root/Development/ray/src/px/pvalue.c
Revision: 2.42
Committed: Thu Mar 10 03:25:54 2022 UTC (3 years, 9 months ago) by greg
Changes since 2.41: +6 -1 lines
fix(pvalue): Remove NCOMP=, NROWS=, NCOLS= lines from header (either direction)
2 static const char RCSid[] = "$Id: pvalue.c,v 2.41 2022/02/04 20:11:49 greg Exp $";
5 * pvalue.c - program to print pixel values.
6 *
7 * 4/23/86
8 */
9
10 #include "platform.h"
11 #include "standard.h"
12 #include "color.h"
13 #include "resolu.h"
14 #include "view.h"
15
16 #define min(a,b) ((a)<(b)?(a):(b))
17
18 /* what to put out (also RED, GRN, BLU) */
19 #define ALL 3
20 #define BRIGHT 4
21
22 RESOLU picres; /* resolution of picture */
23 int uniq = 0; /* print only unique values? */
24 int doexposure = 0; /* exposure change? (>100 to print) */
25 int dataonly = 0; /* data only format? */
26 int putprim = ALL; /* what to put out */
27 int reverse = 0; /* reverse conversion? */
28 int format = 'a'; /* input/output format */
29 char *fmtid = "ascii"; /* format identifier for header */
30 int header = 1; /* do header? */
31 long skipbytes = 0; /* skip bytes in input? */
32 int swapbytes = 0; /* swap bytes? */
33 int interleave = 1; /* file is interleaved? */
34 int resolution = 1; /* put/get resolution string? */
35 int original = 0; /* convert to original values? */
36 int wrongformat = 0; /* wrong input format? */
37 double gamcor = 1.0; /* gamma correction */
38
39 RGBPRIMP outprims = stdprims; /* output primaries for reverse conversion */
40 RGBPRIMS myprims;
41
42 int ord[3] = {RED, GRN, BLU}; /* RGB ordering */
43 int rord[4]; /* reverse ordering */
44
45 COLOR exposure = WHTCOLOR;
46
47 char *progname;
48
49 FILE *fin;
50 FILE *fin2 = NULL, *fin3 = NULL; /* for other color channels */
51
52
53 typedef int getfunc_t(COLOR col);
54 typedef int putfunc_t(COLOR col);
55 typedef double brightfunc_t(COLOR col);
56
57 getfunc_t *getval;
58 putfunc_t *putval;
59 brightfunc_t *mybright;
60
61 static gethfunc checkhead;
62 static brightfunc_t rgb_bright, xyz_bright;
63 static getfunc_t getbascii, getbint, getbdouble, getbfloat, getbbyte, getbword;
64 static getfunc_t getcascii, getcint, getcdouble, getcfloat, getcbyte, getcword;
65 static putfunc_t putbascii, putbint, putbdouble, putbfloat, putbbyte, putbword;
66 static putfunc_t putcascii, putcint, putcdouble, putcfloat, putcbyte, putcword;
67 static putfunc_t putpascii, putpint, putpdouble, putpfloat, putpbyte, putpword;
68
69 static void set_io(void);
70 static void pixtoval(void);
71 static void valtopix(void);
72
73
74 static double
75 rgb_bright(
76 COLOR clr
77 )
78 {
79 return(bright(clr));
80 }
81
82 static double
83 xyz_bright(
84 COLOR clr
85 )
86 {
87 return(clr[CIEY]);
88 }
89
90 int
91 main(
92 int argc,
93 char **argv
94 )
95 {
96 const char *inpmode = "r";
97 double d, expval = 1.0;
98 int i;
99
100 progname = argv[0];
101 mybright = &rgb_bright; /* default */
102
103 for (i = 1; i < argc; i++)
104 if (argv[i][0] == '-' || argv[i][0] == '+')
105 switch (argv[i][1]) {
106 case 'h': /* header */
107 header = argv[i][0] == '+';
108 break;
109 case 'H': /* resolution string */
110 resolution = argv[i][0] == '+';
111 break;
112 case 's': /* skip bytes in header */
113 skipbytes = atol(argv[++i]);
114 break;
115 case 'u': /* unique values */
116 uniq = argv[i][0] == '-';
117 break;
118 case 'o': /* original values */
119 original = argv[i][0] == '-';
120 break;
121 case 'O': /* original watts/sr/m^2 */
122 original = -(argv[i][0] == '-');
123 break;
124 case 'g': /* gamma correction */
125 gamcor = atof(argv[i+1]);
126 if (argv[i][0] == '+')
127 gamcor = 1.0/gamcor;
128 i++;
129 break;
130 case 'e': /* exposure correction */
131 d = atof(argv[i+1]);
132 if (argv[i+1][0] == '-' || argv[i+1][0] == '+')
133 d = pow(2.0, d);
134 if (argv[i][0] == '-')
135 expval *= d;
136 scalecolor(exposure, d);
137 doexposure++;
138 i++;
139 break;
140 case 'R': /* reverse byte sequence */
141 if (argv[i][0] == '-') {
142 ord[0]=BLU; ord[1]=GRN; ord[2]=RED;
143 } else {
144 ord[0]=RED; ord[1]=GRN; ord[2]=BLU;
145 }
146 break;
147 case 'r': /* reverse conversion */
148 reverse = argv[i][0] == '-';
149 break;
150 case 'n': /* non-interleaved RGB */
151 interleave = argv[i][0] == '+';
152 break;
153 case 'b': /* brightness values */
154 putprim = argv[i][0] == '-' ? BRIGHT : ALL;
155 break;
156 case 'p': /* primary controls */
157 switch (argv[i][2]) {
158 /* these two options affect -r conversion */
159 case '\0':
160 myprims[RED][CIEX] = atof(argv[++i]);
161 myprims[RED][CIEY] = atof(argv[++i]);
162 myprims[GRN][CIEX] = atof(argv[++i]);
163 myprims[GRN][CIEY] = atof(argv[++i]);
164 myprims[BLU][CIEX] = atof(argv[++i]);
165 myprims[BLU][CIEY] = atof(argv[++i]);
166 myprims[WHT][CIEX] = atof(argv[++i]);
167 myprims[WHT][CIEY] = atof(argv[++i]);
168 outprims = myprims;
169 break;
170 case 'x': case 'X': outprims = NULL; break;
171 /* the following options affect +r only */
172 case 'r': case 'R': putprim = RED; break;
173 case 'g': case 'G': putprim = GRN; break;
174 case 'b': case 'B': putprim = BLU; break;
175 default: goto unkopt;
176 }
177 break;
178 case 'd': /* data only (no indices) */
179 dataonly = (argv[i][0] == '-');
180 switch (argv[i][2]) {
181 case '\0':
182 case 'a': /* ascii */
183 format = 'a';
184 fmtid = "ascii";
185 break;
186 case 'i': /* integer */
187 format = 'i';
188 fmtid = "ascii";
189 break;
190 case 'b': /* byte */
191 dataonly = 1;
192 format = 'b';
193 fmtid = "byte";
194 break;
195 case 'W': /* 16-bit swapped */
196 swapbytes = 1;
197 case 'w': /* 16-bit */
198 dataonly = 1;
199 format = 'w';
200 fmtid = "16-bit";
201 break;
202 case 'F': /* swapped floats */
203 swapbytes = 1;
204 case 'f': /* float */
205 dataonly = 1;
206 format = 'f';
207 fmtid = "float";
208 break;
209 case 'D': /* swapped doubles */
210 swapbytes = 1;
211 case 'd': /* double */
212 dataonly = 1;
213 format = 'd';
214 fmtid = "double";
215 break;
216 default:
217 goto unkopt;
218 }
219 break;
220 case 'x': /* x resolution */
221 case 'X': /* x resolution */
222 resolution = 0;
223 if (argv[i][0] == '-')
224 picres.rt |= XDECR;
225 picres.xr = atoi(argv[++i]);
226 break;
227 case 'y': /* y resolution */
228 case 'Y': /* y resolution */
229 resolution = 0;
230 if (argv[i][0] == '-')
231 picres.rt |= YDECR;
232 if (picres.xr == 0)
233 picres.rt |= YMAJOR;
234 picres.yr = atoi(argv[++i]);
235 break;
236 default:
237 unkopt:
238 fprintf(stderr, "%s: unknown option: %s\n",
239 progname, argv[i]);
240 quit(1);
241 break;
242 }
243 else
244 break;
245 /* recognize special formats */
246 if (dataonly && format == 'b') {
247 if (putprim == ALL)
248 fmtid = "24-bit_rgb";
249 else
250 fmtid = "8-bit_grey";
251 }
252 if (dataonly && format == 'w') {
253 if (putprim == ALL)
254 fmtid = "48-bit_rgb";
255 else
256 fmtid = "16-bit_grey";
257 }
258 if (!reverse || (format != 'a') & (format != 'i'))
259 inpmode = "rb";
260 /* assign reverse ordering */
261 rord[ord[0]] = 0;
262 rord[ord[1]] = 1;
263 rord[ord[2]] = 2;
264 /* get input */
265 if (i == argc) {
266 long n = skipbytes;
267 if (inpmode[1] == 'b')
268 SET_FILE_BINARY(stdin);
269 while (n-- > 0)
270 if (getchar() == EOF) {
271 fprintf(stderr,
272 "%s: cannot skip %ld bytes on standard input\n",
273 progname, skipbytes);
274 quit(1);
275 }
276 fin = stdin;
277 } else if (i < argc) {
278 if ((fin = fopen(argv[i], inpmode)) == NULL) {
279 fprintf(stderr, "%s: can't open file \"%s\"\n",
280 progname, argv[i]);
281 quit(1);
282 }
283 if (reverse && putprim != BRIGHT && i == argc-3) {
284 if ((fin2 = fopen(argv[i+1], inpmode)) == NULL) {
285 fprintf(stderr, "%s: can't open file \"%s\"\n",
286 progname, argv[i+1]);
287 quit(1);
288 }
289 if ((fin3 = fopen(argv[i+2], inpmode)) == NULL) {
290 fprintf(stderr, "%s: can't open file \"%s\"\n",
291 progname, argv[i+2]);
292 quit(1);
293 }
294 interleave = -1;
295 } else if (i != argc-1)
296 fin = NULL;
297 if (reverse && putprim != BRIGHT && !interleave) {
298 fin2 = fopen(argv[i], inpmode);
299 fin3 = fopen(argv[i], inpmode);
300 }
301 if (skipbytes && (fseek(fin, skipbytes, SEEK_SET) || (fin2 != NULL &&
302 fseek(fin2, skipbytes, SEEK_SET) |
303 fseek(fin3, skipbytes, SEEK_SET)))) {
304 fprintf(stderr, "%s: cannot skip %ld bytes on input\n",
305 progname, skipbytes);
306 quit(1);
307 }
308 }
309 if (fin == NULL) {
310 fprintf(stderr, "%s: bad # file arguments\n", progname);
311 quit(1);
312 }
313
314 if (reverse) {
315 SET_FILE_BINARY(stdout);
316 /* get header */
317 if (header) {
318 getheader(fin, checkhead, stdout);
319 if (wrongformat) {
320 fprintf(stderr, "%s: wrong input format (expected %s)\n",
321 progname, fmtid);
322 quit(1);
323 }
324 if (fin2 != NULL) {
325 getheader(fin2, NULL, NULL);
326 getheader(fin3, NULL, NULL);
327 }
328 } else
329 newheader("RADIANCE", stdout);
330 /* get resolution */
331 if ((resolution && !fgetsresolu(&picres, fin)) ||
332 picres.xr <= 0 || picres.yr <= 0) {
333 fprintf(stderr, "%s: missing resolution\n", progname);
334 quit(1);
335 }
336 if (resolution && fin2 != NULL) {
337 RESOLU pres2;
338 if (!fgetsresolu(&pres2, fin2) ||
339 pres2.rt != picres.rt ||
340 pres2.xr != picres.xr ||
341 pres2.yr != picres.yr ||
342 !fgetsresolu(&pres2, fin3) ||
343 pres2.rt != picres.rt ||
344 pres2.xr != picres.xr ||
345 pres2.yr != picres.yr) {
346 fprintf(stderr, "%s: resolution mismatch\n",
347 progname);
348 quit(1);
349 }
350 }
351 /* add to header */
352 printargs(i, argv, stdout);
353 if (expval < .99 || expval > 1.01)
354 fputexpos(expval, stdout);
355 if (outprims != NULL) {
356 if (outprims != stdprims)
357 fputprims(outprims, stdout);
358 fputformat(COLRFMT, stdout);
359 } else { /* XYZ data */
360 if (original < 0) {
361 scalecolor(exposure, WHTEFFICACY);
362 doexposure++;
363 }
364 fputformat(CIEFMT, stdout);
365 }
366 putchar('\n');
367 fputsresolu(&picres, stdout); /* always put resolution */
368 valtopix();
369 } else {
370 if ((format != 'a') & (format != 'i'))
371 SET_FILE_BINARY(stdout);
372 /* get header */
373 getheader(fin, checkhead, header ? stdout : (FILE *)NULL);
374 if (wrongformat) {
375 fprintf(stderr,
376 "%s: input not a Radiance RGBE picture\n",
377 progname);
378 quit(1);
379 }
380 if (!fgetsresolu(&picres, fin)) {
381 fprintf(stderr, "%s: missing resolution\n", progname);
382 quit(1);
383 }
384 if (original < 0 && mybright == &xyz_bright) {
385 scalecolor(exposure, 1./WHTEFFICACY);
386 doexposure++;
387 }
388 if (header) {
389 printargs(i, argv, stdout);
390 printf("NCOMP=%d\n", putprim==ALL ? 3 : 1);
391 if (!resolution && dataonly && !uniq)
392 printf("NCOLS=%d\nNROWS=%d\n", scanlen(&picres),
393 numscans(&picres));
394 if (expval < .99 || expval > 1.01)
395 fputexpos(expval, stdout);
396 if (swapbytes) {
397 if (nativebigendian())
398 puts("BigEndian=0");
399 else
400 puts("BigEndian=1");
401 } else if ((format != 'a') & (format != 'i') &
402 (format != 'b'))
403 fputendian(stdout);
404 fputformat(fmtid, stdout);
405 putchar('\n');
406 }
407 if (resolution) /* put resolution */
408 fputsresolu(&picres, stdout);
409 pixtoval();
410 }
411
412 quit(0);
413 return 0; /* pro forma return */
414 }
415
416
417 static int
418 checkhead( /* deal with line from header */
419 char *line,
420 void *p
421 )
422 {
423 FILE *fout = (FILE *)p;
424 char fmt[MAXFMTLEN];
425 double d;
426 COLOR ctmp;
427 int rv;
428
429 if (formatval(fmt, line)) {
430 if (reverse)
431 wrongformat = strcmp(fmt, fmtid);
432 else if (!strcmp(fmt, CIEFMT))
433 mybright = &xyz_bright;
434 else if (!strcmp(fmt, COLRFMT))
435 mybright = &rgb_bright;
436 else
437 wrongformat++;
438 return(1);
439 }
440 if (!strncmp(line,"NROWS=",6) ||
441 !strncmp(line,"NCOLS=",6) ||
442 !strncmp(line,"NCOMP=",6))
443 return(1);
444
445 if (original && isexpos(line)) {
446 d = 1.0/exposval(line);
447 scalecolor(exposure, d);
448 doexposure++;
449 return(1);
450 }
451 if (original && iscolcor(line)) {
452 colcorval(ctmp, line);
453 setcolor(exposure, colval(exposure,RED)/colval(ctmp,RED),
454 colval(exposure,GRN)/colval(ctmp,GRN),
455 colval(exposure,BLU)/colval(ctmp,BLU));
456 doexposure++;
457 return(1);
458 }
459 if ((rv = isbigendian(line)) >= 0) {
460 if (reverse)
461 swapbytes = (nativebigendian() != rv);
462 return(1);
463 }
464 if (fout != NULL)
465 fputs(line, fout);
466 return(0);
467 }
468
469
470 static void
471 pixtoval(void) /* convert picture to values */
472 {
473 COLOR *scanln;
474 int dogamma;
475 COLOR lastc;
476 RREAL hv[2];
477 int startprim, endprim;
478 long startpos;
479 int x, y;
480
481 scanln = (COLOR *)malloc(scanlen(&picres)*sizeof(COLOR));
482 if (scanln == NULL) {
483 fprintf(stderr, "%s: out of memory\n", progname);
484 quit(1);
485 }
486 dogamma = gamcor < .95 || gamcor > 1.05;
487 if ((putprim == ALL) & !interleave) {
488 startprim = RED; endprim = BLU;
489 startpos = ftell(fin);
490 } else {
491 startprim = putprim; endprim = putprim;
492 }
493 for (putprim = startprim; putprim <= endprim; putprim++) {
494 if (putprim != startprim && fseek(fin, startpos, SEEK_SET)) {
495 fprintf(stderr, "%s: seek error on input file\n",
496 progname);
497 quit(1);
498 }
499 set_io();
500 setcolor(lastc, 0.0, 0.0, 0.0);
501 for (y = 0; y < numscans(&picres); y++) {
502 if (freadscan(scanln, scanlen(&picres), fin) < 0) {
503 fprintf(stderr, "%s: read error\n", progname);
504 quit(1);
505 }
506 for (x = 0; x < scanlen(&picres); x++) {
507 if (uniq) {
508 if ( colval(scanln[x],RED) ==
509 colval(lastc,RED) &&
510 colval(scanln[x],GRN) ==
511 colval(lastc,GRN) &&
512 colval(scanln[x],BLU) ==
513 colval(lastc,BLU) )
514 continue;
515 else
516 copycolor(lastc, scanln[x]);
517 }
518 if (doexposure)
519 multcolor(scanln[x], exposure);
520 if (dogamma)
521 setcolor(scanln[x],
522 pow(colval(scanln[x],RED), 1.0/gamcor),
523 pow(colval(scanln[x],GRN), 1.0/gamcor),
524 pow(colval(scanln[x],BLU), 1.0/gamcor));
525 if (!dataonly) {
526 pix2loc(hv, &picres, x, y);
527 printf("%7d %7d ",
528 (int)(hv[0]*picres.xr),
529 (int)(hv[1]*picres.yr));
530 }
531 if ((*putval)(scanln[x]) < 0) {
532 fprintf(stderr, "%s: write error\n",
533 progname);
534 quit(1);
535 }
536 }
537 }
538 }
539 free((void *)scanln);
540 }
541
542
543 static void
544 valtopix(void) /* convert values to a pixel file */
545 {
546 int dogamma;
547 COLOR *scanln;
548 COLR rgbe;
549 int x, y;
550
551 scanln = (COLOR *)malloc(scanlen(&picres)*sizeof(COLOR));
552 if (scanln == NULL) {
553 fprintf(stderr, "%s: out of memory\n", progname);
554 quit(1);
555 }
556 dogamma = gamcor < .95 || gamcor > 1.05;
557 set_io();
558 for (y = 0; y < numscans(&picres); y++) {
559 for (x = 0; x < scanlen(&picres); x++) {
560 if (!dataonly) {
561 fscanf(fin, "%*d %*d");
562 if (fin2 != NULL) {
563 fscanf(fin2, "%*d %*d");
564 fscanf(fin3, "%*d %*d");
565 }
566 }
567 if ((*getval)(scanln[x]) < 0) {
568 fprintf(stderr, "%s: read error\n", progname);
569 quit(1);
570 }
571 if (dogamma)
572 setcolor(scanln[x],
573 pow(colval(scanln[x],RED), gamcor),
574 pow(colval(scanln[x],GRN), gamcor),
575 pow(colval(scanln[x],BLU), gamcor));
576 if (doexposure)
577 multcolor(scanln[x], exposure);
578 if (uniq) { /* uncompressed? */
579 setcolr(rgbe, scanln[x][RED],
580 scanln[x][GRN],
581 scanln[x][BLU]);
582 if (putbinary(rgbe, sizeof(COLR), 1, stdout) != 1)
583 goto writerr;
584 }
585 }
586 /* write scan if compressed */
587 if (!uniq && fwritescan(scanln, scanlen(&picres), stdout) < 0)
588 goto writerr;
589 }
590 free((void *)scanln);
591 return;
592 writerr:
593 fprintf(stderr, "%s: write error\n", progname);
594 quit(1);
595 }
596
597
598 void
599 quit(code)
600 int code;
601 {
602 exit(code);
603 }
604
605
606 static int
607 getcascii( /* get an ascii color value from stream(s) */
608 COLOR col
609 )
610 {
611 double vd[3];
612
613 if (fin2 == NULL) {
614 if (fscanf(fin, "%lf %lf %lf", &vd[0], &vd[1], &vd[2]) != 3)
615 return(-1);
616 } else {
617 if (fscanf(fin, "%lf", &vd[0]) != 1 ||
618 fscanf(fin2, "%lf", &vd[1]) != 1 ||
619 fscanf(fin3, "%lf", &vd[2]) != 1)
620 return(-1);
621 }
622 setcolor(col, vd[rord[RED]], vd[rord[GRN]], vd[rord[BLU]]);
623 return(0);
624 }
625
626
627 static int
628 getcdouble( /* get a double color value from stream(s) */
629 COLOR col
630 )
631 {
632 double vd[3];
633
634 if (fin2 == NULL) {
635 if (getbinary(vd, sizeof(double), 3, fin) != 3)
636 return(-1);
637 } else {
638 if (getbinary(vd, sizeof(double), 1, fin) != 1 ||
639 getbinary(vd+1, sizeof(double), 1, fin2) != 1 ||
640 getbinary(vd+2, sizeof(double), 1, fin3) != 1)
641 return(-1);
642 }
643 if (swapbytes)
644 swap64((char *)vd, 3);
645 setcolor(col, vd[rord[RED]], vd[rord[GRN]], vd[rord[BLU]]);
646 return(0);
647 }
648
649
650 static int
651 getcfloat( /* get a float color value from stream(s) */
652 COLOR col
653 )
654 {
655 float vf[3];
656
657 if (fin2 == NULL) {
658 if (getbinary(vf, sizeof(float), 3, fin) != 3)
659 return(-1);
660 } else {
661 if (getbinary(vf, sizeof(float), 1, fin) != 1 ||
662 getbinary(vf+1, sizeof(float), 1, fin2) != 1 ||
663 getbinary(vf+2, sizeof(float), 1, fin3) != 1)
664 return(-1);
665 }
666 if (swapbytes)
667 swap32((char *)vf, 3);
668 setcolor(col, vf[rord[RED]], vf[rord[GRN]], vf[rord[BLU]]);
669 return(0);
670 }
671
672
673 static int
674 getcint( /* get an int color value from stream(s) */
675 COLOR col
676 )
677 {
678 int vi[3];
679
680 if (fin2 == NULL) {
681 if (fscanf(fin, "%d %d %d", &vi[0], &vi[1], &vi[2]) != 3)
682 return(-1);
683 } else {
684 if (fscanf(fin, "%d", &vi[0]) != 1 ||
685 fscanf(fin2, "%d", &vi[1]) != 1 ||
686 fscanf(fin3, "%d", &vi[2]) != 1)
687 return(-1);
688 }
689 setcolor(col, (vi[rord[RED]]+.5)/256.,
690 (vi[rord[GRN]]+.5)/256., (vi[rord[BLU]]+.5)/256.);
691 return(0);
692 }
693
694
695 static int
696 getcbyte( /* get a byte color value from stream(s) */
697 COLOR col
698 )
699 {
700 uby8 vb[3];
701
702 if (fin2 == NULL) {
703 if (getbinary(vb, sizeof(uby8), 3, fin) != 3)
704 return(-1);
705 } else {
706 if (getbinary(vb, sizeof(uby8), 1, fin) != 1 ||
707 getbinary(vb+1, sizeof(uby8), 1, fin2) != 1 ||
708 getbinary(vb+2, sizeof(uby8), 1, fin3) != 1)
709 return(-1);
710 }
711 setcolor(col, (vb[rord[RED]]+.5)/256.,
712 (vb[rord[GRN]]+.5)/256., (vb[rord[BLU]]+.5)/256.);
713 return(0);
714 }
715
716
717 static int
718 getcword( /* get a 16-bit color value from stream(s) */
719 COLOR col
720 )
721 {
722 uint16 vw[3];
723
724 if (fin2 == NULL) {
725 if (getbinary(vw, sizeof(uint16), 3, fin) != 3)
726 return(-1);
727 } else {
728 if (getbinary(vw, sizeof(uint16), 1, fin) != 1 ||
729 getbinary(vw+1, sizeof(uint16), 1, fin2) != 1 ||
730 getbinary(vw+2, sizeof(uint16), 1, fin3) != 1)
731 return(-1);
732 }
733 if (swapbytes)
734 swap16((char *)vw, 3);
735 setcolor(col, (vw[rord[RED]]+.5)/65536.,
736 (vw[rord[GRN]]+.5)/65536., (vw[rord[BLU]]+.5)/65536.);
737 return(0);
738 }
739
740
741 static int
742 getbascii( /* get an ascii brightness value from fin */
743 COLOR col
744 )
745 {
746 double vd;
747
748 if (fscanf(fin, "%lf", &vd) != 1)
749 return(-1);
750 setcolor(col, vd, vd, vd);
751 return(0);
752 }
753
754
755 static int
756 getbdouble( /* get a double brightness value from fin */
757 COLOR col
758 )
759 {
760 double vd;
761
762 if (getbinary(&vd, sizeof(double), 1, fin) != 1)
763 return(-1);
764 if (swapbytes)
765 swap64((char *)&vd, 1);
766 setcolor(col, vd, vd, vd);
767 return(0);
768 }
769
770
771 static int
772 getbfloat( /* get a float brightness value from fin */
773 COLOR col
774 )
775 {
776 float vf;
777
778 if (getbinary(&vf, sizeof(float), 1, fin) != 1)
779 return(-1);
780 if (swapbytes)
781 swap32((char *)&vf, 1);
782 setcolor(col, vf, vf, vf);
783 return(0);
784 }
785
786
787 static int
788 getbint( /* get an int brightness value from fin */
789 COLOR col
790 )
791 {
792 int vi;
793 double d;
794
795 if (fscanf(fin, "%d", &vi) != 1)
796 return(-1);
797 d = (vi+.5)/256.;
798 setcolor(col, d, d, d);
799 return(0);
800 }
801
802
803 static int
804 getbbyte( /* get a byte brightness value from fin */
805 COLOR col
806 )
807 {
808 uby8 vb;
809 double d;
810
811 if (getbinary(&vb, sizeof(uby8), 1, fin) != 1)
812 return(-1);
813 d = (vb+.5)/256.;
814 setcolor(col, d, d, d);
815 return(0);
816 }
817
818
819 static int
820 getbword( /* get a 16-bit brightness value from fin */
821 COLOR col
822 )
823 {
824 uint16 vw;
825 double d;
826
827 if (getbinary(&vw, sizeof(uint16), 1, fin) != 1)
828 return(-1);
829 if (swapbytes)
830 swap16((char *)&vw, 1);
831 d = (vw+.5)/65536.;
832 setcolor(col, d, d, d);
833 return(0);
834 }
835
836
837 static int
838 putcascii( /* put an ascii color to stdout */
839 COLOR col
840 )
841 {
842 fprintf(stdout, "%15.3e %15.3e %15.3e\n",
843 colval(col,ord[0]),
844 colval(col,ord[1]),
845 colval(col,ord[2]));
846
847 return(ferror(stdout) ? -1 : 0);
848 }
849
850
851 static int
852 putcfloat( /* put a float color to stdout */
853 COLOR col
854 )
855 {
856 float vf[3];
857
858 vf[0] = colval(col,ord[0]);
859 vf[1] = colval(col,ord[1]);
860 vf[2] = colval(col,ord[2]);
861 if (swapbytes)
862 swap32((char *)vf, 3);
863 putbinary(vf, sizeof(float), 3, stdout);
864
865 return(ferror(stdout) ? -1 : 0);
866 }
867
868
869 static int
870 putcdouble( /* put a double color to stdout */
871 COLOR col
872 )
873 {
874 double vd[3];
875
876 vd[0] = colval(col,ord[0]);
877 vd[1] = colval(col,ord[1]);
878 vd[2] = colval(col,ord[2]);
879 if (swapbytes)
880 swap64((char *)vd, 3);
881 putbinary(vd, sizeof(double), 3, stdout);
882
883 return(ferror(stdout) ? -1 : 0);
884 }
885
886
887 static int
888 putcint( /* put an int color to stdout */
889 COLOR col
890 )
891 {
892 fprintf(stdout, "%d %d %d\n",
893 (int)(colval(col,ord[0])*256.),
894 (int)(colval(col,ord[1])*256.),
895 (int)(colval(col,ord[2])*256.));
896
897 return(ferror(stdout) ? -1 : 0);
898 }
899
900
901 static int
902 putcbyte( /* put a byte color to stdout */
903 COLOR col
904 )
905 {
906 long i;
907 uby8 vb[3];
908
909 i = colval(col,ord[0])*256.;
910 vb[0] = min(i,255);
911 i = colval(col,ord[1])*256.;
912 vb[1] = min(i,255);
913 i = colval(col,ord[2])*256.;
914 vb[2] = min(i,255);
915 putbinary(vb, sizeof(uby8), 3, stdout);
916
917 return(ferror(stdout) ? -1 : 0);
918 }
919
920
921 static int
922 putcword( /* put a 16-bit color to stdout */
923 COLOR col
924 )
925 {
926 long i;
927 uint16 vw[3];
928
929 i = colval(col,ord[0])*65536.;
930 vw[0] = min(i,65535);
931 i = colval(col,ord[1])*65536.;
932 vw[1] = min(i,65535);
933 i = colval(col,ord[2])*65536.;
934 vw[2] = min(i,65535);
935 if (swapbytes)
936 swap16((char *)vw, 3);
937 putbinary(vw, sizeof(uint16), 3, stdout);
938
939 return(ferror(stdout) ? -1 : 0);
940 }
941
942
943 static int
944 putbascii( /* put an ascii brightness to stdout */
945 COLOR col
946 )
947 {
948 fprintf(stdout, "%15.3e\n", (*mybright)(col));
949
950 return(ferror(stdout) ? -1 : 0);
951 }
952
953
954 static int
955 putbfloat( /* put a float brightness to stdout */
956 COLOR col
957 )
958 {
959 float vf;
960
961 vf = (*mybright)(col);
962 if (swapbytes)
963 swap32((char *)&vf, 1);
964 putbinary(&vf, sizeof(float), 1, stdout);
965
966 return(ferror(stdout) ? -1 : 0);
967 }
968
969
970 static int
971 putbdouble( /* put a double brightness to stdout */
972 COLOR col
973 )
974 {
975 double vd;
976
977 vd = (*mybright)(col);
978 if (swapbytes)
979 swap64((char *)&vd, 1);
980 putbinary(&vd, sizeof(double), 1, stdout);
981
982 return(ferror(stdout) ? -1 : 0);
983 }
984
985
986 static int
987 putbint( /* put an int brightness to stdout */
988 COLOR col
989 )
990 {
991 fprintf(stdout, "%d\n", (int)((*mybright)(col)*256.));
992
993 return(ferror(stdout) ? -1 : 0);
994 }
995
996
997 static int
998 putbbyte( /* put a byte brightness to stdout */
999 COLOR col
1000 )
1001 {
1002 int i;
1003 uby8 vb;
1004
1005 i = (*mybright)(col)*256.;
1006 vb = min(i,255);
1007 putbinary(&vb, sizeof(uby8), 1, stdout);
1008
1009 return(ferror(stdout) ? -1 : 0);
1010 }
1011
1012
1013 static int
1014 putbword( /* put a 16-bit brightness to stdout */
1015 COLOR col
1016 )
1017 {
1018 long i;
1019 uint16 vw;
1020
1021 i = (*mybright)(col)*65536.;
1022 vw = min(i,65535);
1023 if (swapbytes)
1024 swap16((char *)&vw, 1);
1025 putbinary(&vw, sizeof(uint16), 1, stdout);
1026
1027 return(ferror(stdout) ? -1 : 0);
1028 }
1029
1030
1031 static int
1032 putpascii( /* put an ascii primary to stdout */
1033 COLOR col
1034 )
1035 {
1036 fprintf(stdout, "%15.3e\n", colval(col,putprim));
1037
1038 return(ferror(stdout) ? -1 : 0);
1039 }
1040
1041
1042 static int
1043 putpfloat( /* put a float primary to stdout */
1044 COLOR col
1045 )
1046 {
1047 float vf;
1048
1049 vf = colval(col,putprim);
1050 if (swapbytes)
1051 swap32((char *)&vf, 1);
1052 putbinary(&vf, sizeof(float), 1, stdout);
1053
1054 return(ferror(stdout) ? -1 : 0);
1055 }
1056
1057
1058 static int
1059 putpdouble( /* put a double primary to stdout */
1060 COLOR col
1061 )
1062 {
1063 double vd;
1064
1065 vd = colval(col,putprim);
1066 if (swapbytes)
1067 swap64((char *)&vd, 1);
1068 putbinary(&vd, sizeof(double), 1, stdout);
1069
1070 return(ferror(stdout) ? -1 : 0);
1071 }
1072
1073
1074 static int
1075 putpint( /* put an int primary to stdout */
1076 COLOR col
1077 )
1078 {
1079 fprintf(stdout, "%d\n", (int)(colval(col,putprim)*256.));
1080
1081 return(ferror(stdout) ? -1 : 0);
1082 }
1083
1084
1085 static int
1086 putpbyte( /* put a byte primary to stdout */
1087 COLOR col
1088 )
1089 {
1090 long i;
1091 uby8 vb;
1092
1093 i = colval(col,putprim)*256.;
1094 vb = min(i,255);
1095 putbinary(&vb, sizeof(uby8), 1, stdout);
1096
1097 return(ferror(stdout) ? -1 : 0);
1098 }
1099
1100
1101 static int
1102 putpword( /* put a 16-bit primary to stdout */
1103 COLOR col
1104 )
1105 {
1106 long i;
1107 uint16 vw;
1108
1109 i = colval(col,putprim)*65536.;
1110 vw = min(i,65535);
1111 if (swapbytes)
1112 swap16((char *)&vw, 1);
1113 putbinary(&vw, sizeof(uint16), 1, stdout);
1114
1115 return(ferror(stdout) ? -1 : 0);
1116 }
1117
1118
1119 static void
1120 set_io(void) /* set put and get functions */
1121 {
1122 switch (format) {
1123 case 'a': /* ascii */
1124 if (putprim == BRIGHT) {
1125 getval = getbascii;
1126 putval = putbascii;
1127 } else if (putprim != ALL) {
1128 getval = getbascii;
1129 putval = putpascii;
1130 } else {
1131 getval = getcascii;
1132 putval = putcascii;
1133 if (reverse && !interleave) {
1134 fprintf(stderr,
1135 "%s: ASCII input files must be interleaved\n",
1136 progname);
1137 quit(1);
1138 }
1139 }
1140 return;
1141 case 'f': /* binary float */
1142 if (putprim == BRIGHT) {
1143 getval = getbfloat;
1144 putval = putbfloat;
1145 } else if (putprim != ALL) {
1146 getval = getbfloat;
1147 putval = putpfloat;
1148 } else {
1149 getval = getcfloat;
1150 putval = putcfloat;
1151 if (reverse && !interleave) {
1152 if (fin2 == NULL)
1153 goto namerr;
1154 if (fseek(fin2,
1155 (long)sizeof(float)*picres.xr*picres.yr, SEEK_CUR))
1156 goto seekerr;
1157 if (fseek(fin3,
1158 (long)sizeof(float)*2*picres.xr*picres.yr, SEEK_CUR))
1159 goto seekerr;
1160 }
1161 }
1162 return;
1163 case 'd': /* binary double */
1164 if (putprim == BRIGHT) {
1165 getval = getbdouble;
1166 putval = putbdouble;
1167 } else if (putprim != ALL) {
1168 getval = getbdouble;
1169 putval = putpdouble;
1170 } else {
1171 getval = getcdouble;
1172 putval = putcdouble;
1173 if (reverse && !interleave) {
1174 if (fin2 == NULL)
1175 goto namerr;
1176 if (fseek(fin2,
1177 (long)sizeof(double)*picres.xr*picres.yr, SEEK_CUR))
1178 goto seekerr;
1179 if (fseek(fin3,
1180 (long)sizeof(double)*2*picres.xr*picres.yr, SEEK_CUR))
1181 goto seekerr;
1182 }
1183 }
1184 return;
1185 case 'i': /* integer */
1186 if (putprim == BRIGHT) {
1187 getval = getbint;
1188 putval = putbint;
1189 } else if (putprim != ALL) {
1190 getval = getbint;
1191 putval = putpint;
1192 } else {
1193 getval = getcint;
1194 putval = putcint;
1195 if (reverse && !interleave) {
1196 fprintf(stderr,
1197 "%s: integer input files must be interleaved\n",
1198 progname);
1199 quit(1);
1200 }
1201 }
1202 return;
1203 case 'b': /* byte */
1204 if (putprim == BRIGHT) {
1205 getval = getbbyte;
1206 putval = putbbyte;
1207 } else if (putprim != ALL) {
1208 getval = getbbyte;
1209 putval = putpbyte;
1210 } else {
1211 getval = getcbyte;
1212 putval = putcbyte;
1213 if (reverse && !interleave) {
1214 if (fin2 == NULL)
1215 goto namerr;
1216 if (fseek(fin2,
1217 (long)sizeof(uby8)*picres.xr*picres.yr, SEEK_CUR))
1218 goto seekerr;
1219 if (fseek(fin3,
1220 (long)sizeof(uby8)*2*picres.xr*picres.yr, SEEK_CUR))
1221 goto seekerr;
1222 }
1223 }
1224 return;
1225 case 'w': /* 16-bit */
1226 if (putprim == BRIGHT) {
1227 getval = getbword;
1228 putval = putbword;
1229 } else if (putprim != ALL) {
1230 getval = getbword;
1231 putval = putpword;
1232 } else {
1233 getval = getcword;
1234 putval = putcword;
1235 if (reverse && !interleave) {
1236 if (fin2 == NULL)
1237 goto namerr;
1238 if (fseek(fin2,
1239 (long)sizeof(uint16)*picres.xr*picres.yr, SEEK_CUR))
1240 goto seekerr;
1241 if (fseek(fin3,
1242 (long)sizeof(uint16)*2*picres.xr*picres.yr, SEEK_CUR))
1243 goto seekerr;
1244 }
1245 }
1246 return;
1247 }
1248 /* badopt: */ /* label not used */
1249 fprintf(stderr, "%s: botched file type\n", progname);
1250 quit(1);
1251 namerr:
1252 fprintf(stderr, "%s: non-interleaved file(s) must be named\n",
1253 progname);
1254 quit(1);
1255 seekerr:
1256 fprintf(stderr, "%s: cannot seek on interleaved input file\n",
1257 progname);
1258 quit(1);
1259 }
