--- ray/src/px/pvalue.c 1990/01/18 23:58:17 1.4 +++ ray/src/px/pvalue.c 2003/02/25 16:22:05 2.15 @@ -1,97 +1,208 @@ -/* Copyright (c) 1986 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: pvalue.c,v 2.15 2003/02/25 16:22:05 greg Exp $"; #endif - /* * pvalue.c - program to print pixel values. * * 4/23/86 */ -#include +#include "standard.h" #include "color.h" -#define min(a,b) ((a)<(b)?(a):(b)) +#include -int xres = 0; /* resolution of input */ -int yres = 0; +#include "resolu.h" -int uniq = 0; /* unique values? */ +typedef unsigned short uint16; /* sizeof (uint16) must == 2 */ -int original = 0; /* original values? */ +#define min(a,b) ((a)<(b)?(a):(b)) + /* what to put out (also RED, GRN, BLU) */ +#define ALL 3 +#define BRIGHT 4 + +#define brightonly (putprim==BRIGHT) + +RESOLU picres; /* resolution of picture */ + +int uniq = 0; /* print only unique values? */ + +int doexposure = 0; /* exposure change? (>100 to print) */ + int dataonly = 0; /* data only format? */ -int brightonly = 0; /* only brightness values? */ +int putprim = ALL; /* what to put out */ int reverse = 0; /* reverse conversion? */ int format = 'a'; /* input/output format */ +char *fmtid = "ascii"; /* format identifier for header */ -int header = 1; /* do header */ +int header = 1; /* do header? */ -double exposure = 1.0; +long skipbytes = 0; /* skip bytes in input? */ +int interleave = 1; /* file is interleaved? */ + +int resolution = 1; /* put/get resolution string? */ + +int original = 0; /* convert to original values? */ + +int wrongformat = 0; /* wrong input format? */ + +double gamcor = 1.0; /* gamma correction */ + +int ord[3] = {RED, GRN, BLU}; /* RGB ordering */ +int rord[4]; /* reverse ordering */ + +COLOR exposure = WHTCOLOR; + char *progname; FILE *fin; +FILE *fin2 = NULL, *fin3 = NULL; /* for other color channels */ int (*getval)(), (*putval)(); +double +rgb_bright(clr) +COLOR clr; +{ + return(bright(clr)); +} +double +xyz_bright(clr) +COLOR clr; +{ + return(clr[CIEY]); +} + +double (*mybright)() = &rgb_bright; + + main(argc, argv) int argc; char **argv; { - extern double atof(); extern int checkhead(); + extern long atol(); + double d, expval = 1.0; int i; progname = argv[0]; for (i = 1; i < argc; i++) - if (argv[i][0] == '-') + if (argv[i][0] == '-' || argv[i][0] == '+') switch (argv[i][1]) { - case 'h': /* no header */ - header = 0; + case 'h': /* header */ + header = argv[i][0] == '+'; break; + case 'H': /* resolution string */ + resolution = argv[i][0] == '+'; + break; + case 's': /* skip bytes in header */ + skipbytes = atol(argv[++i]); + break; case 'u': /* unique values */ - uniq = 1; + uniq = argv[i][0] == '-'; break; case 'o': /* original values */ - original = 1; + original = argv[i][0] == '-'; break; + case 'g': /* gamma correction */ + gamcor = atof(argv[i+1]); + if (argv[i][0] == '+') + gamcor = 1.0/gamcor; + i++; + break; + case 'e': /* exposure correction */ + d = atof(argv[i+1]); + if (argv[i+1][0] == '-' || argv[i+1][0] == '+') + d = pow(2.0, d); + if (argv[i][0] == '-') + expval *= d; + scalecolor(exposure, d); + doexposure++; + i++; + break; + case 'R': /* reverse byte sequence */ + if (argv[i][0] == '-') { + ord[0]=BLU; ord[1]=GRN; ord[2]=RED; + } else { + ord[0]=RED; ord[1]=GRN; ord[2]=BLU; + } + break; case 'r': /* reverse conversion */ - reverse = 1; + reverse = argv[i][0] == '-'; break; + case 'n': /* non-interleaved RGB */ + interleave = argv[i][0] == '+'; + break; case 'b': /* brightness values */ - brightonly = 1; + putprim = argv[i][0] == '-' ? BRIGHT : ALL; break; + case 'p': /* put primary */ + switch (argv[i][2]) { + case 'r': case 'R': putprim = RED; break; + case 'g': case 'G': putprim = GRN; break; + case 'b': case 'B': putprim = BLU; break; + default: goto unkopt; + } + break; case 'd': /* data only (no indices) */ - dataonly = 1; + dataonly = argv[i][0] == '-'; switch (argv[i][2]) { case '\0': case 'a': /* ascii */ format = 'a'; + fmtid = "ascii"; break; case 'i': /* integer */ + format = 'i'; + fmtid = "ascii"; + break; case 'b': /* byte */ + dataonly = 1; + format = 'b'; + fmtid = "byte"; + break; + case 'w': /* 16-bit */ + dataonly = 1; + format = 'w'; + fmtid = "16-bit"; + break; case 'f': /* float */ + dataonly = 1; + format = 'f'; + fmtid = "float"; + break; case 'd': /* double */ - format = argv[i][2]; + dataonly = 1; + format = 'd'; + fmtid = "double"; break; default: goto unkopt; } break; case 'x': /* x resolution */ - xres = atoi(argv[++i]); + case 'X': /* x resolution */ + resolution = 0; + if (argv[i][0] == '-') + picres.rt |= XDECR; + picres.xr = atoi(argv[++i]); break; case 'y': /* y resolution */ - yres = atoi(argv[++i]); + case 'Y': /* y resolution */ + resolution = 0; + if (argv[i][0] == '-') + picres.rt |= YDECR; + if (picres.xr == 0) + picres.rt |= YMAJOR; + picres.yr = atoi(argv[++i]); break; default: unkopt: @@ -102,50 +213,136 @@ unkopt: } else break; - + /* recognize special formats */ + if (dataonly && format == 'b') + if (brightonly) + fmtid = "8-bit_grey"; + else + fmtid = "24-bit_rgb"; + if (dataonly && format == 'w') + if (brightonly) + fmtid = "16-bit_grey"; + else + fmtid = "48-bit_rgb"; + /* assign reverse ordering */ + rord[ord[0]] = 0; + rord[ord[1]] = 1; + rord[ord[2]] = 2; + /* get input */ if (i == argc) { fin = stdin; - } else if (i == argc-1) { + } else if (i < argc) { if ((fin = fopen(argv[i], "r")) == NULL) { fprintf(stderr, "%s: can't open file \"%s\"\n", progname, argv[i]); quit(1); } - } else { + if (reverse && !brightonly && i == argc-3) { + if ((fin2 = fopen(argv[i+1], "r")) == NULL) { + fprintf(stderr, "%s: can't open file \"%s\"\n", + progname, argv[i+1]); + quit(1); + } + if ((fin3 = fopen(argv[i+2], "r")) == NULL) { + fprintf(stderr, "%s: can't open file \"%s\"\n", + progname, argv[i+2]); + quit(1); + } + interleave = -1; + } else if (i != argc-1) + fin = NULL; + if (reverse && !brightonly && !interleave) { + fin2 = fopen(argv[i], "r"); + fin3 = fopen(argv[i], "r"); + } + if (skipbytes && (fseek(fin, skipbytes, 0) || (fin2 != NULL && + (fseek(fin2, skipbytes, 0) || + fseek(fin3, skipbytes, 0))))) { + fprintf(stderr, "%s: cannot skip %ld bytes on input\n", + progname, skipbytes); + quit(1); + } + } + if (fin == NULL) { fprintf(stderr, "%s: bad # file arguments\n", progname); quit(1); } - set_io(); - if (reverse) { - if (header) /* get header */ - copyheader(fin, stdout); - /* add to header */ - printargs(i, argv, stdout); - printf("\n"); - if (yres <= 0 || xres <= 0) { - fprintf(stderr, "%s: missing x and y resolution\n", - progname); +#ifdef MSDOS + setmode(fileno(stdout), O_BINARY); + if (format != 'a' && format != 'i') + setmode(fileno(fin), O_BINARY); +#endif + /* get header */ + if (header) { + if (checkheader(fin, fmtid, stdout) < 0) { + fprintf(stderr, "%s: wrong input format\n", + progname); + quit(1); + } + if (fin2 != NULL) { + getheader(fin2, NULL, NULL); + getheader(fin3, NULL, NULL); + } + } else + newheader("RADIANCE", stdout); + /* get resolution */ + if ((resolution && !fgetsresolu(&picres, fin)) || + picres.xr <= 0 || picres.yr <= 0) { + fprintf(stderr, "%s: missing resolution\n", progname); quit(1); } - fputresolu(YMAJOR|YDECR, xres, yres, stdout); - valtopix(); - } else { - /* get header */ - getheader(fin, checkhead); - - if (xres <= 0 || yres <= 0) /* get picture size */ - if (fgetresolu(&xres, &yres, fin) != (YMAJOR|YDECR)) { - fprintf(stderr, - "%s: missing x and y resolution\n", + if (resolution && fin2 != NULL) { + RESOLU pres2; + if (!fgetsresolu(&pres2, fin2) || + pres2.rt != picres.rt || + pres2.xr != picres.xr || + pres2.yr != picres.yr || + !fgetsresolu(&pres2, fin3) || + pres2.rt != picres.rt || + pres2.xr != picres.xr || + pres2.yr != picres.yr) { + fprintf(stderr, "%s: resolution mismatch\n", progname); quit(1); } + } + /* add to header */ + printargs(i, argv, stdout); + if (expval < .99 || expval > 1.01) + fputexpos(expval, stdout); + fputformat(COLRFMT, stdout); + putchar('\n'); + fputsresolu(&picres, stdout); /* always put resolution */ + valtopix(); + } else { +#ifdef MSDOS + setmode(fileno(fin), O_BINARY); + if (format != 'a' && format != 'i') + setmode(fileno(stdout), O_BINARY); +#endif + /* get header */ + getheader(fin, checkhead, NULL); + if (wrongformat) { + fprintf(stderr, + "%s: input not a Radiance RGBE picture\n", + progname); + quit(1); + } + if (!fgetsresolu(&picres, fin)) { + fprintf(stderr, "%s: missing resolution\n", progname); + quit(1); + } if (header) { printargs(i, argv, stdout); - printf("\n"); + if (expval < .99 || expval > 1.01) + fputexpos(expval, stdout); + fputformat(fmtid, stdout); + putchar('\n'); } + if (resolution) /* put resolution */ + fputsresolu(&picres, stdout); pixtoval(); } @@ -153,86 +350,158 @@ unkopt: } +int checkhead(line) /* deal with line from header */ char *line; { - if (header) + char fmt[32]; + double d; + COLOR ctmp; + + if (formatval(fmt, line)) { + if (!strcmp(fmt, CIEFMT)) { + mybright = &xyz_bright; + if (original) { + scalecolor(exposure, 1./WHTEFFICACY); + doexposure++; + } + } else if (!strcmp(fmt, COLRFMT)) + mybright = &rgb_bright; + else + wrongformat++; + } else if (original && isexpos(line)) { + d = 1.0/exposval(line); + scalecolor(exposure, d); + doexposure++; + } else if (original && iscolcor(line)) { + colcorval(ctmp, line); + setcolor(exposure, colval(exposure,RED)/colval(ctmp,RED), + colval(exposure,GRN)/colval(ctmp,GRN), + colval(exposure,BLU)/colval(ctmp,BLU)); + doexposure++; + } else if (header) fputs(line, stdout); - if (isexpos(line)) - exposure *= exposval(line); + return(0); } pixtoval() /* convert picture to values */ { - COLOR *scanln; + register COLOR *scanln; + int dogamma; COLOR lastc; + FLOAT hv[2]; + int startprim, endprim; + long startpos; int y; register int x; - scanln = (COLOR *)malloc(xres*sizeof(COLOR)); + scanln = (COLOR *)malloc(scanlen(&picres)*sizeof(COLOR)); if (scanln == NULL) { fprintf(stderr, "%s: out of memory\n", progname); quit(1); } - setcolor(lastc, 0.0, 0.0, 0.0); - for (y = yres-1; y >= 0; y--) { - if (freadscan(scanln, xres, fin) < 0) { - fprintf(stderr, "%s: read error\n", progname); + dogamma = gamcor < .95 || gamcor > 1.05; + if (putprim == ALL && !interleave) { + startprim = RED; endprim = BLU; + startpos = ftell(fin); + } else { + startprim = putprim; endprim = putprim; + } + for (putprim = startprim; putprim <= endprim; putprim++) { + if (putprim != startprim && fseek(fin, startpos, 0)) { + fprintf(stderr, "%s: seek error on input file\n", + progname); quit(1); } - for (x = 0; x < xres; x++) { - if (uniq) - if ( scanln[x][RED] == lastc[RED] && - scanln[x][GRN] == lastc[GRN] && - scanln[x][BLU] == lastc[BLU] ) - continue; - else - copycolor(lastc, scanln[x]); - if (original) - scalecolor(scanln[x], 1.0/exposure); - if (!dataonly) - printf("%7d %7d ", x, y); - if ((*putval)(scanln[x], stdout) < 0) { - fprintf(stderr, "%s: write error\n", progname); + set_io(); + setcolor(lastc, 0.0, 0.0, 0.0); + for (y = 0; y < numscans(&picres); y++) { + if (freadscan(scanln, scanlen(&picres), fin) < 0) { + fprintf(stderr, "%s: read error\n", progname); quit(1); } + for (x = 0; x < scanlen(&picres); x++) { + if (uniq) + if ( colval(scanln[x],RED) == + colval(lastc,RED) && + colval(scanln[x],GRN) == + colval(lastc,GRN) && + colval(scanln[x],BLU) == + colval(lastc,BLU) ) + continue; + else + copycolor(lastc, scanln[x]); + if (doexposure) + multcolor(scanln[x], exposure); + if (dogamma) + setcolor(scanln[x], + pow(colval(scanln[x],RED), 1.0/gamcor), + pow(colval(scanln[x],GRN), 1.0/gamcor), + pow(colval(scanln[x],BLU), 1.0/gamcor)); + if (!dataonly) { + pix2loc(hv, &picres, x, y); + printf("%7d %7d ", + (int)(hv[0]*picres.xr), + (int)(hv[1]*picres.yr)); + } + if ((*putval)(scanln[x]) < 0) { + fprintf(stderr, "%s: write error\n", + progname); + quit(1); + } + } } } - free((char *)scanln); + free((void *)scanln); } valtopix() /* convert values to a pixel file */ { - COLOR *scanln; + int dogamma; + register COLOR *scanln; int y; register int x; - scanln = (COLOR *)malloc(xres*sizeof(COLOR)); + scanln = (COLOR *)malloc(scanlen(&picres)*sizeof(COLOR)); if (scanln == NULL) { fprintf(stderr, "%s: out of memory\n", progname); quit(1); } - for (y = yres-1; y >= 0; y--) { - for (x = 0; x < xres; x++) { - if (!dataonly) + dogamma = gamcor < .95 || gamcor > 1.05; + set_io(); + for (y = 0; y < numscans(&picres); y++) { + for (x = 0; x < scanlen(&picres); x++) { + if (!dataonly) { fscanf(fin, "%*d %*d"); - if ((*getval)(scanln[x], fin) < 0) { + if (fin2 != NULL) { + fscanf(fin2, "%*d %*d"); + fscanf(fin3, "%*d %*d"); + } + } + if ((*getval)(scanln[x]) < 0) { fprintf(stderr, "%s: read error\n", progname); quit(1); } + if (dogamma) + setcolor(scanln[x], + pow(colval(scanln[x],RED), gamcor), + pow(colval(scanln[x],GRN), gamcor), + pow(colval(scanln[x],BLU), gamcor)); + if (doexposure) + multcolor(scanln[x], exposure); } - if (fwritescan(scanln, xres, stdout) < 0 - || fflush(stdout) < 0) { + if (fwritescan(scanln, scanlen(&picres), stdout) < 0) { fprintf(stderr, "%s: write error\n", progname); quit(1); } } - free((char *)scanln); + free((void *)scanln); } +void quit(code) int code; { @@ -240,118 +509,166 @@ int code; } -getcascii(col, fp) /* get an ascii color value from fp */ +getcascii(col) /* get an ascii color value from stream(s) */ COLOR col; -FILE *fp; { - double vd[3]; + double vd[3]; - if (fscanf(fp, "%lf %lf %lf", &vd[0], &vd[1], &vd[2]) != 3) - return(-1); - setcolor(col, vd[0], vd[1], vd[2]); + if (fin2 == NULL) { + if (fscanf(fin, "%lf %lf %lf", &vd[0], &vd[1], &vd[2]) != 3) + return(-1); + } else { + if (fscanf(fin, "%lf", &vd[0]) != 1 || + fscanf(fin2, "%lf", &vd[1]) != 1 || + fscanf(fin3, "%lf", &vd[2]) != 1) + return(-1); + } + setcolor(col, vd[rord[RED]], vd[rord[GRN]], vd[rord[BLU]]); return(0); } -getcdouble(col, fp) /* get a double color value from fp */ +getcdouble(col) /* get a double color value from stream(s) */ COLOR col; -FILE *fp; { - double vd[3]; + double vd[3]; - if (fread((char *)vd, sizeof(double), 3, fp) != 3) - return(-1); - setcolor(col, vd[0], vd[1], vd[2]); + if (fin2 == NULL) { + if (fread((char *)vd, sizeof(double), 3, fin) != 3) + return(-1); + } else { + if (fread((char *)vd, sizeof(double), 1, fin) != 1 || + fread((char *)(vd+1), sizeof(double), 1, fin2) != 1 || + fread((char *)(vd+2), sizeof(double), 1, fin3) != 1) + return(-1); + } + setcolor(col, vd[rord[RED]], vd[rord[GRN]], vd[rord[BLU]]); return(0); } -getcfloat(col, fp) /* get a float color value from fp */ +getcfloat(col) /* get a float color value from stream(s) */ COLOR col; -FILE *fp; { float vf[3]; - if (fread((char *)vf, sizeof(float), 3, fp) != 3) - return(-1); - setcolor(col, vf[0], vf[1], vf[2]); + if (fin2 == NULL) { + if (fread((char *)vf, sizeof(float), 3, fin) != 3) + return(-1); + } else { + if (fread((char *)vf, sizeof(float), 1, fin) != 1 || + fread((char *)(vf+1), sizeof(float), 1, fin2) != 1 || + fread((char *)(vf+2), sizeof(float), 1, fin3) != 1) + return(-1); + } + setcolor(col, vf[rord[RED]], vf[rord[GRN]], vf[rord[BLU]]); return(0); } -getcint(col, fp) /* get an int color value from fp */ +getcint(col) /* get an int color value from stream(s) */ COLOR col; -FILE *fp; { int vi[3]; - if (fscanf(fp, "%d %d %d", &vi[0], &vi[1], &vi[2]) != 3) - return(-1); - setcolor(col,(vi[0]+.5)/256.,(vi[1]+.5)/256.,(vi[2]+.5)/256.); + if (fin2 == NULL) { + if (fscanf(fin, "%d %d %d", &vi[0], &vi[1], &vi[2]) != 3) + return(-1); + } else { + if (fscanf(fin, "%d", &vi[0]) != 1 || + fscanf(fin2, "%d", &vi[1]) != 1 || + fscanf(fin3, "%d", &vi[2]) != 1) + return(-1); + } + setcolor(col, (vi[rord[RED]]+.5)/256., + (vi[rord[GRN]]+.5)/256., (vi[rord[BLU]]+.5)/256.); return(0); } -getcbyte(col, fp) /* get a byte color value from fp */ +getcbyte(col) /* get a byte color value from stream(s) */ COLOR col; -FILE *fp; { BYTE vb[3]; - if (fread((char *)vb, sizeof(BYTE), 3, fp) != 3) - return(-1); - setcolor(col,(vb[0]+.5)/256.,(vb[1]+.5)/256.,(vb[2]+.5)/256.); + if (fin2 == NULL) { + if (fread((char *)vb, sizeof(BYTE), 3, fin) != 3) + return(-1); + } else { + if (fread((char *)vb, sizeof(BYTE), 1, fin) != 1 || + fread((char *)(vb+1), sizeof(BYTE), 1, fin2) != 1 || + fread((char *)(vb+2), sizeof(BYTE), 1, fin3) != 1) + return(-1); + } + setcolor(col, (vb[rord[RED]]+.5)/256., + (vb[rord[GRN]]+.5)/256., (vb[rord[BLU]]+.5)/256.); return(0); } -getbascii(col, fp) /* get an ascii brightness value from fp */ +getcword(col) /* get a 16-bit color value from stream(s) */ COLOR col; -FILE *fp; { - double vd; + uint16 vw[3]; - if (fscanf(fp, "%lf", &vd) != 1) + if (fin2 == NULL) { + if (fread((char *)vw, sizeof(uint16), 3, fin) != 3) + return(-1); + } else { + if (fread((char *)vw, sizeof(uint16), 1, fin) != 1 || + fread((char *)(vw+1), sizeof(uint16), 1, fin2) != 1 || + fread((char *)(vw+2), sizeof(uint16), 1, fin3) != 1) + return(-1); + } + setcolor(col, (vw[rord[RED]]+.5)/65536., + (vw[rord[GRN]]+.5)/65536., (vw[rord[BLU]]+.5)/65536.); + return(0); +} + + +getbascii(col) /* get an ascii brightness value from fin */ +COLOR col; +{ + double vd; + + if (fscanf(fin, "%lf", &vd) != 1) return(-1); setcolor(col, vd, vd, vd); return(0); } -getbdouble(col, fp) /* get a double brightness value from fp */ +getbdouble(col) /* get a double brightness value from fin */ COLOR col; -FILE *fp; { - double vd; + double vd; - if (fread((char *)&vd, sizeof(double), 1, fp) != 1) + if (fread((char *)&vd, sizeof(double), 1, fin) != 1) return(-1); setcolor(col, vd, vd, vd); return(0); } -getbfloat(col, fp) /* get a float brightness value from fp */ +getbfloat(col) /* get a float brightness value from fin */ COLOR col; -FILE *fp; { float vf; - if (fread((char *)&vf, sizeof(float), 1, fp) != 1) + if (fread((char *)&vf, sizeof(float), 1, fin) != 1) return(-1); setcolor(col, vf, vf, vf); return(0); } -getbint(col, fp) /* get an int brightness value from fp */ +getbint(col) /* get an int brightness value from fin */ COLOR col; -FILE *fp; { int vi; - double d; + double d; - if (fscanf(fp, "%d", &vi) != 1) + if (fscanf(fin, "%d", &vi) != 1) return(-1); d = (vi+.5)/256.; setcolor(col, d, d, d); @@ -359,14 +676,13 @@ FILE *fp; } -getbbyte(col, fp) /* get a byte brightness value from fp */ +getbbyte(col) /* get a byte brightness value from fin */ COLOR col; -FILE *fp; { BYTE vb; - double d; + double d; - if (fread((char *)&vb, sizeof(BYTE), 1, fp) != 1) + if (fread((char *)&vb, sizeof(BYTE), 1, fin) != 1) return(-1); d = (vb+.5)/256.; setcolor(col, d, d, d); @@ -374,189 +690,385 @@ FILE *fp; } -putcascii(col, fp) /* put an ascii color to fp */ +getbword(col) /* get a 16-bit brightness value from fin */ COLOR col; -FILE *fp; { - fprintf(fp, "%15.3e %15.3e %15.3e\n", - colval(col,RED), - colval(col,GRN), - colval(col,BLU)); + uint16 vw; + double d; - return(ferror(fp) ? -1 : 0); + if (fread((char *)&vw, sizeof(uint16), 1, fin) != 1) + return(-1); + d = (vw+.5)/65536.; + setcolor(col, d, d, d); + return(0); } -putcfloat(col, fp) /* put a float color to fp */ +putcascii(col) /* put an ascii color to stdout */ COLOR col; -FILE *fp; { + fprintf(stdout, "%15.3e %15.3e %15.3e\n", + colval(col,ord[0]), + colval(col,ord[1]), + colval(col,ord[2])); + + return(ferror(stdout) ? -1 : 0); +} + + +putcfloat(col) /* put a float color to stdout */ +COLOR col; +{ float vf[3]; - vf[0] = colval(col,RED); - vf[1] = colval(col,GRN); - vf[2] = colval(col,BLU); - fwrite((char *)vf, sizeof(float), 3, fp); + vf[0] = colval(col,ord[0]); + vf[1] = colval(col,ord[1]); + vf[2] = colval(col,ord[2]); + fwrite((char *)vf, sizeof(float), 3, stdout); - return(ferror(fp) ? -1 : 0); + return(ferror(stdout) ? -1 : 0); } -putcdouble(col, fp) /* put a double color to fp */ +putcdouble(col) /* put a double color to stdout */ COLOR col; -FILE *fp; { - double vd[3]; + double vd[3]; - vd[0] = colval(col,RED); - vd[1] = colval(col,GRN); - vd[2] = colval(col,BLU); - fwrite((char *)vd, sizeof(double), 3, fp); + vd[0] = colval(col,ord[0]); + vd[1] = colval(col,ord[1]); + vd[2] = colval(col,ord[2]); + fwrite((char *)vd, sizeof(double), 3, stdout); - return(ferror(fp) ? -1 : 0); + return(ferror(stdout) ? -1 : 0); } -putcint(col, fp) /* put an int color to fp */ +putcint(col) /* put an int color to stdout */ COLOR col; -FILE *fp; { - fprintf(fp, "%d %d %d\n", - (int)(colval(col,RED)*256.), - (int)(colval(col,GRN)*256.), - (int)(colval(col,BLU)*256.)); + fprintf(stdout, "%d %d %d\n", + (int)(colval(col,ord[0])*256.), + (int)(colval(col,ord[1])*256.), + (int)(colval(col,ord[2])*256.)); - return(ferror(fp) ? -1 : 0); + return(ferror(stdout) ? -1 : 0); } -putcbyte(col, fp) /* put a byte color to fp */ +putcbyte(col) /* put a byte color to stdout */ COLOR col; -FILE *fp; { - register int i; + long i; BYTE vb[3]; - i = colval(col,RED)*256.; + i = colval(col,ord[0])*256.; vb[0] = min(i,255); - i = colval(col,GRN)*256.; + i = colval(col,ord[1])*256.; vb[1] = min(i,255); - i = colval(col,BLU)*256.; + i = colval(col,ord[2])*256.; vb[2] = min(i,255); - fwrite((char *)vb, sizeof(BYTE), 3, fp); + fwrite((char *)vb, sizeof(BYTE), 3, stdout); - return(ferror(fp) ? -1 : 0); + return(ferror(stdout) ? -1 : 0); } -putbascii(col, fp) /* put an ascii brightness to fp */ +putcword(col) /* put a 16-bit color to stdout */ COLOR col; -FILE *fp; { - fprintf(fp, "%15.3e\n", bright(col)); + long i; + uint16 vw[3]; - return(ferror(fp) ? -1 : 0); + i = colval(col,ord[0])*65536.; + vw[0] = min(i,65535); + i = colval(col,ord[1])*65536.; + vw[1] = min(i,65535); + i = colval(col,ord[2])*65536.; + vw[2] = min(i,65535); + fwrite((char *)vw, sizeof(uint16), 3, stdout); + + return(ferror(stdout) ? -1 : 0); } -putbfloat(col, fp) /* put a float brightness to fp */ +putbascii(col) /* put an ascii brightness to stdout */ COLOR col; -FILE *fp; { + fprintf(stdout, "%15.3e\n", (*mybright)(col)); + + return(ferror(stdout) ? -1 : 0); +} + + +putbfloat(col) /* put a float brightness to stdout */ +COLOR col; +{ float vf; - vf = bright(col); - fwrite((char *)&vf, sizeof(float), 1, fp); + vf = (*mybright)(col); + fwrite((char *)&vf, sizeof(float), 1, stdout); - return(ferror(fp) ? -1 : 0); + return(ferror(stdout) ? -1 : 0); } -putbdouble(col, fp) /* put a double brightness to fp */ +putbdouble(col) /* put a double brightness to stdout */ COLOR col; -FILE *fp; { - double vd; + double vd; - vd = bright(col); - fwrite((char *)&vd, sizeof(double), 1, fp); + vd = (*mybright)(col); + fwrite((char *)&vd, sizeof(double), 1, stdout); - return(ferror(fp) ? -1 : 0); + return(ferror(stdout) ? -1 : 0); } -putbint(col, fp) /* put an int brightness to fp */ +putbint(col) /* put an int brightness to stdout */ COLOR col; -FILE *fp; { - fprintf(fp, "%d\n", (int)(bright(col)*256.)); + fprintf(stdout, "%d\n", (int)((*mybright)(col)*256.)); - return(ferror(fp) ? -1 : 0); + return(ferror(stdout) ? -1 : 0); } -putbbyte(col, fp) /* put a byte brightness to fp */ +putbbyte(col) /* put a byte brightness to stdout */ COLOR col; -FILE *fp; { register int i; BYTE vb; - i = bright(col)*256.; + i = (*mybright)(col)*256.; vb = min(i,255); - fwrite((char *)&vb, sizeof(BYTE), 1, fp); + fwrite((char *)&vb, sizeof(BYTE), 1, stdout); - return(ferror(fp) ? -1 : 0); + return(ferror(stdout) ? -1 : 0); } +putbword(col) /* put a 16-bit brightness to stdout */ +COLOR col; +{ + long i; + uint16 vw; + + i = (*mybright)(col)*65536.; + vw = min(i,65535); + fwrite((char *)&vw, sizeof(uint16), 1, stdout); + + return(ferror(stdout) ? -1 : 0); +} + + +putpascii(col) /* put an ascii primary to stdout */ +COLOR col; +{ + fprintf(stdout, "%15.3e\n", colval(col,putprim)); + + return(ferror(stdout) ? -1 : 0); +} + + +putpfloat(col) /* put a float primary to stdout */ +COLOR col; +{ + float vf; + + vf = colval(col,putprim); + fwrite((char *)&vf, sizeof(float), 1, stdout); + + return(ferror(stdout) ? -1 : 0); +} + + +putpdouble(col) /* put a double primary to stdout */ +COLOR col; +{ + double vd; + + vd = colval(col,putprim); + fwrite((char *)&vd, sizeof(double), 1, stdout); + + return(ferror(stdout) ? -1 : 0); +} + + +putpint(col) /* put an int primary to stdout */ +COLOR col; +{ + fprintf(stdout, "%d\n", (int)(colval(col,putprim)*256.)); + + return(ferror(stdout) ? -1 : 0); +} + + +putpbyte(col) /* put a byte primary to stdout */ +COLOR col; +{ + long i; + BYTE vb; + + i = colval(col,putprim)*256.; + vb = min(i,255); + fwrite((char *)&vb, sizeof(BYTE), 1, stdout); + + return(ferror(stdout) ? -1 : 0); +} + + +putpword(col) /* put a 16-bit primary to stdout */ +COLOR col; +{ + long i; + uint16 vw; + + i = colval(col,putprim)*65536.; + vw = min(i,65535); + fwrite((char *)&vw, sizeof(uint16), 1, stdout); + + return(ferror(stdout) ? -1 : 0); +} + + set_io() /* set put and get functions */ { switch (format) { case 'a': /* ascii */ - if (brightonly) { + if (putprim == BRIGHT) { getval = getbascii; putval = putbascii; + } else if (putprim != ALL) { + getval = getbascii; + putval = putpascii; } else { getval = getcascii; putval = putcascii; + if (reverse && !interleave) { + fprintf(stderr, + "%s: ASCII input files must be interleaved\n", + progname); + quit(1); + } } return; case 'f': /* binary float */ - if (brightonly) { + if (putprim == BRIGHT) { getval = getbfloat; putval = putbfloat; + } else if (putprim != ALL) { + getval = getbfloat; + putval = putpfloat; } else { getval = getcfloat; putval = putcfloat; + if (reverse && !interleave) { + if (fin2 == NULL) + goto namerr; + if (fseek(fin2, + (long)sizeof(float)*picres.xr*picres.yr, 1)) + goto seekerr; + if (fseek(fin3, + (long)sizeof(float)*2*picres.xr*picres.yr, 1)) + goto seekerr; + } } return; case 'd': /* binary double */ - if (brightonly) { + if (putprim == BRIGHT) { getval = getbdouble; putval = putbdouble; + } else if (putprim != ALL) { + getval = getbdouble; + putval = putpdouble; } else { getval = getcdouble; putval = putcdouble; + if (reverse && !interleave) { + if (fin2 == NULL) + goto namerr; + if (fseek(fin2, + (long)sizeof(double)*picres.xr*picres.yr, 1)) + goto seekerr; + if (fseek(fin3, + (long)sizeof(double)*2*picres.xr*picres.yr, 1)) + goto seekerr; + } } return; case 'i': /* integer */ - if (brightonly) { + if (putprim == BRIGHT) { getval = getbint; putval = putbint; + } else if (putprim != ALL) { + getval = getbint; + putval = putpint; } else { getval = getcint; putval = putcint; + if (reverse && !interleave) { + fprintf(stderr, + "%s: integer input files must be interleaved\n", + progname); + quit(1); + } } return; case 'b': /* byte */ - if (brightonly) { + if (putprim == BRIGHT) { getval = getbbyte; putval = putbbyte; + } else if (putprim != ALL) { + getval = getbbyte; + putval = putpbyte; } else { getval = getcbyte; putval = putcbyte; + if (reverse && !interleave) { + if (fin2 == NULL) + goto namerr; + if (fseek(fin2, + (long)sizeof(BYTE)*picres.xr*picres.yr, 1)) + goto seekerr; + if (fseek(fin3, + (long)sizeof(BYTE)*2*picres.xr*picres.yr, 1)) + goto seekerr; + } } return; + case 'w': /* 16-bit */ + if (putprim == BRIGHT) { + getval = getbword; + putval = putbword; + } else if (putprim != ALL) { + getval = getbword; + putval = putpword; + } else { + getval = getcword; + putval = putcword; + if (reverse && !interleave) { + if (fin2 == NULL) + goto namerr; + if (fseek(fin2, + (long)sizeof(uint16)*picres.xr*picres.yr, 1)) + goto seekerr; + if (fseek(fin3, + (long)sizeof(uint16)*2*picres.xr*picres.yr, 1)) + goto seekerr; + } + } + return; } +badopt: + fprintf(stderr, "%s: botched file type\n", progname); + quit(1); +namerr: + fprintf(stderr, "%s: non-interleaved file(s) must be named\n", + progname); + quit(1); +seekerr: + fprintf(stderr, "%s: cannot seek on interleaved input file\n", + progname); + quit(1); }
