--- ray/src/px/pvalue.c 2003/02/25 16:47:23 2.16 +++ ray/src/px/pvalue.c 2004/10/01 07:45:30 2.27 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: pvalue.c,v 2.16 2003/02/25 16:47:23 greg Exp $"; +static const char RCSid[] = "$Id: pvalue.c,v 2.27 2004/10/01 07:45:30 greg Exp $"; #endif /* * pvalue.c - program to print pixel values. @@ -7,53 +7,33 @@ static const char RCSid[] = "$Id: pvalue.c,v 2.16 2003 * 4/23/86 */ +#include "platform.h" #include "standard.h" - #include "color.h" - -#include - #include "resolu.h" +#include "view.h" -typedef unsigned short uint16; /* sizeof (uint16) must == 2 */ - #define min(a,b) ((a)<(b)?(a):(b)) /* what to put out (also RED, GRN, BLU) */ #define ALL 3 #define BRIGHT 4 -#define brightonly (putprim==BRIGHT) - RESOLU picres; /* resolution of picture */ - int uniq = 0; /* print only unique values? */ - int doexposure = 0; /* exposure change? (>100 to print) */ - int dataonly = 0; /* data only format? */ - int putprim = ALL; /* what to put out */ - int reverse = 0; /* reverse conversion? */ - int format = 'a'; /* input/output format */ char *fmtid = "ascii"; /* format identifier for header */ - int header = 1; /* do header? */ - long skipbytes = 0; /* skip bytes in input? */ - -int swapbytes = 0; /* swap bytes in 16-bit words? */ - +int swapbytes = 0; /* swap bytes? */ int interleave = 1; /* file is interleaved? */ - int resolution = 1; /* put/get resolution string? */ - int original = 0; /* convert to original values? */ - int wrongformat = 0; /* wrong input format? */ - double gamcor = 1.0; /* gamma correction */ int ord[3] = {RED, GRN, BLU}; /* RGB ordering */ @@ -66,35 +46,58 @@ char *progname; FILE *fin; FILE *fin2 = NULL, *fin3 = NULL; /* for other color channels */ -int (*getval)(), (*putval)(); -double -rgb_bright(clr) -COLOR clr; +typedef int getfunc_t(COLOR col); +typedef int putfunc_t(COLOR col); +typedef double brightfunc_t(COLOR col); + +getfunc_t *getval; +putfunc_t *putval; +brightfunc_t *mybright; + +static gethfunc checkhead; +static brightfunc_t rgb_bright, xyz_bright; +static getfunc_t getbascii, getbint, getbdouble, getbfloat, getbbyte, getbword; +static getfunc_t getcascii, getcint, getcdouble, getcfloat, getcbyte, getcword; +static putfunc_t putbascii, putbint, putbdouble, putbfloat, putbbyte, putbword; +static putfunc_t putcascii, putcint, putcdouble, putcfloat, putcbyte, putcword; +static putfunc_t putpascii, putpint, putpdouble, putpfloat, putpbyte, putpword; + +static void set_io(void); +static void pixtoval(void); +static void valtopix(void); +static void swap16(uint16 *wp, int n); +static void swap32(uint32 *wp, int n); +static void swap64(char *wp, int n); + + +static double +rgb_bright( + COLOR clr +) { return(bright(clr)); } -double -xyz_bright(clr) -COLOR clr; +static double +xyz_bright( + COLOR clr +) { return(clr[CIEY]); } -double (*mybright)() = &rgb_bright; - - -main(argc, argv) -int argc; -char **argv; +int +main( + int argc, + char **argv +) { - extern int checkhead(); - extern long atol(); double d, expval = 1.0; int i; progname = argv[0]; + mybright = &rgb_bright; /* default */ for (i = 1; i < argc; i++) if (argv[i][0] == '-' || argv[i][0] == '+') @@ -178,11 +181,15 @@ char **argv; format = 'w'; fmtid = "16-bit"; break; + case 'F': /* swapped floats */ + swapbytes = 1; case 'f': /* float */ dataonly = 1; format = 'f'; fmtid = "float"; break; + case 'D': /* swapped doubles */ + swapbytes = 1; case 'd': /* double */ dataonly = 1; format = 'd'; @@ -218,16 +225,18 @@ unkopt: else break; /* recognize special formats */ - if (dataonly && format == 'b') - if (brightonly) - fmtid = "8-bit_grey"; - else + if (dataonly && format == 'b') { + if (putprim == ALL) fmtid = "24-bit_rgb"; - if (dataonly && format == 'w') - if (brightonly) - fmtid = "16-bit_grey"; else + fmtid = "8-bit_grey"; + } + if (dataonly && format == 'w') { + if (putprim == ALL) fmtid = "48-bit_rgb"; + else + fmtid = "16-bit_grey"; + } /* assign reverse ordering */ rord[ord[0]] = 0; rord[ord[1]] = 1; @@ -241,7 +250,7 @@ unkopt: progname, argv[i]); quit(1); } - if (reverse && !brightonly && i == argc-3) { + if (reverse && putprim != BRIGHT && i == argc-3) { if ((fin2 = fopen(argv[i+1], "r")) == NULL) { fprintf(stderr, "%s: can't open file \"%s\"\n", progname, argv[i+1]); @@ -255,7 +264,7 @@ unkopt: interleave = -1; } else if (i != argc-1) fin = NULL; - if (reverse && !brightonly && !interleave) { + if (reverse && putprim != BRIGHT && !interleave) { fin2 = fopen(argv[i], "r"); fin3 = fopen(argv[i], "r"); } @@ -273,10 +282,10 @@ unkopt: } if (reverse) { -#ifdef MSDOS - setmode(fileno(stdout), O_BINARY); +#ifdef _WIN32 + SET_FILE_BINARY(stdout); if (format != 'a' && format != 'i') - setmode(fileno(fin), O_BINARY); + SET_FILE_BINARY(fin); #endif /* get header */ if (header) { @@ -321,10 +330,10 @@ unkopt: fputsresolu(&picres, stdout); /* always put resolution */ valtopix(); } else { -#ifdef MSDOS - setmode(fileno(fin), O_BINARY); +#ifdef _WIN32 + SET_FILE_BINARY(fin); if (format != 'a' && format != 'i') - setmode(fileno(stdout), O_BINARY); + SET_FILE_BINARY(stdout); #endif /* get header */ getheader(fin, checkhead, NULL); @@ -351,31 +360,31 @@ unkopt: } quit(0); + return 0; /* pro forma return */ } -int -checkhead(line) /* deal with line from header */ -char *line; +static int +checkhead( /* deal with line from header */ + char *line, + void *p +) { char fmt[32]; double d; COLOR ctmp; if (formatval(fmt, line)) { - if (!strcmp(fmt, CIEFMT)) { + if (!strcmp(fmt, CIEFMT)) mybright = &xyz_bright; - if (original) { - scalecolor(exposure, 1./WHTEFFICACY); - doexposure++; - } - } else if (!strcmp(fmt, COLRFMT)) + else if (!strcmp(fmt, COLRFMT)) mybright = &rgb_bright; else wrongformat++; } else if (original && isexpos(line)) { d = 1.0/exposval(line); scalecolor(exposure, d); +fprintf(stderr, "scaled exposure by %f, now at %f\n", d, bright(exposure)); doexposure++; } else if (original && iscolcor(line)) { colcorval(ctmp, line); @@ -389,12 +398,13 @@ char *line; } -pixtoval() /* convert picture to values */ +static void +pixtoval(void) /* convert picture to values */ { register COLOR *scanln; int dogamma; COLOR lastc; - FLOAT hv[2]; + RREAL hv[2]; int startprim, endprim; long startpos; int y; @@ -426,7 +436,7 @@ pixtoval() /* convert picture to values */ quit(1); } for (x = 0; x < scanlen(&picres); x++) { - if (uniq) + if (uniq) { if ( colval(scanln[x],RED) == colval(lastc,RED) && colval(scanln[x],GRN) == @@ -436,6 +446,7 @@ pixtoval() /* convert picture to values */ continue; else copycolor(lastc, scanln[x]); + } if (doexposure) multcolor(scanln[x], exposure); if (dogamma) @@ -461,7 +472,8 @@ pixtoval() /* convert picture to values */ } -valtopix() /* convert values to a pixel file */ +static void +valtopix(void) /* convert values to a pixel file */ { int dogamma; register COLOR *scanln; @@ -513,9 +525,11 @@ int code; } -swap16(wp, n) /* swap n 16-bit words */ -register uint16 *wp; -int n; +static void +swap16( /* swap n 16-bit words */ + register uint16 *wp, + int n +) { while (n-- > 0) { *wp = *wp << 8 | ((*wp >> 8) & 0xff); @@ -523,9 +537,44 @@ int n; } } -getcascii(col) /* get an ascii color value from stream(s) */ -COLOR col; + +static void +swap32( /* swap n 32-bit words */ + register uint32 *wp, + int n +) { + while (n-- > 0) { + *wp = *wp << 24 | ((*wp >> 24) & 0xff) | + (*wp & 0xff00) << 8 | (*wp & 0xff0000) >> 8; + wp++; + } +} + + +static void +swap64( /* swap n 64-bit words */ + register char *wp, + int n +) +{ + register int t; + + while (n-- > 0) { + t = wp[0]; wp[0] = wp[7]; wp[7] = t; + t = wp[1]; wp[1] = wp[6]; wp[6] = t; + t = wp[2]; wp[2] = wp[5]; wp[5] = t; + t = wp[3]; wp[3] = wp[4]; wp[4] = t; + wp += 8; + } +} + + +static int +getcascii( /* get an ascii color value from stream(s) */ + COLOR col +) +{ double vd[3]; if (fin2 == NULL) { @@ -542,8 +591,10 @@ COLOR col; } -getcdouble(col) /* get a double color value from stream(s) */ -COLOR col; +static int +getcdouble( /* get a double color value from stream(s) */ + COLOR col +) { double vd[3]; @@ -556,13 +607,17 @@ COLOR col; fread((char *)(vd+2), sizeof(double), 1, fin3) != 1) return(-1); } + if (swapbytes) + swap64((char *)vd, 3); setcolor(col, vd[rord[RED]], vd[rord[GRN]], vd[rord[BLU]]); return(0); } -getcfloat(col) /* get a float color value from stream(s) */ -COLOR col; +static int +getcfloat( /* get a float color value from stream(s) */ + COLOR col +) { float vf[3]; @@ -575,13 +630,17 @@ COLOR col; fread((char *)(vf+2), sizeof(float), 1, fin3) != 1) return(-1); } + if (swapbytes) + swap32((uint32 *)vf, 3); setcolor(col, vf[rord[RED]], vf[rord[GRN]], vf[rord[BLU]]); return(0); } -getcint(col) /* get an int color value from stream(s) */ -COLOR col; +static int +getcint( /* get an int color value from stream(s) */ + COLOR col +) { int vi[3]; @@ -600,8 +659,10 @@ COLOR col; } -getcbyte(col) /* get a byte color value from stream(s) */ -COLOR col; +static int +getcbyte( /* get a byte color value from stream(s) */ + COLOR col +) { BYTE vb[3]; @@ -620,8 +681,10 @@ COLOR col; } -getcword(col) /* get a 16-bit color value from stream(s) */ -COLOR col; +static int +getcword( /* get a 16-bit color value from stream(s) */ + COLOR col +) { uint16 vw[3]; @@ -642,8 +705,10 @@ COLOR col; } -getbascii(col) /* get an ascii brightness value from fin */ -COLOR col; +static int +getbascii( /* get an ascii brightness value from fin */ + COLOR col +) { double vd; @@ -654,32 +719,42 @@ COLOR col; } -getbdouble(col) /* get a double brightness value from fin */ -COLOR col; +static int +getbdouble( /* get a double brightness value from fin */ + COLOR col +) { double vd; if (fread((char *)&vd, sizeof(double), 1, fin) != 1) return(-1); + if (swapbytes) + swap64((char *)&vd, 1); setcolor(col, vd, vd, vd); return(0); } -getbfloat(col) /* get a float brightness value from fin */ -COLOR col; +static int +getbfloat( /* get a float brightness value from fin */ + COLOR col +) { float vf; if (fread((char *)&vf, sizeof(float), 1, fin) != 1) return(-1); + if (swapbytes) + swap32((uint32 *)&vf, 1); setcolor(col, vf, vf, vf); return(0); } -getbint(col) /* get an int brightness value from fin */ -COLOR col; +static int +getbint( /* get an int brightness value from fin */ + COLOR col +) { int vi; double d; @@ -692,8 +767,10 @@ COLOR col; } -getbbyte(col) /* get a byte brightness value from fin */ -COLOR col; +static int +getbbyte( /* get a byte brightness value from fin */ + COLOR col +) { BYTE vb; double d; @@ -706,8 +783,10 @@ COLOR col; } -getbword(col) /* get a 16-bit brightness value from fin */ -COLOR col; +static int +getbword( /* get a 16-bit brightness value from fin */ + COLOR col +) { uint16 vw; double d; @@ -722,8 +801,10 @@ COLOR col; } -putcascii(col) /* put an ascii color to stdout */ -COLOR col; +static int +putcascii( /* put an ascii color to stdout */ + COLOR col +) { fprintf(stdout, "%15.3e %15.3e %15.3e\n", colval(col,ord[0]), @@ -734,36 +815,46 @@ COLOR col; } -putcfloat(col) /* put a float color to stdout */ -COLOR col; +static int +putcfloat( /* put a float color to stdout */ + COLOR col +) { float vf[3]; vf[0] = colval(col,ord[0]); vf[1] = colval(col,ord[1]); vf[2] = colval(col,ord[2]); + if (swapbytes) + swap32((uint32 *)vf, 3); fwrite((char *)vf, sizeof(float), 3, stdout); return(ferror(stdout) ? -1 : 0); } -putcdouble(col) /* put a double color to stdout */ -COLOR col; +static int +putcdouble( /* put a double color to stdout */ + COLOR col +) { double vd[3]; vd[0] = colval(col,ord[0]); vd[1] = colval(col,ord[1]); vd[2] = colval(col,ord[2]); + if (swapbytes) + swap64((char *)vd, 3); fwrite((char *)vd, sizeof(double), 3, stdout); return(ferror(stdout) ? -1 : 0); } -putcint(col) /* put an int color to stdout */ -COLOR col; +static int +putcint( /* put an int color to stdout */ + COLOR col +) { fprintf(stdout, "%d %d %d\n", (int)(colval(col,ord[0])*256.), @@ -774,8 +865,10 @@ COLOR col; } -putcbyte(col) /* put a byte color to stdout */ -COLOR col; +static int +putcbyte( /* put a byte color to stdout */ + COLOR col +) { long i; BYTE vb[3]; @@ -792,8 +885,10 @@ COLOR col; } -putcword(col) /* put a 16-bit color to stdout */ -COLOR col; +static int +putcword( /* put a 16-bit color to stdout */ + COLOR col +) { long i; uint16 vw[3]; @@ -812,8 +907,10 @@ COLOR col; } -putbascii(col) /* put an ascii brightness to stdout */ -COLOR col; +static int +putbascii( /* put an ascii brightness to stdout */ + COLOR col +) { fprintf(stdout, "%15.3e\n", (*mybright)(col)); @@ -821,32 +918,42 @@ COLOR col; } -putbfloat(col) /* put a float brightness to stdout */ -COLOR col; +static int +putbfloat( /* put a float brightness to stdout */ + COLOR col +) { float vf; vf = (*mybright)(col); + if (swapbytes) + swap32((uint32 *)&vf, 1); fwrite((char *)&vf, sizeof(float), 1, stdout); return(ferror(stdout) ? -1 : 0); } -putbdouble(col) /* put a double brightness to stdout */ -COLOR col; +static int +putbdouble( /* put a double brightness to stdout */ + COLOR col +) { double vd; vd = (*mybright)(col); + if (swapbytes) + swap64((char *)&vd, 1); fwrite((char *)&vd, sizeof(double), 1, stdout); return(ferror(stdout) ? -1 : 0); } -putbint(col) /* put an int brightness to stdout */ -COLOR col; +static int +putbint( /* put an int brightness to stdout */ + COLOR col +) { fprintf(stdout, "%d\n", (int)((*mybright)(col)*256.)); @@ -854,8 +961,10 @@ COLOR col; } -putbbyte(col) /* put a byte brightness to stdout */ -COLOR col; +static int +putbbyte( /* put a byte brightness to stdout */ + COLOR col +) { register int i; BYTE vb; @@ -868,8 +977,10 @@ COLOR col; } -putbword(col) /* put a 16-bit brightness to stdout */ -COLOR col; +static int +putbword( /* put a 16-bit brightness to stdout */ + COLOR col +) { long i; uint16 vw; @@ -884,8 +995,10 @@ COLOR col; } -putpascii(col) /* put an ascii primary to stdout */ -COLOR col; +static int +putpascii( /* put an ascii primary to stdout */ + COLOR col +) { fprintf(stdout, "%15.3e\n", colval(col,putprim)); @@ -893,32 +1006,42 @@ COLOR col; } -putpfloat(col) /* put a float primary to stdout */ -COLOR col; +static int +putpfloat( /* put a float primary to stdout */ + COLOR col +) { float vf; vf = colval(col,putprim); + if (swapbytes) + swap32((uint32 *)&vf, 1); fwrite((char *)&vf, sizeof(float), 1, stdout); return(ferror(stdout) ? -1 : 0); } -putpdouble(col) /* put a double primary to stdout */ -COLOR col; +static int +putpdouble( /* put a double primary to stdout */ + COLOR col +) { double vd; vd = colval(col,putprim); + if (swapbytes) + swap64((char *)&vd, 1); fwrite((char *)&vd, sizeof(double), 1, stdout); return(ferror(stdout) ? -1 : 0); } -putpint(col) /* put an int primary to stdout */ -COLOR col; +static int +putpint( /* put an int primary to stdout */ + COLOR col +) { fprintf(stdout, "%d\n", (int)(colval(col,putprim)*256.)); @@ -926,8 +1049,10 @@ COLOR col; } -putpbyte(col) /* put a byte primary to stdout */ -COLOR col; +static int +putpbyte( /* put a byte primary to stdout */ + COLOR col +) { long i; BYTE vb; @@ -940,8 +1065,10 @@ COLOR col; } -putpword(col) /* put a 16-bit primary to stdout */ -COLOR col; +static int +putpword( /* put a 16-bit primary to stdout */ + COLOR col +) { long i; uint16 vw; @@ -956,7 +1083,8 @@ COLOR col; } -set_io() /* set put and get functions */ +static void +set_io(void) /* set put and get functions */ { switch (format) { case 'a': /* ascii */ @@ -1084,7 +1212,7 @@ set_io() /* set put and get functions */ } return; } -badopt: +/* badopt: */ /* label not used */ fprintf(stderr, "%s: botched file type\n", progname); quit(1); namerr:
