root/radiance/ray/src/px/pvalue.c
Revision: 2.17
Committed: Thu Feb 27 02:00:12 2003 UTC (21 years, 2 months ago) by greg
Changes since 2.16: +8 -10 lines
Corrected format string for -pP option
5 * pvalue.c - program to print pixel values.
6 *
7 * 4/23/86
8 */
9
10 #include "standard.h"
11
12 #include "color.h"
13
14 #include <time.h>
15
16 #include "resolu.h"
17
18 typedef unsigned short uint16; /* sizeof (uint16) must == 2 */
19
20 #define min(a,b) ((a)<(b)?(a):(b))
21
22 /* what to put out (also RED, GRN, BLU) */
23 #define ALL 3
24 #define BRIGHT 4
25
26 RESOLU picres; /* resolution of picture */
27
28 int uniq = 0; /* print only unique values? */
29
30 int doexposure = 0; /* exposure change? (>100 to print) */
31
32 int dataonly = 0; /* data only format? */
33
34 int putprim = ALL; /* what to put out */
35
36 int reverse = 0; /* reverse conversion? */
37
38 int format = 'a'; /* input/output format */
39 char *fmtid = "ascii"; /* format identifier for header */
40
41 int header = 1; /* do header? */
42
43 long skipbytes = 0; /* skip bytes in input? */
44
45 int swapbytes = 0; /* swap bytes in 16-bit words? */
46
47 int interleave = 1; /* file is interleaved? */
48
49 int resolution = 1; /* put/get resolution string? */
50
51 int original = 0; /* convert to original values? */
52
53 int wrongformat = 0; /* wrong input format? */
54
55 double gamcor = 1.0; /* gamma correction */
56
57 int ord[3] = {RED, GRN, BLU}; /* RGB ordering */
58 int rord[4]; /* reverse ordering */
59
60 COLOR exposure = WHTCOLOR;
61
62 char *progname;
63
64 FILE *fin;
65 FILE *fin2 = NULL, *fin3 = NULL; /* for other color channels */
66
67 int (*getval)(), (*putval)();
68
69 double
70 rgb_bright(clr)
71 COLOR clr;
72 {
73 return(bright(clr));
74 }
75
76 double
77 xyz_bright(clr)
78 COLOR clr;
79 {
80 return(clr[CIEY]);
81 }
82
83 double (*mybright)() = &rgb_bright;
84
85
86 main(argc, argv)
87 int argc;
88 char **argv;
89 {
90 extern int checkhead();
91 extern long atol();
92 double d, expval = 1.0;
93 int i;
94
95 progname = argv[0];
96
97 for (i = 1; i < argc; i++)
98 if (argv[i][0] == '-' || argv[i][0] == '+')
99 switch (argv[i][1]) {
100 case 'h': /* header */
101 header = argv[i][0] == '+';
102 break;
103 case 'H': /* resolution string */
104 resolution = argv[i][0] == '+';
105 break;
106 case 's': /* skip bytes in header */
107 skipbytes = atol(argv[++i]);
108 break;
109 case 'u': /* unique values */
110 uniq = argv[i][0] == '-';
111 break;
112 case 'o': /* original values */
113 original = argv[i][0] == '-';
114 break;
115 case 'g': /* gamma correction */
116 gamcor = atof(argv[i+1]);
117 if (argv[i][0] == '+')
118 gamcor = 1.0/gamcor;
119 i++;
120 break;
121 case 'e': /* exposure correction */
122 d = atof(argv[i+1]);
123 if (argv[i+1][0] == '-' || argv[i+1][0] == '+')
124 d = pow(2.0, d);
125 if (argv[i][0] == '-')
126 expval *= d;
127 scalecolor(exposure, d);
128 doexposure++;
129 i++;
130 break;
131 case 'R': /* reverse byte sequence */
132 if (argv[i][0] == '-') {
133 ord[0]=BLU; ord[1]=GRN; ord[2]=RED;
134 } else {
135 ord[0]=RED; ord[1]=GRN; ord[2]=BLU;
136 }
137 break;
138 case 'r': /* reverse conversion */
139 reverse = argv[i][0] == '-';
140 break;
141 case 'n': /* non-interleaved RGB */
142 interleave = argv[i][0] == '+';
143 break;
144 case 'b': /* brightness values */
145 putprim = argv[i][0] == '-' ? BRIGHT : ALL;
146 break;
147 case 'p': /* put primary */
148 switch (argv[i][2]) {
149 case 'r': case 'R': putprim = RED; break;
150 case 'g': case 'G': putprim = GRN; break;
151 case 'b': case 'B': putprim = BLU; break;
152 default: goto unkopt;
153 }
154 break;
155 case 'd': /* data only (no indices) */
156 dataonly = argv[i][0] == '-';
157 switch (argv[i][2]) {
158 case '\0':
159 case 'a': /* ascii */
160 format = 'a';
161 fmtid = "ascii";
162 break;
163 case 'i': /* integer */
164 format = 'i';
165 fmtid = "ascii";
166 break;
167 case 'b': /* byte */
168 dataonly = 1;
169 format = 'b';
170 fmtid = "byte";
171 break;
172 case 'W': /* 16-bit swapped */
173 swapbytes = 1;
174 case 'w': /* 16-bit */
175 dataonly = 1;
176 format = 'w';
177 fmtid = "16-bit";
178 break;
179 case 'f': /* float */
180 dataonly = 1;
181 format = 'f';
182 fmtid = "float";
183 break;
184 case 'd': /* double */
185 dataonly = 1;
186 format = 'd';
187 fmtid = "double";
188 break;
189 default:
190 goto unkopt;
191 }
192 break;
193 case 'x': /* x resolution */
194 case 'X': /* x resolution */
195 resolution = 0;
196 if (argv[i][0] == '-')
197 picres.rt |= XDECR;
198 picres.xr = atoi(argv[++i]);
199 break;
200 case 'y': /* y resolution */
201 case 'Y': /* y resolution */
202 resolution = 0;
203 if (argv[i][0] == '-')
204 picres.rt |= YDECR;
205 if (picres.xr == 0)
206 picres.rt |= YMAJOR;
207 picres.yr = atoi(argv[++i]);
208 break;
209 default:
210 unkopt:
211 fprintf(stderr, "%s: unknown option: %s\n",
212 progname, argv[i]);
213 quit(1);
214 break;
215 }
216 else
217 break;
218 /* recognize special formats */
219 if (dataonly && format == 'b')
220 if (putprim == ALL)
221 fmtid = "24-bit_rgb";
222 else
223 fmtid = "8-bit_grey";
224 if (dataonly && format == 'w')
225 if (putprim == ALL)
226 fmtid = "48-bit_rgb";
227 else
228 fmtid = "16-bit_grey";
229 /* assign reverse ordering */
230 rord[ord[0]] = 0;
231 rord[ord[1]] = 1;
232 rord[ord[2]] = 2;
233 /* get input */
234 if (i == argc) {
235 fin = stdin;
236 } else if (i < argc) {
237 if ((fin = fopen(argv[i], "r")) == NULL) {
238 fprintf(stderr, "%s: can't open file \"%s\"\n",
239 progname, argv[i]);
240 quit(1);
241 }
242 if (reverse && putprim != BRIGHT && i == argc-3) {
243 if ((fin2 = fopen(argv[i+1], "r")) == NULL) {
244 fprintf(stderr, "%s: can't open file \"%s\"\n",
245 progname, argv[i+1]);
246 quit(1);
247 }
248 if ((fin3 = fopen(argv[i+2], "r")) == NULL) {
249 fprintf(stderr, "%s: can't open file \"%s\"\n",
250 progname, argv[i+2]);
251 quit(1);
252 }
253 interleave = -1;
254 } else if (i != argc-1)
255 fin = NULL;
256 if (reverse && putprim != BRIGHT && !interleave) {
257 fin2 = fopen(argv[i], "r");
258 fin3 = fopen(argv[i], "r");
259 }
260 if (skipbytes && (fseek(fin, skipbytes, 0) || (fin2 != NULL &&
261 (fseek(fin2, skipbytes, 0) ||
262 fseek(fin3, skipbytes, 0))))) {
263 fprintf(stderr, "%s: cannot skip %ld bytes on input\n",
264 progname, skipbytes);
265 quit(1);
266 }
267 }
268 if (fin == NULL) {
269 fprintf(stderr, "%s: bad # file arguments\n", progname);
270 quit(1);
271 }
272
273 if (reverse) {
274 #ifdef MSDOS
275 setmode(fileno(stdout), O_BINARY);
276 if (format != 'a' && format != 'i')
277 setmode(fileno(fin), O_BINARY);
278 #endif
279 /* get header */
280 if (header) {
281 if (checkheader(fin, fmtid, stdout) < 0) {
282 fprintf(stderr, "%s: wrong input format\n",
283 progname);
284 quit(1);
285 }
286 if (fin2 != NULL) {
287 getheader(fin2, NULL, NULL);
288 getheader(fin3, NULL, NULL);
289 }
290 } else
291 newheader("RADIANCE", stdout);
292 /* get resolution */
293 if ((resolution && !fgetsresolu(&picres, fin)) ||
294 picres.xr <= 0 || picres.yr <= 0) {
295 fprintf(stderr, "%s: missing resolution\n", progname);
296 quit(1);
297 }
298 if (resolution && fin2 != NULL) {
299 RESOLU pres2;
300 if (!fgetsresolu(&pres2, fin2) ||
301 pres2.rt != picres.rt ||
302 pres2.xr != picres.xr ||
303 pres2.yr != picres.yr ||
304 !fgetsresolu(&pres2, fin3) ||
305 pres2.rt != picres.rt ||
306 pres2.xr != picres.xr ||
307 pres2.yr != picres.yr) {
308 fprintf(stderr, "%s: resolution mismatch\n",
309 progname);
310 quit(1);
311 }
312 }
313 /* add to header */
314 printargs(i, argv, stdout);
315 if (expval < .99 || expval > 1.01)
316 fputexpos(expval, stdout);
317 fputformat(COLRFMT, stdout);
318 putchar('\n');
319 fputsresolu(&picres, stdout); /* always put resolution */
320 valtopix();
321 } else {
322 #ifdef MSDOS
323 setmode(fileno(fin), O_BINARY);
324 if (format != 'a' && format != 'i')
325 setmode(fileno(stdout), O_BINARY);
326 #endif
327 /* get header */
328 getheader(fin, checkhead, NULL);
329 if (wrongformat) {
330 fprintf(stderr,
331 "%s: input not a Radiance RGBE picture\n",
332 progname);
333 quit(1);
334 }
335 if (!fgetsresolu(&picres, fin)) {
336 fprintf(stderr, "%s: missing resolution\n", progname);
337 quit(1);
338 }
339 if (header) {
340 printargs(i, argv, stdout);
341 if (expval < .99 || expval > 1.01)
342 fputexpos(expval, stdout);
343 fputformat(fmtid, stdout);
344 putchar('\n');
345 }
346 if (resolution) /* put resolution */
347 fputsresolu(&picres, stdout);
348 pixtoval();
349 }
350
351 quit(0);
352 }
353
354
355 int
356 checkhead(line) /* deal with line from header */
357 char *line;
358 {
359 char fmt[32];
360 double d;
361 COLOR ctmp;
362
363 if (formatval(fmt, line)) {
364 if (!strcmp(fmt, CIEFMT)) {
365 mybright = &xyz_bright;
366 if (original) {
367 scalecolor(exposure, 1./WHTEFFICACY);
368 doexposure++;
369 }
370 } else if (!strcmp(fmt, COLRFMT))
371 mybright = &rgb_bright;
372 else
373 wrongformat++;
374 } else if (original && isexpos(line)) {
375 d = 1.0/exposval(line);
376 scalecolor(exposure, d);
377 doexposure++;
378 } else if (original && iscolcor(line)) {
379 colcorval(ctmp, line);
380 setcolor(exposure, colval(exposure,RED)/colval(ctmp,RED),
381 colval(exposure,GRN)/colval(ctmp,GRN),
382 colval(exposure,BLU)/colval(ctmp,BLU));
383 doexposure++;
384 } else if (header)
385 fputs(line, stdout);
386 return(0);
387 }
388
389
390 pixtoval() /* convert picture to values */
391 {
392 register COLOR *scanln;
393 int dogamma;
394 COLOR lastc;
395 FLOAT hv[2];
396 int startprim, endprim;
397 long startpos;
398 int y;
399 register int x;
400
401 scanln = (COLOR *)malloc(scanlen(&picres)*sizeof(COLOR));
402 if (scanln == NULL) {
403 fprintf(stderr, "%s: out of memory\n", progname);
404 quit(1);
405 }
406 dogamma = gamcor < .95 || gamcor > 1.05;
407 if (putprim == ALL && !interleave) {
408 startprim = RED; endprim = BLU;
409 startpos = ftell(fin);
410 } else {
411 startprim = putprim; endprim = putprim;
412 }
413 for (putprim = startprim; putprim <= endprim; putprim++) {
414 if (putprim != startprim && fseek(fin, startpos, 0)) {
415 fprintf(stderr, "%s: seek error on input file\n",
416 progname);
417 quit(1);
418 }
419 set_io();
420 setcolor(lastc, 0.0, 0.0, 0.0);
421 for (y = 0; y < numscans(&picres); y++) {
422 if (freadscan(scanln, scanlen(&picres), fin) < 0) {
423 fprintf(stderr, "%s: read error\n", progname);
424 quit(1);
425 }
426 for (x = 0; x < scanlen(&picres); x++) {
427 if (uniq)
428 if ( colval(scanln[x],RED) ==
429 colval(lastc,RED) &&
430 colval(scanln[x],GRN) ==
431 colval(lastc,GRN) &&
432 colval(scanln[x],BLU) ==
433 colval(lastc,BLU) )
434 continue;
435 else
436 copycolor(lastc, scanln[x]);
437 if (doexposure)
438 multcolor(scanln[x], exposure);
439 if (dogamma)
440 setcolor(scanln[x],
441 pow(colval(scanln[x],RED), 1.0/gamcor),
442 pow(colval(scanln[x],GRN), 1.0/gamcor),
443 pow(colval(scanln[x],BLU), 1.0/gamcor));
444 if (!dataonly) {
445 pix2loc(hv, &picres, x, y);
446 printf("%7d %7d ",
447 (int)(hv[0]*picres.xr),
448 (int)(hv[1]*picres.yr));
449 }
450 if ((*putval)(scanln[x]) < 0) {
451 fprintf(stderr, "%s: write error\n",
452 progname);
453 quit(1);
454 }
455 }
456 }
457 }
458 free((void *)scanln);
459 }
460
461
462 valtopix() /* convert values to a pixel file */
463 {
464 int dogamma;
465 register COLOR *scanln;
466 int y;
467 register int x;
468
469 scanln = (COLOR *)malloc(scanlen(&picres)*sizeof(COLOR));
470 if (scanln == NULL) {
471 fprintf(stderr, "%s: out of memory\n", progname);
472 quit(1);
473 }
474 dogamma = gamcor < .95 || gamcor > 1.05;
475 set_io();
476 for (y = 0; y < numscans(&picres); y++) {
477 for (x = 0; x < scanlen(&picres); x++) {
478 if (!dataonly) {
479 fscanf(fin, "%*d %*d");
480 if (fin2 != NULL) {
481 fscanf(fin2, "%*d %*d");
482 fscanf(fin3, "%*d %*d");
483 }
484 }
485 if ((*getval)(scanln[x]) < 0) {
486 fprintf(stderr, "%s: read error\n", progname);
487 quit(1);
488 }
489 if (dogamma)
490 setcolor(scanln[x],
491 pow(colval(scanln[x],RED), gamcor),
492 pow(colval(scanln[x],GRN), gamcor),
493 pow(colval(scanln[x],BLU), gamcor));
494 if (doexposure)
495 multcolor(scanln[x], exposure);
496 }
497 if (fwritescan(scanln, scanlen(&picres), stdout) < 0) {
498 fprintf(stderr, "%s: write error\n", progname);
499 quit(1);
500 }
501 }
502 free((void *)scanln);
503 }
504
505
506 void
507 quit(code)
508 int code;
509 {
510 exit(code);
511 }
512
513
514 swap16(wp, n) /* swap n 16-bit words */
515 register uint16 *wp;
516 int n;
517 {
518 while (n-- > 0) {
519 *wp = *wp << 8 | ((*wp >> 8) & 0xff);
520 wp++;
521 }
522 }
523
524 getcascii(col) /* get an ascii color value from stream(s) */
525 COLOR col;
526 {
527 double vd[3];
528
529 if (fin2 == NULL) {
530 if (fscanf(fin, "%lf %lf %lf", &vd[0], &vd[1], &vd[2]) != 3)
531 return(-1);
532 } else {
533 if (fscanf(fin, "%lf", &vd[0]) != 1 ||
534 fscanf(fin2, "%lf", &vd[1]) != 1 ||
535 fscanf(fin3, "%lf", &vd[2]) != 1)
536 return(-1);
537 }
538 setcolor(col, vd[rord[RED]], vd[rord[GRN]], vd[rord[BLU]]);
539 return(0);
540 }
541
542
543 getcdouble(col) /* get a double color value from stream(s) */
544 COLOR col;
545 {
546 double vd[3];
547
548 if (fin2 == NULL) {
549 if (fread((char *)vd, sizeof(double), 3, fin) != 3)
550 return(-1);
551 } else {
552 if (fread((char *)vd, sizeof(double), 1, fin) != 1 ||
553 fread((char *)(vd+1), sizeof(double), 1, fin2) != 1 ||
554 fread((char *)(vd+2), sizeof(double), 1, fin3) != 1)
555 return(-1);
556 }
557 setcolor(col, vd[rord[RED]], vd[rord[GRN]], vd[rord[BLU]]);
558 return(0);
559 }
560
561
562 getcfloat(col) /* get a float color value from stream(s) */
563 COLOR col;
564 {
565 float vf[3];
566
567 if (fin2 == NULL) {
568 if (fread((char *)vf, sizeof(float), 3, fin) != 3)
569 return(-1);
570 } else {
571 if (fread((char *)vf, sizeof(float), 1, fin) != 1 ||
572 fread((char *)(vf+1), sizeof(float), 1, fin2) != 1 ||
573 fread((char *)(vf+2), sizeof(float), 1, fin3) != 1)
574 return(-1);
575 }
576 setcolor(col, vf[rord[RED]], vf[rord[GRN]], vf[rord[BLU]]);
577 return(0);
578 }
579
580
581 getcint(col) /* get an int color value from stream(s) */
582 COLOR col;
583 {
584 int vi[3];
585
586 if (fin2 == NULL) {
587 if (fscanf(fin, "%d %d %d", &vi[0], &vi[1], &vi[2]) != 3)
588 return(-1);
589 } else {
590 if (fscanf(fin, "%d", &vi[0]) != 1 ||
591 fscanf(fin2, "%d", &vi[1]) != 1 ||
592 fscanf(fin3, "%d", &vi[2]) != 1)
593 return(-1);
594 }
595 setcolor(col, (vi[rord[RED]]+.5)/256.,
596 (vi[rord[GRN]]+.5)/256., (vi[rord[BLU]]+.5)/256.);
597 return(0);
598 }
599
600
601 getcbyte(col) /* get a byte color value from stream(s) */
602 COLOR col;
603 {
604 BYTE vb[3];
605
606 if (fin2 == NULL) {
607 if (fread((char *)vb, sizeof(BYTE), 3, fin) != 3)
608 return(-1);
609 } else {
610 if (fread((char *)vb, sizeof(BYTE), 1, fin) != 1 ||
611 fread((char *)(vb+1), sizeof(BYTE), 1, fin2) != 1 ||
612 fread((char *)(vb+2), sizeof(BYTE), 1, fin3) != 1)
613 return(-1);
614 }
615 setcolor(col, (vb[rord[RED]]+.5)/256.,
616 (vb[rord[GRN]]+.5)/256., (vb[rord[BLU]]+.5)/256.);
617 return(0);
618 }
619
620
621 getcword(col) /* get a 16-bit color value from stream(s) */
622 COLOR col;
623 {
624 uint16 vw[3];
625
626 if (fin2 == NULL) {
627 if (fread((char *)vw, sizeof(uint16), 3, fin) != 3)
628 return(-1);
629 } else {
630 if (fread((char *)vw, sizeof(uint16), 1, fin) != 1 ||
631 fread((char *)(vw+1), sizeof(uint16), 1, fin2) != 1 ||
632 fread((char *)(vw+2), sizeof(uint16), 1, fin3) != 1)
633 return(-1);
634 }
635 if (swapbytes)
636 swap16(vw, 3);
637 setcolor(col, (vw[rord[RED]]+.5)/65536.,
638 (vw[rord[GRN]]+.5)/65536., (vw[rord[BLU]]+.5)/65536.);
639 return(0);
640 }
641
642
643 getbascii(col) /* get an ascii brightness value from fin */
644 COLOR col;
645 {
646 double vd;
647
648 if (fscanf(fin, "%lf", &vd) != 1)
649 return(-1);
650 setcolor(col, vd, vd, vd);
651 return(0);
652 }
653
654
655 getbdouble(col) /* get a double brightness value from fin */
656 COLOR col;
657 {
658 double vd;
659
660 if (fread((char *)&vd, sizeof(double), 1, fin) != 1)
661 return(-1);
662 setcolor(col, vd, vd, vd);
663 return(0);
664 }
665
666
667 getbfloat(col) /* get a float brightness value from fin */
668 COLOR col;
669 {
670 float vf;
671
672 if (fread((char *)&vf, sizeof(float), 1, fin) != 1)
673 return(-1);
674 setcolor(col, vf, vf, vf);
675 return(0);
676 }
677
678
679 getbint(col) /* get an int brightness value from fin */
680 COLOR col;
681 {
682 int vi;
683 double d;
684
685 if (fscanf(fin, "%d", &vi) != 1)
686 return(-1);
687 d = (vi+.5)/256.;
688 setcolor(col, d, d, d);
689 return(0);
690 }
691
692
693 getbbyte(col) /* get a byte brightness value from fin */
694 COLOR col;
695 {
696 BYTE vb;
697 double d;
698
699 if (fread((char *)&vb, sizeof(BYTE), 1, fin) != 1)
700 return(-1);
701 d = (vb+.5)/256.;
702 setcolor(col, d, d, d);
703 return(0);
704 }
705
706
707 getbword(col) /* get a 16-bit brightness value from fin */
708 COLOR col;
709 {
710 uint16 vw;
711 double d;
712
713 if (fread((char *)&vw, sizeof(uint16), 1, fin) != 1)
714 return(-1);
715 if (swapbytes)
716 swap16(&vw, 1);
717 d = (vw+.5)/65536.;
718 setcolor(col, d, d, d);
719 return(0);
720 }
721
722
723 putcascii(col) /* put an ascii color to stdout */
724 COLOR col;
725 {
726 fprintf(stdout, "%15.3e %15.3e %15.3e\n",
727 colval(col,ord[0]),
728 colval(col,ord[1]),
729 colval(col,ord[2]));
730
731 return(ferror(stdout) ? -1 : 0);
732 }
733
734
735 putcfloat(col) /* put a float color to stdout */
736 COLOR col;
737 {
738 float vf[3];
739
740 vf[0] = colval(col,ord[0]);
741 vf[1] = colval(col,ord[1]);
742 vf[2] = colval(col,ord[2]);
743 fwrite((char *)vf, sizeof(float), 3, stdout);
744
745 return(ferror(stdout) ? -1 : 0);
746 }
747
748
749 putcdouble(col) /* put a double color to stdout */
750 COLOR col;
751 {
752 double vd[3];
753
754 vd[0] = colval(col,ord[0]);
755 vd[1] = colval(col,ord[1]);
756 vd[2] = colval(col,ord[2]);
757 fwrite((char *)vd, sizeof(double), 3, stdout);
758
759 return(ferror(stdout) ? -1 : 0);
760 }
761
762
763 putcint(col) /* put an int color to stdout */
764 COLOR col;
765 {
766 fprintf(stdout, "%d %d %d\n",
767 (int)(colval(col,ord[0])*256.),
768 (int)(colval(col,ord[1])*256.),
769 (int)(colval(col,ord[2])*256.));
770
771 return(ferror(stdout) ? -1 : 0);
772 }
773
774
775 putcbyte(col) /* put a byte color to stdout */
776 COLOR col;
777 {
778 long i;
779 BYTE vb[3];
780
781 i = colval(col,ord[0])*256.;
782 vb[0] = min(i,255);
783 i = colval(col,ord[1])*256.;
784 vb[1] = min(i,255);
785 i = colval(col,ord[2])*256.;
786 vb[2] = min(i,255);
787 fwrite((char *)vb, sizeof(BYTE), 3, stdout);
788
789 return(ferror(stdout) ? -1 : 0);
790 }
791
792
793 putcword(col) /* put a 16-bit color to stdout */
794 COLOR col;
795 {
796 long i;
797 uint16 vw[3];
798
799 i = colval(col,ord[0])*65536.;
800 vw[0] = min(i,65535);
801 i = colval(col,ord[1])*65536.;
802 vw[1] = min(i,65535);
803 i = colval(col,ord[2])*65536.;
804 vw[2] = min(i,65535);
805 if (swapbytes)
806 swap16(vw, 3);
807 fwrite((char *)vw, sizeof(uint16), 3, stdout);
808
809 return(ferror(stdout) ? -1 : 0);
810 }
811
812
813 putbascii(col) /* put an ascii brightness to stdout */
814 COLOR col;
815 {
816 fprintf(stdout, "%15.3e\n", (*mybright)(col));
817
818 return(ferror(stdout) ? -1 : 0);
819 }
820
821
822 putbfloat(col) /* put a float brightness to stdout */
823 COLOR col;
824 {
825 float vf;
826
827 vf = (*mybright)(col);
828 fwrite((char *)&vf, sizeof(float), 1, stdout);
829
830 return(ferror(stdout) ? -1 : 0);
831 }
832
833
834 putbdouble(col) /* put a double brightness to stdout */
835 COLOR col;
836 {
837 double vd;
838
839 vd = (*mybright)(col);
840 fwrite((char *)&vd, sizeof(double), 1, stdout);
841
842 return(ferror(stdout) ? -1 : 0);
843 }
844
845
846 putbint(col) /* put an int brightness to stdout */
847 COLOR col;
848 {
849 fprintf(stdout, "%d\n", (int)((*mybright)(col)*256.));
850
851 return(ferror(stdout) ? -1 : 0);
852 }
853
854
855 putbbyte(col) /* put a byte brightness to stdout */
856 COLOR col;
857 {
858 register int i;
859 BYTE vb;
860
861 i = (*mybright)(col)*256.;
862 vb = min(i,255);
863 fwrite((char *)&vb, sizeof(BYTE), 1, stdout);
864
865 return(ferror(stdout) ? -1 : 0);
866 }
867
868
869 putbword(col) /* put a 16-bit brightness to stdout */
870 COLOR col;
871 {
872 long i;
873 uint16 vw;
874
875 i = (*mybright)(col)*65536.;
876 vw = min(i,65535);
877 if (swapbytes)
878 swap16(&vw, 1);
879 fwrite((char *)&vw, sizeof(uint16), 1, stdout);
880
881 return(ferror(stdout) ? -1 : 0);
882 }
883
884
885 putpascii(col) /* put an ascii primary to stdout */
886 COLOR col;
887 {
888 fprintf(stdout, "%15.3e\n", colval(col,putprim));
889
890 return(ferror(stdout) ? -1 : 0);
891 }
892
893
894 putpfloat(col) /* put a float primary to stdout */
895 COLOR col;
896 {
897 float vf;
898
899 vf = colval(col,putprim);
900 fwrite((char *)&vf, sizeof(float), 1, stdout);
901
902 return(ferror(stdout) ? -1 : 0);
903 }
904
905
906 putpdouble(col) /* put a double primary to stdout */
907 COLOR col;
908 {
909 double vd;
910
911 vd = colval(col,putprim);
912 fwrite((char *)&vd, sizeof(double), 1, stdout);
913
914 return(ferror(stdout) ? -1 : 0);
915 }
916
917
918 putpint(col) /* put an int primary to stdout */
919 COLOR col;
920 {
921 fprintf(stdout, "%d\n", (int)(colval(col,putprim)*256.));
922
923 return(ferror(stdout) ? -1 : 0);
924 }
925
926
927 putpbyte(col) /* put a byte primary to stdout */
928 COLOR col;
929 {
930 long i;
931 BYTE vb;
932
933 i = colval(col,putprim)*256.;
934 vb = min(i,255);
935 fwrite((char *)&vb, sizeof(BYTE), 1, stdout);
936
937 return(ferror(stdout) ? -1 : 0);
938 }
939
940
941 putpword(col) /* put a 16-bit primary to stdout */
942 COLOR col;
943 {
944 long i;
945 uint16 vw;
946
947 i = colval(col,putprim)*65536.;
948 vw = min(i,65535);
949 if (swapbytes)
950 swap16(&vw, 1);
951 fwrite((char *)&vw, sizeof(uint16), 1, stdout);
952
953 return(ferror(stdout) ? -1 : 0);
954 }
955
956
957 set_io() /* set put and get functions */
958 {
959 switch (format) {
960 case 'a': /* ascii */
961 if (putprim == BRIGHT) {
962 getval = getbascii;
963 putval = putbascii;
964 } else if (putprim != ALL) {
965 getval = getbascii;
966 putval = putpascii;
967 } else {
968 getval = getcascii;
969 putval = putcascii;
970 if (reverse && !interleave) {
971 fprintf(stderr,
972 "%s: ASCII input files must be interleaved\n",
973 progname);
974 quit(1);
975 }
976 }
977 return;
978 case 'f': /* binary float */
979 if (putprim == BRIGHT) {
980 getval = getbfloat;
981 putval = putbfloat;
982 } else if (putprim != ALL) {
983 getval = getbfloat;
984 putval = putpfloat;
985 } else {
986 getval = getcfloat;
987 putval = putcfloat;
988 if (reverse && !interleave) {
989 if (fin2 == NULL)
990 goto namerr;
991 if (fseek(fin2,
992 (long)sizeof(float)*picres.xr*picres.yr, 1))
993 goto seekerr;
994 if (fseek(fin3,
995 (long)sizeof(float)*2*picres.xr*picres.yr, 1))
996 goto seekerr;
997 }
998 }
999 return;
1000 case 'd': /* binary double */
1001 if (putprim == BRIGHT) {
1002 getval = getbdouble;
1003 putval = putbdouble;
1004 } else if (putprim != ALL) {
1005 getval = getbdouble;
1006 putval = putpdouble;
1007 } else {
1008 getval = getcdouble;
1009 putval = putcdouble;
1010 if (reverse && !interleave) {
1011 if (fin2 == NULL)
1012 goto namerr;
1013 if (fseek(fin2,
1014 (long)sizeof(double)*picres.xr*picres.yr, 1))
1015 goto seekerr;
1016 if (fseek(fin3,
1017 (long)sizeof(double)*2*picres.xr*picres.yr, 1))
1018 goto seekerr;
1019 }
1020 }
1021 return;
1022 case 'i': /* integer */
1023 if (putprim == BRIGHT) {
1024 getval = getbint;
1025 putval = putbint;
1026 } else if (putprim != ALL) {
1027 getval = getbint;
1028 putval = putpint;
1029 } else {
1030 getval = getcint;
1031 putval = putcint;
1032 if (reverse && !interleave) {
1033 fprintf(stderr,
1034 "%s: integer input files must be interleaved\n",
1035 progname);
1036 quit(1);
1037 }
1038 }
1039 return;
1040 case 'b': /* byte */
1041 if (putprim == BRIGHT) {
1042 getval = getbbyte;
1043 putval = putbbyte;
1044 } else if (putprim != ALL) {
1045 getval = getbbyte;
1046 putval = putpbyte;
1047 } else {
1048 getval = getcbyte;
1049 putval = putcbyte;
1050 if (reverse && !interleave) {
1051 if (fin2 == NULL)
1052 goto namerr;
1053 if (fseek(fin2,
1054 (long)sizeof(BYTE)*picres.xr*picres.yr, 1))
1055 goto seekerr;
1056 if (fseek(fin3,
1057 (long)sizeof(BYTE)*2*picres.xr*picres.yr, 1))
1058 goto seekerr;
1059 }
1060 }
1061 return;
1062 case 'w': /* 16-bit */
1063 if (putprim == BRIGHT) {
1064 getval = getbword;
1065 putval = putbword;
1066 } else if (putprim != ALL) {
1067 getval = getbword;
1068 putval = putpword;
1069 } else {
1070 getval = getcword;
1071 putval = putcword;
1072 if (reverse && !interleave) {
1073 if (fin2 == NULL)
1074 goto namerr;
1075 if (fseek(fin2,
1076 (long)sizeof(uint16)*picres.xr*picres.yr, 1))
1077 goto seekerr;
1078 if (fseek(fin3,
1079 (long)sizeof(uint16)*2*picres.xr*picres.yr, 1))
1080 goto seekerr;
1081 }
1082 }
1083 return;
1084 }
1085 badopt:
1086 fprintf(stderr, "%s: botched file type\n", progname);
1087 quit(1);
1088 namerr:
1089 fprintf(stderr, "%s: non-interleaved file(s) must be named\n",
1090 progname);
1091 quit(1);
1092 seekerr:
1093 fprintf(stderr, "%s: cannot seek on interleaved input file\n",
1094 progname);
1095 quit(1);
1096 }
