root/radiance/ray/src/px/pvalue.c
Tue Jun 3 21:31:51 2025 UTC (2 months ago) by greg
CVS Tags: HEAD, rad6R0
Changes since 2.45: +2 -4 lines
Diff to previous 2.45 , to selected 2.10
Mon Sep 16 23:02:53 2024 UTC (10 months, 2 weeks ago) by greg
Changes since 2.44: +4 -2 lines
Diff to previous 2.44 , to selected 2.10
fix(pvalue): Fixed issue with -r -h -b combo
Wed Sep 11 23:21:01 2024 UTC (10 months, 3 weeks ago) by greg
Changes since 2.43: +3 -2 lines
Diff to previous 2.43 , to selected 2.10
fix(pvalue): Don't output NCOMP line in header if including pixel coords
Wed Sep 11 18:56:12 2024 UTC (10 months, 3 weeks ago) by greg
Changes since 2.42: +94 -35 lines
Diff to previous 2.42 , to selected 2.10
feat(pcond,pvalue): Added hyperspectral input handling
Thu Mar 10 03:25:54 2022 UTC (3 years, 4 months ago) by greg
Changes since 2.41: +6 -1 lines
Diff to previous 2.41 , to selected 2.10
fix(pvalue): Remove NCOMP=, NROWS=, NCOLS= lines from header (either direction)
Fri Feb 4 20:11:49 2022 UTC (3 years, 5 months ago) by greg
Changes since 2.40: +14 -2 lines
Diff to previous 2.40 , to selected 2.10
feat(pvalue,pextrem): Added -O option to report watts/sr/meter^2 always
Tue Jun 30 22:30:29 2020 UTC (5 years, 1 month ago) by greg
Changes since 2.39: +3 -2 lines
Diff to previous 2.39 , to selected 2.10
fix(pvalue): removed output of BigEndian flag when not needed for -db mode
Mon Mar 30 19:02:26 2020 UTC (5 years, 4 months ago) by greg
Changes since 2.38: +18 -6 lines
Diff to previous 2.38 , to selected 2.10
Made output a little more compatible with matrix file types
Thu Feb 6 19:33:32 2020 UTC (5 years, 5 months ago) by greg
Changes since 2.37: +15 -10 lines
Diff to previous 2.37 , to selected 2.10
Fixed issue with BigEndian handling in header
Wed Aug 14 18:20:02 2019 UTC (5 years, 11 months ago) by greg
Changes since 2.36: +11 -1 lines
Diff to previous 2.36 , to selected 2.10
Mon Jul 15 23:42:44 2019 UTC (6 years ago) by greg
Changes since 2.35: +35 -29 lines
Diff to previous 2.35 , to selected 2.10
Allow skipping header bytes on standard input and more logical binary mode
Mon Jul 15 22:39:50 2019 UTC (6 years ago) by greg
Changes since 2.34: +22 -13 lines
Diff to previous 2.34 , to selected 2.10
Made pvalue -u option mean "uncompressed" with -r.
Thu Aug 2 18:33:46 2018 UTC (7 years ago) by greg
Changes since 2.33: +2 -2 lines
Diff to previous 2.33 , to selected 2.10
Thu Aug 18 00:52:48 2016 UTC (8 years, 11 months ago) by greg
Changes since 2.32: +33 -33 lines
Diff to previous 2.32 , to selected 2.10
Sun Mar 6 01:13:17 2016 UTC (9 years, 5 months ago) by schorsch
Diff to previous 2.31 , to selected 2.10
Fri May 20 02:06:39 2011 UTC (14 years, 2 months ago) by greg
Changes since 2.30: +16 -16 lines
Diff to previous 2.30 , to selected 2.10
Thu Dec 16 21:34:41 2010 UTC (14 years, 7 months ago) by greg
Changes since 2.29: +25 -3 lines
Diff to previous 2.29 , to selected 2.10
Added recording of other color spaces to pvalue -r conversion
Sat Dec 23 17:27:46 2006 UTC (18 years, 7 months ago) by greg
CVS Tags: rad3R9, rad4R0
Changes since 2.28: +11 -59 lines
Diff to previous 2.28 , to selected 2.10
Fri Oct 1 07:46:26 2004 UTC (20 years, 10 months ago) by greg
Changes since 2.27: +1 -2 lines
Diff to previous 2.27 , to selected 2.10
Forgot to remove debug statement on last check-in
Fri Oct 1 07:45:30 2004 UTC (20 years, 10 months ago) by greg
Changes since 2.26: +4 -7 lines
Diff to previous 2.26 , to selected 2.10
Sun Mar 28 20:33:14 2004 UTC (21 years, 4 months ago) by schorsch
Changes since 2.25: +182 -104 lines
Diff to previous 2.25 , to selected 2.10
Fri Jan 2 12:47:01 2004 UTC (21 years, 7 months ago) by schorsch
Changes since 2.24: +9 -5 lines
Diff to previous 2.24 , to selected 2.10
Wed Oct 22 02:06:35 2003 UTC (21 years, 9 months ago) by greg
Diff to previous 2.23 , to selected 2.10
Sat Sep 13 15:24:13 2003 UTC (21 years, 10 months ago) by greg
Changes since 2.22: +55 -4 lines
Diff to previous 2.22 , to selected 2.10
Mon Jul 21 22:30:19 2003 UTC (22 years ago) by schorsch
Changes since 2.21: +7 -4 lines
Diff to previous 2.21 , to selected 2.10
Thu Jun 26 00:58:10 2003 UTC (22 years, 1 month ago) by schorsch
Diff to previous 2.20 , to selected 2.10
Fri Jun 20 00:25:50 2003 UTC (22 years, 1 month ago) by greg
Changes since 2.19: +1 -3 lines
Diff to previous 2.19 , to selected 2.10
Sun Jun 8 12:03:10 2003 UTC (22 years, 2 months ago) by schorsch
Changes since 2.18: +2 -1 lines
Diff to previous 2.18 , to selected 2.10
Thu Jun 5 19:29:34 2003 UTC (22 years, 2 months ago) by schorsch
Changes since 2.17: +9 -11 lines
Diff to previous 2.17 , to selected 2.10
Thu Feb 27 02:00:12 2003 UTC (22 years, 5 months ago) by greg
Changes since 2.16: +8 -10 lines
Diff to previous 2.16 , to selected 2.10
Corrected format string for -pP option
Tue Feb 25 16:47:23 2003 UTC (22 years, 5 months ago) by greg
Changes since 2.15: +25 -1 lines
Diff to previous 2.15 , to selected 2.10
Added -dW option for 16-bit byte-swapped words
Tue Feb 25 16:22:05 2003 UTC (22 years, 5 months ago) by greg
Changes since 2.14: +116 -2 lines
Added -dw option for 16-bit i/o
Sat Feb 22 02:07:27 2003 UTC (22 years, 5 months ago) by greg
Changes since 2.13: +46 -20 lines
Tue Oct 27 09:08:27 1998 UTC (26 years, 9 months ago) by gwlarson
Changes since 2.12: +2 -0 lines
Wed Jan 8 08:51:43 1997 UTC (28 years, 7 months ago) by greg
Changes since 2.11: +118 -40 lines
added -n option for non-interleaved RGB input and output
Wed Jan 8 08:00:23 1997 UTC (28 years, 7 months ago) by greg
Changes since 2.10: +87 -112 lines
took out file arguments from get and put value routines
Wed Jan 8 07:43:49 1997 UTC (28 years, 7 months ago) by greg
Changes since 2.9: +210 -31 lines
added routines for reading and writing separate RGB files
added -pP (where P is one of 'R', 'G' or 'B' upper or lower case)
added -s option to skip specified number of bytes on header
Thu Oct 6 13:27:16 1994 UTC (30 years, 10 months ago) by greg
Changes since 2.8: +3 -4 lines
made it so -e and +e work well together
Sun Feb 27 10:16:48 1994 UTC (31 years, 5 months ago) by greg
Changes since 2.7: +10 -7 lines
Tue Nov 9 15:21:00 1993 UTC (31 years, 9 months ago) by greg
Changes since 2.6: +26 -3 lines
added +/-e option to correct/adjust exposure
Thu Jul 29 13:36:19 1993 UTC (32 years ago) by greg
made pvalue accept upper case X and Y for resolution spec. also
Mon Sep 21 12:14:37 1992 UTC (32 years, 10 months ago) by greg
Changes since 2.4: +24 -14 lines
Changes for PC port
Fri May 8 11:55:42 1992 UTC (33 years, 3 months ago) by greg
Changes since 2.3: +37 -21 lines
added -R option for color order reversal
Fri May 8 10:58:52 1992 UTC (33 years, 3 months ago) by greg
Changes since 2.2: +21 -15 lines
added +/-H option for no/yes to resolution string
Thu Dec 19 14:52:04 1991 UTC (33 years, 7 months ago) by greg
Tue Nov 12 16:04:16 1991 UTC (33 years, 9 months ago) by greg
Diff to previous 1.8 , to selected 2.10
Mon Nov 11 14:01:37 1991 UTC (33 years, 9 months ago) by greg
Changes since 1.7: +61 -45 lines
Diff to previous 1.7 , to selected 2.10
Fri May 10 08:51:53 1991 UTC (34 years, 3 months ago) by greg
Changes since 1.6: +34 -12 lines
Diff to previous 1.6 , to selected 2.10
added -g (gamma correction) option
Fri Apr 19 09:00:55 1991 UTC (34 years, 3 months ago) by greg
Changes since 1.5: +48 -15 lines
Diff to previous 1.5 , to selected 2.10
added format info to header
Fri Dec 14 16:33:19 1990 UTC (34 years, 7 months ago) by greg
Changes since 1.4: +14 -4 lines
Diff to previous 1.4 , to selected 2.10
added use of COLORCORR header i/o
Thu Jan 18 23:58:17 1990 UTC (35 years, 6 months ago) by greg
Changes since 1.3: +12 -12 lines
Diff to previous 1.3 , to selected 2.10
Fri Jan 5 17:52:54 1990 UTC (35 years, 7 months ago) by greg
Diff to previous 1.2 , to selected 2.10
changed EXPOSURE information interface
Tue Sep 12 13:04:30 1989 UTC (35 years, 11 months ago) by greg
Diff to previous 1.1 , to selected 2.10
Thu Feb 2 10:49:31 1989 UTC (36 years, 6 months ago) by greg
Diff to selected 2.10
