--- ray/src/px/pvalue.c 2003/02/25 16:22:05 2.15 +++ ray/src/px/pvalue.c 2003/10/22 02:06:35 2.24 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: pvalue.c,v 2.15 2003/02/25 16:22:05 greg Exp $"; +static const char RCSid[] = "$Id: pvalue.c,v 2.24 2003/10/22 02:06:35 greg Exp $"; #endif /* * pvalue.c - program to print pixel values. @@ -7,24 +7,17 @@ static const char RCSid[] = "$Id: pvalue.c,v 2.15 2003 * 4/23/86 */ +#include "platform.h" #include "standard.h" - #include "color.h" - -#include - #include "resolu.h" -typedef unsigned short uint16; /* sizeof (uint16) must == 2 */ - #define min(a,b) ((a)<(b)?(a):(b)) /* what to put out (also RED, GRN, BLU) */ #define ALL 3 #define BRIGHT 4 -#define brightonly (putprim==BRIGHT) - RESOLU picres; /* resolution of picture */ int uniq = 0; /* print only unique values? */ @@ -44,6 +37,8 @@ int header = 1; /* do header? */ long skipbytes = 0; /* skip bytes in input? */ +int swapbytes = 0; /* swap bytes? */ + int interleave = 1; /* file is interleaved? */ int resolution = 1; /* put/get resolution string? */ @@ -169,16 +164,22 @@ char **argv; format = 'b'; fmtid = "byte"; break; + case 'W': /* 16-bit swapped */ + swapbytes = 1; case 'w': /* 16-bit */ dataonly = 1; format = 'w'; fmtid = "16-bit"; break; + case 'F': /* swapped floats */ + swapbytes = 1; case 'f': /* float */ dataonly = 1; format = 'f'; fmtid = "float"; break; + case 'D': /* swapped doubles */ + swapbytes = 1; case 'd': /* double */ dataonly = 1; format = 'd'; @@ -214,16 +215,18 @@ unkopt: else break; /* recognize special formats */ - if (dataonly && format == 'b') - if (brightonly) - fmtid = "8-bit_grey"; - else + if (dataonly && format == 'b') { + if (putprim == ALL) fmtid = "24-bit_rgb"; - if (dataonly && format == 'w') - if (brightonly) - fmtid = "16-bit_grey"; else + fmtid = "8-bit_grey"; + } + if (dataonly && format == 'w') { + if (putprim == ALL) fmtid = "48-bit_rgb"; + else + fmtid = "16-bit_grey"; + } /* assign reverse ordering */ rord[ord[0]] = 0; rord[ord[1]] = 1; @@ -237,7 +240,7 @@ unkopt: progname, argv[i]); quit(1); } - if (reverse && !brightonly && i == argc-3) { + if (reverse && putprim != BRIGHT && i == argc-3) { if ((fin2 = fopen(argv[i+1], "r")) == NULL) { fprintf(stderr, "%s: can't open file \"%s\"\n", progname, argv[i+1]); @@ -251,7 +254,7 @@ unkopt: interleave = -1; } else if (i != argc-1) fin = NULL; - if (reverse && !brightonly && !interleave) { + if (reverse && putprim != BRIGHT && !interleave) { fin2 = fopen(argv[i], "r"); fin3 = fopen(argv[i], "r"); } @@ -269,10 +272,10 @@ unkopt: } if (reverse) { -#ifdef MSDOS - setmode(fileno(stdout), O_BINARY); +#ifdef _WIN32 + SET_FILE_BINARY(stdout); if (format != 'a' && format != 'i') - setmode(fileno(fin), O_BINARY); + SET_FILE_BINARY(fin); #endif /* get header */ if (header) { @@ -317,10 +320,10 @@ unkopt: fputsresolu(&picres, stdout); /* always put resolution */ valtopix(); } else { -#ifdef MSDOS - setmode(fileno(fin), O_BINARY); +#ifdef _WIN32 + SET_FILE_BINARY(fin); if (format != 'a' && format != 'i') - setmode(fileno(stdout), O_BINARY); + SET_FILE_BINARY(stdout); #endif /* get header */ getheader(fin, checkhead, NULL); @@ -390,7 +393,7 @@ pixtoval() /* convert picture to values */ register COLOR *scanln; int dogamma; COLOR lastc; - FLOAT hv[2]; + RREAL hv[2]; int startprim, endprim; long startpos; int y; @@ -422,7 +425,7 @@ pixtoval() /* convert picture to values */ quit(1); } for (x = 0; x < scanlen(&picres); x++) { - if (uniq) + if (uniq) { if ( colval(scanln[x],RED) == colval(lastc,RED) && colval(scanln[x],GRN) == @@ -432,6 +435,7 @@ pixtoval() /* convert picture to values */ continue; else copycolor(lastc, scanln[x]); + } if (doexposure) multcolor(scanln[x], exposure); if (dogamma) @@ -509,6 +513,45 @@ int code; } +swap16(wp, n) /* swap n 16-bit words */ +register uint16 *wp; +int n; +{ + while (n-- > 0) { + *wp = *wp << 8 | ((*wp >> 8) & 0xff); + wp++; + } +} + + +swap32(wp, n) /* swap n 32-bit words */ +register uint32 *wp; +int n; +{ + while (n-- > 0) { + *wp = *wp << 24 | ((*wp >> 24) & 0xff) | + (*wp & 0xff00) << 8 | (*wp & 0xff0000) >> 8; + wp++; + } +} + + +swap64(wp, n) /* swap n 64-bit words */ +register char *wp; +int n; +{ + register int t; + + while (n-- > 0) { + t = wp[0]; wp[0] = wp[7]; wp[7] = t; + t = wp[1]; wp[1] = wp[6]; wp[6] = t; + t = wp[2]; wp[2] = wp[5]; wp[5] = t; + t = wp[3]; wp[3] = wp[4]; wp[4] = t; + wp += 8; + } +} + + getcascii(col) /* get an ascii color value from stream(s) */ COLOR col; { @@ -542,6 +585,8 @@ COLOR col; fread((char *)(vd+2), sizeof(double), 1, fin3) != 1) return(-1); } + if (swapbytes) + swap64((char *)vd, 3); setcolor(col, vd[rord[RED]], vd[rord[GRN]], vd[rord[BLU]]); return(0); } @@ -561,6 +606,8 @@ COLOR col; fread((char *)(vf+2), sizeof(float), 1, fin3) != 1) return(-1); } + if (swapbytes) + swap32((uint32 *)vf, 3); setcolor(col, vf[rord[RED]], vf[rord[GRN]], vf[rord[BLU]]); return(0); } @@ -620,6 +667,8 @@ COLOR col; fread((char *)(vw+2), sizeof(uint16), 1, fin3) != 1) return(-1); } + if (swapbytes) + swap16(vw, 3); setcolor(col, (vw[rord[RED]]+.5)/65536., (vw[rord[GRN]]+.5)/65536., (vw[rord[BLU]]+.5)/65536.); return(0); @@ -645,6 +694,8 @@ COLOR col; if (fread((char *)&vd, sizeof(double), 1, fin) != 1) return(-1); + if (swapbytes) + swap64((char *)&vd, 1); setcolor(col, vd, vd, vd); return(0); } @@ -657,6 +708,8 @@ COLOR col; if (fread((char *)&vf, sizeof(float), 1, fin) != 1) return(-1); + if (swapbytes) + swap32((uint32 *)&vf, 1); setcolor(col, vf, vf, vf); return(0); } @@ -698,6 +751,8 @@ COLOR col; if (fread((char *)&vw, sizeof(uint16), 1, fin) != 1) return(-1); + if (swapbytes) + swap16(&vw, 1); d = (vw+.5)/65536.; setcolor(col, d, d, d); return(0); @@ -724,6 +779,8 @@ COLOR col; vf[0] = colval(col,ord[0]); vf[1] = colval(col,ord[1]); vf[2] = colval(col,ord[2]); + if (swapbytes) + swap32((uint32 *)vf, 3); fwrite((char *)vf, sizeof(float), 3, stdout); return(ferror(stdout) ? -1 : 0); @@ -738,6 +795,8 @@ COLOR col; vd[0] = colval(col,ord[0]); vd[1] = colval(col,ord[1]); vd[2] = colval(col,ord[2]); + if (swapbytes) + swap64((char *)vd, 3); fwrite((char *)vd, sizeof(double), 3, stdout); return(ferror(stdout) ? -1 : 0); @@ -786,6 +845,8 @@ COLOR col; vw[1] = min(i,65535); i = colval(col,ord[2])*65536.; vw[2] = min(i,65535); + if (swapbytes) + swap16(vw, 3); fwrite((char *)vw, sizeof(uint16), 3, stdout); return(ferror(stdout) ? -1 : 0); @@ -807,6 +868,8 @@ COLOR col; float vf; vf = (*mybright)(col); + if (swapbytes) + swap32((uint32 *)&vf, 1); fwrite((char *)&vf, sizeof(float), 1, stdout); return(ferror(stdout) ? -1 : 0); @@ -819,6 +882,8 @@ COLOR col; double vd; vd = (*mybright)(col); + if (swapbytes) + swap64((char *)&vd, 1); fwrite((char *)&vd, sizeof(double), 1, stdout); return(ferror(stdout) ? -1 : 0); @@ -856,6 +921,8 @@ COLOR col; i = (*mybright)(col)*65536.; vw = min(i,65535); + if (swapbytes) + swap16(&vw, 1); fwrite((char *)&vw, sizeof(uint16), 1, stdout); return(ferror(stdout) ? -1 : 0); @@ -877,6 +944,8 @@ COLOR col; float vf; vf = colval(col,putprim); + if (swapbytes) + swap32((uint32 *)&vf, 1); fwrite((char *)&vf, sizeof(float), 1, stdout); return(ferror(stdout) ? -1 : 0); @@ -889,6 +958,8 @@ COLOR col; double vd; vd = colval(col,putprim); + if (swapbytes) + swap64((char *)&vd, 1); fwrite((char *)&vd, sizeof(double), 1, stdout); return(ferror(stdout) ? -1 : 0); @@ -926,6 +997,8 @@ COLOR col; i = colval(col,putprim)*65536.; vw = min(i,65535); + if (swapbytes) + swap16(&vw, 1); fwrite((char *)&vw, sizeof(uint16), 1, stdout); return(ferror(stdout) ? -1 : 0);
