root/radiance/ray/src/px/pvalue.c
Revision: 2.14
Committed: Sat Feb 22 02:07:27 2003 UTC (22 years, 3 months ago) by greg
Changes since 2.13: +46 -20 lines
5 * pvalue.c - program to print pixel values.
6 *
7 * 4/23/86
8 */
9
10 #include "standard.h"
11
12 #include "color.h"
13
14 #include <time.h>
15
16 #include "resolu.h"
17
18 #define min(a,b) ((a)<(b)?(a):(b))
19
20 /* what to put out (also RED, GRN, BLU) */
21 #define ALL 3
22 #define BRIGHT 4
23
24 #define brightonly (putprim==BRIGHT)
25
26 RESOLU picres; /* resolution of picture */
27
28 int uniq = 0; /* print only unique values? */
29
30 int doexposure = 0; /* exposure change? (>100 to print) */
31
32 int dataonly = 0; /* data only format? */
33
34 int putprim = ALL; /* what to put out */
35
36 int reverse = 0; /* reverse conversion? */
37
38 int format = 'a'; /* input/output format */
39 char *fmtid = "ascii"; /* format identifier for header */
40
41 int header = 1; /* do header? */
42
43 long skipbytes = 0; /* skip bytes in input? */
44
45 int interleave = 1; /* file is interleaved? */
46
47 int resolution = 1; /* put/get resolution string? */
48
49 int original = 0; /* convert to original values? */
50
51 int wrongformat = 0; /* wrong input format? */
52
53 double gamcor = 1.0; /* gamma correction */
54
55 int ord[3] = {RED, GRN, BLU}; /* RGB ordering */
56 int rord[4]; /* reverse ordering */
57
58 COLOR exposure = WHTCOLOR;
59
60 char *progname;
61
62 FILE *fin;
63 FILE *fin2 = NULL, *fin3 = NULL; /* for other color channels */
64
65 int (*getval)(), (*putval)();
66
67 double
68 rgb_bright(clr)
69 COLOR clr;
70 {
71 return(bright(clr));
72 }
73
74 double
75 xyz_bright(clr)
76 COLOR clr;
77 {
78 return(clr[CIEY]);
79 }
80
81 double (*mybright)() = &rgb_bright;
82
83
84 main(argc, argv)
85 int argc;
86 char **argv;
87 {
88 extern int checkhead();
89 extern long atol();
90 double d, expval = 1.0;
91 int i;
92
93 progname = argv[0];
94
95 for (i = 1; i < argc; i++)
96 if (argv[i][0] == '-' || argv[i][0] == '+')
97 switch (argv[i][1]) {
98 case 'h': /* header */
99 header = argv[i][0] == '+';
100 break;
101 case 'H': /* resolution string */
102 resolution = argv[i][0] == '+';
103 break;
104 case 's': /* skip bytes in header */
105 skipbytes = atol(argv[++i]);
106 break;
107 case 'u': /* unique values */
108 uniq = argv[i][0] == '-';
109 break;
110 case 'o': /* original values */
111 original = argv[i][0] == '-';
112 break;
113 case 'g': /* gamma correction */
114 gamcor = atof(argv[i+1]);
115 if (argv[i][0] == '+')
116 gamcor = 1.0/gamcor;
117 i++;
118 break;
119 case 'e': /* exposure correction */
120 d = atof(argv[i+1]);
121 if (argv[i+1][0] == '-' || argv[i+1][0] == '+')
122 d = pow(2.0, d);
123 if (argv[i][0] == '-')
124 expval *= d;
125 scalecolor(exposure, d);
126 doexposure++;
127 i++;
128 break;
129 case 'R': /* reverse byte sequence */
130 if (argv[i][0] == '-') {
131 ord[0]=BLU; ord[1]=GRN; ord[2]=RED;
132 } else {
133 ord[0]=RED; ord[1]=GRN; ord[2]=BLU;
134 }
135 break;
136 case 'r': /* reverse conversion */
137 reverse = argv[i][0] == '-';
138 break;
139 case 'n': /* non-interleaved RGB */
140 interleave = argv[i][0] == '+';
141 break;
142 case 'b': /* brightness values */
143 putprim = argv[i][0] == '-' ? BRIGHT : ALL;
144 break;
145 case 'p': /* put primary */
146 switch (argv[i][2]) {
147 case 'r': case 'R': putprim = RED; break;
148 case 'g': case 'G': putprim = GRN; break;
149 case 'b': case 'B': putprim = BLU; break;
150 default: goto unkopt;
151 }
152 break;
153 case 'd': /* data only (no indices) */
154 dataonly = argv[i][0] == '-';
155 switch (argv[i][2]) {
156 case '\0':
157 case 'a': /* ascii */
158 format = 'a';
159 fmtid = "ascii";
160 break;
161 case 'i': /* integer */
162 format = 'i';
163 fmtid = "ascii";
164 break;
165 case 'b': /* byte */
166 dataonly = 1;
167 format = 'b';
168 fmtid = "byte";
169 break;
170 case 'f': /* float */
171 dataonly = 1;
172 format = 'f';
173 fmtid = "float";
174 break;
175 case 'd': /* double */
176 dataonly = 1;
177 format = 'd';
178 fmtid = "double";
179 break;
180 default:
181 goto unkopt;
182 }
183 break;
184 case 'x': /* x resolution */
185 case 'X': /* x resolution */
186 resolution = 0;
187 if (argv[i][0] == '-')
188 picres.rt |= XDECR;
189 picres.xr = atoi(argv[++i]);
190 break;
191 case 'y': /* y resolution */
192 case 'Y': /* y resolution */
193 resolution = 0;
194 if (argv[i][0] == '-')
195 picres.rt |= YDECR;
196 if (picres.xr == 0)
197 picres.rt |= YMAJOR;
198 picres.yr = atoi(argv[++i]);
199 break;
200 default:
201 unkopt:
202 fprintf(stderr, "%s: unknown option: %s\n",
203 progname, argv[i]);
204 quit(1);
205 break;
206 }
207 else
208 break;
209 /* recognize special formats */
210 if (dataonly && format == 'b')
211 if (brightonly)
212 fmtid = "8-bit_grey";
213 else
214 fmtid = "24-bit_rgb";
215 /* assign reverse ordering */
216 rord[ord[0]] = 0;
217 rord[ord[1]] = 1;
218 rord[ord[2]] = 2;
219 /* get input */
220 if (i == argc) {
221 fin = stdin;
222 } else if (i < argc) {
223 if ((fin = fopen(argv[i], "r")) == NULL) {
224 fprintf(stderr, "%s: can't open file \"%s\"\n",
225 progname, argv[i]);
226 quit(1);
227 }
228 if (reverse && !brightonly && i == argc-3) {
229 if ((fin2 = fopen(argv[i+1], "r")) == NULL) {
230 fprintf(stderr, "%s: can't open file \"%s\"\n",
231 progname, argv[i+1]);
232 quit(1);
233 }
234 if ((fin3 = fopen(argv[i+2], "r")) == NULL) {
235 fprintf(stderr, "%s: can't open file \"%s\"\n",
236 progname, argv[i+2]);
237 quit(1);
238 }
239 interleave = -1;
240 } else if (i != argc-1)
241 fin = NULL;
242 if (reverse && !brightonly && !interleave) {
243 fin2 = fopen(argv[i], "r");
244 fin3 = fopen(argv[i], "r");
245 }
246 if (skipbytes && (fseek(fin, skipbytes, 0) || (fin2 != NULL &&
247 (fseek(fin2, skipbytes, 0) ||
248 fseek(fin3, skipbytes, 0))))) {
249 fprintf(stderr, "%s: cannot skip %ld bytes on input\n",
250 progname, skipbytes);
251 quit(1);
252 }
253 }
254 if (fin == NULL) {
255 fprintf(stderr, "%s: bad # file arguments\n", progname);
256 quit(1);
257 }
258
259 if (reverse) {
260 #ifdef MSDOS
261 setmode(fileno(stdout), O_BINARY);
262 if (format != 'a' && format != 'i')
263 setmode(fileno(fin), O_BINARY);
264 #endif
265 /* get header */
266 if (header) {
267 if (checkheader(fin, fmtid, stdout) < 0) {
268 fprintf(stderr, "%s: wrong input format\n",
269 progname);
270 quit(1);
271 }
272 if (fin2 != NULL) {
273 getheader(fin2, NULL, NULL);
274 getheader(fin3, NULL, NULL);
275 }
276 } else
277 newheader("RADIANCE", stdout);
278 /* get resolution */
279 if ((resolution && !fgetsresolu(&picres, fin)) ||
280 picres.xr <= 0 || picres.yr <= 0) {
281 fprintf(stderr, "%s: missing resolution\n", progname);
282 quit(1);
283 }
284 if (resolution && fin2 != NULL) {
285 RESOLU pres2;
286 if (!fgetsresolu(&pres2, fin2) ||
287 pres2.rt != picres.rt ||
288 pres2.xr != picres.xr ||
289 pres2.yr != picres.yr ||
290 !fgetsresolu(&pres2, fin3) ||
291 pres2.rt != picres.rt ||
292 pres2.xr != picres.xr ||
293 pres2.yr != picres.yr) {
294 fprintf(stderr, "%s: resolution mismatch\n",
295 progname);
296 quit(1);
297 }
298 }
299 /* add to header */
300 printargs(i, argv, stdout);
301 if (expval < .99 || expval > 1.01)
302 fputexpos(expval, stdout);
303 fputformat(COLRFMT, stdout);
304 putchar('\n');
305 fputsresolu(&picres, stdout); /* always put resolution */
306 valtopix();
307 } else {
308 #ifdef MSDOS
309 setmode(fileno(fin), O_BINARY);
310 if (format != 'a' && format != 'i')
311 setmode(fileno(stdout), O_BINARY);
312 #endif
313 /* get header */
314 getheader(fin, checkhead, NULL);
315 if (wrongformat) {
316 fprintf(stderr,
317 "%s: input not a Radiance RGBE picture\n",
318 progname);
319 quit(1);
320 }
321 if (!fgetsresolu(&picres, fin)) {
322 fprintf(stderr, "%s: missing resolution\n", progname);
323 quit(1);
324 }
325 if (header) {
326 printargs(i, argv, stdout);
327 if (expval < .99 || expval > 1.01)
328 fputexpos(expval, stdout);
329 fputformat(fmtid, stdout);
330 putchar('\n');
331 }
332 if (resolution) /* put resolution */
333 fputsresolu(&picres, stdout);
334 pixtoval();
335 }
336
337 quit(0);
338 }
339
340
341 int
342 checkhead(line) /* deal with line from header */
343 char *line;
344 {
345 char fmt[32];
346 double d;
347 COLOR ctmp;
348
349 if (formatval(fmt, line)) {
350 if (!strcmp(fmt, CIEFMT)) {
351 mybright = &xyz_bright;
352 if (original) {
353 scalecolor(exposure, 1./WHTEFFICACY);
354 doexposure++;
355 }
356 } else if (!strcmp(fmt, COLRFMT))
357 mybright = &rgb_bright;
358 else
359 wrongformat++;
360 } else if (original && isexpos(line)) {
361 d = 1.0/exposval(line);
362 scalecolor(exposure, d);
363 doexposure++;
364 } else if (original && iscolcor(line)) {
365 colcorval(ctmp, line);
366 setcolor(exposure, colval(exposure,RED)/colval(ctmp,RED),
367 colval(exposure,GRN)/colval(ctmp,GRN),
368 colval(exposure,BLU)/colval(ctmp,BLU));
369 doexposure++;
370 } else if (header)
371 fputs(line, stdout);
372 return(0);
373 }
374
375
376 pixtoval() /* convert picture to values */
377 {
378 register COLOR *scanln;
379 int dogamma;
380 COLOR lastc;
381 FLOAT hv[2];
382 int startprim, endprim;
383 long startpos;
384 int y;
385 register int x;
386
387 scanln = (COLOR *)malloc(scanlen(&picres)*sizeof(COLOR));
388 if (scanln == NULL) {
389 fprintf(stderr, "%s: out of memory\n", progname);
390 quit(1);
391 }
392 dogamma = gamcor < .95 || gamcor > 1.05;
393 if (putprim == ALL && !interleave) {
394 startprim = RED; endprim = BLU;
395 startpos = ftell(fin);
396 } else {
397 startprim = putprim; endprim = putprim;
398 }
399 for (putprim = startprim; putprim <= endprim; putprim++) {
400 if (putprim != startprim && fseek(fin, startpos, 0)) {
401 fprintf(stderr, "%s: seek error on input file\n",
402 progname);
403 quit(1);
404 }
405 set_io();
406 setcolor(lastc, 0.0, 0.0, 0.0);
407 for (y = 0; y < numscans(&picres); y++) {
408 if (freadscan(scanln, scanlen(&picres), fin) < 0) {
409 fprintf(stderr, "%s: read error\n", progname);
410 quit(1);
411 }
412 for (x = 0; x < scanlen(&picres); x++) {
413 if (uniq)
414 if ( colval(scanln[x],RED) ==
415 colval(lastc,RED) &&
416 colval(scanln[x],GRN) ==
417 colval(lastc,GRN) &&
418 colval(scanln[x],BLU) ==
419 colval(lastc,BLU) )
420 continue;
421 else
422 copycolor(lastc, scanln[x]);
423 if (doexposure)
424 multcolor(scanln[x], exposure);
425 if (dogamma)
426 setcolor(scanln[x],
427 pow(colval(scanln[x],RED), 1.0/gamcor),
428 pow(colval(scanln[x],GRN), 1.0/gamcor),
429 pow(colval(scanln[x],BLU), 1.0/gamcor));
430 if (!dataonly) {
431 pix2loc(hv, &picres, x, y);
432 printf("%7d %7d ",
433 (int)(hv[0]*picres.xr),
434 (int)(hv[1]*picres.yr));
435 }
436 if ((*putval)(scanln[x]) < 0) {
437 fprintf(stderr, "%s: write error\n",
438 progname);
439 quit(1);
440 }
441 }
442 }
443 }
444 free((void *)scanln);
445 }
446
447
448 valtopix() /* convert values to a pixel file */
449 {
450 int dogamma;
451 register COLOR *scanln;
452 int y;
453 register int x;
454
455 scanln = (COLOR *)malloc(scanlen(&picres)*sizeof(COLOR));
456 if (scanln == NULL) {
457 fprintf(stderr, "%s: out of memory\n", progname);
458 quit(1);
459 }
460 dogamma = gamcor < .95 || gamcor > 1.05;
461 set_io();
462 for (y = 0; y < numscans(&picres); y++) {
463 for (x = 0; x < scanlen(&picres); x++) {
464 if (!dataonly) {
465 fscanf(fin, "%*d %*d");
466 if (fin2 != NULL) {
467 fscanf(fin2, "%*d %*d");
468 fscanf(fin3, "%*d %*d");
469 }
470 }
471 if ((*getval)(scanln[x]) < 0) {
472 fprintf(stderr, "%s: read error\n", progname);
473 quit(1);
474 }
475 if (dogamma)
476 setcolor(scanln[x],
477 pow(colval(scanln[x],RED), gamcor),
478 pow(colval(scanln[x],GRN), gamcor),
479 pow(colval(scanln[x],BLU), gamcor));
480 if (doexposure)
481 multcolor(scanln[x], exposure);
482 }
483 if (fwritescan(scanln, scanlen(&picres), stdout) < 0) {
484 fprintf(stderr, "%s: write error\n", progname);
485 quit(1);
486 }
487 }
488 free((void *)scanln);
489 }
490
491
492 void
493 quit(code)
494 int code;
495 {
496 exit(code);
497 }
498
499
500 getcascii(col) /* get an ascii color value from stream(s) */
501 COLOR col;
502 {
503 double vd[3];
504
505 if (fin2 == NULL) {
506 if (fscanf(fin, "%lf %lf %lf", &vd[0], &vd[1], &vd[2]) != 3)
507 return(-1);
508 } else {
509 if (fscanf(fin, "%lf", &vd[0]) != 1 ||
510 fscanf(fin2, "%lf", &vd[1]) != 1 ||
511 fscanf(fin3, "%lf", &vd[2]) != 1)
512 return(-1);
513 }
514 setcolor(col, vd[rord[RED]], vd[rord[GRN]], vd[rord[BLU]]);
515 return(0);
516 }
517
518
519 getcdouble(col) /* get a double color value from stream(s) */
520 COLOR col;
521 {
522 double vd[3];
523
524 if (fin2 == NULL) {
525 if (fread((char *)vd, sizeof(double), 3, fin) != 3)
526 return(-1);
527 } else {
528 if (fread((char *)vd, sizeof(double), 1, fin) != 1 ||
529 fread((char *)(vd+1), sizeof(double), 1, fin2) != 1 ||
530 fread((char *)(vd+2), sizeof(double), 1, fin3) != 1)
531 return(-1);
532 }
533 setcolor(col, vd[rord[RED]], vd[rord[GRN]], vd[rord[BLU]]);
534 return(0);
535 }
536
537
538 getcfloat(col) /* get a float color value from stream(s) */
539 COLOR col;
540 {
541 float vf[3];
542
543 if (fin2 == NULL) {
544 if (fread((char *)vf, sizeof(float), 3, fin) != 3)
545 return(-1);
546 } else {
547 if (fread((char *)vf, sizeof(float), 1, fin) != 1 ||
548 fread((char *)(vf+1), sizeof(float), 1, fin2) != 1 ||
549 fread((char *)(vf+2), sizeof(float), 1, fin3) != 1)
550 return(-1);
551 }
552 setcolor(col, vf[rord[RED]], vf[rord[GRN]], vf[rord[BLU]]);
553 return(0);
554 }
555
556
557 getcint(col) /* get an int color value from stream(s) */
558 COLOR col;
559 {
560 int vi[3];
561
562 if (fin2 == NULL) {
563 if (fscanf(fin, "%d %d %d", &vi[0], &vi[1], &vi[2]) != 3)
564 return(-1);
565 } else {
566 if (fscanf(fin, "%d", &vi[0]) != 1 ||
567 fscanf(fin2, "%d", &vi[1]) != 1 ||
568 fscanf(fin3, "%d", &vi[2]) != 1)
569 return(-1);
570 }
571 setcolor(col, (vi[rord[RED]]+.5)/256.,
572 (vi[rord[GRN]]+.5)/256., (vi[rord[BLU]]+.5)/256.);
573 return(0);
574 }
575
576
577 getcbyte(col) /* get a byte color value from stream(s) */
578 COLOR col;
579 {
580 BYTE vb[3];
581
582 if (fin2 == NULL) {
583 if (fread((char *)vb, sizeof(BYTE), 3, fin) != 3)
584 return(-1);
585 } else {
586 if (fread((char *)vb, sizeof(BYTE), 1, fin) != 1 ||
587 fread((char *)(vb+1), sizeof(BYTE), 1, fin2) != 1 ||
588 fread((char *)(vb+2), sizeof(BYTE), 1, fin3) != 1)
589 return(-1);
590 }
591 setcolor(col, (vb[rord[RED]]+.5)/256.,
592 (vb[rord[GRN]]+.5)/256., (vb[rord[BLU]]+.5)/256.);
593 return(0);
594 }
595
596
597 getbascii(col) /* get an ascii brightness value from fin */
598 COLOR col;
599 {
600 double vd;
601
602 if (fscanf(fin, "%lf", &vd) != 1)
603 return(-1);
604 setcolor(col, vd, vd, vd);
605 return(0);
606 }
607
608
609 getbdouble(col) /* get a double brightness value from fin */
610 COLOR col;
611 {
612 double vd;
613
614 if (fread((char *)&vd, sizeof(double), 1, fin) != 1)
615 return(-1);
616 setcolor(col, vd, vd, vd);
617 return(0);
618 }
619
620
621 getbfloat(col) /* get a float brightness value from fin */
622 COLOR col;
623 {
624 float vf;
625
626 if (fread((char *)&vf, sizeof(float), 1, fin) != 1)
627 return(-1);
628 setcolor(col, vf, vf, vf);
629 return(0);
630 }
631
632
633 getbint(col) /* get an int brightness value from fin */
634 COLOR col;
635 {
636 int vi;
637 double d;
638
639 if (fscanf(fin, "%d", &vi) != 1)
640 return(-1);
641 d = (vi+.5)/256.;
642 setcolor(col, d, d, d);
643 return(0);
644 }
645
646
647 getbbyte(col) /* get a byte brightness value from fin */
648 COLOR col;
649 {
650 BYTE vb;
651 double d;
652
653 if (fread((char *)&vb, sizeof(BYTE), 1, fin) != 1)
654 return(-1);
655 d = (vb+.5)/256.;
656 setcolor(col, d, d, d);
657 return(0);
658 }
659
660
661 putcascii(col) /* put an ascii color to stdout */
662 COLOR col;
663 {
664 fprintf(stdout, "%15.3e %15.3e %15.3e\n",
665 colval(col,ord[0]),
666 colval(col,ord[1]),
667 colval(col,ord[2]));
668
669 return(ferror(stdout) ? -1 : 0);
670 }
671
672
673 putcfloat(col) /* put a float color to stdout */
674 COLOR col;
675 {
676 float vf[3];
677
678 vf[0] = colval(col,ord[0]);
679 vf[1] = colval(col,ord[1]);
680 vf[2] = colval(col,ord[2]);
681 fwrite((char *)vf, sizeof(float), 3, stdout);
682
683 return(ferror(stdout) ? -1 : 0);
684 }
685
686
687 putcdouble(col) /* put a double color to stdout */
688 COLOR col;
689 {
690 double vd[3];
691
692 vd[0] = colval(col,ord[0]);
693 vd[1] = colval(col,ord[1]);
694 vd[2] = colval(col,ord[2]);
695 fwrite((char *)vd, sizeof(double), 3, stdout);
696
697 return(ferror(stdout) ? -1 : 0);
698 }
699
700
701 putcint(col) /* put an int color to stdout */
702 COLOR col;
703 {
704 fprintf(stdout, "%d %d %d\n",
705 (int)(colval(col,ord[0])*256.),
706 (int)(colval(col,ord[1])*256.),
707 (int)(colval(col,ord[2])*256.));
708
709 return(ferror(stdout) ? -1 : 0);
710 }
711
712
713 putcbyte(col) /* put a byte color to stdout */
714 COLOR col;
715 {
716 register int i;
717 BYTE vb[3];
718
719 i = colval(col,ord[0])*256.;
720 vb[0] = min(i,255);
721 i = colval(col,ord[1])*256.;
722 vb[1] = min(i,255);
723 i = colval(col,ord[2])*256.;
724 vb[2] = min(i,255);
725 fwrite((char *)vb, sizeof(BYTE), 3, stdout);
726
727 return(ferror(stdout) ? -1 : 0);
728 }
729
730
731 putbascii(col) /* put an ascii brightness to stdout */
732 COLOR col;
733 {
734 fprintf(stdout, "%15.3e\n", (*mybright)(col));
735
736 return(ferror(stdout) ? -1 : 0);
737 }
738
739
740 putbfloat(col) /* put a float brightness to stdout */
741 COLOR col;
742 {
743 float vf;
744
745 vf = (*mybright)(col);
746 fwrite((char *)&vf, sizeof(float), 1, stdout);
747
748 return(ferror(stdout) ? -1 : 0);
749 }
750
751
752 putbdouble(col) /* put a double brightness to stdout */
753 COLOR col;
754 {
755 double vd;
756
757 vd = (*mybright)(col);
758 fwrite((char *)&vd, sizeof(double), 1, stdout);
759
760 return(ferror(stdout) ? -1 : 0);
761 }
762
763
764 putbint(col) /* put an int brightness to stdout */
765 COLOR col;
766 {
767 fprintf(stdout, "%d\n", (int)((*mybright)(col)*256.));
768
769 return(ferror(stdout) ? -1 : 0);
770 }
771
772
773 putbbyte(col) /* put a byte brightness to stdout */
774 COLOR col;
775 {
776 register int i;
777 BYTE vb;
778
779 i = (*mybright)(col)*256.;
780 vb = min(i,255);
781 fwrite((char *)&vb, sizeof(BYTE), 1, stdout);
782
783 return(ferror(stdout) ? -1 : 0);
784 }
785
786
787 putpascii(col) /* put an ascii primary to stdout */
788 COLOR col;
789 {
790 fprintf(stdout, "%15.3e\n", colval(col,putprim));
791
792 return(ferror(stdout) ? -1 : 0);
793 }
794
795
796 putpfloat(col) /* put a float primary to stdout */
797 COLOR col;
798 {
799 float vf;
800
801 vf = colval(col,putprim);
802 fwrite((char *)&vf, sizeof(float), 1, stdout);
803
804 return(ferror(stdout) ? -1 : 0);
805 }
806
807
808 putpdouble(col) /* put a double primary to stdout */
809 COLOR col;
810 {
811 double vd;
812
813 vd = colval(col,putprim);
814 fwrite((char *)&vd, sizeof(double), 1, stdout);
815
816 return(ferror(stdout) ? -1 : 0);
817 }
818
819
820 putpint(col) /* put an int primary to stdout */
821 COLOR col;
822 {
823 fprintf(stdout, "%d\n", (int)(colval(col,putprim)*256.));
824
825 return(ferror(stdout) ? -1 : 0);
826 }
827
828
829 putpbyte(col) /* put a byte primary to stdout */
830 COLOR col;
831 {
832 register int i;
833 BYTE vb;
834
835 i = colval(col,putprim)*256.;
836 vb = min(i,255);
837 fwrite((char *)&vb, sizeof(BYTE), 1, stdout);
838
839 return(ferror(stdout) ? -1 : 0);
840 }
841
842
843 set_io() /* set put and get functions */
844 {
845 switch (format) {
846 case 'a': /* ascii */
847 if (putprim == BRIGHT) {
848 getval = getbascii;
849 putval = putbascii;
850 } else if (putprim != ALL) {
851 getval = getbascii;
852 putval = putpascii;
853 } else {
854 getval = getcascii;
855 putval = putcascii;
856 if (reverse && !interleave) {
857 fprintf(stderr,
858 "%s: ASCII input files must be interleaved\n",
859 progname);
860 quit(1);
861 }
862 }
863 return;
864 case 'f': /* binary float */
865 if (putprim == BRIGHT) {
866 getval = getbfloat;
867 putval = putbfloat;
868 } else if (putprim != ALL) {
869 getval = getbfloat;
870 putval = putpfloat;
871 } else {
872 getval = getcfloat;
873 putval = putcfloat;
874 if (reverse && !interleave) {
875 if (fin2 == NULL)
876 goto namerr;
877 if (fseek(fin2,
878 (long)sizeof(float)*picres.xr*picres.yr, 1))
879 goto seekerr;
880 if (fseek(fin3,
881 (long)sizeof(float)*2*picres.xr*picres.yr, 1))
882 goto seekerr;
883 }
884 }
885 return;
886 case 'd': /* binary double */
887 if (putprim == BRIGHT) {
888 getval = getbdouble;
889 putval = putbdouble;
890 } else if (putprim != ALL) {
891 getval = getbdouble;
892 putval = putpdouble;
893 } else {
894 getval = getcdouble;
895 putval = putcdouble;
896 if (reverse && !interleave) {
897 if (fin2 == NULL)
898 goto namerr;
899 if (fseek(fin2,
900 (long)sizeof(double)*picres.xr*picres.yr, 1))
901 goto seekerr;
902 if (fseek(fin3,
903 (long)sizeof(double)*2*picres.xr*picres.yr, 1))
904 goto seekerr;
905 }
906 }
907 return;
908 case 'i': /* integer */
909 if (putprim == BRIGHT) {
910 getval = getbint;
911 putval = putbint;
912 } else if (putprim != ALL) {
913 getval = getbint;
914 putval = putpint;
915 } else {
916 getval = getcint;
917 putval = putcint;
918 if (reverse && !interleave) {
919 fprintf(stderr,
920 "%s: integer input files must be interleaved\n",
921 progname);
922 quit(1);
923 }
924 }
925 return;
926 case 'b': /* byte */
927 if (putprim == BRIGHT) {
928 getval = getbbyte;
929 putval = putbbyte;
930 } else if (putprim != ALL) {
931 getval = getbbyte;
932 putval = putpbyte;
933 } else {
934 getval = getcbyte;
935 putval = putcbyte;
936 if (reverse && !interleave) {
937 if (fin2 == NULL)
938 goto namerr;
939 if (fseek(fin2,
940 (long)sizeof(BYTE)*picres.xr*picres.yr, 1))
941 goto seekerr;
942 if (fseek(fin3,
943 (long)sizeof(BYTE)*2*picres.xr*picres.yr, 1))
944 goto seekerr;
945 }
946 }
947 return;
948 }
949 badopt:
950 fprintf(stderr, "%s: botched file type\n", progname);
951 quit(1);
952 namerr:
953 fprintf(stderr, "%s: non-interleaved file(s) must be named\n",
954 progname);
955 quit(1);
956 seekerr:
957 fprintf(stderr, "%s: cannot seek on interleaved input file\n",
958 progname);
959 quit(1);
960 }
