--- ray/src/px/pvalue.c 2003/06/20 00:25:50 2.20 +++ ray/src/px/pvalue.c 2003/09/13 15:24:13 2.23 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: pvalue.c,v 2.20 2003/06/20 00:25:50 greg Exp $"; +static const char RCSid[] = "$Id: pvalue.c,v 2.23 2003/09/13 15:24:13 greg Exp $"; #endif /* * pvalue.c - program to print pixel values. @@ -7,8 +7,6 @@ static const char RCSid[] = "$Id: pvalue.c,v 2.20 2003 * 4/23/86 */ -#include - #include "standard.h" #include "platform.h" #include "color.h" @@ -39,7 +37,7 @@ int header = 1; /* do header? */ long skipbytes = 0; /* skip bytes in input? */ -int swapbytes = 0; /* swap bytes in 16-bit words? */ +int swapbytes = 0; /* swap bytes? */ int interleave = 1; /* file is interleaved? */ @@ -173,11 +171,15 @@ char **argv; format = 'w'; fmtid = "16-bit"; break; + case 'F': /* swapped floats */ + swapbytes = 1; case 'f': /* float */ dataonly = 1; format = 'f'; fmtid = "float"; break; + case 'D': /* swapped doubles */ + swapbytes = 1; case 'd': /* double */ dataonly = 1; format = 'd'; @@ -213,16 +215,18 @@ unkopt: else break; /* recognize special formats */ - if (dataonly && format == 'b') + if (dataonly && format == 'b') { if (putprim == ALL) fmtid = "24-bit_rgb"; else fmtid = "8-bit_grey"; - if (dataonly && format == 'w') + } + if (dataonly && format == 'w') { if (putprim == ALL) fmtid = "48-bit_rgb"; else fmtid = "16-bit_grey"; + } /* assign reverse ordering */ rord[ord[0]] = 0; rord[ord[1]] = 1; @@ -389,7 +393,7 @@ pixtoval() /* convert picture to values */ register COLOR *scanln; int dogamma; COLOR lastc; - FLOAT hv[2]; + RREAL hv[2]; int startprim, endprim; long startpos; int y; @@ -421,7 +425,7 @@ pixtoval() /* convert picture to values */ quit(1); } for (x = 0; x < scanlen(&picres); x++) { - if (uniq) + if (uniq) { if ( colval(scanln[x],RED) == colval(lastc,RED) && colval(scanln[x],GRN) == @@ -431,6 +435,7 @@ pixtoval() /* convert picture to values */ continue; else copycolor(lastc, scanln[x]); + } if (doexposure) multcolor(scanln[x], exposure); if (dogamma) @@ -518,6 +523,35 @@ int n; } } + +swap32(wp, n) /* swap n 32-bit words */ +register uint32 *wp; +int n; +{ + while (n-- > 0) { + *wp = *wp << 24 | ((*wp >> 24) & 0xff) | + (*wp & 0xff00) << 8 | (*wp & 0xff0000) >> 8; + wp++; + } +} + + +swap64(wp, n) /* swap n 64-bit words */ +register char *wp; +int n; +{ + register int t; + + while (n-- > 0) { + t = wp[0]; wp[0] = wp[7]; wp[7] = t; + t = wp[1]; wp[1] = wp[6]; wp[6] = t; + t = wp[2]; wp[2] = wp[5]; wp[5] = t; + t = wp[3]; wp[3] = wp[4]; wp[4] = t; + wp += 8; + } +} + + getcascii(col) /* get an ascii color value from stream(s) */ COLOR col; { @@ -551,6 +585,8 @@ COLOR col; fread((char *)(vd+2), sizeof(double), 1, fin3) != 1) return(-1); } + if (swapbytes) + swap64((char *)vd, 3); setcolor(col, vd[rord[RED]], vd[rord[GRN]], vd[rord[BLU]]); return(0); } @@ -570,6 +606,8 @@ COLOR col; fread((char *)(vf+2), sizeof(float), 1, fin3) != 1) return(-1); } + if (swapbytes) + swap32((uint32 *)vf, 3); setcolor(col, vf[rord[RED]], vf[rord[GRN]], vf[rord[BLU]]); return(0); } @@ -656,6 +694,8 @@ COLOR col; if (fread((char *)&vd, sizeof(double), 1, fin) != 1) return(-1); + if (swapbytes) + swap64((char *)&vd, 1); setcolor(col, vd, vd, vd); return(0); } @@ -668,6 +708,8 @@ COLOR col; if (fread((char *)&vf, sizeof(float), 1, fin) != 1) return(-1); + if (swapbytes) + swap32((uint32 *)&vf, 1); setcolor(col, vf, vf, vf); return(0); } @@ -737,6 +779,8 @@ COLOR col; vf[0] = colval(col,ord[0]); vf[1] = colval(col,ord[1]); vf[2] = colval(col,ord[2]); + if (swapbytes) + swap32((uint32 *)vf, 3); fwrite((char *)vf, sizeof(float), 3, stdout); return(ferror(stdout) ? -1 : 0); @@ -751,6 +795,8 @@ COLOR col; vd[0] = colval(col,ord[0]); vd[1] = colval(col,ord[1]); vd[2] = colval(col,ord[2]); + if (swapbytes) + swap64((char *)vd, 3); fwrite((char *)vd, sizeof(double), 3, stdout); return(ferror(stdout) ? -1 : 0); @@ -822,6 +868,8 @@ COLOR col; float vf; vf = (*mybright)(col); + if (swapbytes) + swap32((uint32 *)&vf, 1); fwrite((char *)&vf, sizeof(float), 1, stdout); return(ferror(stdout) ? -1 : 0); @@ -834,6 +882,8 @@ COLOR col; double vd; vd = (*mybright)(col); + if (swapbytes) + swap64((char *)&vd, 1); fwrite((char *)&vd, sizeof(double), 1, stdout); return(ferror(stdout) ? -1 : 0); @@ -894,6 +944,8 @@ COLOR col; float vf; vf = colval(col,putprim); + if (swapbytes) + swap32((uint32 *)&vf, 1); fwrite((char *)&vf, sizeof(float), 1, stdout); return(ferror(stdout) ? -1 : 0); @@ -906,6 +958,8 @@ COLOR col; double vd; vd = colval(col,putprim); + if (swapbytes) + swap64((char *)&vd, 1); fwrite((char *)&vd, sizeof(double), 1, stdout); return(ferror(stdout) ? -1 : 0);
