--- ray/src/px/pvalue.c 1991/11/11 14:01:37 1.8 +++ ray/src/px/pvalue.c 1993/11/09 15:21:00 2.7 @@ -1,4 +1,4 @@ -/* Copyright (c) 1991 Regents of the University of California */ +/* Copyright (c) 1992 Regents of the University of California */ #ifndef lint static char SCCSid[] = "$SunId$ LBL"; @@ -16,13 +16,13 @@ static char SCCSid[] = "$SunId$ LBL"; #include "resolu.h" -#define min(a,b) ((a)<(b)?(a):(b)) +#define min(a,b) ((a)<(b)?(a):(b)) -RESOLU picres; /* resolution of picture */ +RESOLU picres; /* resolution of picture */ int uniq = 0; /* print only unique values? */ -int original = 0; /* convert back to original values? */ +int doexposure = 0; /* exposure change? (>100 to print) */ int dataonly = 0; /* data only format? */ @@ -33,20 +33,25 @@ int reverse = 0; /* reverse conversion? */ int format = 'a'; /* input/output format */ char *fmtid = "ascii"; /* format identifier for header */ -int header = 1; /* do header */ +int header = 1; /* do header? */ +int resolution = 1; /* put/get resolution string? */ + +int original = 0; /* convert to original values? */ + int wrongformat = 0; /* wrong input format? */ -double gamcor = 1.0; /* gamma correction */ +double gamcor = 1.0; /* gamma correction */ +int ord[3] = {RED, GRN, BLU}; /* RGB ordering */ +int rord[4]; /* reverse ordering */ + COLOR exposure = WHTCOLOR; char *progname; FILE *fin; -extern double atof(), pow(); - int (*getval)(), (*putval)(); @@ -55,6 +60,7 @@ int argc; char **argv; { extern int checkhead(); + double d, expval = 1.0; int i; progname = argv[0]; @@ -65,6 +71,9 @@ char **argv; case 'h': /* header */ header = argv[i][0] == '+'; break; + case 'H': /* resolution string */ + resolution = argv[i][0] == '+'; + break; case 'u': /* unique values */ uniq = argv[i][0] == '-'; break; @@ -72,10 +81,29 @@ char **argv; original = argv[i][0] == '-'; break; case 'g': /* gamma correction */ - gamcor = atof(argv[++i]); + gamcor = atof(argv[i+1]); if (argv[i][0] == '+') gamcor = 1.0/gamcor; + i++; break; + case 'e': /* exposure correction */ + d = atof(argv[i+1]); + if (argv[i+1][0] == '-' || argv[i+1][0] == '+') + d = pow(2.0, d); + if (argv[i][0] == '-') + doexposure = 100; + scalecolor(exposure, d); + expval *= d; + doexposure++; + i++; + break; + case 'R': /* reverse byte sequence */ + if (argv[i][0] == '-') { + ord[0]=BLU; ord[1]=GRN; ord[2]=RED; + } else { + ord[0]=RED; ord[1]=GRN; ord[2]=BLU; + } + break; case 'r': /* reverse conversion */ reverse = argv[i][0] == '-'; break; @@ -114,11 +142,15 @@ char **argv; } break; case 'x': /* x resolution */ + case 'X': /* x resolution */ + resolution = 0; if (argv[i][0] == '-') picres.or |= XDECR; picres.xr = atoi(argv[++i]); break; case 'y': /* y resolution */ + case 'Y': /* y resolution */ + resolution = 0; if (argv[i][0] == '-') picres.or |= YDECR; if (picres.xr == 0) @@ -140,7 +172,11 @@ unkopt: fmtid = "8-bit_grey"; else fmtid = "24-bit_rgb"; - + /* assign reverse ordering */ + rord[ord[0]] = 0; + rord[ord[1]] = 1; + rord[ord[2]] = 2; + /* get input */ if (i == argc) { fin = stdin; } else if (i == argc-1) { @@ -157,24 +193,36 @@ unkopt: set_io(); if (reverse) { +#ifdef MSDOS + setmode(fileno(stdout), O_BINARY); + if (format != 'a' && format != 'i') + setmode(fileno(fin), O_BINARY); +#endif /* get header */ if (header && checkheader(fin, fmtid, stdout) < 0) { fprintf(stderr, "%s: wrong input format\n", progname); quit(1); } - if (picres.xr <= 0 || picres.yr <= 0) /* get resolution */ - if (!fgetsresolu(&picres, fin)) { - fprintf(stderr, "%s: missing resolution\n", - progname); - quit(1); - } + /* get resolution */ + if ((resolution && !fgetsresolu(&picres, fin)) || + picres.xr <= 0 || picres.yr <= 0) { + fprintf(stderr, "%s: missing resolution\n", progname); + quit(1); + } /* add to header */ printargs(i, argv, stdout); + if (doexposure > 100) + fputexpos(expval, stdout); fputformat(COLRFMT, stdout); putchar('\n'); - fputsresolu(&picres, stdout); + fputsresolu(&picres, stdout); /* always put resolution */ valtopix(); } else { +#ifdef MSDOS + setmode(fileno(fin), O_BINARY); + if (format != 'a' && format != 'i') + setmode(fileno(stdout), O_BINARY); +#endif /* get header */ getheader(fin, checkhead, NULL); if (wrongformat) { @@ -182,18 +230,19 @@ unkopt: progname); quit(1); } - - if (picres.xr <= 0 || picres.yr <= 0) /* get picture size */ - if (!fgetsresolu(&picres, fin)) { - fprintf(stderr, "%s: missing resolution\n", - progname); - quit(1); - } + if (!fgetsresolu(&picres, fin)) { + fprintf(stderr, "%s: missing resolution\n", progname); + quit(1); + } if (header) { printargs(i, argv, stdout); + if (doexposure > 100) + fputexpos(expval, stdout); fputformat(fmtid, stdout); putchar('\n'); } + if (resolution) /* put resolution */ + fputsresolu(&picres, stdout); pixtoval(); } @@ -214,11 +263,13 @@ char *line; } else if (original && isexpos(line)) { d = 1.0/exposval(line); scalecolor(exposure, d); + doexposure++; } else if (original && iscolcor(line)) { colcorval(ctmp, line); setcolor(exposure, colval(exposure,RED)/colval(ctmp,RED), colval(exposure,GRN)/colval(ctmp,GRN), colval(exposure,BLU)/colval(ctmp,BLU)); + doexposure++; } else if (header) fputs(line, stdout); } @@ -226,7 +277,7 @@ char *line; pixtoval() /* convert picture to values */ { - register COLOR *scanln; + register COLOR *scanln; int dogamma; COLOR lastc; FLOAT hv[2]; @@ -256,7 +307,7 @@ pixtoval() /* convert picture to values */ continue; else copycolor(lastc, scanln[x]); - if (original) + if (doexposure) multcolor(scanln[x], exposure); if (dogamma) setcolor(scanln[x], @@ -281,7 +332,7 @@ pixtoval() /* convert picture to values */ valtopix() /* convert values to a pixel file */ { int dogamma; - register COLOR *scanln; + register COLOR *scanln; int y; register int x; @@ -304,6 +355,8 @@ valtopix() /* convert values to a pixel file */ pow(colval(scanln[x],RED), gamcor), pow(colval(scanln[x],GRN), gamcor), pow(colval(scanln[x],BLU), gamcor)); + if (doexposure) + multcolor(scanln[x], exposure); } if (fwritescan(scanln, scanlen(&picres), stdout) < 0) { fprintf(stderr, "%s: write error\n", progname); @@ -325,11 +378,11 @@ getcascii(col, fp) /* get an ascii color value from f COLOR col; FILE *fp; { - double vd[3]; + double vd[3]; if (fscanf(fp, "%lf %lf %lf", &vd[0], &vd[1], &vd[2]) != 3) return(-1); - setcolor(col, vd[0], vd[1], vd[2]); + setcolor(col, vd[rord[RED]], vd[rord[GRN]], vd[rord[BLU]]); return(0); } @@ -338,11 +391,11 @@ getcdouble(col, fp) /* get a double color value from COLOR col; FILE *fp; { - double vd[3]; + double vd[3]; if (fread((char *)vd, sizeof(double), 3, fp) != 3) return(-1); - setcolor(col, vd[0], vd[1], vd[2]); + setcolor(col, vd[rord[RED]], vd[rord[GRN]], vd[rord[BLU]]); return(0); } @@ -355,7 +408,7 @@ FILE *fp; if (fread((char *)vf, sizeof(float), 3, fp) != 3) return(-1); - setcolor(col, vf[0], vf[1], vf[2]); + setcolor(col, vf[rord[RED]], vf[rord[GRN]], vf[rord[BLU]]); return(0); } @@ -368,7 +421,8 @@ FILE *fp; if (fscanf(fp, "%d %d %d", &vi[0], &vi[1], &vi[2]) != 3) return(-1); - setcolor(col,(vi[0]+.5)/256.,(vi[1]+.5)/256.,(vi[2]+.5)/256.); + setcolor(col, (vi[rord[RED]]+.5)/256., + (vi[rord[GRN]]+.5)/256., (vi[rord[BLU]]+.5)/256.); return(0); } @@ -381,7 +435,8 @@ FILE *fp; if (fread((char *)vb, sizeof(BYTE), 3, fp) != 3) return(-1); - setcolor(col,(vb[0]+.5)/256.,(vb[1]+.5)/256.,(vb[2]+.5)/256.); + setcolor(col, (vb[rord[RED]]+.5)/256., + (vb[rord[GRN]]+.5)/256., (vb[rord[BLU]]+.5)/256.); return(0); } @@ -390,7 +445,7 @@ getbascii(col, fp) /* get an ascii brightness value f COLOR col; FILE *fp; { - double vd; + double vd; if (fscanf(fp, "%lf", &vd) != 1) return(-1); @@ -403,7 +458,7 @@ getbdouble(col, fp) /* get a double brightness value COLOR col; FILE *fp; { - double vd; + double vd; if (fread((char *)&vd, sizeof(double), 1, fp) != 1) return(-1); @@ -430,7 +485,7 @@ COLOR col; FILE *fp; { int vi; - double d; + double d; if (fscanf(fp, "%d", &vi) != 1) return(-1); @@ -445,7 +500,7 @@ COLOR col; FILE *fp; { BYTE vb; - double d; + double d; if (fread((char *)&vb, sizeof(BYTE), 1, fp) != 1) return(-1); @@ -460,9 +515,9 @@ COLOR col; FILE *fp; { fprintf(fp, "%15.3e %15.3e %15.3e\n", - colval(col,RED), - colval(col,GRN), - colval(col,BLU)); + colval(col,ord[0]), + colval(col,ord[1]), + colval(col,ord[2])); return(ferror(fp) ? -1 : 0); } @@ -474,9 +529,9 @@ FILE *fp; { float vf[3]; - vf[0] = colval(col,RED); - vf[1] = colval(col,GRN); - vf[2] = colval(col,BLU); + vf[0] = colval(col,ord[0]); + vf[1] = colval(col,ord[1]); + vf[2] = colval(col,ord[2]); fwrite((char *)vf, sizeof(float), 3, fp); return(ferror(fp) ? -1 : 0); @@ -487,11 +542,11 @@ putcdouble(col, fp) /* put a double color to fp */ COLOR col; FILE *fp; { - double vd[3]; + double vd[3]; - vd[0] = colval(col,RED); - vd[1] = colval(col,GRN); - vd[2] = colval(col,BLU); + vd[0] = colval(col,ord[0]); + vd[1] = colval(col,ord[1]); + vd[2] = colval(col,ord[2]); fwrite((char *)vd, sizeof(double), 3, fp); return(ferror(fp) ? -1 : 0); @@ -503,9 +558,9 @@ COLOR col; FILE *fp; { fprintf(fp, "%d %d %d\n", - (int)(colval(col,RED)*256.), - (int)(colval(col,GRN)*256.), - (int)(colval(col,BLU)*256.)); + (int)(colval(col,ord[0])*256.), + (int)(colval(col,ord[1])*256.), + (int)(colval(col,ord[2])*256.)); return(ferror(fp) ? -1 : 0); } @@ -518,11 +573,11 @@ FILE *fp; register int i; BYTE vb[3]; - i = colval(col,RED)*256.; + i = colval(col,ord[0])*256.; vb[0] = min(i,255); - i = colval(col,GRN)*256.; + i = colval(col,ord[1])*256.; vb[1] = min(i,255); - i = colval(col,BLU)*256.; + i = colval(col,ord[2])*256.; vb[2] = min(i,255); fwrite((char *)vb, sizeof(BYTE), 3, fp); @@ -557,7 +612,7 @@ putbdouble(col, fp) /* put a double brightness to fp COLOR col; FILE *fp; { - double vd; + double vd; vd = bright(col); fwrite((char *)&vd, sizeof(double), 1, fp);
