root/radiance/ray/src/px/pvalue.c
Sat Dec 23 17:27:46 2006 UTC (18 years, 5 months ago) by greg
CVS Tags: rad3R9, rad4R0
Changes since 2.28: +11 -59 lines
Diff to previous 2.28 , to selected 2.24
Fri Oct 1 07:46:26 2004 UTC (20 years, 8 months ago) by greg
Changes since 2.27: +1 -2 lines
Diff to previous 2.27 , to selected 2.24
Forgot to remove debug statement on last check-in
Fri Oct 1 07:45:30 2004 UTC (20 years, 8 months ago) by greg
Changes since 2.26: +4 -7 lines
Diff to previous 2.26 , to selected 2.24
Sun Mar 28 20:33:14 2004 UTC (21 years, 2 months ago) by schorsch
Changes since 2.25: +182 -104 lines
Diff to previous 2.25 , to selected 2.24
Fri Jan 2 12:47:01 2004 UTC (21 years, 5 months ago) by schorsch
Changes since 2.24: +9 -5 lines
Diff to previous 2.24
Revision 2.24 - (view) (download) (annotate) - [selected]
Wed Oct 22 02:06:35 2003 UTC (21 years, 7 months ago) by greg
Diff to previous 2.23
Sat Sep 13 15:24:13 2003 UTC (21 years, 8 months ago) by greg
Changes since 2.22: +55 -4 lines
Diff to previous 2.22 , to selected 2.24
Mon Jul 21 22:30:19 2003 UTC (21 years, 10 months ago) by schorsch
Changes since 2.21: +7 -4 lines
Diff to previous 2.21 , to selected 2.24
Thu Jun 26 00:58:10 2003 UTC (21 years, 11 months ago) by schorsch
Diff to previous 2.20 , to selected 2.24
Fri Jun 20 00:25:50 2003 UTC (21 years, 11 months ago) by greg
Changes since 2.19: +1 -3 lines
Diff to previous 2.19 , to selected 2.24
Sun Jun 8 12:03:10 2003 UTC (22 years ago) by schorsch
Changes since 2.18: +2 -1 lines
Diff to previous 2.18 , to selected 2.24
Thu Jun 5 19:29:34 2003 UTC (22 years ago) by schorsch
Changes since 2.17: +9 -11 lines
Diff to previous 2.17 , to selected 2.24
Thu Feb 27 02:00:12 2003 UTC (22 years, 3 months ago) by greg
Changes since 2.16: +8 -10 lines
Diff to previous 2.16 , to selected 2.24
Corrected format string for -pP option
Tue Feb 25 16:47:23 2003 UTC (22 years, 3 months ago) by greg
Changes since 2.15: +25 -1 lines
Diff to previous 2.15 , to selected 2.24
Added -dW option for 16-bit byte-swapped words
Tue Feb 25 16:22:05 2003 UTC (22 years, 3 months ago) by greg
Changes since 2.14: +116 -2 lines
Diff to previous 2.14 , to selected 2.24
Added -dw option for 16-bit i/o
Sat Feb 22 02:07:27 2003 UTC (22 years, 3 months ago) by greg
Changes since 2.13: +46 -20 lines
Diff to previous 2.13 , to selected 2.24
Tue Oct 27 09:08:27 1998 UTC (26 years, 7 months ago) by gwlarson
Changes since 2.12: +2 -0 lines
Diff to previous 2.12 , to selected 2.24
Wed Jan 8 08:51:43 1997 UTC (28 years, 5 months ago) by greg
Changes since 2.11: +118 -40 lines
Diff to previous 2.11 , to selected 2.24
added -n option for non-interleaved RGB input and output
Wed Jan 8 08:00:23 1997 UTC (28 years, 5 months ago) by greg
Changes since 2.10: +87 -112 lines
Diff to previous 2.10 , to selected 2.24
took out file arguments from get and put value routines
Wed Jan 8 07:43:49 1997 UTC (28 years, 5 months ago) by greg
Changes since 2.9: +210 -31 lines
Diff to previous 2.9 , to selected 2.24
added routines for reading and writing separate RGB files
added -pP (where P is one of 'R', 'G' or 'B' upper or lower case)
added -s option to skip specified number of bytes on header
Thu Oct 6 13:27:16 1994 UTC (30 years, 8 months ago) by greg
Changes since 2.8: +3 -4 lines
Diff to previous 2.8 , to selected 2.24
made it so -e and +e work well together
Sun Feb 27 10:16:48 1994 UTC (31 years, 3 months ago) by greg
Changes since 2.7: +10 -7 lines
Diff to previous 2.7 , to selected 2.24
Tue Nov 9 15:21:00 1993 UTC (31 years, 7 months ago) by greg
Changes since 2.6: +26 -3 lines
Diff to previous 2.6 , to selected 2.24
added +/-e option to correct/adjust exposure
Thu Jul 29 13:36:19 1993 UTC (31 years, 10 months ago) by greg
Diff to previous 2.5 , to selected 2.24
made pvalue accept upper case X and Y for resolution spec. also
Mon Sep 21 12:14:37 1992 UTC (32 years, 8 months ago) by greg
Changes since 2.4: +24 -14 lines
Diff to previous 2.4 , to selected 2.24
Changes for PC port
Fri May 8 11:55:42 1992 UTC (33 years, 1 month ago) by greg
Changes since 2.3: +37 -21 lines
Diff to previous 2.3 , to selected 2.24
added -R option for color order reversal
Fri May 8 10:58:52 1992 UTC (33 years, 1 month ago) by greg
Changes since 2.2: +21 -15 lines
Diff to previous 2.2 , to selected 2.24
added +/-H option for no/yes to resolution string
Thu Dec 19 14:52:04 1991 UTC (33 years, 5 months ago) by greg
Diff to previous 2.1 , to selected 2.24
Tue Nov 12 16:04:16 1991 UTC (33 years, 6 months ago) by greg
Diff to previous 1.8 , to selected 2.24
Mon Nov 11 14:01:37 1991 UTC (33 years, 6 months ago) by greg
Changes since 1.7: +61 -45 lines
Diff to previous 1.7 , to selected 2.24
Fri May 10 08:51:53 1991 UTC (34 years, 1 month ago) by greg
Changes since 1.6: +34 -12 lines
Diff to previous 1.6 , to selected 2.24
added -g (gamma correction) option
Fri Apr 19 09:00:55 1991 UTC (34 years, 1 month ago) by greg
Changes since 1.5: +48 -15 lines
Diff to previous 1.5 , to selected 2.24
added format info to header
Fri Dec 14 16:33:19 1990 UTC (34 years, 5 months ago) by greg
Changes since 1.4: +14 -4 lines
Diff to previous 1.4 , to selected 2.24
added use of COLORCORR header i/o
Thu Jan 18 23:58:17 1990 UTC (35 years, 4 months ago) by greg
Changes since 1.3: +12 -12 lines
Diff to previous 1.3 , to selected 2.24
Fri Jan 5 17:52:54 1990 UTC (35 years, 5 months ago) by greg
Diff to previous 1.2 , to selected 2.24
changed EXPOSURE information interface
Tue Sep 12 13:04:30 1989 UTC (35 years, 8 months ago) by greg
Diff to previous 1.1 , to selected 2.24
Thu Feb 2 10:49:31 1989 UTC (36 years, 4 months ago) by greg
Diff to selected 2.24
