--- ray/src/px/pvalue.c 1994/10/06 13:27:16 2.9 +++ ray/src/px/pvalue.c 1997/01/08 07:43:49 2.10 @@ -18,6 +18,12 @@ static char SCCSid[] = "$SunId$ LBL"; #define min(a,b) ((a)<(b)?(a):(b)) + /* what to put out (also RED, GRN, BLU) */ +#define ALL 3 +#define BRIGHT 4 + +#define brightonly (putprim==BRIGHT) + RESOLU picres; /* resolution of picture */ int uniq = 0; /* print only unique values? */ @@ -26,7 +32,7 @@ int doexposure = 0; /* exposure change? (>100 to pri int dataonly = 0; /* data only format? */ -int brightonly = 0; /* only brightness values? */ +int putprim = ALL; /* what to put out */ int reverse = 0; /* reverse conversion? */ @@ -35,6 +41,8 @@ char *fmtid = "ascii"; /* format identifier for head int header = 1; /* do header? */ +long skipbytes = 0; /* skip bytes in input? */ + int resolution = 1; /* put/get resolution string? */ int original = 0; /* convert to original values? */ @@ -51,6 +59,7 @@ COLOR exposure = WHTCOLOR; char *progname; FILE *fin; +FILE *fin2 = NULL, *fin3 = NULL; /* for other color channels */ int (*getval)(), (*putval)(); @@ -60,6 +69,7 @@ int argc; char **argv; { extern int checkhead(); + extern long atol(); double d, expval = 1.0; int i; @@ -74,6 +84,9 @@ char **argv; case 'H': /* resolution string */ resolution = argv[i][0] == '+'; break; + case 's': /* skip bytes in header */ + skipbytes = atol(argv[++i]); + break; case 'u': /* unique values */ uniq = argv[i][0] == '-'; break; @@ -107,8 +120,16 @@ char **argv; reverse = argv[i][0] == '-'; break; case 'b': /* brightness values */ - brightonly = argv[i][0] == '-'; + putprim = argv[i][0] == '-' ? BRIGHT : ALL; break; + case 'p': /* put primary */ + switch (argv[i][2]) { + case 'r': case 'R': putprim = RED; break; + case 'g': case 'G': putprim = GRN; break; + case 'b': case 'B': putprim = BLU; break; + default: goto unkopt; + } + break; case 'd': /* data only (no indices) */ dataonly = argv[i][0] == '-'; switch (argv[i][2]) { @@ -178,13 +199,32 @@ unkopt: /* get input */ if (i == argc) { fin = stdin; - } else if (i == argc-1) { + } else if (i < argc) { if ((fin = fopen(argv[i], "r")) == NULL) { fprintf(stderr, "%s: can't open file \"%s\"\n", progname, argv[i]); quit(1); } - } else { + if (skipbytes && fseek(fin, skipbytes, 0)) + goto seekerr; + if (reverse && !brightonly && i == argc-3) { + if ((fin2 = fopen(argv[i+1], "r")) == NULL) { + fprintf(stderr, "%s: can't open file \"%s\"\n", + progname, argv[i+1]); + quit(1); + } + if ((fin3 = fopen(argv[i+2], "r")) == NULL) { + fprintf(stderr, "%s: can't open file \"%s\"\n", + progname, argv[i+2]); + quit(1); + } + if (skipbytes && (fseek(fin2, skipbytes, 0) || + fseek(fin3, skipbytes, 0))) + goto seekerr; + } else if (i != argc-1) + fin = NULL; + } + if (fin == NULL) { fprintf(stderr, "%s: bad # file arguments\n", progname); quit(1); } @@ -204,6 +244,10 @@ unkopt: progname); quit(1); } + if (fin2 != NULL) { + getheader(fin2, NULL, NULL); + getheader(fin3, NULL, NULL); + } } else newheader("RADIANCE", stdout); /* get resolution */ @@ -212,6 +256,21 @@ unkopt: fprintf(stderr, "%s: missing resolution\n", progname); quit(1); } + if (resolution && fin2 != NULL) { + RESOLU pres2; + if (!fgetsresolu(&pres2, fin2) || + pres2.or != picres.or || + pres2.xr != picres.xr || + pres2.yr != picres.yr || + !fgetsresolu(&pres2, fin3) || + pres2.or != picres.or || + pres2.xr != picres.xr || + pres2.yr != picres.yr) { + fprintf(stderr, "%s: resolution mismatch\n", + progname); + quit(1); + } + } /* add to header */ printargs(i, argv, stdout); if (expval < .99 || expval > 1.01) @@ -250,6 +309,10 @@ unkopt: } quit(0); +seekerr: + fprintf(stderr, "%s: cannot skip %ld bytes on input\n", + progname, skipbytes); + quit(1); } @@ -346,9 +409,14 @@ valtopix() /* convert values to a pixel file */ dogamma = gamcor < .95 || gamcor > 1.05; for (y = 0; y < numscans(&picres); y++) { for (x = 0; x < scanlen(&picres); x++) { - if (!dataonly) + if (!dataonly) { fscanf(fin, "%*d %*d"); - if ((*getval)(scanln[x], fin) < 0) { + if (fin2 != NULL) { + fscanf(fin2, "%*d %*d"); + fscanf(fin3, "%*d %*d"); + } + } + if ((*getval)(scanln[x], fin, fin2, fin3) < 0) { fprintf(stderr, "%s: read error\n", progname); quit(1); } @@ -376,67 +444,102 @@ int code; } -getcascii(col, fp) /* get an ascii color value from fp */ +getcascii(col, f1, f2, f3) /* get an ascii color value from stream(s) */ COLOR col; -FILE *fp; +FILE *f1, *f2, *f3; { double vd[3]; - if (fscanf(fp, "%lf %lf %lf", &vd[0], &vd[1], &vd[2]) != 3) - return(-1); + if (f2 == NULL) { + if (fscanf(f1, "%lf %lf %lf", &vd[0], &vd[1], &vd[2]) != 3) + return(-1); + } else { + if (fscanf(f1, "%lf", &vd[0]) != 1 || + fscanf(f2, "%lf", &vd[1]) != 1 || + fscanf(f3, "%lf", &vd[2]) != 1) + return(-1); + } setcolor(col, vd[rord[RED]], vd[rord[GRN]], vd[rord[BLU]]); return(0); } -getcdouble(col, fp) /* get a double color value from fp */ +getcdouble(col, f1, f2, f3) /* get a double color value from stream(s) */ COLOR col; -FILE *fp; +FILE *f1, *f2, *f3; { double vd[3]; - if (fread((char *)vd, sizeof(double), 3, fp) != 3) - return(-1); + if (f2 == NULL) { + if (fread((char *)vd, sizeof(double), 3, f1) != 3) + return(-1); + } else { + if (fread((char *)vd, sizeof(double), 1, f1) != 1 || + fread((char *)(vd+1), sizeof(double), 1, f2) != 1 || + fread((char *)(vd+2), sizeof(double), 1, f3) != 1) + return(-1); + } setcolor(col, vd[rord[RED]], vd[rord[GRN]], vd[rord[BLU]]); return(0); } -getcfloat(col, fp) /* get a float color value from fp */ +getcfloat(col, f1, f2, f3) /* get a float color value from stream(s) */ COLOR col; -FILE *fp; +FILE *f1, *f2, *f3; { float vf[3]; - if (fread((char *)vf, sizeof(float), 3, fp) != 3) - return(-1); + if (f2 == NULL) { + if (fread((char *)vf, sizeof(float), 3, f1) != 3) + return(-1); + } else { + if (fread((char *)vf, sizeof(float), 1, f1) != 1 || + fread((char *)(vf+1), sizeof(float), 1, f2) != 1 || + fread((char *)(vf+2), sizeof(float), 1, f3) != 1) + return(-1); + } setcolor(col, vf[rord[RED]], vf[rord[GRN]], vf[rord[BLU]]); return(0); } -getcint(col, fp) /* get an int color value from fp */ +getcint(col, f1, f2, f3) /* get an int color value from stream(s) */ COLOR col; -FILE *fp; +FILE *f1, *f2, *f3; { int vi[3]; - if (fscanf(fp, "%d %d %d", &vi[0], &vi[1], &vi[2]) != 3) - return(-1); + if (f2 == NULL) { + if (fscanf(f1, "%d %d %d", &vi[0], &vi[1], &vi[2]) != 3) + return(-1); + } else { + if (fscanf(f1, "%d", &vi[0]) != 1 || + fscanf(f2, "%d", &vi[1]) != 1 || + fscanf(f3, "%d", &vi[2]) != 1) + return(-1); + } setcolor(col, (vi[rord[RED]]+.5)/256., (vi[rord[GRN]]+.5)/256., (vi[rord[BLU]]+.5)/256.); return(0); } -getcbyte(col, fp) /* get a byte color value from fp */ +getcbyte(col, f1, f2, f3) /* get a byte color value from stream(s) */ COLOR col; -FILE *fp; +FILE *f1, *f2, *f3; { BYTE vb[3]; - if (fread((char *)vb, sizeof(BYTE), 3, fp) != 3) - return(-1); + if (f2 == NULL) { + if (fread((char *)vb, sizeof(BYTE), 3, f1) != 3) + return(-1); + } else { + if (fread((char *)vb, sizeof(BYTE), 1, f1) != 1 || + fread((char *)(vb+1), sizeof(BYTE), 1, f2) != 1 || + fread((char *)(vb+2), sizeof(BYTE), 1, f3) != 1) + return(-1); + } setcolor(col, (vb[rord[RED]]+.5)/256., (vb[rord[GRN]]+.5)/256., (vb[rord[BLU]]+.5)/256.); return(0); @@ -648,49 +751,125 @@ FILE *fp; } +putpascii(col, fp) /* put an ascii primary to fp */ +COLOR col; +FILE *fp; +{ + fprintf(fp, "%15.3e\n", colval(col,putprim)); + + return(ferror(fp) ? -1 : 0); +} + + +putpfloat(col, fp) /* put a float primary to fp */ +COLOR col; +FILE *fp; +{ + float vf; + + vf = colval(col,putprim); + fwrite((char *)&vf, sizeof(float), 1, fp); + + return(ferror(fp) ? -1 : 0); +} + + +putpdouble(col, fp) /* put a double primary to fp */ +COLOR col; +FILE *fp; +{ + double vd; + + vd = colval(col,putprim); + fwrite((char *)&vd, sizeof(double), 1, fp); + + return(ferror(fp) ? -1 : 0); +} + + +putpint(col, fp) /* put an int primary to fp */ +COLOR col; +FILE *fp; +{ + fprintf(fp, "%d\n", (int)(colval(col,putprim)*256.)); + + return(ferror(fp) ? -1 : 0); +} + + +putpbyte(col, fp) /* put a byte primary to fp */ +COLOR col; +FILE *fp; +{ + register int i; + BYTE vb; + + i = colval(col,putprim)*256.; + vb = min(i,255); + fwrite((char *)&vb, sizeof(BYTE), 1, fp); + + return(ferror(fp) ? -1 : 0); +} + + set_io() /* set put and get functions */ { switch (format) { case 'a': /* ascii */ - if (brightonly) { + if (putprim == BRIGHT) { getval = getbascii; putval = putbascii; + } else if (putprim != ALL) { + getval = getbascii; + putval = putpascii; } else { getval = getcascii; putval = putcascii; } return; case 'f': /* binary float */ - if (brightonly) { + if (putprim == BRIGHT) { getval = getbfloat; putval = putbfloat; + } else if (putprim != ALL) { + getval = getbfloat; + putval = putpfloat; } else { getval = getcfloat; putval = putcfloat; } return; case 'd': /* binary double */ - if (brightonly) { + if (putprim == BRIGHT) { getval = getbdouble; putval = putbdouble; + } else if (putprim != ALL) { + getval = getbdouble; + putval = putpdouble; } else { getval = getcdouble; putval = putcdouble; } return; case 'i': /* integer */ - if (brightonly) { + if (putprim == BRIGHT) { getval = getbint; putval = putbint; + } else if (putprim != ALL) { + getval = getbint; + putval = putpint; } else { getval = getcint; putval = putcint; } return; case 'b': /* byte */ - if (brightonly) { + if (putprim == BRIGHT) { getval = getbbyte; putval = putbbyte; + } else if (putprim != ALL) { + getval = getbbyte; + putval = putpbyte; } else { getval = getcbyte; putval = putcbyte;
