root/radiance/ray/src/px/pvalue.c
Revision: 2.21
Committed: Thu Jun 26 00:58:10 2003 UTC (22 years ago) by schorsch
2 static const char RCSid[] = "$Id: pvalue.c,v 2.20 2003/06/20 00:25:50 greg Exp $";
5 * pvalue.c - program to print pixel values.
6 *
7 * 4/23/86
8 */
9
10 #include <time.h>
11
12 #include "standard.h"
13 #include "platform.h"
14 #include "color.h"
15 #include "resolu.h"
16
17 #define min(a,b) ((a)<(b)?(a):(b))
18
19 /* what to put out (also RED, GRN, BLU) */
20 #define ALL 3
21 #define BRIGHT 4
22
23 RESOLU picres; /* resolution of picture */
24
25 int uniq = 0; /* print only unique values? */
26
27 int doexposure = 0; /* exposure change? (>100 to print) */
28
29 int dataonly = 0; /* data only format? */
30
31 int putprim = ALL; /* what to put out */
32
33 int reverse = 0; /* reverse conversion? */
34
35 int format = 'a'; /* input/output format */
36 char *fmtid = "ascii"; /* format identifier for header */
37
38 int header = 1; /* do header? */
39
40 long skipbytes = 0; /* skip bytes in input? */
41
42 int swapbytes = 0; /* swap bytes in 16-bit words? */
43
44 int interleave = 1; /* file is interleaved? */
45
46 int resolution = 1; /* put/get resolution string? */
47
48 int original = 0; /* convert to original values? */
49
50 int wrongformat = 0; /* wrong input format? */
51
52 double gamcor = 1.0; /* gamma correction */
53
54 int ord[3] = {RED, GRN, BLU}; /* RGB ordering */
55 int rord[4]; /* reverse ordering */
56
57 COLOR exposure = WHTCOLOR;
58
59 char *progname;
60
61 FILE *fin;
62 FILE *fin2 = NULL, *fin3 = NULL; /* for other color channels */
63
64 int (*getval)(), (*putval)();
65
66 double
67 rgb_bright(clr)
68 COLOR clr;
69 {
70 return(bright(clr));
71 }
72
73 double
74 xyz_bright(clr)
75 COLOR clr;
76 {
77 return(clr[CIEY]);
78 }
79
80 double (*mybright)() = &rgb_bright;
81
82
83 main(argc, argv)
84 int argc;
85 char **argv;
86 {
87 extern int checkhead();
88 extern long atol();
89 double d, expval = 1.0;
90 int i;
91
92 progname = argv[0];
93
94 for (i = 1; i < argc; i++)
95 if (argv[i][0] == '-' || argv[i][0] == '+')
96 switch (argv[i][1]) {
97 case 'h': /* header */
98 header = argv[i][0] == '+';
99 break;
100 case 'H': /* resolution string */
101 resolution = argv[i][0] == '+';
102 break;
103 case 's': /* skip bytes in header */
104 skipbytes = atol(argv[++i]);
105 break;
106 case 'u': /* unique values */
107 uniq = argv[i][0] == '-';
108 break;
109 case 'o': /* original values */
110 original = argv[i][0] == '-';
111 break;
112 case 'g': /* gamma correction */
113 gamcor = atof(argv[i+1]);
114 if (argv[i][0] == '+')
115 gamcor = 1.0/gamcor;
116 i++;
117 break;
118 case 'e': /* exposure correction */
119 d = atof(argv[i+1]);
120 if (argv[i+1][0] == '-' || argv[i+1][0] == '+')
121 d = pow(2.0, d);
122 if (argv[i][0] == '-')
123 expval *= d;
124 scalecolor(exposure, d);
125 doexposure++;
126 i++;
127 break;
128 case 'R': /* reverse byte sequence */
129 if (argv[i][0] == '-') {
130 ord[0]=BLU; ord[1]=GRN; ord[2]=RED;
131 } else {
132 ord[0]=RED; ord[1]=GRN; ord[2]=BLU;
133 }
134 break;
135 case 'r': /* reverse conversion */
136 reverse = argv[i][0] == '-';
137 break;
138 case 'n': /* non-interleaved RGB */
139 interleave = argv[i][0] == '+';
140 break;
141 case 'b': /* brightness values */
142 putprim = argv[i][0] == '-' ? BRIGHT : ALL;
143 break;
144 case 'p': /* put primary */
145 switch (argv[i][2]) {
146 case 'r': case 'R': putprim = RED; break;
147 case 'g': case 'G': putprim = GRN; break;
148 case 'b': case 'B': putprim = BLU; break;
149 default: goto unkopt;
150 }
151 break;
152 case 'd': /* data only (no indices) */
153 dataonly = argv[i][0] == '-';
154 switch (argv[i][2]) {
155 case '\0':
156 case 'a': /* ascii */
157 format = 'a';
158 fmtid = "ascii";
159 break;
160 case 'i': /* integer */
161 format = 'i';
162 fmtid = "ascii";
163 break;
164 case 'b': /* byte */
165 dataonly = 1;
166 format = 'b';
167 fmtid = "byte";
168 break;
169 case 'W': /* 16-bit swapped */
170 swapbytes = 1;
171 case 'w': /* 16-bit */
172 dataonly = 1;
173 format = 'w';
174 fmtid = "16-bit";
175 break;
176 case 'f': /* float */
177 dataonly = 1;
178 format = 'f';
179 fmtid = "float";
180 break;
181 case 'd': /* double */
182 dataonly = 1;
183 format = 'd';
184 fmtid = "double";
185 break;
186 default:
187 goto unkopt;
188 }
189 break;
190 case 'x': /* x resolution */
191 case 'X': /* x resolution */
192 resolution = 0;
193 if (argv[i][0] == '-')
194 picres.rt |= XDECR;
195 picres.xr = atoi(argv[++i]);
196 break;
197 case 'y': /* y resolution */
198 case 'Y': /* y resolution */
199 resolution = 0;
200 if (argv[i][0] == '-')
201 picres.rt |= YDECR;
202 if (picres.xr == 0)
203 picres.rt |= YMAJOR;
204 picres.yr = atoi(argv[++i]);
205 break;
206 default:
207 unkopt:
208 fprintf(stderr, "%s: unknown option: %s\n",
209 progname, argv[i]);
210 quit(1);
211 break;
212 }
213 else
214 break;
215 /* recognize special formats */
216 if (dataonly && format == 'b')
217 if (putprim == ALL)
218 fmtid = "24-bit_rgb";
219 else
220 fmtid = "8-bit_grey";
221 if (dataonly && format == 'w')
222 if (putprim == ALL)
223 fmtid = "48-bit_rgb";
224 else
225 fmtid = "16-bit_grey";
226 /* assign reverse ordering */
227 rord[ord[0]] = 0;
228 rord[ord[1]] = 1;
229 rord[ord[2]] = 2;
230 /* get input */
231 if (i == argc) {
232 fin = stdin;
233 } else if (i < argc) {
234 if ((fin = fopen(argv[i], "r")) == NULL) {
235 fprintf(stderr, "%s: can't open file \"%s\"\n",
236 progname, argv[i]);
237 quit(1);
238 }
239 if (reverse && putprim != BRIGHT && i == argc-3) {
240 if ((fin2 = fopen(argv[i+1], "r")) == NULL) {
241 fprintf(stderr, "%s: can't open file \"%s\"\n",
242 progname, argv[i+1]);
243 quit(1);
244 }
245 if ((fin3 = fopen(argv[i+2], "r")) == NULL) {
246 fprintf(stderr, "%s: can't open file \"%s\"\n",
247 progname, argv[i+2]);
248 quit(1);
249 }
250 interleave = -1;
251 } else if (i != argc-1)
252 fin = NULL;
253 if (reverse && putprim != BRIGHT && !interleave) {
254 fin2 = fopen(argv[i], "r");
255 fin3 = fopen(argv[i], "r");
256 }
257 if (skipbytes && (fseek(fin, skipbytes, 0) || (fin2 != NULL &&
258 (fseek(fin2, skipbytes, 0) ||
259 fseek(fin3, skipbytes, 0))))) {
260 fprintf(stderr, "%s: cannot skip %ld bytes on input\n",
261 progname, skipbytes);
262 quit(1);
263 }
264 }
265 if (fin == NULL) {
266 fprintf(stderr, "%s: bad # file arguments\n", progname);
267 quit(1);
268 }
269
270 if (reverse) {
271 #ifdef _WIN32
272 SET_FILE_BINARY(stdout);
273 if (format != 'a' && format != 'i')
274 SET_FILE_BINARY(fin);
275 #endif
276 /* get header */
277 if (header) {
278 if (checkheader(fin, fmtid, stdout) < 0) {
279 fprintf(stderr, "%s: wrong input format\n",
280 progname);
281 quit(1);
282 }
283 if (fin2 != NULL) {
284 getheader(fin2, NULL, NULL);
285 getheader(fin3, NULL, NULL);
286 }
287 } else
288 newheader("RADIANCE", stdout);
289 /* get resolution */
290 if ((resolution && !fgetsresolu(&picres, fin)) ||
291 picres.xr <= 0 || picres.yr <= 0) {
292 fprintf(stderr, "%s: missing resolution\n", progname);
293 quit(1);
294 }
295 if (resolution && fin2 != NULL) {
296 RESOLU pres2;
297 if (!fgetsresolu(&pres2, fin2) ||
298 pres2.rt != picres.rt ||
299 pres2.xr != picres.xr ||
300 pres2.yr != picres.yr ||
301 !fgetsresolu(&pres2, fin3) ||
302 pres2.rt != picres.rt ||
303 pres2.xr != picres.xr ||
304 pres2.yr != picres.yr) {
305 fprintf(stderr, "%s: resolution mismatch\n",
306 progname);
307 quit(1);
308 }
309 }
310 /* add to header */
311 printargs(i, argv, stdout);
312 if (expval < .99 || expval > 1.01)
313 fputexpos(expval, stdout);
314 fputformat(COLRFMT, stdout);
315 putchar('\n');
316 fputsresolu(&picres, stdout); /* always put resolution */
317 valtopix();
318 } else {
319 #ifdef _WIN32
320 SET_FILE_BINARY(fin);
321 if (format != 'a' && format != 'i')
322 SET_FILE_BINARY(stdout);
323 #endif
324 /* get header */
325 getheader(fin, checkhead, NULL);
326 if (wrongformat) {
327 fprintf(stderr,
328 "%s: input not a Radiance RGBE picture\n",
329 progname);
330 quit(1);
331 }
332 if (!fgetsresolu(&picres, fin)) {
333 fprintf(stderr, "%s: missing resolution\n", progname);
334 quit(1);
335 }
336 if (header) {
337 printargs(i, argv, stdout);
338 if (expval < .99 || expval > 1.01)
339 fputexpos(expval, stdout);
340 fputformat(fmtid, stdout);
341 putchar('\n');
342 }
343 if (resolution) /* put resolution */
344 fputsresolu(&picres, stdout);
345 pixtoval();
346 }
347
348 quit(0);
349 }
350
351
352 int
353 checkhead(line) /* deal with line from header */
354 char *line;
355 {
356 char fmt[32];
357 double d;
358 COLOR ctmp;
359
360 if (formatval(fmt, line)) {
361 if (!strcmp(fmt, CIEFMT)) {
362 mybright = &xyz_bright;
363 if (original) {
364 scalecolor(exposure, 1./WHTEFFICACY);
365 doexposure++;
366 }
367 } else if (!strcmp(fmt, COLRFMT))
368 mybright = &rgb_bright;
369 else
370 wrongformat++;
371 } else if (original && isexpos(line)) {
372 d = 1.0/exposval(line);
373 scalecolor(exposure, d);
374 doexposure++;
375 } else if (original && iscolcor(line)) {
376 colcorval(ctmp, line);
377 setcolor(exposure, colval(exposure,RED)/colval(ctmp,RED),
378 colval(exposure,GRN)/colval(ctmp,GRN),
379 colval(exposure,BLU)/colval(ctmp,BLU));
380 doexposure++;
381 } else if (header)
382 fputs(line, stdout);
383 return(0);
384 }
385
386
387 pixtoval() /* convert picture to values */
388 {
389 register COLOR *scanln;
390 int dogamma;
391 COLOR lastc;
392 RREAL hv[2];
393 int startprim, endprim;
394 long startpos;
395 int y;
396 register int x;
397
398 scanln = (COLOR *)malloc(scanlen(&picres)*sizeof(COLOR));
399 if (scanln == NULL) {
400 fprintf(stderr, "%s: out of memory\n", progname);
401 quit(1);
402 }
403 dogamma = gamcor < .95 || gamcor > 1.05;
404 if (putprim == ALL && !interleave) {
405 startprim = RED; endprim = BLU;
406 startpos = ftell(fin);
407 } else {
408 startprim = putprim; endprim = putprim;
409 }
410 for (putprim = startprim; putprim <= endprim; putprim++) {
411 if (putprim != startprim && fseek(fin, startpos, 0)) {
412 fprintf(stderr, "%s: seek error on input file\n",
413 progname);
414 quit(1);
415 }
416 set_io();
417 setcolor(lastc, 0.0, 0.0, 0.0);
418 for (y = 0; y < numscans(&picres); y++) {
419 if (freadscan(scanln, scanlen(&picres), fin) < 0) {
420 fprintf(stderr, "%s: read error\n", progname);
421 quit(1);
422 }
423 for (x = 0; x < scanlen(&picres); x++) {
424 if (uniq)
425 if ( colval(scanln[x],RED) ==
426 colval(lastc,RED) &&
427 colval(scanln[x],GRN) ==
428 colval(lastc,GRN) &&
429 colval(scanln[x],BLU) ==
430 colval(lastc,BLU) )
431 continue;
432 else
433 copycolor(lastc, scanln[x]);
434 if (doexposure)
435 multcolor(scanln[x], exposure);
436 if (dogamma)
437 setcolor(scanln[x],
438 pow(colval(scanln[x],RED), 1.0/gamcor),
439 pow(colval(scanln[x],GRN), 1.0/gamcor),
440 pow(colval(scanln[x],BLU), 1.0/gamcor));
441 if (!dataonly) {
442 pix2loc(hv, &picres, x, y);
443 printf("%7d %7d ",
444 (int)(hv[0]*picres.xr),
445 (int)(hv[1]*picres.yr));
446 }
447 if ((*putval)(scanln[x]) < 0) {
448 fprintf(stderr, "%s: write error\n",
449 progname);
450 quit(1);
451 }
452 }
453 }
454 }
455 free((void *)scanln);
456 }
457
458
459 valtopix() /* convert values to a pixel file */
460 {
461 int dogamma;
462 register COLOR *scanln;
463 int y;
464 register int x;
465
466 scanln = (COLOR *)malloc(scanlen(&picres)*sizeof(COLOR));
467 if (scanln == NULL) {
468 fprintf(stderr, "%s: out of memory\n", progname);
469 quit(1);
470 }
471 dogamma = gamcor < .95 || gamcor > 1.05;
472 set_io();
473 for (y = 0; y < numscans(&picres); y++) {
474 for (x = 0; x < scanlen(&picres); x++) {
475 if (!dataonly) {
476 fscanf(fin, "%*d %*d");
477 if (fin2 != NULL) {
478 fscanf(fin2, "%*d %*d");
479 fscanf(fin3, "%*d %*d");
480 }
481 }
482 if ((*getval)(scanln[x]) < 0) {
483 fprintf(stderr, "%s: read error\n", progname);
484 quit(1);
485 }
486 if (dogamma)
487 setcolor(scanln[x],
488 pow(colval(scanln[x],RED), gamcor),
489 pow(colval(scanln[x],GRN), gamcor),
490 pow(colval(scanln[x],BLU), gamcor));
491 if (doexposure)
492 multcolor(scanln[x], exposure);
493 }
494 if (fwritescan(scanln, scanlen(&picres), stdout) < 0) {
495 fprintf(stderr, "%s: write error\n", progname);
496 quit(1);
497 }
498 }
499 free((void *)scanln);
500 }
501
502
503 void
504 quit(code)
505 int code;
506 {
507 exit(code);
508 }
509
510
511 swap16(wp, n) /* swap n 16-bit words */
512 register uint16 *wp;
513 int n;
514 {
515 while (n-- > 0) {
516 *wp = *wp << 8 | ((*wp >> 8) & 0xff);
517 wp++;
518 }
519 }
520
521 getcascii(col) /* get an ascii color value from stream(s) */
522 COLOR col;
523 {
524 double vd[3];
525
526 if (fin2 == NULL) {
527 if (fscanf(fin, "%lf %lf %lf", &vd[0], &vd[1], &vd[2]) != 3)
528 return(-1);
529 } else {
530 if (fscanf(fin, "%lf", &vd[0]) != 1 ||
531 fscanf(fin2, "%lf", &vd[1]) != 1 ||
532 fscanf(fin3, "%lf", &vd[2]) != 1)
533 return(-1);
534 }
535 setcolor(col, vd[rord[RED]], vd[rord[GRN]], vd[rord[BLU]]);
536 return(0);
537 }
538
539
540 getcdouble(col) /* get a double color value from stream(s) */
541 COLOR col;
542 {
543 double vd[3];
544
545 if (fin2 == NULL) {
546 if (fread((char *)vd, sizeof(double), 3, fin) != 3)
547 return(-1);
548 } else {
549 if (fread((char *)vd, sizeof(double), 1, fin) != 1 ||
550 fread((char *)(vd+1), sizeof(double), 1, fin2) != 1 ||
551 fread((char *)(vd+2), sizeof(double), 1, fin3) != 1)
552 return(-1);
553 }
554 setcolor(col, vd[rord[RED]], vd[rord[GRN]], vd[rord[BLU]]);
555 return(0);
556 }
557
558
559 getcfloat(col) /* get a float color value from stream(s) */
560 COLOR col;
561 {
562 float vf[3];
563
564 if (fin2 == NULL) {
565 if (fread((char *)vf, sizeof(float), 3, fin) != 3)
566 return(-1);
567 } else {
568 if (fread((char *)vf, sizeof(float), 1, fin) != 1 ||
569 fread((char *)(vf+1), sizeof(float), 1, fin2) != 1 ||
570 fread((char *)(vf+2), sizeof(float), 1, fin3) != 1)
571 return(-1);
572 }
573 setcolor(col, vf[rord[RED]], vf[rord[GRN]], vf[rord[BLU]]);
574 return(0);
575 }
576
577
578 getcint(col) /* get an int color value from stream(s) */
579 COLOR col;
580 {
581 int vi[3];
582
583 if (fin2 == NULL) {
584 if (fscanf(fin, "%d %d %d", &vi[0], &vi[1], &vi[2]) != 3)
585 return(-1);
586 } else {
587 if (fscanf(fin, "%d", &vi[0]) != 1 ||
588 fscanf(fin2, "%d", &vi[1]) != 1 ||
589 fscanf(fin3, "%d", &vi[2]) != 1)
590 return(-1);
591 }
592 setcolor(col, (vi[rord[RED]]+.5)/256.,
593 (vi[rord[GRN]]+.5)/256., (vi[rord[BLU]]+.5)/256.);
594 return(0);
595 }
596
597
598 getcbyte(col) /* get a byte color value from stream(s) */
599 COLOR col;
600 {
601 BYTE vb[3];
602
603 if (fin2 == NULL) {
604 if (fread((char *)vb, sizeof(BYTE), 3, fin) != 3)
605 return(-1);
606 } else {
607 if (fread((char *)vb, sizeof(BYTE), 1, fin) != 1 ||
608 fread((char *)(vb+1), sizeof(BYTE), 1, fin2) != 1 ||
609 fread((char *)(vb+2), sizeof(BYTE), 1, fin3) != 1)
610 return(-1);
611 }
612 setcolor(col, (vb[rord[RED]]+.5)/256.,
613 (vb[rord[GRN]]+.5)/256., (vb[rord[BLU]]+.5)/256.);
614 return(0);
615 }
616
617
618 getcword(col) /* get a 16-bit color value from stream(s) */
619 COLOR col;
620 {
621 uint16 vw[3];
622
623 if (fin2 == NULL) {
624 if (fread((char *)vw, sizeof(uint16), 3, fin) != 3)
625 return(-1);
626 } else {
627 if (fread((char *)vw, sizeof(uint16), 1, fin) != 1 ||
628 fread((char *)(vw+1), sizeof(uint16), 1, fin2) != 1 ||
629 fread((char *)(vw+2), sizeof(uint16), 1, fin3) != 1)
630 return(-1);
631 }
632 if (swapbytes)
633 swap16(vw, 3);
634 setcolor(col, (vw[rord[RED]]+.5)/65536.,
635 (vw[rord[GRN]]+.5)/65536., (vw[rord[BLU]]+.5)/65536.);
636 return(0);
637 }
638
639
640 getbascii(col) /* get an ascii brightness value from fin */
641 COLOR col;
642 {
643 double vd;
644
645 if (fscanf(fin, "%lf", &vd) != 1)
646 return(-1);
647 setcolor(col, vd, vd, vd);
648 return(0);
649 }
650
651
652 getbdouble(col) /* get a double brightness value from fin */
653 COLOR col;
654 {
655 double vd;
656
657 if (fread((char *)&vd, sizeof(double), 1, fin) != 1)
658 return(-1);
659 setcolor(col, vd, vd, vd);
660 return(0);
661 }
662
663
664 getbfloat(col) /* get a float brightness value from fin */
665 COLOR col;
666 {
667 float vf;
668
669 if (fread((char *)&vf, sizeof(float), 1, fin) != 1)
670 return(-1);
671 setcolor(col, vf, vf, vf);
672 return(0);
673 }
674
675
676 getbint(col) /* get an int brightness value from fin */
677 COLOR col;
678 {
679 int vi;
680 double d;
681
682 if (fscanf(fin, "%d", &vi) != 1)
683 return(-1);
684 d = (vi+.5)/256.;
685 setcolor(col, d, d, d);
686 return(0);
687 }
688
689
690 getbbyte(col) /* get a byte brightness value from fin */
691 COLOR col;
692 {
693 BYTE vb;
694 double d;
695
696 if (fread((char *)&vb, sizeof(BYTE), 1, fin) != 1)
697 return(-1);
698 d = (vb+.5)/256.;
699 setcolor(col, d, d, d);
700 return(0);
701 }
702
703
704 getbword(col) /* get a 16-bit brightness value from fin */
705 COLOR col;
706 {
707 uint16 vw;
708 double d;
709
710 if (fread((char *)&vw, sizeof(uint16), 1, fin) != 1)
711 return(-1);
712 if (swapbytes)
713 swap16(&vw, 1);
714 d = (vw+.5)/65536.;
715 setcolor(col, d, d, d);
716 return(0);
717 }
718
719
720 putcascii(col) /* put an ascii color to stdout */
721 COLOR col;
722 {
723 fprintf(stdout, "%15.3e %15.3e %15.3e\n",
724 colval(col,ord[0]),
725 colval(col,ord[1]),
726 colval(col,ord[2]));
727
728 return(ferror(stdout) ? -1 : 0);
729 }
730
731
732 putcfloat(col) /* put a float color to stdout */
733 COLOR col;
734 {
735 float vf[3];
736
737 vf[0] = colval(col,ord[0]);
738 vf[1] = colval(col,ord[1]);
739 vf[2] = colval(col,ord[2]);
740 fwrite((char *)vf, sizeof(float), 3, stdout);
741
742 return(ferror(stdout) ? -1 : 0);
743 }
744
745
746 putcdouble(col) /* put a double color to stdout */
747 COLOR col;
748 {
749 double vd[3];
750
751 vd[0] = colval(col,ord[0]);
752 vd[1] = colval(col,ord[1]);
753 vd[2] = colval(col,ord[2]);
754 fwrite((char *)vd, sizeof(double), 3, stdout);
755
756 return(ferror(stdout) ? -1 : 0);
757 }
758
759
760 putcint(col) /* put an int color to stdout */
761 COLOR col;
762 {
763 fprintf(stdout, "%d %d %d\n",
764 (int)(colval(col,ord[0])*256.),
765 (int)(colval(col,ord[1])*256.),
766 (int)(colval(col,ord[2])*256.));
767
768 return(ferror(stdout) ? -1 : 0);
769 }
770
771
772 putcbyte(col) /* put a byte color to stdout */
773 COLOR col;
774 {
775 long i;
776 BYTE vb[3];
777
778 i = colval(col,ord[0])*256.;
779 vb[0] = min(i,255);
780 i = colval(col,ord[1])*256.;
781 vb[1] = min(i,255);
782 i = colval(col,ord[2])*256.;
783 vb[2] = min(i,255);
784 fwrite((char *)vb, sizeof(BYTE), 3, stdout);
785
786 return(ferror(stdout) ? -1 : 0);
787 }
788
789
790 putcword(col) /* put a 16-bit color to stdout */
791 COLOR col;
792 {
793 long i;
794 uint16 vw[3];
795
796 i = colval(col,ord[0])*65536.;
797 vw[0] = min(i,65535);
798 i = colval(col,ord[1])*65536.;
799 vw[1] = min(i,65535);
800 i = colval(col,ord[2])*65536.;
801 vw[2] = min(i,65535);
802 if (swapbytes)
803 swap16(vw, 3);
804 fwrite((char *)vw, sizeof(uint16), 3, stdout);
805
806 return(ferror(stdout) ? -1 : 0);
807 }
808
809
810 putbascii(col) /* put an ascii brightness to stdout */
811 COLOR col;
812 {
813 fprintf(stdout, "%15.3e\n", (*mybright)(col));
814
815 return(ferror(stdout) ? -1 : 0);
816 }
817
818
819 putbfloat(col) /* put a float brightness to stdout */
820 COLOR col;
821 {
822 float vf;
823
824 vf = (*mybright)(col);
825 fwrite((char *)&vf, sizeof(float), 1, stdout);
826
827 return(ferror(stdout) ? -1 : 0);
828 }
829
830
831 putbdouble(col) /* put a double brightness to stdout */
832 COLOR col;
833 {
834 double vd;
835
836 vd = (*mybright)(col);
837 fwrite((char *)&vd, sizeof(double), 1, stdout);
838
839 return(ferror(stdout) ? -1 : 0);
840 }
841
842
843 putbint(col) /* put an int brightness to stdout */
844 COLOR col;
845 {
846 fprintf(stdout, "%d\n", (int)((*mybright)(col)*256.));
847
848 return(ferror(stdout) ? -1 : 0);
849 }
850
851
852 putbbyte(col) /* put a byte brightness to stdout */
853 COLOR col;
854 {
855 register int i;
856 BYTE vb;
857
858 i = (*mybright)(col)*256.;
859 vb = min(i,255);
860 fwrite((char *)&vb, sizeof(BYTE), 1, stdout);
861
862 return(ferror(stdout) ? -1 : 0);
863 }
864
865
866 putbword(col) /* put a 16-bit brightness to stdout */
867 COLOR col;
868 {
869 long i;
870 uint16 vw;
871
872 i = (*mybright)(col)*65536.;
873 vw = min(i,65535);
874 if (swapbytes)
875 swap16(&vw, 1);
876 fwrite((char *)&vw, sizeof(uint16), 1, stdout);
877
878 return(ferror(stdout) ? -1 : 0);
879 }
880
881
882 putpascii(col) /* put an ascii primary to stdout */
883 COLOR col;
884 {
885 fprintf(stdout, "%15.3e\n", colval(col,putprim));
886
887 return(ferror(stdout) ? -1 : 0);
888 }
889
890
891 putpfloat(col) /* put a float primary to stdout */
892 COLOR col;
893 {
894 float vf;
895
896 vf = colval(col,putprim);
897 fwrite((char *)&vf, sizeof(float), 1, stdout);
898
899 return(ferror(stdout) ? -1 : 0);
900 }
901
902
903 putpdouble(col) /* put a double primary to stdout */
904 COLOR col;
905 {
906 double vd;
907
908 vd = colval(col,putprim);
909 fwrite((char *)&vd, sizeof(double), 1, stdout);
910
911 return(ferror(stdout) ? -1 : 0);
912 }
913
914
915 putpint(col) /* put an int primary to stdout */
916 COLOR col;
917 {
918 fprintf(stdout, "%d\n", (int)(colval(col,putprim)*256.));
919
920 return(ferror(stdout) ? -1 : 0);
921 }
922
923
924 putpbyte(col) /* put a byte primary to stdout */
925 COLOR col;
926 {
927 long i;
928 BYTE vb;
929
930 i = colval(col,putprim)*256.;
931 vb = min(i,255);
932 fwrite((char *)&vb, sizeof(BYTE), 1, stdout);
933
934 return(ferror(stdout) ? -1 : 0);
935 }
936
937
938 putpword(col) /* put a 16-bit primary to stdout */
939 COLOR col;
940 {
941 long i;
942 uint16 vw;
943
944 i = colval(col,putprim)*65536.;
945 vw = min(i,65535);
946 if (swapbytes)
947 swap16(&vw, 1);
948 fwrite((char *)&vw, sizeof(uint16), 1, stdout);
949
950 return(ferror(stdout) ? -1 : 0);
951 }
952
953
954 set_io() /* set put and get functions */
955 {
956 switch (format) {
957 case 'a': /* ascii */
958 if (putprim == BRIGHT) {
959 getval = getbascii;
960 putval = putbascii;
961 } else if (putprim != ALL) {
962 getval = getbascii;
963 putval = putpascii;
964 } else {
965 getval = getcascii;
966 putval = putcascii;
967 if (reverse && !interleave) {
968 fprintf(stderr,
969 "%s: ASCII input files must be interleaved\n",
970 progname);
971 quit(1);
972 }
973 }
974 return;
975 case 'f': /* binary float */
976 if (putprim == BRIGHT) {
977 getval = getbfloat;
978 putval = putbfloat;
979 } else if (putprim != ALL) {
980 getval = getbfloat;
981 putval = putpfloat;
982 } else {
983 getval = getcfloat;
984 putval = putcfloat;
985 if (reverse && !interleave) {
986 if (fin2 == NULL)
987 goto namerr;
988 if (fseek(fin2,
989 (long)sizeof(float)*picres.xr*picres.yr, 1))
990 goto seekerr;
991 if (fseek(fin3,
992 (long)sizeof(float)*2*picres.xr*picres.yr, 1))
993 goto seekerr;
994 }
995 }
996 return;
997 case 'd': /* binary double */
998 if (putprim == BRIGHT) {
999 getval = getbdouble;
1000 putval = putbdouble;
1001 } else if (putprim != ALL) {
1002 getval = getbdouble;
1003 putval = putpdouble;
1004 } else {
1005 getval = getcdouble;
1006 putval = putcdouble;
1007 if (reverse && !interleave) {
1008 if (fin2 == NULL)
1009 goto namerr;
1010 if (fseek(fin2,
1011 (long)sizeof(double)*picres.xr*picres.yr, 1))
1012 goto seekerr;
1013 if (fseek(fin3,
1014 (long)sizeof(double)*2*picres.xr*picres.yr, 1))
1015 goto seekerr;
1016 }
1017 }
1018 return;
1019 case 'i': /* integer */
1020 if (putprim == BRIGHT) {
1021 getval = getbint;
1022 putval = putbint;
1023 } else if (putprim != ALL) {
1024 getval = getbint;
1025 putval = putpint;
1026 } else {
1027 getval = getcint;
1028 putval = putcint;
1029 if (reverse && !interleave) {
1030 fprintf(stderr,
1031 "%s: integer input files must be interleaved\n",
1032 progname);
1033 quit(1);
1034 }
1035 }
1036 return;
1037 case 'b': /* byte */
1038 if (putprim == BRIGHT) {
1039 getval = getbbyte;
1040 putval = putbbyte;
1041 } else if (putprim != ALL) {
1042 getval = getbbyte;
1043 putval = putpbyte;
1044 } else {
1045 getval = getcbyte;
1046 putval = putcbyte;
1047 if (reverse && !interleave) {
1048 if (fin2 == NULL)
1049 goto namerr;
1050 if (fseek(fin2,
1051 (long)sizeof(BYTE)*picres.xr*picres.yr, 1))
1052 goto seekerr;
1053 if (fseek(fin3,
1054 (long)sizeof(BYTE)*2*picres.xr*picres.yr, 1))
1055 goto seekerr;
1056 }
1057 }
1058 return;
1059 case 'w': /* 16-bit */
1060 if (putprim == BRIGHT) {
1061 getval = getbword;
1062 putval = putbword;
1063 } else if (putprim != ALL) {
1064 getval = getbword;
1065 putval = putpword;
1066 } else {
1067 getval = getcword;
1068 putval = putcword;
1069 if (reverse && !interleave) {
1070 if (fin2 == NULL)
1071 goto namerr;
1072 if (fseek(fin2,
1073 (long)sizeof(uint16)*picres.xr*picres.yr, 1))
1074 goto seekerr;
1075 if (fseek(fin3,
1076 (long)sizeof(uint16)*2*picres.xr*picres.yr, 1))
1077 goto seekerr;
1078 }
1079 }
1080 return;
1081 }
1082 badopt:
1083 fprintf(stderr, "%s: botched file type\n", progname);
1084 quit(1);
1085 namerr:
1086 fprintf(stderr, "%s: non-interleaved file(s) must be named\n",
1087 progname);
1088 quit(1);
1089 seekerr:
1090 fprintf(stderr, "%s: cannot seek on interleaved input file\n",
1091 progname);
1092 quit(1);
1093 }
