root/radiance/ray/src/px/pvalue.c
Revision: 2.8
Committed: Sun Feb 27 10:16:48 1994 UTC (31 years, 5 months ago) by greg
Changes since 2.7: +10 -7 lines
1 /* Copyright (c) 1992 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * pvalue.c - program to print pixel values.
9 *
10 * 4/23/86
11 */
12
13 #include "standard.h"
14
15 #include "color.h"
16
17 #include "resolu.h"
18
19 #define min(a,b) ((a)<(b)?(a):(b))
20
21 RESOLU picres; /* resolution of picture */
22
23 int uniq = 0; /* print only unique values? */
24
25 int doexposure = 0; /* exposure change? (>100 to print) */
26
27 int dataonly = 0; /* data only format? */
28
29 int brightonly = 0; /* only brightness values? */
30
31 int reverse = 0; /* reverse conversion? */
32
33 int format = 'a'; /* input/output format */
34 char *fmtid = "ascii"; /* format identifier for header */
35
36 int header = 1; /* do header? */
37
38 int resolution = 1; /* put/get resolution string? */
39
40 int original = 0; /* convert to original values? */
41
42 int wrongformat = 0; /* wrong input format? */
43
44 double gamcor = 1.0; /* gamma correction */
45
46 int ord[3] = {RED, GRN, BLU}; /* RGB ordering */
47 int rord[4]; /* reverse ordering */
48
49 COLOR exposure = WHTCOLOR;
50
51 char *progname;
52
53 FILE *fin;
54
55 int (*getval)(), (*putval)();
56
57
58 main(argc, argv)
59 int argc;
60 char **argv;
61 {
62 extern int checkhead();
63 double d, expval = 1.0;
64 int i;
65
66 progname = argv[0];
67
68 for (i = 1; i < argc; i++)
69 if (argv[i][0] == '-' || argv[i][0] == '+')
70 switch (argv[i][1]) {
71 case 'h': /* header */
72 header = argv[i][0] == '+';
73 break;
74 case 'H': /* resolution string */
75 resolution = argv[i][0] == '+';
76 break;
77 case 'u': /* unique values */
78 uniq = argv[i][0] == '-';
79 break;
80 case 'o': /* original values */
81 original = argv[i][0] == '-';
82 break;
83 case 'g': /* gamma correction */
84 gamcor = atof(argv[i+1]);
85 if (argv[i][0] == '+')
86 gamcor = 1.0/gamcor;
87 i++;
88 break;
89 case 'e': /* exposure correction */
90 d = atof(argv[i+1]);
91 if (argv[i+1][0] == '-' || argv[i+1][0] == '+')
92 d = pow(2.0, d);
93 if (argv[i][0] == '-')
94 doexposure = 100;
95 scalecolor(exposure, d);
96 expval *= d;
97 doexposure++;
98 i++;
99 break;
100 case 'R': /* reverse byte sequence */
101 if (argv[i][0] == '-') {
102 ord[0]=BLU; ord[1]=GRN; ord[2]=RED;
103 } else {
104 ord[0]=RED; ord[1]=GRN; ord[2]=BLU;
105 }
106 break;
107 case 'r': /* reverse conversion */
108 reverse = argv[i][0] == '-';
109 break;
110 case 'b': /* brightness values */
111 brightonly = argv[i][0] == '-';
112 break;
113 case 'd': /* data only (no indices) */
114 dataonly = argv[i][0] == '-';
115 switch (argv[i][2]) {
116 case '\0':
117 case 'a': /* ascii */
118 format = 'a';
119 fmtid = "ascii";
120 break;
121 case 'i': /* integer */
122 format = 'i';
123 fmtid = "ascii";
124 break;
125 case 'b': /* byte */
126 dataonly = 1;
127 format = 'b';
128 fmtid = "byte";
129 break;
130 case 'f': /* float */
131 dataonly = 1;
132 format = 'f';
133 fmtid = "float";
134 break;
135 case 'd': /* double */
136 dataonly = 1;
137 format = 'd';
138 fmtid = "double";
139 break;
140 default:
141 goto unkopt;
142 }
143 break;
144 case 'x': /* x resolution */
145 case 'X': /* x resolution */
146 resolution = 0;
147 if (argv[i][0] == '-')
148 picres.or |= XDECR;
149 picres.xr = atoi(argv[++i]);
150 break;
151 case 'y': /* y resolution */
152 case 'Y': /* y resolution */
153 resolution = 0;
154 if (argv[i][0] == '-')
155 picres.or |= YDECR;
156 if (picres.xr == 0)
157 picres.or |= YMAJOR;
158 picres.yr = atoi(argv[++i]);
159 break;
160 default:
161 unkopt:
162 fprintf(stderr, "%s: unknown option: %s\n",
163 progname, argv[i]);
164 quit(1);
165 break;
166 }
167 else
168 break;
169 /* recognize special formats */
170 if (dataonly && format == 'b')
171 if (brightonly)
172 fmtid = "8-bit_grey";
173 else
174 fmtid = "24-bit_rgb";
175 /* assign reverse ordering */
176 rord[ord[0]] = 0;
177 rord[ord[1]] = 1;
178 rord[ord[2]] = 2;
179 /* get input */
180 if (i == argc) {
181 fin = stdin;
182 } else if (i == argc-1) {
183 if ((fin = fopen(argv[i], "r")) == NULL) {
184 fprintf(stderr, "%s: can't open file \"%s\"\n",
185 progname, argv[i]);
186 quit(1);
187 }
188 } else {
189 fprintf(stderr, "%s: bad # file arguments\n", progname);
190 quit(1);
191 }
192
193 set_io();
194
195 if (reverse) {
196 #ifdef MSDOS
197 setmode(fileno(stdout), O_BINARY);
198 if (format != 'a' && format != 'i')
199 setmode(fileno(fin), O_BINARY);
200 #endif
201 /* get header */
202 if (header) {
203 if (checkheader(fin, fmtid, stdout) < 0) {
204 fprintf(stderr, "%s: wrong input format\n",
205 progname);
206 quit(1);
207 }
208 } else
209 newheader("RADIANCE", stdout);
210 /* get resolution */
211 if ((resolution && !fgetsresolu(&picres, fin)) ||
212 picres.xr <= 0 || picres.yr <= 0) {
213 fprintf(stderr, "%s: missing resolution\n", progname);
214 quit(1);
215 }
216 /* add to header */
217 printargs(i, argv, stdout);
218 if (doexposure > 100)
219 fputexpos(expval, stdout);
220 fputformat(COLRFMT, stdout);
221 putchar('\n');
222 fputsresolu(&picres, stdout); /* always put resolution */
223 valtopix();
224 } else {
225 #ifdef MSDOS
226 setmode(fileno(fin), O_BINARY);
227 if (format != 'a' && format != 'i')
228 setmode(fileno(stdout), O_BINARY);
229 #endif
230 /* get header */
231 getheader(fin, checkhead, NULL);
232 if (wrongformat) {
233 fprintf(stderr, "%s: input not a Radiance picture\n",
234 progname);
235 quit(1);
236 }
237 if (!fgetsresolu(&picres, fin)) {
238 fprintf(stderr, "%s: missing resolution\n", progname);
239 quit(1);
240 }
241 if (header) {
242 printargs(i, argv, stdout);
243 if (doexposure > 100)
244 fputexpos(expval, stdout);
245 fputformat(fmtid, stdout);
246 putchar('\n');
247 }
248 if (resolution) /* put resolution */
249 fputsresolu(&picres, stdout);
250 pixtoval();
251 }
252
253 quit(0);
254 }
255
256
257 checkhead(line) /* deal with line from header */
258 char *line;
259 {
260 char fmt[32];
261 double d;
262 COLOR ctmp;
263
264 if (formatval(fmt, line))
265 wrongformat = strcmp(fmt, COLRFMT);
266 else if (original && isexpos(line)) {
267 d = 1.0/exposval(line);
268 scalecolor(exposure, d);
269 doexposure++;
270 } else if (original && iscolcor(line)) {
271 colcorval(ctmp, line);
272 setcolor(exposure, colval(exposure,RED)/colval(ctmp,RED),
273 colval(exposure,GRN)/colval(ctmp,GRN),
274 colval(exposure,BLU)/colval(ctmp,BLU));
275 doexposure++;
276 } else if (header)
277 fputs(line, stdout);
278 }
279
280
281 pixtoval() /* convert picture to values */
282 {
283 register COLOR *scanln;
284 int dogamma;
285 COLOR lastc;
286 FLOAT hv[2];
287 int y;
288 register int x;
289
290 scanln = (COLOR *)malloc(scanlen(&picres)*sizeof(COLOR));
291 if (scanln == NULL) {
292 fprintf(stderr, "%s: out of memory\n", progname);
293 quit(1);
294 }
295 dogamma = gamcor < .95 || gamcor > 1.05;
296 setcolor(lastc, 0.0, 0.0, 0.0);
297 for (y = 0; y < numscans(&picres); y++) {
298 if (freadscan(scanln, scanlen(&picres), fin) < 0) {
299 fprintf(stderr, "%s: read error\n", progname);
300 quit(1);
301 }
302 for (x = 0; x < scanlen(&picres); x++) {
303 if (uniq)
304 if ( colval(scanln[x],RED) ==
305 colval(lastc,RED) &&
306 colval(scanln[x],GRN) ==
307 colval(lastc,GRN) &&
308 colval(scanln[x],BLU) ==
309 colval(lastc,BLU) )
310 continue;
311 else
312 copycolor(lastc, scanln[x]);
313 if (doexposure)
314 multcolor(scanln[x], exposure);
315 if (dogamma)
316 setcolor(scanln[x],
317 pow(colval(scanln[x],RED), 1.0/gamcor),
318 pow(colval(scanln[x],GRN), 1.0/gamcor),
319 pow(colval(scanln[x],BLU), 1.0/gamcor));
320 if (!dataonly) {
321 pix2loc(hv, &picres, x, y);
322 printf("%7d %7d ", (int)(hv[0]*picres.xr),
323 (int)(hv[1]*picres.yr));
324 }
325 if ((*putval)(scanln[x], stdout) < 0) {
326 fprintf(stderr, "%s: write error\n", progname);
327 quit(1);
328 }
329 }
330 }
331 free((char *)scanln);
332 }
333
334
335 valtopix() /* convert values to a pixel file */
336 {
337 int dogamma;
338 register COLOR *scanln;
339 int y;
340 register int x;
341
342 scanln = (COLOR *)malloc(scanlen(&picres)*sizeof(COLOR));
343 if (scanln == NULL) {
344 fprintf(stderr, "%s: out of memory\n", progname);
345 quit(1);
346 }
347 dogamma = gamcor < .95 || gamcor > 1.05;
348 for (y = 0; y < numscans(&picres); y++) {
349 for (x = 0; x < scanlen(&picres); x++) {
350 if (!dataonly)
351 fscanf(fin, "%*d %*d");
352 if ((*getval)(scanln[x], fin) < 0) {
353 fprintf(stderr, "%s: read error\n", progname);
354 quit(1);
355 }
356 if (dogamma)
357 setcolor(scanln[x],
358 pow(colval(scanln[x],RED), gamcor),
359 pow(colval(scanln[x],GRN), gamcor),
360 pow(colval(scanln[x],BLU), gamcor));
361 if (doexposure)
362 multcolor(scanln[x], exposure);
363 }
364 if (fwritescan(scanln, scanlen(&picres), stdout) < 0) {
365 fprintf(stderr, "%s: write error\n", progname);
366 quit(1);
367 }
368 }
369 free((char *)scanln);
370 }
371
372
373 quit(code)
374 int code;
375 {
376 exit(code);
377 }
378
379
380 getcascii(col, fp) /* get an ascii color value from fp */
381 COLOR col;
382 FILE *fp;
383 {
384 double vd[3];
385
386 if (fscanf(fp, "%lf %lf %lf", &vd[0], &vd[1], &vd[2]) != 3)
387 return(-1);
388 setcolor(col, vd[rord[RED]], vd[rord[GRN]], vd[rord[BLU]]);
389 return(0);
390 }
391
392
393 getcdouble(col, fp) /* get a double color value from fp */
394 COLOR col;
395 FILE *fp;
396 {
397 double vd[3];
398
399 if (fread((char *)vd, sizeof(double), 3, fp) != 3)
400 return(-1);
401 setcolor(col, vd[rord[RED]], vd[rord[GRN]], vd[rord[BLU]]);
402 return(0);
403 }
404
405
406 getcfloat(col, fp) /* get a float color value from fp */
407 COLOR col;
408 FILE *fp;
409 {
410 float vf[3];
411
412 if (fread((char *)vf, sizeof(float), 3, fp) != 3)
413 return(-1);
414 setcolor(col, vf[rord[RED]], vf[rord[GRN]], vf[rord[BLU]]);
415 return(0);
416 }
417
418
419 getcint(col, fp) /* get an int color value from fp */
420 COLOR col;
421 FILE *fp;
422 {
423 int vi[3];
424
425 if (fscanf(fp, "%d %d %d", &vi[0], &vi[1], &vi[2]) != 3)
426 return(-1);
427 setcolor(col, (vi[rord[RED]]+.5)/256.,
428 (vi[rord[GRN]]+.5)/256., (vi[rord[BLU]]+.5)/256.);
429 return(0);
430 }
431
432
433 getcbyte(col, fp) /* get a byte color value from fp */
434 COLOR col;
435 FILE *fp;
436 {
437 BYTE vb[3];
438
439 if (fread((char *)vb, sizeof(BYTE), 3, fp) != 3)
440 return(-1);
441 setcolor(col, (vb[rord[RED]]+.5)/256.,
442 (vb[rord[GRN]]+.5)/256., (vb[rord[BLU]]+.5)/256.);
443 return(0);
444 }
445
446
447 getbascii(col, fp) /* get an ascii brightness value from fp */
448 COLOR col;
449 FILE *fp;
450 {
451 double vd;
452
453 if (fscanf(fp, "%lf", &vd) != 1)
454 return(-1);
455 setcolor(col, vd, vd, vd);
456 return(0);
457 }
458
459
460 getbdouble(col, fp) /* get a double brightness value from fp */
461 COLOR col;
462 FILE *fp;
463 {
464 double vd;
465
466 if (fread((char *)&vd, sizeof(double), 1, fp) != 1)
467 return(-1);
468 setcolor(col, vd, vd, vd);
469 return(0);
470 }
471
472
473 getbfloat(col, fp) /* get a float brightness value from fp */
474 COLOR col;
475 FILE *fp;
476 {
477 float vf;
478
479 if (fread((char *)&vf, sizeof(float), 1, fp) != 1)
480 return(-1);
481 setcolor(col, vf, vf, vf);
482 return(0);
483 }
484
485
486 getbint(col, fp) /* get an int brightness value from fp */
487 COLOR col;
488 FILE *fp;
489 {
490 int vi;
491 double d;
492
493 if (fscanf(fp, "%d", &vi) != 1)
494 return(-1);
495 d = (vi+.5)/256.;
496 setcolor(col, d, d, d);
497 return(0);
498 }
499
500
501 getbbyte(col, fp) /* get a byte brightness value from fp */
502 COLOR col;
503 FILE *fp;
504 {
505 BYTE vb;
506 double d;
507
508 if (fread((char *)&vb, sizeof(BYTE), 1, fp) != 1)
509 return(-1);
510 d = (vb+.5)/256.;
511 setcolor(col, d, d, d);
512 return(0);
513 }
514
515
516 putcascii(col, fp) /* put an ascii color to fp */
517 COLOR col;
518 FILE *fp;
519 {
520 fprintf(fp, "%15.3e %15.3e %15.3e\n",
521 colval(col,ord[0]),
522 colval(col,ord[1]),
523 colval(col,ord[2]));
524
525 return(ferror(fp) ? -1 : 0);
526 }
527
528
529 putcfloat(col, fp) /* put a float color to fp */
530 COLOR col;
531 FILE *fp;
532 {
533 float vf[3];
534
535 vf[0] = colval(col,ord[0]);
536 vf[1] = colval(col,ord[1]);
537 vf[2] = colval(col,ord[2]);
538 fwrite((char *)vf, sizeof(float), 3, fp);
539
540 return(ferror(fp) ? -1 : 0);
541 }
542
543
544 putcdouble(col, fp) /* put a double color to fp */
545 COLOR col;
546 FILE *fp;
547 {
548 double vd[3];
549
550 vd[0] = colval(col,ord[0]);
551 vd[1] = colval(col,ord[1]);
552 vd[2] = colval(col,ord[2]);
553 fwrite((char *)vd, sizeof(double), 3, fp);
554
555 return(ferror(fp) ? -1 : 0);
556 }
557
558
559 putcint(col, fp) /* put an int color to fp */
560 COLOR col;
561 FILE *fp;
562 {
563 fprintf(fp, "%d %d %d\n",
564 (int)(colval(col,ord[0])*256.),
565 (int)(colval(col,ord[1])*256.),
566 (int)(colval(col,ord[2])*256.));
567
568 return(ferror(fp) ? -1 : 0);
569 }
570
571
572 putcbyte(col, fp) /* put a byte color to fp */
573 COLOR col;
574 FILE *fp;
575 {
576 register int i;
577 BYTE vb[3];
578
579 i = colval(col,ord[0])*256.;
580 vb[0] = min(i,255);
581 i = colval(col,ord[1])*256.;
582 vb[1] = min(i,255);
583 i = colval(col,ord[2])*256.;
584 vb[2] = min(i,255);
585 fwrite((char *)vb, sizeof(BYTE), 3, fp);
586
587 return(ferror(fp) ? -1 : 0);
588 }
589
590
591 putbascii(col, fp) /* put an ascii brightness to fp */
592 COLOR col;
593 FILE *fp;
594 {
595 fprintf(fp, "%15.3e\n", bright(col));
596
597 return(ferror(fp) ? -1 : 0);
598 }
599
600
601 putbfloat(col, fp) /* put a float brightness to fp */
602 COLOR col;
603 FILE *fp;
604 {
605 float vf;
606
607 vf = bright(col);
608 fwrite((char *)&vf, sizeof(float), 1, fp);
609
610 return(ferror(fp) ? -1 : 0);
611 }
612
613
614 putbdouble(col, fp) /* put a double brightness to fp */
615 COLOR col;
616 FILE *fp;
617 {
618 double vd;
619
620 vd = bright(col);
621 fwrite((char *)&vd, sizeof(double), 1, fp);
622
623 return(ferror(fp) ? -1 : 0);
624 }
625
626
627 putbint(col, fp) /* put an int brightness to fp */
628 COLOR col;
629 FILE *fp;
630 {
631 fprintf(fp, "%d\n", (int)(bright(col)*256.));
632
633 return(ferror(fp) ? -1 : 0);
634 }
635
636
637 putbbyte(col, fp) /* put a byte brightness to fp */
638 COLOR col;
639 FILE *fp;
640 {
641 register int i;
642 BYTE vb;
643
644 i = bright(col)*256.;
645 vb = min(i,255);
646 fwrite((char *)&vb, sizeof(BYTE), 1, fp);
647
648 return(ferror(fp) ? -1 : 0);
649 }
650
651
652 set_io() /* set put and get functions */
653 {
654 switch (format) {
655 case 'a': /* ascii */
656 if (brightonly) {
657 getval = getbascii;
658 putval = putbascii;
659 } else {
660 getval = getcascii;
661 putval = putcascii;
662 }
663 return;
664 case 'f': /* binary float */
665 if (brightonly) {
666 getval = getbfloat;
667 putval = putbfloat;
668 } else {
669 getval = getcfloat;
670 putval = putcfloat;
671 }
672 return;
673 case 'd': /* binary double */
674 if (brightonly) {
675 getval = getbdouble;
676 putval = putbdouble;
677 } else {
678 getval = getcdouble;
679 putval = putcdouble;
680 }
681 return;
682 case 'i': /* integer */
683 if (brightonly) {
684 getval = getbint;
685 putval = putbint;
686 } else {
687 getval = getcint;
688 putval = putcint;
689 }
690 return;
691 case 'b': /* byte */
692 if (brightonly) {
693 getval = getbbyte;
694 putval = putbbyte;
695 } else {
696 getval = getcbyte;
697 putval = putcbyte;
698 }
699 return;
700 }
701 }
