--- ray/src/px/pvalue.c 1989/02/02 10:49:31 1.1 +++ ray/src/px/pvalue.c 1991/04/19 09:00:55 1.6 @@ -19,9 +19,9 @@ static char SCCSid[] = "$SunId$ LBL"; int xres = 0; /* resolution of input */ int yres = 0; -int uniq = 0; /* unique values? */ +int uniq = 0; /* print only unique values? */ -int original = 0; /* original values? */ +int original = 0; /* convert back to original values? */ int dataonly = 0; /* data only format? */ @@ -30,11 +30,14 @@ int brightonly = 0; /* only brightness values? */ int reverse = 0; /* reverse conversion? */ int format = 'a'; /* input/output format */ +char *fmtid = "ascii"; /* format identifier for header */ int header = 1; /* do header */ -double exposure = 1.0; +int wrongformat = 0; /* wrong input format? */ +COLOR exposure = WHTCOLOR; + char *progname; FILE *fin; @@ -76,12 +79,23 @@ char **argv; case '\0': case 'a': /* ascii */ format = 'a'; + fmtid = "ascii"; break; case 'i': /* integer */ + format = 'i'; + fmtid = "ascii"; + break; case 'b': /* byte */ + format = 'b'; + fmtid = "byte"; + break; case 'f': /* float */ + format = 'f'; + fmtid = "float"; + break; case 'd': /* double */ - format = argv[i][2]; + format = 'd'; + fmtid = "double"; break; default: goto unkopt; @@ -102,7 +116,13 @@ unkopt: } else break; - + /* recognize special formats */ + if (dataonly && format == 'b') + if (brightonly) + fmtid = "8-bit_grey"; + else + fmtid = "24-bit_rgb"; + if (i == argc) { fin = stdin; } else if (i == argc-1) { @@ -119,24 +139,33 @@ unkopt: set_io(); if (reverse) { - if (header) /* get header */ - copyheader(fin, stdout); - /* add to header */ - printargs(i, argv, stdout); - printf("\n"); if (yres <= 0 || xres <= 0) { fprintf(stderr, "%s: missing x and y resolution\n", progname); quit(1); } - printf("-Y %d +X %d\n", yres, xres); /* resolution */ + /* get header */ + if (header && checkheader(fin, fmtid, stdout) < 0) { + fprintf(stderr, "%s: wrong input format\n", progname); + quit(1); + } + /* add to header */ + printargs(i, argv, stdout); + fputformat(COLRFMT, stdout); + printf("\n"); + fputresolu(YMAJOR|YDECR, xres, yres, stdout); valtopix(); } else { /* get header */ - getheader(fin, checkhead); + getheader(fin, checkhead, NULL); + if (wrongformat) { + fprintf(stderr, "%s: input not a Radiance picture\n", + progname); + quit(1); + } if (xres <= 0 || yres <= 0) /* get picture size */ - if (fscanf(fin, "-Y %d +X %d\n", &yres, &xres) != 2) { + if (fgetresolu(&xres, &yres, fin) != (YMAJOR|YDECR)) { fprintf(stderr, "%s: missing x and y resolution\n", progname); @@ -144,6 +173,7 @@ unkopt: } if (header) { printargs(i, argv, stdout); + fputformat(fmtid, stdout); printf("\n"); } pixtoval(); @@ -156,10 +186,23 @@ unkopt: checkhead(line) /* deal with line from header */ char *line; { - if (header) + char fmt[32]; + double d; + COLOR ctmp; + + if (isformat(line)) { + formatval(fmt, line); + wrongformat = strcmp(fmt, COLRFMT); + } else if (original && isexpos(line)) { + d = 1.0/exposval(line); + scalecolor(exposure, d); + } else if (original && iscolcor(line)) { + colcorval(ctmp, line); + colval(exposure,RED) /= colval(ctmp,RED); + colval(exposure,GRN) /= colval(ctmp,GRN); + colval(exposure,BLU) /= colval(ctmp,BLU); + } else if (header) fputs(line, stdout); - if (!strncmp(line, "EXPOSURE=", 9)) - exposure *= atof(line+9); } @@ -190,7 +233,7 @@ pixtoval() /* convert picture to values */ else copycolor(lastc, scanln[x]); if (original) - scalecolor(scanln[x], 1.0/exposure); + multcolor(scanln[x], exposure); if (!dataonly) printf("%7d %7d ", x, y); if ((*putval)(scanln[x], stdout) < 0) { @@ -259,7 +302,7 @@ FILE *fp; { double vd[3]; - if (fread(vd, sizeof(double), 3, fp) != 3) + if (fread((char *)vd, sizeof(double), 3, fp) != 3) return(-1); setcolor(col, vd[0], vd[1], vd[2]); return(0); @@ -272,7 +315,7 @@ FILE *fp; { float vf[3]; - if (fread(vf, sizeof(float), 3, fp) != 3) + if (fread((char *)vf, sizeof(float), 3, fp) != 3) return(-1); setcolor(col, vf[0], vf[1], vf[2]); return(0); @@ -298,7 +341,7 @@ FILE *fp; { BYTE vb[3]; - if (fread(vb, sizeof(BYTE), 3, fp) != 3) + if (fread((char *)vb, sizeof(BYTE), 3, fp) != 3) return(-1); setcolor(col,(vb[0]+.5)/256.,(vb[1]+.5)/256.,(vb[2]+.5)/256.); return(0); @@ -324,7 +367,7 @@ FILE *fp; { double vd; - if (fread(&vd, sizeof(double), 1, fp) != 1) + if (fread((char *)&vd, sizeof(double), 1, fp) != 1) return(-1); setcolor(col, vd, vd, vd); return(0); @@ -337,7 +380,7 @@ FILE *fp; { float vf; - if (fread(&vf, sizeof(float), 1, fp) != 1) + if (fread((char *)&vf, sizeof(float), 1, fp) != 1) return(-1); setcolor(col, vf, vf, vf); return(0); @@ -366,7 +409,7 @@ FILE *fp; BYTE vb; double d; - if (fread(&vb, sizeof(BYTE), 1, fp) != 1) + if (fread((char *)&vb, sizeof(BYTE), 1, fp) != 1) return(-1); d = (vb+.5)/256.; setcolor(col, d, d, d); @@ -396,7 +439,7 @@ FILE *fp; vf[0] = colval(col,RED); vf[1] = colval(col,GRN); vf[2] = colval(col,BLU); - fwrite(vf, sizeof(float), 3, fp); + fwrite((char *)vf, sizeof(float), 3, fp); return(ferror(fp) ? -1 : 0); } @@ -411,7 +454,7 @@ FILE *fp; vd[0] = colval(col,RED); vd[1] = colval(col,GRN); vd[2] = colval(col,BLU); - fwrite(vd, sizeof(double), 3, fp); + fwrite((char *)vd, sizeof(double), 3, fp); return(ferror(fp) ? -1 : 0); } @@ -443,7 +486,7 @@ FILE *fp; vb[1] = min(i,255); i = colval(col,BLU)*256.; vb[2] = min(i,255); - fwrite(vb, sizeof(BYTE), 3, fp); + fwrite((char *)vb, sizeof(BYTE), 3, fp); return(ferror(fp) ? -1 : 0); } @@ -466,7 +509,7 @@ FILE *fp; float vf; vf = bright(col); - fwrite(&vf, sizeof(float), 1, fp); + fwrite((char *)&vf, sizeof(float), 1, fp); return(ferror(fp) ? -1 : 0); } @@ -479,7 +522,7 @@ FILE *fp; double vd; vd = bright(col); - fwrite(&vd, sizeof(double), 1, fp); + fwrite((char *)&vd, sizeof(double), 1, fp); return(ferror(fp) ? -1 : 0); } @@ -504,7 +547,7 @@ FILE *fp; i = bright(col)*256.; vb = min(i,255); - fwrite(&vb, sizeof(BYTE), 1, fp); + fwrite((char *)&vb, sizeof(BYTE), 1, fp); return(ferror(fp) ? -1 : 0); }
