1 |
/* Copyright (c) 1986 Regents of the University of California */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ LBL"; |
5 |
#endif |
6 |
7 |
8 |
* pvalue.c - program to print pixel values. |
9 |
10 |
* 4/23/86 |
11 |
12 |
13 |
#include <stdio.h> |
14 |
15 |
#include "color.h" |
16 |
17 |
#define min(a,b) ((a)<(b)?(a):(b)) |
18 |
19 |
int xres = 0; /* resolution of input */ |
20 |
int yres = 0; |
21 |
22 |
int uniq = 0; /* unique values? */ |
23 |
24 |
int original = 0; /* original values? */ |
25 |
26 |
int dataonly = 0; /* data only format? */ |
27 |
28 |
int brightonly = 0; /* only brightness values? */ |
29 |
30 |
int reverse = 0; /* reverse conversion? */ |
31 |
32 |
int format = 'a'; /* input/output format */ |
33 |
34 |
int header = 1; /* do header */ |
35 |
36 |
double exposure = 1.0; |
37 |
38 |
char *progname; |
39 |
40 |
FILE *fin; |
41 |
42 |
int (*getval)(), (*putval)(); |
43 |
44 |
45 |
main(argc, argv) |
46 |
int argc; |
47 |
char **argv; |
48 |
49 |
extern double atof(); |
50 |
extern int checkhead(); |
51 |
int i; |
52 |
53 |
progname = argv[0]; |
54 |
55 |
for (i = 1; i < argc; i++) |
56 |
if (argv[i][0] == '-') |
57 |
switch (argv[i][1]) { |
58 |
case 'h': /* no header */ |
59 |
header = 0; |
60 |
break; |
61 |
case 'u': /* unique values */ |
62 |
uniq = 1; |
63 |
break; |
64 |
case 'o': /* original values */ |
65 |
original = 1; |
66 |
break; |
67 |
case 'r': /* reverse conversion */ |
68 |
reverse = 1; |
69 |
break; |
70 |
case 'b': /* brightness values */ |
71 |
brightonly = 1; |
72 |
break; |
73 |
case 'd': /* data only (no indices) */ |
74 |
dataonly = 1; |
75 |
switch (argv[i][2]) { |
76 |
case '\0': |
77 |
case 'a': /* ascii */ |
78 |
format = 'a'; |
79 |
break; |
80 |
case 'i': /* integer */ |
81 |
case 'b': /* byte */ |
82 |
case 'f': /* float */ |
83 |
case 'd': /* double */ |
84 |
format = argv[i][2]; |
85 |
break; |
86 |
default: |
87 |
goto unkopt; |
88 |
89 |
break; |
90 |
case 'x': /* x resolution */ |
91 |
xres = atoi(argv[++i]); |
92 |
break; |
93 |
case 'y': /* y resolution */ |
94 |
yres = atoi(argv[++i]); |
95 |
break; |
96 |
default: |
97 |
unkopt: |
98 |
fprintf(stderr, "%s: unknown option: %s\n", |
99 |
progname, argv[i]); |
100 |
quit(1); |
101 |
break; |
102 |
103 |
else |
104 |
break; |
105 |
106 |
if (i == argc) { |
107 |
fin = stdin; |
108 |
} else if (i == argc-1) { |
109 |
if ((fin = fopen(argv[i], "r")) == NULL) { |
110 |
fprintf(stderr, "%s: can't open file \"%s\"\n", |
111 |
112 |
quit(1); |
113 |
114 |
} else { |
115 |
fprintf(stderr, "%s: bad # file arguments\n", progname); |
116 |
quit(1); |
117 |
118 |
119 |
set_io(); |
120 |
121 |
if (reverse) { |
122 |
if (header) /* get header */ |
123 |
copyheader(fin, stdout); |
124 |
/* add to header */ |
125 |
printargs(i, argv, stdout); |
126 |
printf("\n"); |
127 |
if (yres <= 0 || xres <= 0) { |
128 |
fprintf(stderr, "%s: missing x and y resolution\n", |
129 |
progname); |
130 |
quit(1); |
131 |
132 |
fputresolu(YMAJOR|YDECR, xres, yres, stdout); |
133 |
valtopix(); |
134 |
} else { |
135 |
/* get header */ |
136 |
getheader(fin, checkhead); |
137 |
138 |
if (xres <= 0 || yres <= 0) /* get picture size */ |
139 |
if (fgetresolu(&xres, &yres, fin) != (YMAJOR|YDECR)) { |
140 |
fprintf(stderr, |
141 |
142 |
progname); |
143 |
quit(1); |
144 |
145 |
if (header) { |
146 |
147 |
printf("\n"); |
148 |
149 |
pixtoval(); |
150 |
151 |
152 |
quit(0); |
153 |
154 |
155 |
156 |
checkhead(line) /* deal with line from header */ |
157 |
char *line; |
158 |
159 |
if (header) |
160 |
fputs(line, stdout); |
161 |
if (isexpos(line)) |
162 |
exposure *= exposval(line); |
163 |
164 |
165 |
166 |
pixtoval() /* convert picture to values */ |
167 |
168 |
COLOR *scanln; |
169 |
COLOR lastc; |
170 |
int y; |
171 |
register int x; |
172 |
173 |
scanln = (COLOR *)malloc(xres*sizeof(COLOR)); |
174 |
if (scanln == NULL) { |
175 |
fprintf(stderr, "%s: out of memory\n", progname); |
176 |
quit(1); |
177 |
178 |
setcolor(lastc, 0.0, 0.0, 0.0); |
179 |
for (y = yres-1; y >= 0; y--) { |
180 |
if (freadscan(scanln, xres, fin) < 0) { |
181 |
fprintf(stderr, "%s: read error\n", progname); |
182 |
quit(1); |
183 |
184 |
for (x = 0; x < xres; x++) { |
185 |
if (uniq) |
186 |
if ( scanln[x][RED] == lastc[RED] && |
187 |
scanln[x][GRN] == lastc[GRN] && |
188 |
scanln[x][BLU] == lastc[BLU] ) |
189 |
continue; |
190 |
else |
191 |
copycolor(lastc, scanln[x]); |
192 |
if (original) |
193 |
scalecolor(scanln[x], 1.0/exposure); |
194 |
if (!dataonly) |
195 |
printf("%7d %7d ", x, y); |
196 |
if ((*putval)(scanln[x], stdout) < 0) { |
197 |
fprintf(stderr, "%s: write error\n", progname); |
198 |
quit(1); |
199 |
200 |
201 |
202 |
free((char *)scanln); |
203 |
204 |
205 |
206 |
valtopix() /* convert values to a pixel file */ |
207 |
208 |
COLOR *scanln; |
209 |
int y; |
210 |
register int x; |
211 |
212 |
213 |
214 |
215 |
quit(1); |
216 |
217 |
218 |
219 |
if (!dataonly) |
220 |
fscanf(fin, "%*d %*d"); |
221 |
if ((*getval)(scanln[x], fin) < 0) { |
222 |
223 |
quit(1); |
224 |
225 |
226 |
if (fwritescan(scanln, xres, stdout) < 0 |
227 |
|| fflush(stdout) < 0) { |
228 |
229 |
quit(1); |
230 |
231 |
232 |
233 |
234 |
235 |
236 |
quit(code) |
237 |
int code; |
238 |
239 |
exit(code); |
240 |
241 |
242 |
243 |
getcascii(col, fp) /* get an ascii color value from fp */ |
244 |
COLOR col; |
245 |
FILE *fp; |
246 |
247 |
double vd[3]; |
248 |
249 |
if (fscanf(fp, "%lf %lf %lf", &vd[0], &vd[1], &vd[2]) != 3) |
250 |
return(-1); |
251 |
setcolor(col, vd[0], vd[1], vd[2]); |
252 |
return(0); |
253 |
254 |
255 |
256 |
getcdouble(col, fp) /* get a double color value from fp */ |
257 |
COLOR col; |
258 |
FILE *fp; |
259 |
260 |
double vd[3]; |
261 |
262 |
if (fread(vd, sizeof(double), 3, fp) != 3) |
263 |
return(-1); |
264 |
265 |
return(0); |
266 |
267 |
268 |
269 |
getcfloat(col, fp) /* get a float color value from fp */ |
270 |
COLOR col; |
271 |
FILE *fp; |
272 |
273 |
float vf[3]; |
274 |
275 |
if (fread(vf, sizeof(float), 3, fp) != 3) |
276 |
return(-1); |
277 |
setcolor(col, vf[0], vf[1], vf[2]); |
278 |
return(0); |
279 |
280 |
281 |
282 |
getcint(col, fp) /* get an int color value from fp */ |
283 |
COLOR col; |
284 |
FILE *fp; |
285 |
286 |
int vi[3]; |
287 |
288 |
if (fscanf(fp, "%d %d %d", &vi[0], &vi[1], &vi[2]) != 3) |
289 |
return(-1); |
290 |
setcolor(col,(vi[0]+.5)/256.,(vi[1]+.5)/256.,(vi[2]+.5)/256.); |
291 |
return(0); |
292 |
293 |
294 |
295 |
getcbyte(col, fp) /* get a byte color value from fp */ |
296 |
COLOR col; |
297 |
FILE *fp; |
298 |
299 |
BYTE vb[3]; |
300 |
301 |
if (fread(vb, sizeof(BYTE), 3, fp) != 3) |
302 |
return(-1); |
303 |
setcolor(col,(vb[0]+.5)/256.,(vb[1]+.5)/256.,(vb[2]+.5)/256.); |
304 |
return(0); |
305 |
306 |
307 |
308 |
getbascii(col, fp) /* get an ascii brightness value from fp */ |
309 |
COLOR col; |
310 |
FILE *fp; |
311 |
312 |
double vd; |
313 |
314 |
if (fscanf(fp, "%lf", &vd) != 1) |
315 |
return(-1); |
316 |
setcolor(col, vd, vd, vd); |
317 |
return(0); |
318 |
319 |
320 |
321 |
getbdouble(col, fp) /* get a double brightness value from fp */ |
322 |
COLOR col; |
323 |
FILE *fp; |
324 |
325 |
double vd; |
326 |
327 |
if (fread(&vd, sizeof(double), 1, fp) != 1) |
328 |
return(-1); |
329 |
330 |
return(0); |
331 |
332 |
333 |
334 |
getbfloat(col, fp) /* get a float brightness value from fp */ |
335 |
COLOR col; |
336 |
FILE *fp; |
337 |
338 |
float vf; |
339 |
340 |
if (fread(&vf, sizeof(float), 1, fp) != 1) |
341 |
return(-1); |
342 |
setcolor(col, vf, vf, vf); |
343 |
return(0); |
344 |
345 |
346 |
347 |
getbint(col, fp) /* get an int brightness value from fp */ |
348 |
COLOR col; |
349 |
FILE *fp; |
350 |
351 |
int vi; |
352 |
double d; |
353 |
354 |
if (fscanf(fp, "%d", &vi) != 1) |
355 |
return(-1); |
356 |
d = (vi+.5)/256.; |
357 |
setcolor(col, d, d, d); |
358 |
return(0); |
359 |
360 |
361 |
362 |
getbbyte(col, fp) /* get a byte brightness value from fp */ |
363 |
COLOR col; |
364 |
FILE *fp; |
365 |
366 |
BYTE vb; |
367 |
double d; |
368 |
369 |
if (fread(&vb, sizeof(BYTE), 1, fp) != 1) |
370 |
return(-1); |
371 |
d = (vb+.5)/256.; |
372 |
373 |
return(0); |
374 |
375 |
376 |
377 |
putcascii(col, fp) /* put an ascii color to fp */ |
378 |
COLOR col; |
379 |
FILE *fp; |
380 |
381 |
fprintf(fp, "%15.3e %15.3e %15.3e\n", |
382 |
colval(col,RED), |
383 |
colval(col,GRN), |
384 |
colval(col,BLU)); |
385 |
386 |
return(ferror(fp) ? -1 : 0); |
387 |
388 |
389 |
390 |
putcfloat(col, fp) /* put a float color to fp */ |
391 |
COLOR col; |
392 |
FILE *fp; |
393 |
394 |
float vf[3]; |
395 |
396 |
vf[0] = colval(col,RED); |
397 |
vf[1] = colval(col,GRN); |
398 |
vf[2] = colval(col,BLU); |
399 |
fwrite(vf, sizeof(float), 3, fp); |
400 |
401 |
402 |
403 |
404 |
405 |
putcdouble(col, fp) /* put a double color to fp */ |
406 |
COLOR col; |
407 |
FILE *fp; |
408 |
409 |
double vd[3]; |
410 |
411 |
vd[0] = colval(col,RED); |
412 |
vd[1] = colval(col,GRN); |
413 |
vd[2] = colval(col,BLU); |
414 |
fwrite(vd, sizeof(double), 3, fp); |
415 |
416 |
417 |
418 |
419 |
420 |
putcint(col, fp) /* put an int color to fp */ |
421 |
COLOR col; |
422 |
FILE *fp; |
423 |
424 |
fprintf(fp, "%d %d %d\n", |
425 |
(int)(colval(col,RED)*256.), |
426 |
(int)(colval(col,GRN)*256.), |
427 |
(int)(colval(col,BLU)*256.)); |
428 |
429 |
430 |
431 |
432 |
433 |
putcbyte(col, fp) /* put a byte color to fp */ |
434 |
COLOR col; |
435 |
FILE *fp; |
436 |
437 |
register int i; |
438 |
BYTE vb[3]; |
439 |
440 |
i = colval(col,RED)*256.; |
441 |
vb[0] = min(i,255); |
442 |
i = colval(col,GRN)*256.; |
443 |
vb[1] = min(i,255); |
444 |
i = colval(col,BLU)*256.; |
445 |
vb[2] = min(i,255); |
446 |
fwrite(vb, sizeof(BYTE), 3, fp); |
447 |
448 |
449 |
450 |
451 |
452 |
putbascii(col, fp) /* put an ascii brightness to fp */ |
453 |
COLOR col; |
454 |
FILE *fp; |
455 |
456 |
fprintf(fp, "%15.3e\n", bright(col)); |
457 |
458 |
459 |
460 |
461 |
462 |
putbfloat(col, fp) /* put a float brightness to fp */ |
463 |
COLOR col; |
464 |
FILE *fp; |
465 |
466 |
float vf; |
467 |
468 |
vf = bright(col); |
469 |
fwrite(&vf, sizeof(float), 1, fp); |
470 |
471 |
472 |
473 |
474 |
475 |
putbdouble(col, fp) /* put a double brightness to fp */ |
476 |
COLOR col; |
477 |
FILE *fp; |
478 |
479 |
double vd; |
480 |
481 |
vd = bright(col); |
482 |
fwrite(&vd, sizeof(double), 1, fp); |
483 |
484 |
485 |
486 |
487 |
488 |
putbint(col, fp) /* put an int brightness to fp */ |
489 |
COLOR col; |
490 |
FILE *fp; |
491 |
492 |
fprintf(fp, "%d\n", (int)(bright(col)*256.)); |
493 |
494 |
495 |
496 |
497 |
498 |
putbbyte(col, fp) /* put a byte brightness to fp */ |
499 |
COLOR col; |
500 |
FILE *fp; |
501 |
502 |
register int i; |
503 |
BYTE vb; |
504 |
505 |
i = bright(col)*256.; |
506 |
vb = min(i,255); |
507 |
fwrite(&vb, sizeof(BYTE), 1, fp); |
508 |
509 |
510 |
511 |
512 |
513 |
set_io() /* set put and get functions */ |
514 |
515 |
switch (format) { |
516 |
517 |
if (brightonly) { |
518 |
getval = getbascii; |
519 |
putval = putbascii; |
520 |
} else { |
521 |
getval = getcascii; |
522 |
putval = putcascii; |
523 |
524 |
return; |
525 |
case 'f': /* binary float */ |
526 |
if (brightonly) { |
527 |
getval = getbfloat; |
528 |
putval = putbfloat; |
529 |
} else { |
530 |
getval = getcfloat; |
531 |
putval = putcfloat; |
532 |
533 |
return; |
534 |
case 'd': /* binary double */ |
535 |
if (brightonly) { |
536 |
getval = getbdouble; |
537 |
putval = putbdouble; |
538 |
} else { |
539 |
getval = getcdouble; |
540 |
putval = putcdouble; |
541 |
542 |
return; |
543 |
544 |
if (brightonly) { |
545 |
getval = getbint; |
546 |
putval = putbint; |
547 |
} else { |
548 |
getval = getcint; |
549 |
putval = putcint; |
550 |
551 |
return; |
552 |
553 |
if (brightonly) { |
554 |
getval = getbbyte; |
555 |
putval = putbbyte; |
556 |
} else { |
557 |
getval = getcbyte; |
558 |
putval = putcbyte; |
559 |
560 |
return; |
561 |
562 |
