; |
653 |
654 |
if (brightonly) { |
655 |
getval = getbbyte; |
656 |
putval = putbbyte; |
657 |
} else { |
658 |
getval = getcbyte; |
659 |
putval = putcbyte; |
660 |
661 |
return; |
662 |
663 |
