| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: pvalue.c,v 2.39 2020/03/30 19:02:26 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* pvalue.c - program to print pixel values.
| 6 |
| 7 |
* 4/23/86
| 8 |
| 9 |
| 10 |
#include "platform.h"
| 11 |
#include "standard.h"
| 12 |
#include "color.h"
| 13 |
#include "resolu.h"
| 14 |
#include "view.h"
| 15 |
| 16 |
#define min(a,b) ((a)<(b)?(a):(b))
| 17 |
| 18 |
/* what to put out (also RED, GRN, BLU) */
| 19 |
#define ALL 3
| 20 |
#define BRIGHT 4
| 21 |
| 22 |
RESOLU picres; /* resolution of picture */
| 23 |
int uniq = 0; /* print only unique values? */
| 24 |
int doexposure = 0; /* exposure change? (>100 to print) */
| 25 |
int dataonly = 0; /* data only format? */
| 26 |
int putprim = ALL; /* what to put out */
| 27 |
int reverse = 0; /* reverse conversion? */
| 28 |
int format = 'a'; /* input/output format */
| 29 |
char *fmtid = "ascii"; /* format identifier for header */
| 30 |
int header = 1; /* do header? */
| 31 |
long skipbytes = 0; /* skip bytes in input? */
| 32 |
int swapbytes = 0; /* swap bytes? */
| 33 |
int interleave = 1; /* file is interleaved? */
| 34 |
int resolution = 1; /* put/get resolution string? */
| 35 |
int original = 0; /* convert to original values? */
| 36 |
int wrongformat = 0; /* wrong input format? */
| 37 |
double gamcor = 1.0; /* gamma correction */
| 38 |
| 39 |
RGBPRIMP outprims = stdprims; /* output primaries for reverse conversion */
| 40 |
RGBPRIMS myprims;
| 41 |
| 42 |
int ord[3] = {RED, GRN, BLU}; /* RGB ordering */
| 43 |
int rord[4]; /* reverse ordering */
| 44 |
| 45 |
COLOR exposure = WHTCOLOR;
| 46 |
| 47 |
char *progname;
| 48 |
| 49 |
FILE *fin;
| 50 |
FILE *fin2 = NULL, *fin3 = NULL; /* for other color channels */
| 51 |
| 52 |
| 53 |
typedef int getfunc_t(COLOR col);
| 54 |
typedef int putfunc_t(COLOR col);
| 55 |
typedef double brightfunc_t(COLOR col);
| 56 |
| 57 |
getfunc_t *getval;
| 58 |
putfunc_t *putval;
| 59 |
brightfunc_t *mybright;
| 60 |
| 61 |
static gethfunc checkhead;
| 62 |
static brightfunc_t rgb_bright, xyz_bright;
| 63 |
static getfunc_t getbascii, getbint, getbdouble, getbfloat, getbbyte, getbword;
| 64 |
static getfunc_t getcascii, getcint, getcdouble, getcfloat, getcbyte, getcword;
| 65 |
static putfunc_t putbascii, putbint, putbdouble, putbfloat, putbbyte, putbword;
| 66 |
static putfunc_t putcascii, putcint, putcdouble, putcfloat, putcbyte, putcword;
| 67 |
static putfunc_t putpascii, putpint, putpdouble, putpfloat, putpbyte, putpword;
| 68 |
| 69 |
static void set_io(void);
| 70 |
static void pixtoval(void);
| 71 |
static void valtopix(void);
| 72 |
| 73 |
| 74 |
static double
| 75 |
rgb_bright(
| 76 |
COLOR clr
| 77 |
| 78 |
| 79 |
return(bright(clr));
| 80 |
| 81 |
| 82 |
static double
| 83 |
xyz_bright(
| 84 |
COLOR clr
| 85 |
| 86 |
| 87 |
return(clr[CIEY]);
| 88 |
| 89 |
| 90 |
int
| 91 |
main(
| 92 |
int argc,
| 93 |
char **argv
| 94 |
| 95 |
| 96 |
const char *inpmode = "r";
| 97 |
double d, expval = 1.0;
| 98 |
int i;
| 99 |
| 100 |
progname = argv[0];
| 101 |
mybright = &rgb_bright; /* default */
| 102 |
| 103 |
for (i = 1; i < argc; i++)
| 104 |
if (argv[i][0] == '-' || argv[i][0] == '+')
| 105 |
switch (argv[i][1]) {
| 106 |
case 'h': /* header */
| 107 |
header = argv[i][0] == '+';
| 108 |
break;
| 109 |
case 'H': /* resolution string */
| 110 |
resolution = argv[i][0] == '+';
| 111 |
break;
| 112 |
case 's': /* skip bytes in header */
| 113 |
skipbytes = atol(argv[++i]);
| 114 |
break;
| 115 |
case 'u': /* unique values */
| 116 |
uniq = argv[i][0] == '-';
| 117 |
break;
| 118 |
case 'o': /* original values */
| 119 |
original = argv[i][0] == '-';
| 120 |
break;
| 121 |
case 'g': /* gamma correction */
| 122 |
gamcor = atof(argv[i+1]);
| 123 |
if (argv[i][0] == '+')
| 124 |
gamcor = 1.0/gamcor;
| 125 |
i++;
| 126 |
break;
| 127 |
case 'e': /* exposure correction */
| 128 |
d = atof(argv[i+1]);
| 129 |
if (argv[i+1][0] == '-' || argv[i+1][0] == '+')
| 130 |
d = pow(2.0, d);
| 131 |
if (argv[i][0] == '-')
| 132 |
expval *= d;
| 133 |
scalecolor(exposure, d);
| 134 |
doexposure++;
| 135 |
i++;
| 136 |
break;
| 137 |
case 'R': /* reverse byte sequence */
| 138 |
if (argv[i][0] == '-') {
| 139 |
ord[0]=BLU; ord[1]=GRN; ord[2]=RED;
| 140 |
} else {
| 141 |
ord[0]=RED; ord[1]=GRN; ord[2]=BLU;
| 142 |
| 143 |
break;
| 144 |
case 'r': /* reverse conversion */
| 145 |
reverse = argv[i][0] == '-';
| 146 |
break;
| 147 |
case 'n': /* non-interleaved RGB */
| 148 |
interleave = argv[i][0] == '+';
| 149 |
break;
| 150 |
case 'b': /* brightness values */
| 151 |
putprim = argv[i][0] == '-' ? BRIGHT : ALL;
| 152 |
break;
| 153 |
case 'p': /* primary controls */
| 154 |
switch (argv[i][2]) {
| 155 |
/* these two options affect -r conversion */
| 156 |
case '\0':
| 157 |
myprims[RED][CIEX] = atof(argv[++i]);
| 158 |
myprims[RED][CIEY] = atof(argv[++i]);
| 159 |
myprims[GRN][CIEX] = atof(argv[++i]);
| 160 |
myprims[GRN][CIEY] = atof(argv[++i]);
| 161 |
myprims[BLU][CIEX] = atof(argv[++i]);
| 162 |
myprims[BLU][CIEY] = atof(argv[++i]);
| 163 |
myprims[WHT][CIEX] = atof(argv[++i]);
| 164 |
myprims[WHT][CIEY] = atof(argv[++i]);
| 165 |
outprims = myprims;
| 166 |
break;
| 167 |
case 'x': case 'X': outprims = NULL; break;
| 168 |
/* the following options affect +r only */
| 169 |
case 'r': case 'R': putprim = RED; break;
| 170 |
case 'g': case 'G': putprim = GRN; break;
| 171 |
case 'b': case 'B': putprim = BLU; break;
| 172 |
default: goto unkopt;
| 173 |
| 174 |
break;
| 175 |
case 'd': /* data only (no indices) */
| 176 |
dataonly = (argv[i][0] == '-');
| 177 |
| 178 |
case '\0':
| 179 |
case 'a': /* ascii */
| 180 |
format = 'a';
| 181 |
fmtid = "ascii";
| 182 |
break;
| 183 |
case 'i': /* integer */
| 184 |
format = 'i';
| 185 |
fmtid = "ascii";
| 186 |
break;
| 187 |
case 'b': /* byte */
| 188 |
dataonly = 1;
| 189 |
format = 'b';
| 190 |
fmtid = "byte";
| 191 |
break;
| 192 |
case 'W': /* 16-bit swapped */
| 193 |
swapbytes = 1;
| 194 |
case 'w': /* 16-bit */
| 195 |
dataonly = 1;
| 196 |
format = 'w';
| 197 |
fmtid = "16-bit";
| 198 |
break;
| 199 |
case 'F': /* swapped floats */
| 200 |
swapbytes = 1;
| 201 |
case 'f': /* float */
| 202 |
dataonly = 1;
| 203 |
format = 'f';
| 204 |
fmtid = "float";
| 205 |
break;
| 206 |
case 'D': /* swapped doubles */
| 207 |
swapbytes = 1;
| 208 |
case 'd': /* double */
| 209 |
dataonly = 1;
| 210 |
format = 'd';
| 211 |
fmtid = "double";
| 212 |
break;
| 213 |
default:
| 214 |
goto unkopt;
| 215 |
| 216 |
break;
| 217 |
case 'x': /* x resolution */
| 218 |
case 'X': /* x resolution */
| 219 |
resolution = 0;
| 220 |
| 221 |
picres.rt |= XDECR;
| 222 |
picres.xr = atoi(argv[++i]);
| 223 |
break;
| 224 |
case 'y': /* y resolution */
| 225 |
case 'Y': /* y resolution */
| 226 |
resolution = 0;
| 227 |
| 228 |
picres.rt |= YDECR;
| 229 |
if (picres.xr == 0)
| 230 |
picres.rt |= YMAJOR;
| 231 |
picres.yr = atoi(argv[++i]);
| 232 |
break;
| 233 |
default:
| 234 |
unkopt:
| 235 |
fprintf(stderr, "%s: unknown option: %s\n",
| 236 |
progname, argv[i]);
| 237 |
quit(1);
| 238 |
break;
| 239 |
| 240 |
else
| 241 |
break;
| 242 |
/* recognize special formats */
| 243 |
if (dataonly && format == 'b') {
| 244 |
if (putprim == ALL)
| 245 |
fmtid = "24-bit_rgb";
| 246 |
else
| 247 |
fmtid = "8-bit_grey";
| 248 |
| 249 |
if (dataonly && format == 'w') {
| 250 |
if (putprim == ALL)
| 251 |
fmtid = "48-bit_rgb";
| 252 |
else
| 253 |
fmtid = "16-bit_grey";
| 254 |
| 255 |
if (!reverse || (format != 'a') & (format != 'i'))
| 256 |
inpmode = "rb";
| 257 |
/* assign reverse ordering */
| 258 |
rord[ord[0]] = 0;
| 259 |
rord[ord[1]] = 1;
| 260 |
rord[ord[2]] = 2;
| 261 |
/* get input */
| 262 |
if (i == argc) {
| 263 |
long n = skipbytes;
| 264 |
if (inpmode[1] == 'b')
| 265 |
SET_FILE_BINARY(stdin);
| 266 |
while (n-- > 0)
| 267 |
if (getchar() == EOF) {
| 268 |
fprintf(stderr,
| 269 |
"%s: cannot skip %ld bytes on standard input\n",
| 270 |
progname, skipbytes);
| 271 |
quit(1);
| 272 |
| 273 |
fin = stdin;
| 274 |
} else if (i < argc) {
| 275 |
if ((fin = fopen(argv[i], inpmode)) == NULL) {
| 276 |
fprintf(stderr, "%s: can't open file \"%s\"\n",
| 277 |
progname, argv[i]);
| 278 |
quit(1);
| 279 |
| 280 |
if (reverse && putprim != BRIGHT && i == argc-3) {
| 281 |
if ((fin2 = fopen(argv[i+1], inpmode)) == NULL) {
| 282 |
| 283 |
progname, argv[i+1]);
| 284 |
quit(1);
| 285 |
| 286 |
if ((fin3 = fopen(argv[i+2], inpmode)) == NULL) {
| 287 |
| 288 |
progname, argv[i+2]);
| 289 |
quit(1);
| 290 |
| 291 |
interleave = -1;
| 292 |
} else if (i != argc-1)
| 293 |
fin = NULL;
| 294 |
if (reverse && putprim != BRIGHT && !interleave) {
| 295 |
fin2 = fopen(argv[i], inpmode);
| 296 |
fin3 = fopen(argv[i], inpmode);
| 297 |
| 298 |
if (skipbytes && (fseek(fin, skipbytes, SEEK_SET) || (fin2 != NULL &&
| 299 |
fseek(fin2, skipbytes, SEEK_SET) |
| 300 |
fseek(fin3, skipbytes, SEEK_SET)))) {
| 301 |
fprintf(stderr, "%s: cannot skip %ld bytes on input\n",
| 302 |
| 303 |
quit(1);
| 304 |
| 305 |
| 306 |
if (fin == NULL) {
| 307 |
fprintf(stderr, "%s: bad # file arguments\n", progname);
| 308 |
quit(1);
| 309 |
| 310 |
| 311 |
if (reverse) {
| 312 |
SET_FILE_BINARY(stdout);
| 313 |
/* get header */
| 314 |
if (header) {
| 315 |
getheader(fin, checkhead, stdout);
| 316 |
if (wrongformat) {
| 317 |
fprintf(stderr, "%s: wrong input format (expected %s)\n",
| 318 |
progname, fmtid);
| 319 |
quit(1);
| 320 |
| 321 |
if (fin2 != NULL) {
| 322 |
getheader(fin2, NULL, NULL);
| 323 |
getheader(fin3, NULL, NULL);
| 324 |
| 325 |
} else
| 326 |
newheader("RADIANCE", stdout);
| 327 |
/* get resolution */
| 328 |
if ((resolution && !fgetsresolu(&picres, fin)) ||
| 329 |
picres.xr <= 0 || picres.yr <= 0) {
| 330 |
fprintf(stderr, "%s: missing resolution\n", progname);
| 331 |
quit(1);
| 332 |
| 333 |
if (resolution && fin2 != NULL) {
| 334 |
RESOLU pres2;
| 335 |
if (!fgetsresolu(&pres2, fin2) ||
| 336 |
pres2.rt != picres.rt ||
| 337 |
pres2.xr != picres.xr ||
| 338 |
pres2.yr != picres.yr ||
| 339 |
!fgetsresolu(&pres2, fin3) ||
| 340 |
| 341 |
| 342 |
pres2.yr != picres.yr) {
| 343 |
fprintf(stderr, "%s: resolution mismatch\n",
| 344 |
progname);
| 345 |
quit(1);
| 346 |
| 347 |
| 348 |
/* add to header */
| 349 |
printargs(i, argv, stdout);
| 350 |
if (expval < .99 || expval > 1.01)
| 351 |
fputexpos(expval, stdout);
| 352 |
if (outprims != NULL) {
| 353 |
if (outprims != stdprims)
| 354 |
fputprims(outprims, stdout);
| 355 |
fputformat(COLRFMT, stdout);
| 356 |
} else /* XYZ data */
| 357 |
fputformat(CIEFMT, stdout);
| 358 |
putchar('\n');
| 359 |
fputsresolu(&picres, stdout); /* always put resolution */
| 360 |
valtopix();
| 361 |
} else {
| 362 |
if ((format != 'a') & (format != 'i'))
| 363 |
| 364 |
/* get header */
| 365 |
getheader(fin, checkhead, header ? stdout : (FILE *)NULL);
| 366 |
if (wrongformat) {
| 367 |
fprintf(stderr,
| 368 |
"%s: input not a Radiance RGBE picture\n",
| 369 |
progname);
| 370 |
quit(1);
| 371 |
| 372 |
if (!fgetsresolu(&picres, fin)) {
| 373 |
| 374 |
quit(1);
| 375 |
| 376 |
if (header) {
| 377 |
| 378 |
printf("NCOMP=%d\n", putprim==ALL ? 3 : 1);
| 379 |
if (!resolution && dataonly && !uniq)
| 380 |
printf("NCOLS=%d\nNROWS=%d\n", scanlen(&picres),
| 381 |
numscans(&picres));
| 382 |
| 383 |
| 384 |
if (swapbytes) {
| 385 |
if (nativebigendian())
| 386 |
puts("BigEndian=0");
| 387 |
else
| 388 |
puts("BigEndian=1");
| 389 |
} else if ((format != 'a') & (format != 'i') &
| 390 |
(format != 'b'))
| 391 |
fputendian(stdout);
| 392 |
fputformat(fmtid, stdout);
| 393 |
putchar('\n');
| 394 |
| 395 |
if (resolution) /* put resolution */
| 396 |
| 397 |
pixtoval();
| 398 |
| 399 |
| 400 |
quit(0);
| 401 |
return 0; /* pro forma return */
| 402 |
| 403 |
| 404 |
| 405 |
static int
| 406 |
checkhead( /* deal with line from header */
| 407 |
char *line,
| 408 |
void *p
| 409 |
| 410 |
| 411 |
FILE *fout = (FILE *)p;
| 412 |
char fmt[MAXFMTLEN];
| 413 |
double d;
| 414 |
COLOR ctmp;
| 415 |
int rv;
| 416 |
| 417 |
if (formatval(fmt, line)) {
| 418 |
if (reverse)
| 419 |
wrongformat = strcmp(fmt, fmtid);
| 420 |
else if (!strcmp(fmt, CIEFMT))
| 421 |
mybright = &xyz_bright;
| 422 |
else if (!strcmp(fmt, COLRFMT))
| 423 |
| 424 |
else
| 425 |
wrongformat++;
| 426 |
return(1);
| 427 |
| 428 |
if (original && isexpos(line)) {
| 429 |
d = 1.0/exposval(line);
| 430 |
| 431 |
doexposure++;
| 432 |
return(1);
| 433 |
| 434 |
if (original && iscolcor(line)) {
| 435 |
colcorval(ctmp, line);
| 436 |
setcolor(exposure, colval(exposure,RED)/colval(ctmp,RED),
| 437 |
colval(exposure,GRN)/colval(ctmp,GRN),
| 438 |
colval(exposure,BLU)/colval(ctmp,BLU));
| 439 |
doexposure++;
| 440 |
return(1);
| 441 |
| 442 |
if ((rv = isbigendian(line)) >= 0) {
| 443 |
if (reverse)
| 444 |
swapbytes = (nativebigendian() != rv);
| 445 |
return(1);
| 446 |
| 447 |
if (fout != NULL)
| 448 |
fputs(line, fout);
| 449 |
return(0);
| 450 |
| 451 |
| 452 |
| 453 |
static void
| 454 |
pixtoval(void) /* convert picture to values */
| 455 |
| 456 |
COLOR *scanln;
| 457 |
int dogamma;
| 458 |
COLOR lastc;
| 459 |
RREAL hv[2];
| 460 |
int startprim, endprim;
| 461 |
long startpos;
| 462 |
int x, y;
| 463 |
| 464 |
scanln = (COLOR *)malloc(scanlen(&picres)*sizeof(COLOR));
| 465 |
if (scanln == NULL) {
| 466 |
fprintf(stderr, "%s: out of memory\n", progname);
| 467 |
quit(1);
| 468 |
| 469 |
dogamma = gamcor < .95 || gamcor > 1.05;
| 470 |
if ((putprim == ALL) & !interleave) {
| 471 |
startprim = RED; endprim = BLU;
| 472 |
startpos = ftell(fin);
| 473 |
} else {
| 474 |
startprim = putprim; endprim = putprim;
| 475 |
| 476 |
for (putprim = startprim; putprim <= endprim; putprim++) {
| 477 |
if (putprim != startprim && fseek(fin, startpos, SEEK_SET)) {
| 478 |
fprintf(stderr, "%s: seek error on input file\n",
| 479 |
progname);
| 480 |
quit(1);
| 481 |
| 482 |
set_io();
| 483 |
setcolor(lastc, 0.0, 0.0, 0.0);
| 484 |
for (y = 0; y < numscans(&picres); y++) {
| 485 |
if (freadscan(scanln, scanlen(&picres), fin) < 0) {
| 486 |
fprintf(stderr, "%s: read error\n", progname);
| 487 |
quit(1);
| 488 |
| 489 |
for (x = 0; x < scanlen(&picres); x++) {
| 490 |
if (uniq) {
| 491 |
if ( colval(scanln[x],RED) ==
| 492 |
colval(lastc,RED) &&
| 493 |
colval(scanln[x],GRN) ==
| 494 |
colval(lastc,GRN) &&
| 495 |
colval(scanln[x],BLU) ==
| 496 |
colval(lastc,BLU) )
| 497 |
continue;
| 498 |
else
| 499 |
copycolor(lastc, scanln[x]);
| 500 |
| 501 |
if (doexposure)
| 502 |
multcolor(scanln[x], exposure);
| 503 |
if (dogamma)
| 504 |
setcolor(scanln[x],
| 505 |
pow(colval(scanln[x],RED), 1.0/gamcor),
| 506 |
pow(colval(scanln[x],GRN), 1.0/gamcor),
| 507 |
pow(colval(scanln[x],BLU), 1.0/gamcor));
| 508 |
if (!dataonly) {
| 509 |
pix2loc(hv, &picres, x, y);
| 510 |
printf("%7d %7d ",
| 511 |
(int)(hv[0]*picres.xr),
| 512 |
(int)(hv[1]*picres.yr));
| 513 |
| 514 |
if ((*putval)(scanln[x]) < 0) {
| 515 |
fprintf(stderr, "%s: write error\n",
| 516 |
progname);
| 517 |
quit(1);
| 518 |
| 519 |
| 520 |
| 521 |
| 522 |
free((void *)scanln);
| 523 |
| 524 |
| 525 |
| 526 |
static void
| 527 |
valtopix(void) /* convert values to a pixel file */
| 528 |
| 529 |
int dogamma;
| 530 |
COLOR *scanln;
| 531 |
COLR rgbe;
| 532 |
int x, y;
| 533 |
| 534 |
| 535 |
| 536 |
| 537 |
quit(1);
| 538 |
| 539 |
| 540 |
set_io();
| 541 |
| 542 |
| 543 |
if (!dataonly) {
| 544 |
fscanf(fin, "%*d %*d");
| 545 |
if (fin2 != NULL) {
| 546 |
fscanf(fin2, "%*d %*d");
| 547 |
fscanf(fin3, "%*d %*d");
| 548 |
| 549 |
| 550 |
if ((*getval)(scanln[x]) < 0) {
| 551 |
| 552 |
quit(1);
| 553 |
| 554 |
if (dogamma)
| 555 |
setcolor(scanln[x],
| 556 |
pow(colval(scanln[x],RED), gamcor),
| 557 |
pow(colval(scanln[x],GRN), gamcor),
| 558 |
pow(colval(scanln[x],BLU), gamcor));
| 559 |
if (doexposure)
| 560 |
| 561 |
if (uniq) { /* uncompressed? */
| 562 |
setcolr(rgbe, scanln[x][RED],
| 563 |
scanln[x][GRN],
| 564 |
scanln[x][BLU]);
| 565 |
if (putbinary(rgbe, sizeof(COLR), 1, stdout) != 1)
| 566 |
goto writerr;
| 567 |
| 568 |
| 569 |
/* write scan if compressed */
| 570 |
if (!uniq && fwritescan(scanln, scanlen(&picres), stdout) < 0)
| 571 |
goto writerr;
| 572 |
| 573 |
| 574 |
return;
| 575 |
writerr:
| 576 |
fprintf(stderr, "%s: write error\n", progname);
| 577 |
quit(1);
| 578 |
| 579 |
| 580 |
| 581 |
void
| 582 |
quit(code)
| 583 |
int code;
| 584 |
| 585 |
exit(code);
| 586 |
| 587 |
| 588 |
| 589 |
static int
| 590 |
getcascii( /* get an ascii color value from stream(s) */
| 591 |
COLOR col
| 592 |
| 593 |
| 594 |
double vd[3];
| 595 |
| 596 |
if (fin2 == NULL) {
| 597 |
if (fscanf(fin, "%lf %lf %lf", &vd[0], &vd[1], &vd[2]) != 3)
| 598 |
return(-1);
| 599 |
} else {
| 600 |
if (fscanf(fin, "%lf", &vd[0]) != 1 ||
| 601 |
fscanf(fin2, "%lf", &vd[1]) != 1 ||
| 602 |
fscanf(fin3, "%lf", &vd[2]) != 1)
| 603 |
return(-1);
| 604 |
| 605 |
setcolor(col, vd[rord[RED]], vd[rord[GRN]], vd[rord[BLU]]);
| 606 |
return(0);
| 607 |
| 608 |
| 609 |
| 610 |
static int
| 611 |
getcdouble( /* get a double color value from stream(s) */
| 612 |
COLOR col
| 613 |
| 614 |
| 615 |
double vd[3];
| 616 |
| 617 |
if (fin2 == NULL) {
| 618 |
if (getbinary(vd, sizeof(double), 3, fin) != 3)
| 619 |
return(-1);
| 620 |
} else {
| 621 |
if (getbinary(vd, sizeof(double), 1, fin) != 1 ||
| 622 |
getbinary(vd+1, sizeof(double), 1, fin2) != 1 ||
| 623 |
getbinary(vd+2, sizeof(double), 1, fin3) != 1)
| 624 |
return(-1);
| 625 |
| 626 |
if (swapbytes)
| 627 |
swap64((char *)vd, 3);
| 628 |
| 629 |
return(0);
| 630 |
| 631 |
| 632 |
| 633 |
static int
| 634 |
getcfloat( /* get a float color value from stream(s) */
| 635 |
COLOR col
| 636 |
| 637 |
| 638 |
float vf[3];
| 639 |
| 640 |
if (fin2 == NULL) {
| 641 |
if (getbinary(vf, sizeof(float), 3, fin) != 3)
| 642 |
return(-1);
| 643 |
} else {
| 644 |
if (getbinary(vf, sizeof(float), 1, fin) != 1 ||
| 645 |
getbinary(vf+1, sizeof(float), 1, fin2) != 1 ||
| 646 |
getbinary(vf+2, sizeof(float), 1, fin3) != 1)
| 647 |
return(-1);
| 648 |
| 649 |
if (swapbytes)
| 650 |
swap32((char *)vf, 3);
| 651 |
setcolor(col, vf[rord[RED]], vf[rord[GRN]], vf[rord[BLU]]);
| 652 |
return(0);
| 653 |
| 654 |
| 655 |
| 656 |
static int
| 657 |
getcint( /* get an int color value from stream(s) */
| 658 |
COLOR col
| 659 |
| 660 |
| 661 |
int vi[3];
| 662 |
| 663 |
if (fin2 == NULL) {
| 664 |
if (fscanf(fin, "%d %d %d", &vi[0], &vi[1], &vi[2]) != 3)
| 665 |
return(-1);
| 666 |
} else {
| 667 |
if (fscanf(fin, "%d", &vi[0]) != 1 ||
| 668 |
fscanf(fin2, "%d", &vi[1]) != 1 ||
| 669 |
fscanf(fin3, "%d", &vi[2]) != 1)
| 670 |
return(-1);
| 671 |
| 672 |
setcolor(col, (vi[rord[RED]]+.5)/256.,
| 673 |
(vi[rord[GRN]]+.5)/256., (vi[rord[BLU]]+.5)/256.);
| 674 |
return(0);
| 675 |
| 676 |
| 677 |
| 678 |
static int
| 679 |
getcbyte( /* get a byte color value from stream(s) */
| 680 |
COLOR col
| 681 |
| 682 |
| 683 |
uby8 vb[3];
| 684 |
| 685 |
if (fin2 == NULL) {
| 686 |
if (getbinary(vb, sizeof(uby8), 3, fin) != 3)
| 687 |
return(-1);
| 688 |
} else {
| 689 |
if (getbinary(vb, sizeof(uby8), 1, fin) != 1 ||
| 690 |
getbinary(vb+1, sizeof(uby8), 1, fin2) != 1 ||
| 691 |
getbinary(vb+2, sizeof(uby8), 1, fin3) != 1)
| 692 |
return(-1);
| 693 |
| 694 |
setcolor(col, (vb[rord[RED]]+.5)/256.,
| 695 |
(vb[rord[GRN]]+.5)/256., (vb[rord[BLU]]+.5)/256.);
| 696 |
return(0);
| 697 |
| 698 |
| 699 |
| 700 |
static int
| 701 |
getcword( /* get a 16-bit color value from stream(s) */
| 702 |
COLOR col
| 703 |
| 704 |
| 705 |
uint16 vw[3];
| 706 |
| 707 |
if (fin2 == NULL) {
| 708 |
if (getbinary(vw, sizeof(uint16), 3, fin) != 3)
| 709 |
return(-1);
| 710 |
} else {
| 711 |
if (getbinary(vw, sizeof(uint16), 1, fin) != 1 ||
| 712 |
getbinary(vw+1, sizeof(uint16), 1, fin2) != 1 ||
| 713 |
getbinary(vw+2, sizeof(uint16), 1, fin3) != 1)
| 714 |
return(-1);
| 715 |
| 716 |
if (swapbytes)
| 717 |
swap16((char *)vw, 3);
| 718 |
setcolor(col, (vw[rord[RED]]+.5)/65536.,
| 719 |
(vw[rord[GRN]]+.5)/65536., (vw[rord[BLU]]+.5)/65536.);
| 720 |
return(0);
| 721 |
| 722 |
| 723 |
| 724 |
static int
| 725 |
getbascii( /* get an ascii brightness value from fin */
| 726 |
COLOR col
| 727 |
| 728 |
| 729 |
double vd;
| 730 |
| 731 |
if (fscanf(fin, "%lf", &vd) != 1)
| 732 |
return(-1);
| 733 |
setcolor(col, vd, vd, vd);
| 734 |
return(0);
| 735 |
| 736 |
| 737 |
| 738 |
static int
| 739 |
getbdouble( /* get a double brightness value from fin */
| 740 |
COLOR col
| 741 |
| 742 |
| 743 |
double vd;
| 744 |
| 745 |
if (getbinary(&vd, sizeof(double), 1, fin) != 1)
| 746 |
return(-1);
| 747 |
if (swapbytes)
| 748 |
swap64((char *)&vd, 1);
| 749 |
| 750 |
return(0);
| 751 |
| 752 |
| 753 |
| 754 |
static int
| 755 |
getbfloat( /* get a float brightness value from fin */
| 756 |
COLOR col
| 757 |
| 758 |
| 759 |
float vf;
| 760 |
| 761 |
if (getbinary(&vf, sizeof(float), 1, fin) != 1)
| 762 |
return(-1);
| 763 |
if (swapbytes)
| 764 |
swap32((char *)&vf, 1);
| 765 |
setcolor(col, vf, vf, vf);
| 766 |
return(0);
| 767 |
| 768 |
| 769 |
| 770 |
static int
| 771 |
getbint( /* get an int brightness value from fin */
| 772 |
COLOR col
| 773 |
| 774 |
| 775 |
int vi;
| 776 |
double d;
| 777 |
| 778 |
if (fscanf(fin, "%d", &vi) != 1)
| 779 |
return(-1);
| 780 |
d = (vi+.5)/256.;
| 781 |
setcolor(col, d, d, d);
| 782 |
return(0);
| 783 |
| 784 |
| 785 |
| 786 |
static int
| 787 |
getbbyte( /* get a byte brightness value from fin */
| 788 |
COLOR col
| 789 |
| 790 |
| 791 |
uby8 vb;
| 792 |
double d;
| 793 |
| 794 |
if (getbinary(&vb, sizeof(uby8), 1, fin) != 1)
| 795 |
return(-1);
| 796 |
d = (vb+.5)/256.;
| 797 |
| 798 |
return(0);
| 799 |
| 800 |
| 801 |
| 802 |
static int
| 803 |
getbword( /* get a 16-bit brightness value from fin */
| 804 |
COLOR col
| 805 |
| 806 |
| 807 |
uint16 vw;
| 808 |
double d;
| 809 |
| 810 |
if (getbinary(&vw, sizeof(uint16), 1, fin) != 1)
| 811 |
return(-1);
| 812 |
if (swapbytes)
| 813 |
swap16((char *)&vw, 1);
| 814 |
d = (vw+.5)/65536.;
| 815 |
| 816 |
return(0);
| 817 |
| 818 |
| 819 |
| 820 |
static int
| 821 |
putcascii( /* put an ascii color to stdout */
| 822 |
COLOR col
| 823 |
| 824 |
| 825 |
fprintf(stdout, "%15.3e %15.3e %15.3e\n",
| 826 |
colval(col,ord[0]),
| 827 |
colval(col,ord[1]),
| 828 |
colval(col,ord[2]));
| 829 |
| 830 |
return(ferror(stdout) ? -1 : 0);
| 831 |
| 832 |
| 833 |
| 834 |
static int
| 835 |
putcfloat( /* put a float color to stdout */
| 836 |
COLOR col
| 837 |
| 838 |
| 839 |
float vf[3];
| 840 |
| 841 |
vf[0] = colval(col,ord[0]);
| 842 |
vf[1] = colval(col,ord[1]);
| 843 |
vf[2] = colval(col,ord[2]);
| 844 |
if (swapbytes)
| 845 |
| 846 |
putbinary(vf, sizeof(float), 3, stdout);
| 847 |
| 848 |
| 849 |
| 850 |
| 851 |
| 852 |
static int
| 853 |
putcdouble( /* put a double color to stdout */
| 854 |
COLOR col
| 855 |
| 856 |
| 857 |
double vd[3];
| 858 |
| 859 |
vd[0] = colval(col,ord[0]);
| 860 |
vd[1] = colval(col,ord[1]);
| 861 |
vd[2] = colval(col,ord[2]);
| 862 |
if (swapbytes)
| 863 |
| 864 |
putbinary(vd, sizeof(double), 3, stdout);
| 865 |
| 866 |
| 867 |
| 868 |
| 869 |
| 870 |
static int
| 871 |
putcint( /* put an int color to stdout */
| 872 |
COLOR col
| 873 |
| 874 |
| 875 |
fprintf(stdout, "%d %d %d\n",
| 876 |
(int)(colval(col,ord[0])*256.),
| 877 |
(int)(colval(col,ord[1])*256.),
| 878 |
(int)(colval(col,ord[2])*256.));
| 879 |
| 880 |
| 881 |
| 882 |
| 883 |
| 884 |
static int
| 885 |
putcbyte( /* put a byte color to stdout */
| 886 |
COLOR col
| 887 |
| 888 |
| 889 |
long i;
| 890 |
uby8 vb[3];
| 891 |
| 892 |
i = colval(col,ord[0])*256.;
| 893 |
vb[0] = min(i,255);
| 894 |
i = colval(col,ord[1])*256.;
| 895 |
vb[1] = min(i,255);
| 896 |
i = colval(col,ord[2])*256.;
| 897 |
vb[2] = min(i,255);
| 898 |
putbinary(vb, sizeof(uby8), 3, stdout);
| 899 |
| 900 |
| 901 |
| 902 |
| 903 |
| 904 |
static int
| 905 |
putcword( /* put a 16-bit color to stdout */
| 906 |
COLOR col
| 907 |
| 908 |
| 909 |
long i;
| 910 |
uint16 vw[3];
| 911 |
| 912 |
i = colval(col,ord[0])*65536.;
| 913 |
vw[0] = min(i,65535);
| 914 |
i = colval(col,ord[1])*65536.;
| 915 |
vw[1] = min(i,65535);
| 916 |
i = colval(col,ord[2])*65536.;
| 917 |
vw[2] = min(i,65535);
| 918 |
if (swapbytes)
| 919 |
| 920 |
putbinary(vw, sizeof(uint16), 3, stdout);
| 921 |
| 922 |
| 923 |
| 924 |
| 925 |
| 926 |
static int
| 927 |
putbascii( /* put an ascii brightness to stdout */
| 928 |
COLOR col
| 929 |
| 930 |
| 931 |
fprintf(stdout, "%15.3e\n", (*mybright)(col));
| 932 |
| 933 |
| 934 |
| 935 |
| 936 |
| 937 |
static int
| 938 |
putbfloat( /* put a float brightness to stdout */
| 939 |
COLOR col
| 940 |
| 941 |
| 942 |
float vf;
| 943 |
| 944 |
vf = (*mybright)(col);
| 945 |
if (swapbytes)
| 946 |
| 947 |
putbinary(&vf, sizeof(float), 1, stdout);
| 948 |
| 949 |
| 950 |
| 951 |
| 952 |
| 953 |
static int
| 954 |
putbdouble( /* put a double brightness to stdout */
| 955 |
COLOR col
| 956 |
| 957 |
| 958 |
double vd;
| 959 |
| 960 |
vd = (*mybright)(col);
| 961 |
if (swapbytes)
| 962 |
| 963 |
putbinary(&vd, sizeof(double), 1, stdout);
| 964 |
| 965 |
| 966 |
| 967 |
| 968 |
| 969 |
static int
| 970 |
putbint( /* put an int brightness to stdout */
| 971 |
COLOR col
| 972 |
| 973 |
| 974 |
fprintf(stdout, "%d\n", (int)((*mybright)(col)*256.));
| 975 |
| 976 |
| 977 |
| 978 |
| 979 |
| 980 |
static int
| 981 |
putbbyte( /* put a byte brightness to stdout */
| 982 |
COLOR col
| 983 |
| 984 |
| 985 |
int i;
| 986 |
uby8 vb;
| 987 |
| 988 |
i = (*mybright)(col)*256.;
| 989 |
vb = min(i,255);
| 990 |
putbinary(&vb, sizeof(uby8), 1, stdout);
| 991 |
| 992 |
| 993 |
| 994 |
| 995 |
| 996 |
static int
| 997 |
putbword( /* put a 16-bit brightness to stdout */
| 998 |
COLOR col
| 999 |
| 1000 |
| 1001 |
long i;
| 1002 |
uint16 vw;
| 1003 |
| 1004 |
i = (*mybright)(col)*65536.;
| 1005 |
vw = min(i,65535);
| 1006 |
if (swapbytes)
| 1007 |
| 1008 |
putbinary(&vw, sizeof(uint16), 1, stdout);
| 1009 |
| 1010 |
| 1011 |
| 1012 |
| 1013 |
| 1014 |
static int
| 1015 |
putpascii( /* put an ascii primary to stdout */
| 1016 |
COLOR col
| 1017 |
| 1018 |
| 1019 |
fprintf(stdout, "%15.3e\n", colval(col,putprim));
| 1020 |
| 1021 |
| 1022 |
| 1023 |
| 1024 |
| 1025 |
static int
| 1026 |
putpfloat( /* put a float primary to stdout */
| 1027 |
COLOR col
| 1028 |
| 1029 |
| 1030 |
float vf;
| 1031 |
| 1032 |
vf = colval(col,putprim);
| 1033 |
if (swapbytes)
| 1034 |
| 1035 |
| 1036 |
| 1037 |
| 1038 |
| 1039 |
| 1040 |
| 1041 |
static int
| 1042 |
putpdouble( /* put a double primary to stdout */
| 1043 |
COLOR col
| 1044 |
| 1045 |
| 1046 |
double vd;
| 1047 |
| 1048 |
vd = colval(col,putprim);
| 1049 |
if (swapbytes)
| 1050 |
| 1051 |
| 1052 |
| 1053 |
| 1054 |
| 1055 |
| 1056 |
| 1057 |
static int
| 1058 |
putpint( /* put an int primary to stdout */
| 1059 |
COLOR col
| 1060 |
| 1061 |
| 1062 |
fprintf(stdout, "%d\n", (int)(colval(col,putprim)*256.));
| 1063 |
| 1064 |
| 1065 |
| 1066 |
| 1067 |
| 1068 |
static int
| 1069 |
putpbyte( /* put a byte primary to stdout */
| 1070 |
COLOR col
| 1071 |
| 1072 |
| 1073 |
long i;
| 1074 |
uby8 vb;
| 1075 |
| 1076 |
i = colval(col,putprim)*256.;
| 1077 |
vb = min(i,255);
| 1078 |
| 1079 |
| 1080 |
| 1081 |
| 1082 |
| 1083 |
| 1084 |
static int
| 1085 |
putpword( /* put a 16-bit primary to stdout */
| 1086 |
COLOR col
| 1087 |
| 1088 |
| 1089 |
long i;
| 1090 |
uint16 vw;
| 1091 |
| 1092 |
i = colval(col,putprim)*65536.;
| 1093 |
vw = min(i,65535);
| 1094 |
if (swapbytes)
| 1095 |
| 1096 |
| 1097 |
| 1098 |
| 1099 |
| 1100 |
| 1101 |
| 1102 |
static void
| 1103 |
set_io(void) /* set put and get functions */
| 1104 |
| 1105 |
switch (format) {
| 1106 |
| 1107 |
if (putprim == BRIGHT) {
| 1108 |
getval = getbascii;
| 1109 |
putval = putbascii;
| 1110 |
} else if (putprim != ALL) {
| 1111 |
getval = getbascii;
| 1112 |
putval = putpascii;
| 1113 |
} else {
| 1114 |
getval = getcascii;
| 1115 |
putval = putcascii;
| 1116 |
if (reverse && !interleave) {
| 1117 |
fprintf(stderr,
| 1118 |
"%s: ASCII input files must be interleaved\n",
| 1119 |
progname);
| 1120 |
quit(1);
| 1121 |
| 1122 |
| 1123 |
return;
| 1124 |
case 'f': /* binary float */
| 1125 |
| 1126 |
getval = getbfloat;
| 1127 |
putval = putbfloat;
| 1128 |
| 1129 |
getval = getbfloat;
| 1130 |
putval = putpfloat;
| 1131 |
} else {
| 1132 |
getval = getcfloat;
| 1133 |
putval = putcfloat;
| 1134 |
| 1135 |
if (fin2 == NULL)
| 1136 |
goto namerr;
| 1137 |
if (fseek(fin2,
| 1138 |
(long)sizeof(float)*picres.xr*picres.yr, SEEK_CUR))
| 1139 |
goto seekerr;
| 1140 |
if (fseek(fin3,
| 1141 |
(long)sizeof(float)*2*picres.xr*picres.yr, SEEK_CUR))
| 1142 |
goto seekerr;
| 1143 |
| 1144 |
| 1145 |
return;
| 1146 |
case 'd': /* binary double */
| 1147 |
| 1148 |
getval = getbdouble;
| 1149 |
putval = putbdouble;
| 1150 |
| 1151 |
| 1152 |
putval = putpdouble;
| 1153 |
} else {
| 1154 |
getval = getcdouble;
| 1155 |
putval = putcdouble;
| 1156 |
| 1157 |
if (fin2 == NULL)
| 1158 |
goto namerr;
| 1159 |
if (fseek(fin2,
| 1160 |
(long)sizeof(double)*picres.xr*picres.yr, SEEK_CUR))
| 1161 |
goto seekerr;
| 1162 |
if (fseek(fin3,
| 1163 |
(long)sizeof(double)*2*picres.xr*picres.yr, SEEK_CUR))
| 1164 |
goto seekerr;
| 1165 |
| 1166 |
| 1167 |
return;
| 1168 |
| 1169 |
| 1170 |
getval = getbint;
| 1171 |
putval = putbint;
| 1172 |
| 1173 |
getval = getbint;
| 1174 |
putval = putpint;
| 1175 |
} else {
| 1176 |
getval = getcint;
| 1177 |
putval = putcint;
| 1178 |
| 1179 |
fprintf(stderr,
| 1180 |
"%s: integer input files must be interleaved\n",
| 1181 |
progname);
| 1182 |
quit(1);
| 1183 |
| 1184 |
| 1185 |
return;
| 1186 |
| 1187 |
| 1188 |
getval = getbbyte;
| 1189 |
putval = putbbyte;
| 1190 |
| 1191 |
getval = getbbyte;
| 1192 |
putval = putpbyte;
| 1193 |
} else {
| 1194 |
getval = getcbyte;
| 1195 |
putval = putcbyte;
| 1196 |
| 1197 |
if (fin2 == NULL)
| 1198 |
goto namerr;
| 1199 |
if (fseek(fin2,
| 1200 |
(long)sizeof(uby8)*picres.xr*picres.yr, SEEK_CUR))
| 1201 |
goto seekerr;
| 1202 |
if (fseek(fin3,
| 1203 |
(long)sizeof(uby8)*2*picres.xr*picres.yr, SEEK_CUR))
| 1204 |
goto seekerr;
| 1205 |
| 1206 |
| 1207 |
return;
| 1208 |
| 1209 |
| 1210 |
getval = getbword;
| 1211 |
putval = putbword;
| 1212 |
| 1213 |
getval = getbword;
| 1214 |
putval = putpword;
| 1215 |
} else {
| 1216 |
getval = getcword;
| 1217 |
putval = putcword;
| 1218 |
| 1219 |
if (fin2 == NULL)
| 1220 |
goto namerr;
| 1221 |
if (fseek(fin2,
| 1222 |
(long)sizeof(uint16)*picres.xr*picres.yr, SEEK_CUR))
| 1223 |
goto seekerr;
| 1224 |
if (fseek(fin3,
| 1225 |
(long)sizeof(uint16)*2*picres.xr*picres.yr, SEEK_CUR))
| 1226 |
goto seekerr;
| 1227 |
| 1228 |
| 1229 |
return;
| 1230 |
| 1231 |
/* badopt: */ /* label not used */
| 1232 |
fprintf(stderr, "%s: botched file type\n", progname);
| 1233 |
quit(1);
| 1234 |
namerr:
| 1235 |
fprintf(stderr, "%s: non-interleaved file(s) must be named\n",
| 1236 |
progname);
| 1237 |
quit(1);
| 1238 |
seekerr:
| 1239 |
fprintf(stderr, "%s: cannot seek on interleaved input file\n",
| 1240 |
progname);
| 1241 |
quit(1);
| 1242 |
