root/radiance/ray/src/px/pvalue.c
Revision: 2.18
Committed: Thu Jun 5 19:29:34 2003 UTC (20 years, 10 months ago) by schorsch
Changes since 2.17: +9 -11 lines
2 static const char RCSid[] = "$Id: pvalue.c,v 2.17 2003/02/27 02:00:12 greg Exp $";
5 * pvalue.c - program to print pixel values.
6 *
7 * 4/23/86
8 */
9
10 #include <time.h>
11
12 #include "standard.h"
13 #include "color.h"
14 #include "resolu.h"
15
16 typedef unsigned short uint16; /* sizeof (uint16) must == 2 */
17
18 #define min(a,b) ((a)<(b)?(a):(b))
19
20 /* what to put out (also RED, GRN, BLU) */
21 #define ALL 3
22 #define BRIGHT 4
23
24 RESOLU picres; /* resolution of picture */
25
26 int uniq = 0; /* print only unique values? */
27
28 int doexposure = 0; /* exposure change? (>100 to print) */
29
30 int dataonly = 0; /* data only format? */
31
32 int putprim = ALL; /* what to put out */
33
34 int reverse = 0; /* reverse conversion? */
35
36 int format = 'a'; /* input/output format */
37 char *fmtid = "ascii"; /* format identifier for header */
38
39 int header = 1; /* do header? */
40
41 long skipbytes = 0; /* skip bytes in input? */
42
43 int swapbytes = 0; /* swap bytes in 16-bit words? */
44
45 int interleave = 1; /* file is interleaved? */
46
47 int resolution = 1; /* put/get resolution string? */
48
49 int original = 0; /* convert to original values? */
50
51 int wrongformat = 0; /* wrong input format? */
52
53 double gamcor = 1.0; /* gamma correction */
54
55 int ord[3] = {RED, GRN, BLU}; /* RGB ordering */
56 int rord[4]; /* reverse ordering */
57
58 COLOR exposure = WHTCOLOR;
59
60 char *progname;
61
62 FILE *fin;
63 FILE *fin2 = NULL, *fin3 = NULL; /* for other color channels */
64
65 int (*getval)(), (*putval)();
66
67 double
68 rgb_bright(clr)
69 COLOR clr;
70 {
71 return(bright(clr));
72 }
73
74 double
75 xyz_bright(clr)
76 COLOR clr;
77 {
78 return(clr[CIEY]);
79 }
80
81 double (*mybright)() = &rgb_bright;
82
83
84 main(argc, argv)
85 int argc;
86 char **argv;
87 {
88 extern int checkhead();
89 extern long atol();
90 double d, expval = 1.0;
91 int i;
92
93 progname = argv[0];
94
95 for (i = 1; i < argc; i++)
96 if (argv[i][0] == '-' || argv[i][0] == '+')
97 switch (argv[i][1]) {
98 case 'h': /* header */
99 header = argv[i][0] == '+';
100 break;
101 case 'H': /* resolution string */
102 resolution = argv[i][0] == '+';
103 break;
104 case 's': /* skip bytes in header */
105 skipbytes = atol(argv[++i]);
106 break;
107 case 'u': /* unique values */
108 uniq = argv[i][0] == '-';
109 break;
110 case 'o': /* original values */
111 original = argv[i][0] == '-';
112 break;
113 case 'g': /* gamma correction */
114 gamcor = atof(argv[i+1]);
115 if (argv[i][0] == '+')
116 gamcor = 1.0/gamcor;
117 i++;
118 break;
119 case 'e': /* exposure correction */
120 d = atof(argv[i+1]);
121 if (argv[i+1][0] == '-' || argv[i+1][0] == '+')
122 d = pow(2.0, d);
123 if (argv[i][0] == '-')
124 expval *= d;
125 scalecolor(exposure, d);
126 doexposure++;
127 i++;
128 break;
129 case 'R': /* reverse byte sequence */
130 if (argv[i][0] == '-') {
131 ord[0]=BLU; ord[1]=GRN; ord[2]=RED;
132 } else {
133 ord[0]=RED; ord[1]=GRN; ord[2]=BLU;
134 }
135 break;
136 case 'r': /* reverse conversion */
137 reverse = argv[i][0] == '-';
138 break;
139 case 'n': /* non-interleaved RGB */
140 interleave = argv[i][0] == '+';
141 break;
142 case 'b': /* brightness values */
143 putprim = argv[i][0] == '-' ? BRIGHT : ALL;
144 break;
145 case 'p': /* put primary */
146 switch (argv[i][2]) {
147 case 'r': case 'R': putprim = RED; break;
148 case 'g': case 'G': putprim = GRN; break;
149 case 'b': case 'B': putprim = BLU; break;
150 default: goto unkopt;
151 }
152 break;
153 case 'd': /* data only (no indices) */
154 dataonly = argv[i][0] == '-';
155 switch (argv[i][2]) {
156 case '\0':
157 case 'a': /* ascii */
158 format = 'a';
159 fmtid = "ascii";
160 break;
161 case 'i': /* integer */
162 format = 'i';
163 fmtid = "ascii";
164 break;
165 case 'b': /* byte */
166 dataonly = 1;
167 format = 'b';
168 fmtid = "byte";
169 break;
170 case 'W': /* 16-bit swapped */
171 swapbytes = 1;
172 case 'w': /* 16-bit */
173 dataonly = 1;
174 format = 'w';
175 fmtid = "16-bit";
176 break;
177 case 'f': /* float */
178 dataonly = 1;
179 format = 'f';
180 fmtid = "float";
181 break;
182 case 'd': /* double */
183 dataonly = 1;
184 format = 'd';
185 fmtid = "double";
186 break;
187 default:
188 goto unkopt;
189 }
190 break;
191 case 'x': /* x resolution */
192 case 'X': /* x resolution */
193 resolution = 0;
194 if (argv[i][0] == '-')
195 picres.rt |= XDECR;
196 picres.xr = atoi(argv[++i]);
197 break;
198 case 'y': /* y resolution */
199 case 'Y': /* y resolution */
200 resolution = 0;
201 if (argv[i][0] == '-')
202 picres.rt |= YDECR;
203 if (picres.xr == 0)
204 picres.rt |= YMAJOR;
205 picres.yr = atoi(argv[++i]);
206 break;
207 default:
208 unkopt:
209 fprintf(stderr, "%s: unknown option: %s\n",
210 progname, argv[i]);
211 quit(1);
212 break;
213 }
214 else
215 break;
216 /* recognize special formats */
217 if (dataonly && format == 'b')
218 if (putprim == ALL)
219 fmtid = "24-bit_rgb";
220 else
221 fmtid = "8-bit_grey";
222 if (dataonly && format == 'w')
223 if (putprim == ALL)
224 fmtid = "48-bit_rgb";
225 else
226 fmtid = "16-bit_grey";
227 /* assign reverse ordering */
228 rord[ord[0]] = 0;
229 rord[ord[1]] = 1;
230 rord[ord[2]] = 2;
231 /* get input */
232 if (i == argc) {
233 fin = stdin;
234 } else if (i < argc) {
235 if ((fin = fopen(argv[i], "r")) == NULL) {
236 fprintf(stderr, "%s: can't open file \"%s\"\n",
237 progname, argv[i]);
238 quit(1);
239 }
240 if (reverse && putprim != BRIGHT && i == argc-3) {
241 if ((fin2 = fopen(argv[i+1], "r")) == NULL) {
242 fprintf(stderr, "%s: can't open file \"%s\"\n",
243 progname, argv[i+1]);
244 quit(1);
245 }
246 if ((fin3 = fopen(argv[i+2], "r")) == NULL) {
247 fprintf(stderr, "%s: can't open file \"%s\"\n",
248 progname, argv[i+2]);
249 quit(1);
250 }
251 interleave = -1;
252 } else if (i != argc-1)
253 fin = NULL;
254 if (reverse && putprim != BRIGHT && !interleave) {
255 fin2 = fopen(argv[i], "r");
256 fin3 = fopen(argv[i], "r");
257 }
258 if (skipbytes && (fseek(fin, skipbytes, 0) || (fin2 != NULL &&
259 (fseek(fin2, skipbytes, 0) ||
260 fseek(fin3, skipbytes, 0))))) {
261 fprintf(stderr, "%s: cannot skip %ld bytes on input\n",
262 progname, skipbytes);
263 quit(1);
264 }
265 }
266 if (fin == NULL) {
267 fprintf(stderr, "%s: bad # file arguments\n", progname);
268 quit(1);
269 }
270
271 if (reverse) {
272 #ifdef _WIN32
273 SET_FILE_BINARY(stdout);
274 if (format != 'a' && format != 'i')
275 SET_FILE_BINARY(fin);
276 #endif
277 /* get header */
278 if (header) {
279 if (checkheader(fin, fmtid, stdout) < 0) {
280 fprintf(stderr, "%s: wrong input format\n",
281 progname);
282 quit(1);
283 }
284 if (fin2 != NULL) {
285 getheader(fin2, NULL, NULL);
286 getheader(fin3, NULL, NULL);
287 }
288 } else
289 newheader("RADIANCE", stdout);
290 /* get resolution */
291 if ((resolution && !fgetsresolu(&picres, fin)) ||
292 picres.xr <= 0 || picres.yr <= 0) {
293 fprintf(stderr, "%s: missing resolution\n", progname);
294 quit(1);
295 }
296 if (resolution && fin2 != NULL) {
297 RESOLU pres2;
298 if (!fgetsresolu(&pres2, fin2) ||
299 pres2.rt != picres.rt ||
300 pres2.xr != picres.xr ||
301 pres2.yr != picres.yr ||
302 !fgetsresolu(&pres2, fin3) ||
303 pres2.rt != picres.rt ||
304 pres2.xr != picres.xr ||
305 pres2.yr != picres.yr) {
306 fprintf(stderr, "%s: resolution mismatch\n",
307 progname);
308 quit(1);
309 }
310 }
311 /* add to header */
312 printargs(i, argv, stdout);
313 if (expval < .99 || expval > 1.01)
314 fputexpos(expval, stdout);
315 fputformat(COLRFMT, stdout);
316 putchar('\n');
317 fputsresolu(&picres, stdout); /* always put resolution */
318 valtopix();
319 } else {
320 #ifdef _WIN32
321 SET_FILE_BINARY(fin);
322 if (format != 'a' && format != 'i')
323 SET_FILE_BINARY(stdout);
324 #endif
325 /* get header */
326 getheader(fin, checkhead, NULL);
327 if (wrongformat) {
328 fprintf(stderr,
329 "%s: input not a Radiance RGBE picture\n",
330 progname);
331 quit(1);
332 }
333 if (!fgetsresolu(&picres, fin)) {
334 fprintf(stderr, "%s: missing resolution\n", progname);
335 quit(1);
336 }
337 if (header) {
338 printargs(i, argv, stdout);
339 if (expval < .99 || expval > 1.01)
340 fputexpos(expval, stdout);
341 fputformat(fmtid, stdout);
342 putchar('\n');
343 }
344 if (resolution) /* put resolution */
345 fputsresolu(&picres, stdout);
346 pixtoval();
347 }
348
349 quit(0);
350 }
351
352
353 int
354 checkhead(line) /* deal with line from header */
355 char *line;
356 {
357 char fmt[32];
358 double d;
359 COLOR ctmp;
360
361 if (formatval(fmt, line)) {
362 if (!strcmp(fmt, CIEFMT)) {
363 mybright = &xyz_bright;
364 if (original) {
365 scalecolor(exposure, 1./WHTEFFICACY);
366 doexposure++;
367 }
368 } else if (!strcmp(fmt, COLRFMT))
369 mybright = &rgb_bright;
370 else
371 wrongformat++;
372 } else if (original && isexpos(line)) {
373 d = 1.0/exposval(line);
374 scalecolor(exposure, d);
375 doexposure++;
376 } else if (original && iscolcor(line)) {
377 colcorval(ctmp, line);
378 setcolor(exposure, colval(exposure,RED)/colval(ctmp,RED),
379 colval(exposure,GRN)/colval(ctmp,GRN),
380 colval(exposure,BLU)/colval(ctmp,BLU));
381 doexposure++;
382 } else if (header)
383 fputs(line, stdout);
384 return(0);
385 }
386
387
388 pixtoval() /* convert picture to values */
389 {
390 register COLOR *scanln;
391 int dogamma;
392 COLOR lastc;
393 FLOAT hv[2];
394 int startprim, endprim;
395 long startpos;
396 int y;
397 register int x;
398
399 scanln = (COLOR *)malloc(scanlen(&picres)*sizeof(COLOR));
400 if (scanln == NULL) {
401 fprintf(stderr, "%s: out of memory\n", progname);
402 quit(1);
403 }
404 dogamma = gamcor < .95 || gamcor > 1.05;
405 if (putprim == ALL && !interleave) {
406 startprim = RED; endprim = BLU;
407 startpos = ftell(fin);
408 } else {
409 startprim = putprim; endprim = putprim;
410 }
411 for (putprim = startprim; putprim <= endprim; putprim++) {
412 if (putprim != startprim && fseek(fin, startpos, 0)) {
413 fprintf(stderr, "%s: seek error on input file\n",
414 progname);
415 quit(1);
416 }
417 set_io();
418 setcolor(lastc, 0.0, 0.0, 0.0);
419 for (y = 0; y < numscans(&picres); y++) {
420 if (freadscan(scanln, scanlen(&picres), fin) < 0) {
421 fprintf(stderr, "%s: read error\n", progname);
422 quit(1);
423 }
424 for (x = 0; x < scanlen(&picres); x++) {
425 if (uniq)
426 if ( colval(scanln[x],RED) ==
427 colval(lastc,RED) &&
428 colval(scanln[x],GRN) ==
429 colval(lastc,GRN) &&
430 colval(scanln[x],BLU) ==
431 colval(lastc,BLU) )
432 continue;
433 else
434 copycolor(lastc, scanln[x]);
435 if (doexposure)
436 multcolor(scanln[x], exposure);
437 if (dogamma)
438 setcolor(scanln[x],
439 pow(colval(scanln[x],RED), 1.0/gamcor),
440 pow(colval(scanln[x],GRN), 1.0/gamcor),
441 pow(colval(scanln[x],BLU), 1.0/gamcor));
442 if (!dataonly) {
443 pix2loc(hv, &picres, x, y);
444 printf("%7d %7d ",
445 (int)(hv[0]*picres.xr),
446 (int)(hv[1]*picres.yr));
447 }
448 if ((*putval)(scanln[x]) < 0) {
449 fprintf(stderr, "%s: write error\n",
450 progname);
451 quit(1);
452 }
453 }
454 }
455 }
456 free((void *)scanln);
457 }
458
459
460 valtopix() /* convert values to a pixel file */
461 {
462 int dogamma;
463 register COLOR *scanln;
464 int y;
465 register int x;
466
467 scanln = (COLOR *)malloc(scanlen(&picres)*sizeof(COLOR));
468 if (scanln == NULL) {
469 fprintf(stderr, "%s: out of memory\n", progname);
470 quit(1);
471 }
472 dogamma = gamcor < .95 || gamcor > 1.05;
473 set_io();
474 for (y = 0; y < numscans(&picres); y++) {
475 for (x = 0; x < scanlen(&picres); x++) {
476 if (!dataonly) {
477 fscanf(fin, "%*d %*d");
478 if (fin2 != NULL) {
479 fscanf(fin2, "%*d %*d");
480 fscanf(fin3, "%*d %*d");
481 }
482 }
483 if ((*getval)(scanln[x]) < 0) {
484 fprintf(stderr, "%s: read error\n", progname);
485 quit(1);
486 }
487 if (dogamma)
488 setcolor(scanln[x],
489 pow(colval(scanln[x],RED), gamcor),
490 pow(colval(scanln[x],GRN), gamcor),
491 pow(colval(scanln[x],BLU), gamcor));
492 if (doexposure)
493 multcolor(scanln[x], exposure);
494 }
495 if (fwritescan(scanln, scanlen(&picres), stdout) < 0) {
496 fprintf(stderr, "%s: write error\n", progname);
497 quit(1);
498 }
499 }
500 free((void *)scanln);
501 }
502
503
504 void
505 quit(code)
506 int code;
507 {
508 exit(code);
509 }
510
511
512 swap16(wp, n) /* swap n 16-bit words */
513 register uint16 *wp;
514 int n;
515 {
516 while (n-- > 0) {
517 *wp = *wp << 8 | ((*wp >> 8) & 0xff);
518 wp++;
519 }
520 }
521
522 getcascii(col) /* get an ascii color value from stream(s) */
523 COLOR col;
524 {
525 double vd[3];
526
527 if (fin2 == NULL) {
528 if (fscanf(fin, "%lf %lf %lf", &vd[0], &vd[1], &vd[2]) != 3)
529 return(-1);
530 } else {
531 if (fscanf(fin, "%lf", &vd[0]) != 1 ||
532 fscanf(fin2, "%lf", &vd[1]) != 1 ||
533 fscanf(fin3, "%lf", &vd[2]) != 1)
534 return(-1);
535 }
536 setcolor(col, vd[rord[RED]], vd[rord[GRN]], vd[rord[BLU]]);
537 return(0);
538 }
539
540
541 getcdouble(col) /* get a double color value from stream(s) */
542 COLOR col;
543 {
544 double vd[3];
545
546 if (fin2 == NULL) {
547 if (fread((char *)vd, sizeof(double), 3, fin) != 3)
548 return(-1);
549 } else {
550 if (fread((char *)vd, sizeof(double), 1, fin) != 1 ||
551 fread((char *)(vd+1), sizeof(double), 1, fin2) != 1 ||
552 fread((char *)(vd+2), sizeof(double), 1, fin3) != 1)
553 return(-1);
554 }
555 setcolor(col, vd[rord[RED]], vd[rord[GRN]], vd[rord[BLU]]);
556 return(0);
557 }
558
559
560 getcfloat(col) /* get a float color value from stream(s) */
561 COLOR col;
562 {
563 float vf[3];
564
565 if (fin2 == NULL) {
566 if (fread((char *)vf, sizeof(float), 3, fin) != 3)
567 return(-1);
568 } else {
569 if (fread((char *)vf, sizeof(float), 1, fin) != 1 ||
570 fread((char *)(vf+1), sizeof(float), 1, fin2) != 1 ||
571 fread((char *)(vf+2), sizeof(float), 1, fin3) != 1)
572 return(-1);
573 }
574 setcolor(col, vf[rord[RED]], vf[rord[GRN]], vf[rord[BLU]]);
575 return(0);
576 }
577
578
579 getcint(col) /* get an int color value from stream(s) */
580 COLOR col;
581 {
582 int vi[3];
583
584 if (fin2 == NULL) {
585 if (fscanf(fin, "%d %d %d", &vi[0], &vi[1], &vi[2]) != 3)
586 return(-1);
587 } else {
588 if (fscanf(fin, "%d", &vi[0]) != 1 ||
589 fscanf(fin2, "%d", &vi[1]) != 1 ||
590 fscanf(fin3, "%d", &vi[2]) != 1)
591 return(-1);
592 }
593 setcolor(col, (vi[rord[RED]]+.5)/256.,
594 (vi[rord[GRN]]+.5)/256., (vi[rord[BLU]]+.5)/256.);
595 return(0);
596 }
597
598
599 getcbyte(col) /* get a byte color value from stream(s) */
600 COLOR col;
601 {
602 BYTE vb[3];
603
604 if (fin2 == NULL) {
605 if (fread((char *)vb, sizeof(BYTE), 3, fin) != 3)
606 return(-1);
607 } else {
608 if (fread((char *)vb, sizeof(BYTE), 1, fin) != 1 ||
609 fread((char *)(vb+1), sizeof(BYTE), 1, fin2) != 1 ||
610 fread((char *)(vb+2), sizeof(BYTE), 1, fin3) != 1)
611 return(-1);
612 }
613 setcolor(col, (vb[rord[RED]]+.5)/256.,
614 (vb[rord[GRN]]+.5)/256., (vb[rord[BLU]]+.5)/256.);
615 return(0);
616 }
617
618
619 getcword(col) /* get a 16-bit color value from stream(s) */
620 COLOR col;
621 {
622 uint16 vw[3];
623
624 if (fin2 == NULL) {
625 if (fread((char *)vw, sizeof(uint16), 3, fin) != 3)
626 return(-1);
627 } else {
628 if (fread((char *)vw, sizeof(uint16), 1, fin) != 1 ||
629 fread((char *)(vw+1), sizeof(uint16), 1, fin2) != 1 ||
630 fread((char *)(vw+2), sizeof(uint16), 1, fin3) != 1)
631 return(-1);
632 }
633 if (swapbytes)
634 swap16(vw, 3);
635 setcolor(col, (vw[rord[RED]]+.5)/65536.,
636 (vw[rord[GRN]]+.5)/65536., (vw[rord[BLU]]+.5)/65536.);
637 return(0);
638 }
639
640
641 getbascii(col) /* get an ascii brightness value from fin */
642 COLOR col;
643 {
644 double vd;
645
646 if (fscanf(fin, "%lf", &vd) != 1)
647 return(-1);
648 setcolor(col, vd, vd, vd);
649 return(0);
650 }
651
652
653 getbdouble(col) /* get a double brightness value from fin */
654 COLOR col;
655 {
656 double vd;
657
658 if (fread((char *)&vd, sizeof(double), 1, fin) != 1)
659 return(-1);
660 setcolor(col, vd, vd, vd);
661 return(0);
662 }
663
664
665 getbfloat(col) /* get a float brightness value from fin */
666 COLOR col;
667 {
668 float vf;
669
670 if (fread((char *)&vf, sizeof(float), 1, fin) != 1)
671 return(-1);
672 setcolor(col, vf, vf, vf);
673 return(0);
674 }
675
676
677 getbint(col) /* get an int brightness value from fin */
678 COLOR col;
679 {
680 int vi;
681 double d;
682
683 if (fscanf(fin, "%d", &vi) != 1)
684 return(-1);
685 d = (vi+.5)/256.;
686 setcolor(col, d, d, d);
687 return(0);
688 }
689
690
691 getbbyte(col) /* get a byte brightness value from fin */
692 COLOR col;
693 {
694 BYTE vb;
695 double d;
696
697 if (fread((char *)&vb, sizeof(BYTE), 1, fin) != 1)
698 return(-1);
699 d = (vb+.5)/256.;
700 setcolor(col, d, d, d);
701 return(0);
702 }
703
704
705 getbword(col) /* get a 16-bit brightness value from fin */
706 COLOR col;
707 {
708 uint16 vw;
709 double d;
710
711 if (fread((char *)&vw, sizeof(uint16), 1, fin) != 1)
712 return(-1);
713 if (swapbytes)
714 swap16(&vw, 1);
715 d = (vw+.5)/65536.;
716 setcolor(col, d, d, d);
717 return(0);
718 }
719
720
721 putcascii(col) /* put an ascii color to stdout */
722 COLOR col;
723 {
724 fprintf(stdout, "%15.3e %15.3e %15.3e\n",
725 colval(col,ord[0]),
726 colval(col,ord[1]),
727 colval(col,ord[2]));
728
729 return(ferror(stdout) ? -1 : 0);
730 }
731
732
733 putcfloat(col) /* put a float color to stdout */
734 COLOR col;
735 {
736 float vf[3];
737
738 vf[0] = colval(col,ord[0]);
739 vf[1] = colval(col,ord[1]);
740 vf[2] = colval(col,ord[2]);
741 fwrite((char *)vf, sizeof(float), 3, stdout);
742
743 return(ferror(stdout) ? -1 : 0);
744 }
745
746
747 putcdouble(col) /* put a double color to stdout */
748 COLOR col;
749 {
750 double vd[3];
751
752 vd[0] = colval(col,ord[0]);
753 vd[1] = colval(col,ord[1]);
754 vd[2] = colval(col,ord[2]);
755 fwrite((char *)vd, sizeof(double), 3, stdout);
756
757 return(ferror(stdout) ? -1 : 0);
758 }
759
760
761 putcint(col) /* put an int color to stdout */
762 COLOR col;
763 {
764 fprintf(stdout, "%d %d %d\n",
765 (int)(colval(col,ord[0])*256.),
766 (int)(colval(col,ord[1])*256.),
767 (int)(colval(col,ord[2])*256.));
768
769 return(ferror(stdout) ? -1 : 0);
770 }
771
772
773 putcbyte(col) /* put a byte color to stdout */
774 COLOR col;
775 {
776 long i;
777 BYTE vb[3];
778
779 i = colval(col,ord[0])*256.;
780 vb[0] = min(i,255);
781 i = colval(col,ord[1])*256.;
782 vb[1] = min(i,255);
783 i = colval(col,ord[2])*256.;
784 vb[2] = min(i,255);
785 fwrite((char *)vb, sizeof(BYTE), 3, stdout);
786
787 return(ferror(stdout) ? -1 : 0);
788 }
789
790
791 putcword(col) /* put a 16-bit color to stdout */
792 COLOR col;
793 {
794 long i;
795 uint16 vw[3];
796
797 i = colval(col,ord[0])*65536.;
798 vw[0] = min(i,65535);
799 i = colval(col,ord[1])*65536.;
800 vw[1] = min(i,65535);
801 i = colval(col,ord[2])*65536.;
802 vw[2] = min(i,65535);
803 if (swapbytes)
804 swap16(vw, 3);
805 fwrite((char *)vw, sizeof(uint16), 3, stdout);
806
807 return(ferror(stdout) ? -1 : 0);
808 }
809
810
811 putbascii(col) /* put an ascii brightness to stdout */
812 COLOR col;
813 {
814 fprintf(stdout, "%15.3e\n", (*mybright)(col));
815
816 return(ferror(stdout) ? -1 : 0);
817 }
818
819
820 putbfloat(col) /* put a float brightness to stdout */
821 COLOR col;
822 {
823 float vf;
824
825 vf = (*mybright)(col);
826 fwrite((char *)&vf, sizeof(float), 1, stdout);
827
828 return(ferror(stdout) ? -1 : 0);
829 }
830
831
832 putbdouble(col) /* put a double brightness to stdout */
833 COLOR col;
834 {
835 double vd;
836
837 vd = (*mybright)(col);
838 fwrite((char *)&vd, sizeof(double), 1, stdout);
839
840 return(ferror(stdout) ? -1 : 0);
841 }
842
843
844 putbint(col) /* put an int brightness to stdout */
845 COLOR col;
846 {
847 fprintf(stdout, "%d\n", (int)((*mybright)(col)*256.));
848
849 return(ferror(stdout) ? -1 : 0);
850 }
851
852
853 putbbyte(col) /* put a byte brightness to stdout */
854 COLOR col;
855 {
856 register int i;
857 BYTE vb;
858
859 i = (*mybright)(col)*256.;
860 vb = min(i,255);
861 fwrite((char *)&vb, sizeof(BYTE), 1, stdout);
862
863 return(ferror(stdout) ? -1 : 0);
864 }
865
866
867 putbword(col) /* put a 16-bit brightness to stdout */
868 COLOR col;
869 {
870 long i;
871 uint16 vw;
872
873 i = (*mybright)(col)*65536.;
874 vw = min(i,65535);
875 if (swapbytes)
876 swap16(&vw, 1);
877 fwrite((char *)&vw, sizeof(uint16), 1, stdout);
878
879 return(ferror(stdout) ? -1 : 0);
880 }
881
882
883 putpascii(col) /* put an ascii primary to stdout */
884 COLOR col;
885 {
886 fprintf(stdout, "%15.3e\n", colval(col,putprim));
887
888 return(ferror(stdout) ? -1 : 0);
889 }
890
891
892 putpfloat(col) /* put a float primary to stdout */
893 COLOR col;
894 {
895 float vf;
896
897 vf = colval(col,putprim);
898 fwrite((char *)&vf, sizeof(float), 1, stdout);
899
900 return(ferror(stdout) ? -1 : 0);
901 }
902
903
904 putpdouble(col) /* put a double primary to stdout */
905 COLOR col;
906 {
907 double vd;
908
909 vd = colval(col,putprim);
910 fwrite((char *)&vd, sizeof(double), 1, stdout);
911
912 return(ferror(stdout) ? -1 : 0);
913 }
914
915
916 putpint(col) /* put an int primary to stdout */
917 COLOR col;
918 {
919 fprintf(stdout, "%d\n", (int)(colval(col,putprim)*256.));
920
921 return(ferror(stdout) ? -1 : 0);
922 }
923
924
925 putpbyte(col) /* put a byte primary to stdout */
926 COLOR col;
927 {
928 long i;
929 BYTE vb;
930
931 i = colval(col,putprim)*256.;
932 vb = min(i,255);
933 fwrite((char *)&vb, sizeof(BYTE), 1, stdout);
934
935 return(ferror(stdout) ? -1 : 0);
936 }
937
938
939 putpword(col) /* put a 16-bit primary to stdout */
940 COLOR col;
941 {
942 long i;
943 uint16 vw;
944
945 i = colval(col,putprim)*65536.;
946 vw = min(i,65535);
947 if (swapbytes)
948 swap16(&vw, 1);
949 fwrite((char *)&vw, sizeof(uint16), 1, stdout);
950
951 return(ferror(stdout) ? -1 : 0);
952 }
953
954
955 set_io() /* set put and get functions */
956 {
957 switch (format) {
958 case 'a': /* ascii */
959 if (putprim == BRIGHT) {
960 getval = getbascii;
961 putval = putbascii;
962 } else if (putprim != ALL) {
963 getval = getbascii;
964 putval = putpascii;
965 } else {
966 getval = getcascii;
967 putval = putcascii;
968 if (reverse && !interleave) {
969 fprintf(stderr,
970 "%s: ASCII input files must be interleaved\n",
971 progname);
972 quit(1);
973 }
974 }
975 return;
976 case 'f': /* binary float */
977 if (putprim == BRIGHT) {
978 getval = getbfloat;
979 putval = putbfloat;
980 } else if (putprim != ALL) {
981 getval = getbfloat;
982 putval = putpfloat;
983 } else {
984 getval = getcfloat;
985 putval = putcfloat;
986 if (reverse && !interleave) {
987 if (fin2 == NULL)
988 goto namerr;
989 if (fseek(fin2,
990 (long)sizeof(float)*picres.xr*picres.yr, 1))
991 goto seekerr;
992 if (fseek(fin3,
993 (long)sizeof(float)*2*picres.xr*picres.yr, 1))
994 goto seekerr;
995 }
996 }
997 return;
998 case 'd': /* binary double */
999 if (putprim == BRIGHT) {
1000 getval = getbdouble;
1001 putval = putbdouble;
1002 } else if (putprim != ALL) {
1003 getval = getbdouble;
1004 putval = putpdouble;
1005 } else {
1006 getval = getcdouble;
1007 putval = putcdouble;
1008 if (reverse && !interleave) {
1009 if (fin2 == NULL)
1010 goto namerr;
1011 if (fseek(fin2,
1012 (long)sizeof(double)*picres.xr*picres.yr, 1))
1013 goto seekerr;
1014 if (fseek(fin3,
1015 (long)sizeof(double)*2*picres.xr*picres.yr, 1))
1016 goto seekerr;
1017 }
1018 }
1019 return;
1020 case 'i': /* integer */
1021 if (putprim == BRIGHT) {
1022 getval = getbint;
1023 putval = putbint;
1024 } else if (putprim != ALL) {
1025 getval = getbint;
1026 putval = putpint;
1027 } else {
1028 getval = getcint;
1029 putval = putcint;
1030 if (reverse && !interleave) {
1031 fprintf(stderr,
1032 "%s: integer input files must be interleaved\n",
1033 progname);
1034 quit(1);
1035 }
1036 }
1037 return;
1038 case 'b': /* byte */
1039 if (putprim == BRIGHT) {
1040 getval = getbbyte;
1041 putval = putbbyte;
1042 } else if (putprim != ALL) {
1043 getval = getbbyte;
1044 putval = putpbyte;
1045 } else {
1046 getval = getcbyte;
1047 putval = putcbyte;
1048 if (reverse && !interleave) {
1049 if (fin2 == NULL)
1050 goto namerr;
1051 if (fseek(fin2,
1052 (long)sizeof(BYTE)*picres.xr*picres.yr, 1))
1053 goto seekerr;
1054 if (fseek(fin3,
1055 (long)sizeof(BYTE)*2*picres.xr*picres.yr, 1))
1056 goto seekerr;
1057 }
1058 }
1059 return;
1060 case 'w': /* 16-bit */
1061 if (putprim == BRIGHT) {
1062 getval = getbword;
1063 putval = putbword;
1064 } else if (putprim != ALL) {
1065 getval = getbword;
1066 putval = putpword;
1067 } else {
1068 getval = getcword;
1069 putval = putcword;
1070 if (reverse && !interleave) {
1071 if (fin2 == NULL)
1072 goto namerr;
1073 if (fseek(fin2,
1074 (long)sizeof(uint16)*picres.xr*picres.yr, 1))
1075 goto seekerr;
1076 if (fseek(fin3,
1077 (long)sizeof(uint16)*2*picres.xr*picres.yr, 1))
1078 goto seekerr;
1079 }
1080 }
1081 return;
1082 }
1083 badopt:
1084 fprintf(stderr, "%s: botched file type\n", progname);
1085 quit(1);
1086 namerr:
1087 fprintf(stderr, "%s: non-interleaved file(s) must be named\n",
1088 progname);
1089 quit(1);
1090 seekerr:
1091 fprintf(stderr, "%s: cannot seek on interleaved input file\n",
1092 progname);
1093 quit(1);
1094 }
