--- ray/src/px/pvalue.c 1997/01/08 07:43:49 2.10 +++ ray/src/px/pvalue.c 2003/06/08 12:03:10 2.19 @@ -1,29 +1,27 @@ -/* Copyright (c) 1992 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: pvalue.c,v 2.19 2003/06/08 12:03:10 schorsch Exp $"; #endif - /* * pvalue.c - program to print pixel values. * * 4/23/86 */ -#include "standard.h" +#include +#include "standard.h" +#include "platform.h" #include "color.h" - #include "resolu.h" +typedef unsigned short uint16; /* sizeof (uint16) must == 2 */ + #define min(a,b) ((a)<(b)?(a):(b)) /* what to put out (also RED, GRN, BLU) */ #define ALL 3 #define BRIGHT 4 -#define brightonly (putprim==BRIGHT) - RESOLU picres; /* resolution of picture */ int uniq = 0; /* print only unique values? */ @@ -43,6 +41,10 @@ int header = 1; /* do header? */ long skipbytes = 0; /* skip bytes in input? */ +int swapbytes = 0; /* swap bytes in 16-bit words? */ + +int interleave = 1; /* file is interleaved? */ + int resolution = 1; /* put/get resolution string? */ int original = 0; /* convert to original values? */ @@ -63,7 +65,23 @@ FILE *fin2 = NULL, *fin3 = NULL; /* for other color c int (*getval)(), (*putval)(); +double +rgb_bright(clr) +COLOR clr; +{ + return(bright(clr)); +} +double +xyz_bright(clr) +COLOR clr; +{ + return(clr[CIEY]); +} + +double (*mybright)() = &rgb_bright; + + main(argc, argv) int argc; char **argv; @@ -119,6 +137,9 @@ char **argv; case 'r': /* reverse conversion */ reverse = argv[i][0] == '-'; break; + case 'n': /* non-interleaved RGB */ + interleave = argv[i][0] == '+'; + break; case 'b': /* brightness values */ putprim = argv[i][0] == '-' ? BRIGHT : ALL; break; @@ -147,6 +168,13 @@ char **argv; format = 'b'; fmtid = "byte"; break; + case 'W': /* 16-bit swapped */ + swapbytes = 1; + case 'w': /* 16-bit */ + dataonly = 1; + format = 'w'; + fmtid = "16-bit"; + break; case 'f': /* float */ dataonly = 1; format = 'f'; @@ -165,16 +193,16 @@ char **argv; case 'X': /* x resolution */ resolution = 0; if (argv[i][0] == '-') - picres.or |= XDECR; + picres.rt |= XDECR; picres.xr = atoi(argv[++i]); break; case 'y': /* y resolution */ case 'Y': /* y resolution */ resolution = 0; if (argv[i][0] == '-') - picres.or |= YDECR; + picres.rt |= YDECR; if (picres.xr == 0) - picres.or |= YMAJOR; + picres.rt |= YMAJOR; picres.yr = atoi(argv[++i]); break; default: @@ -188,10 +216,15 @@ unkopt: break; /* recognize special formats */ if (dataonly && format == 'b') - if (brightonly) + if (putprim == ALL) + fmtid = "24-bit_rgb"; + else fmtid = "8-bit_grey"; + if (dataonly && format == 'w') + if (putprim == ALL) + fmtid = "48-bit_rgb"; else - fmtid = "24-bit_rgb"; + fmtid = "16-bit_grey"; /* assign reverse ordering */ rord[ord[0]] = 0; rord[ord[1]] = 1; @@ -205,9 +238,7 @@ unkopt: progname, argv[i]); quit(1); } - if (skipbytes && fseek(fin, skipbytes, 0)) - goto seekerr; - if (reverse && !brightonly && i == argc-3) { + if (reverse && putprim != BRIGHT && i == argc-3) { if ((fin2 = fopen(argv[i+1], "r")) == NULL) { fprintf(stderr, "%s: can't open file \"%s\"\n", progname, argv[i+1]); @@ -218,24 +249,31 @@ unkopt: progname, argv[i+2]); quit(1); } - if (skipbytes && (fseek(fin2, skipbytes, 0) || - fseek(fin3, skipbytes, 0))) - goto seekerr; + interleave = -1; } else if (i != argc-1) fin = NULL; + if (reverse && putprim != BRIGHT && !interleave) { + fin2 = fopen(argv[i], "r"); + fin3 = fopen(argv[i], "r"); + } + if (skipbytes && (fseek(fin, skipbytes, 0) || (fin2 != NULL && + (fseek(fin2, skipbytes, 0) || + fseek(fin3, skipbytes, 0))))) { + fprintf(stderr, "%s: cannot skip %ld bytes on input\n", + progname, skipbytes); + quit(1); + } } if (fin == NULL) { fprintf(stderr, "%s: bad # file arguments\n", progname); quit(1); } - set_io(); - if (reverse) { -#ifdef MSDOS - setmode(fileno(stdout), O_BINARY); +#ifdef _WIN32 + SET_FILE_BINARY(stdout); if (format != 'a' && format != 'i') - setmode(fileno(fin), O_BINARY); + SET_FILE_BINARY(fin); #endif /* get header */ if (header) { @@ -259,11 +297,11 @@ unkopt: if (resolution && fin2 != NULL) { RESOLU pres2; if (!fgetsresolu(&pres2, fin2) || - pres2.or != picres.or || + pres2.rt != picres.rt || pres2.xr != picres.xr || pres2.yr != picres.yr || !fgetsresolu(&pres2, fin3) || - pres2.or != picres.or || + pres2.rt != picres.rt || pres2.xr != picres.xr || pres2.yr != picres.yr) { fprintf(stderr, "%s: resolution mismatch\n", @@ -280,15 +318,16 @@ unkopt: fputsresolu(&picres, stdout); /* always put resolution */ valtopix(); } else { -#ifdef MSDOS - setmode(fileno(fin), O_BINARY); +#ifdef _WIN32 + SET_FILE_BINARY(fin); if (format != 'a' && format != 'i') - setmode(fileno(stdout), O_BINARY); + SET_FILE_BINARY(stdout); #endif /* get header */ getheader(fin, checkhead, NULL); if (wrongformat) { - fprintf(stderr, "%s: input not a Radiance picture\n", + fprintf(stderr, + "%s: input not a Radiance RGBE picture\n", progname); quit(1); } @@ -309,13 +348,10 @@ unkopt: } quit(0); -seekerr: - fprintf(stderr, "%s: cannot skip %ld bytes on input\n", - progname, skipbytes); - quit(1); } +int checkhead(line) /* deal with line from header */ char *line; { @@ -323,9 +359,18 @@ char *line; double d; COLOR ctmp; - if (formatval(fmt, line)) - wrongformat = strcmp(fmt, COLRFMT); - else if (original && isexpos(line)) { + if (formatval(fmt, line)) { + if (!strcmp(fmt, CIEFMT)) { + mybright = &xyz_bright; + if (original) { + scalecolor(exposure, 1./WHTEFFICACY); + doexposure++; + } + } else if (!strcmp(fmt, COLRFMT)) + mybright = &rgb_bright; + else + wrongformat++; + } else if (original && isexpos(line)) { d = 1.0/exposval(line); scalecolor(exposure, d); doexposure++; @@ -337,6 +382,7 @@ char *line; doexposure++; } else if (header) fputs(line, stdout); + return(0); } @@ -346,6 +392,8 @@ pixtoval() /* convert picture to values */ int dogamma; COLOR lastc; FLOAT hv[2]; + int startprim, endprim; + long startpos; int y; register int x; @@ -355,42 +403,58 @@ pixtoval() /* convert picture to values */ quit(1); } dogamma = gamcor < .95 || gamcor > 1.05; - setcolor(lastc, 0.0, 0.0, 0.0); - for (y = 0; y < numscans(&picres); y++) { - if (freadscan(scanln, scanlen(&picres), fin) < 0) { - fprintf(stderr, "%s: read error\n", progname); + if (putprim == ALL && !interleave) { + startprim = RED; endprim = BLU; + startpos = ftell(fin); + } else { + startprim = putprim; endprim = putprim; + } + for (putprim = startprim; putprim <= endprim; putprim++) { + if (putprim != startprim && fseek(fin, startpos, 0)) { + fprintf(stderr, "%s: seek error on input file\n", + progname); quit(1); } - for (x = 0; x < scanlen(&picres); x++) { - if (uniq) - if ( colval(scanln[x],RED) == - colval(lastc,RED) && - colval(scanln[x],GRN) == - colval(lastc,GRN) && - colval(scanln[x],BLU) == - colval(lastc,BLU) ) - continue; - else - copycolor(lastc, scanln[x]); - if (doexposure) - multcolor(scanln[x], exposure); - if (dogamma) - setcolor(scanln[x], - pow(colval(scanln[x],RED), 1.0/gamcor), - pow(colval(scanln[x],GRN), 1.0/gamcor), - pow(colval(scanln[x],BLU), 1.0/gamcor)); - if (!dataonly) { - pix2loc(hv, &picres, x, y); - printf("%7d %7d ", (int)(hv[0]*picres.xr), - (int)(hv[1]*picres.yr)); - } - if ((*putval)(scanln[x], stdout) < 0) { - fprintf(stderr, "%s: write error\n", progname); + set_io(); + setcolor(lastc, 0.0, 0.0, 0.0); + for (y = 0; y < numscans(&picres); y++) { + if (freadscan(scanln, scanlen(&picres), fin) < 0) { + fprintf(stderr, "%s: read error\n", progname); quit(1); } + for (x = 0; x < scanlen(&picres); x++) { + if (uniq) + if ( colval(scanln[x],RED) == + colval(lastc,RED) && + colval(scanln[x],GRN) == + colval(lastc,GRN) && + colval(scanln[x],BLU) == + colval(lastc,BLU) ) + continue; + else + copycolor(lastc, scanln[x]); + if (doexposure) + multcolor(scanln[x], exposure); + if (dogamma) + setcolor(scanln[x], + pow(colval(scanln[x],RED), 1.0/gamcor), + pow(colval(scanln[x],GRN), 1.0/gamcor), + pow(colval(scanln[x],BLU), 1.0/gamcor)); + if (!dataonly) { + pix2loc(hv, &picres, x, y); + printf("%7d %7d ", + (int)(hv[0]*picres.xr), + (int)(hv[1]*picres.yr)); + } + if ((*putval)(scanln[x]) < 0) { + fprintf(stderr, "%s: write error\n", + progname); + quit(1); + } + } } } - free((char *)scanln); + free((void *)scanln); } @@ -407,6 +471,7 @@ valtopix() /* convert values to a pixel file */ quit(1); } dogamma = gamcor < .95 || gamcor > 1.05; + set_io(); for (y = 0; y < numscans(&picres); y++) { for (x = 0; x < scanlen(&picres); x++) { if (!dataonly) { @@ -416,7 +481,7 @@ valtopix() /* convert values to a pixel file */ fscanf(fin3, "%*d %*d"); } } - if ((*getval)(scanln[x], fin, fin2, fin3) < 0) { + if ((*getval)(scanln[x]) < 0) { fprintf(stderr, "%s: read error\n", progname); quit(1); } @@ -433,10 +498,11 @@ valtopix() /* convert values to a pixel file */ quit(1); } } - free((char *)scanln); + free((void *)scanln); } +void quit(code) int code; { @@ -444,19 +510,28 @@ int code; } -getcascii(col, f1, f2, f3) /* get an ascii color value from stream(s) */ +swap16(wp, n) /* swap n 16-bit words */ +register uint16 *wp; +int n; +{ + while (n-- > 0) { + *wp = *wp << 8 | ((*wp >> 8) & 0xff); + wp++; + } +} + +getcascii(col) /* get an ascii color value from stream(s) */ COLOR col; -FILE *f1, *f2, *f3; { double vd[3]; - if (f2 == NULL) { - if (fscanf(f1, "%lf %lf %lf", &vd[0], &vd[1], &vd[2]) != 3) + if (fin2 == NULL) { + if (fscanf(fin, "%lf %lf %lf", &vd[0], &vd[1], &vd[2]) != 3) return(-1); } else { - if (fscanf(f1, "%lf", &vd[0]) != 1 || - fscanf(f2, "%lf", &vd[1]) != 1 || - fscanf(f3, "%lf", &vd[2]) != 1) + if (fscanf(fin, "%lf", &vd[0]) != 1 || + fscanf(fin2, "%lf", &vd[1]) != 1 || + fscanf(fin3, "%lf", &vd[2]) != 1) return(-1); } setcolor(col, vd[rord[RED]], vd[rord[GRN]], vd[rord[BLU]]); @@ -464,19 +539,18 @@ FILE *f1, *f2, *f3; } -getcdouble(col, f1, f2, f3) /* get a double color value from stream(s) */ +getcdouble(col) /* get a double color value from stream(s) */ COLOR col; -FILE *f1, *f2, *f3; { double vd[3]; - if (f2 == NULL) { - if (fread((char *)vd, sizeof(double), 3, f1) != 3) + if (fin2 == NULL) { + if (fread((char *)vd, sizeof(double), 3, fin) != 3) return(-1); } else { - if (fread((char *)vd, sizeof(double), 1, f1) != 1 || - fread((char *)(vd+1), sizeof(double), 1, f2) != 1 || - fread((char *)(vd+2), sizeof(double), 1, f3) != 1) + if (fread((char *)vd, sizeof(double), 1, fin) != 1 || + fread((char *)(vd+1), sizeof(double), 1, fin2) != 1 || + fread((char *)(vd+2), sizeof(double), 1, fin3) != 1) return(-1); } setcolor(col, vd[rord[RED]], vd[rord[GRN]], vd[rord[BLU]]); @@ -484,19 +558,18 @@ FILE *f1, *f2, *f3; } -getcfloat(col, f1, f2, f3) /* get a float color value from stream(s) */ +getcfloat(col) /* get a float color value from stream(s) */ COLOR col; -FILE *f1, *f2, *f3; { float vf[3]; - if (f2 == NULL) { - if (fread((char *)vf, sizeof(float), 3, f1) != 3) + if (fin2 == NULL) { + if (fread((char *)vf, sizeof(float), 3, fin) != 3) return(-1); } else { - if (fread((char *)vf, sizeof(float), 1, f1) != 1 || - fread((char *)(vf+1), sizeof(float), 1, f2) != 1 || - fread((char *)(vf+2), sizeof(float), 1, f3) != 1) + if (fread((char *)vf, sizeof(float), 1, fin) != 1 || + fread((char *)(vf+1), sizeof(float), 1, fin2) != 1 || + fread((char *)(vf+2), sizeof(float), 1, fin3) != 1) return(-1); } setcolor(col, vf[rord[RED]], vf[rord[GRN]], vf[rord[BLU]]); @@ -504,19 +577,18 @@ FILE *f1, *f2, *f3; } -getcint(col, f1, f2, f3) /* get an int color value from stream(s) */ +getcint(col) /* get an int color value from stream(s) */ COLOR col; -FILE *f1, *f2, *f3; { int vi[3]; - if (f2 == NULL) { - if (fscanf(f1, "%d %d %d", &vi[0], &vi[1], &vi[2]) != 3) + if (fin2 == NULL) { + if (fscanf(fin, "%d %d %d", &vi[0], &vi[1], &vi[2]) != 3) return(-1); } else { - if (fscanf(f1, "%d", &vi[0]) != 1 || - fscanf(f2, "%d", &vi[1]) != 1 || - fscanf(f3, "%d", &vi[2]) != 1) + if (fscanf(fin, "%d", &vi[0]) != 1 || + fscanf(fin2, "%d", &vi[1]) != 1 || + fscanf(fin3, "%d", &vi[2]) != 1) return(-1); } setcolor(col, (vi[rord[RED]]+.5)/256., @@ -525,19 +597,18 @@ FILE *f1, *f2, *f3; } -getcbyte(col, f1, f2, f3) /* get a byte color value from stream(s) */ +getcbyte(col) /* get a byte color value from stream(s) */ COLOR col; -FILE *f1, *f2, *f3; { BYTE vb[3]; - if (f2 == NULL) { - if (fread((char *)vb, sizeof(BYTE), 3, f1) != 3) + if (fin2 == NULL) { + if (fread((char *)vb, sizeof(BYTE), 3, fin) != 3) return(-1); } else { - if (fread((char *)vb, sizeof(BYTE), 1, f1) != 1 || - fread((char *)(vb+1), sizeof(BYTE), 1, f2) != 1 || - fread((char *)(vb+2), sizeof(BYTE), 1, f3) != 1) + if (fread((char *)vb, sizeof(BYTE), 1, fin) != 1 || + fread((char *)(vb+1), sizeof(BYTE), 1, fin2) != 1 || + fread((char *)(vb+2), sizeof(BYTE), 1, fin3) != 1) return(-1); } setcolor(col, (vb[rord[RED]]+.5)/256., @@ -546,53 +617,71 @@ FILE *f1, *f2, *f3; } -getbascii(col, fp) /* get an ascii brightness value from fp */ +getcword(col) /* get a 16-bit color value from stream(s) */ COLOR col; -FILE *fp; { + uint16 vw[3]; + + if (fin2 == NULL) { + if (fread((char *)vw, sizeof(uint16), 3, fin) != 3) + return(-1); + } else { + if (fread((char *)vw, sizeof(uint16), 1, fin) != 1 || + fread((char *)(vw+1), sizeof(uint16), 1, fin2) != 1 || + fread((char *)(vw+2), sizeof(uint16), 1, fin3) != 1) + return(-1); + } + if (swapbytes) + swap16(vw, 3); + setcolor(col, (vw[rord[RED]]+.5)/65536., + (vw[rord[GRN]]+.5)/65536., (vw[rord[BLU]]+.5)/65536.); + return(0); +} + + +getbascii(col) /* get an ascii brightness value from fin */ +COLOR col; +{ double vd; - if (fscanf(fp, "%lf", &vd) != 1) + if (fscanf(fin, "%lf", &vd) != 1) return(-1); setcolor(col, vd, vd, vd); return(0); } -getbdouble(col, fp) /* get a double brightness value from fp */ +getbdouble(col) /* get a double brightness value from fin */ COLOR col; -FILE *fp; { double vd; - if (fread((char *)&vd, sizeof(double), 1, fp) != 1) + if (fread((char *)&vd, sizeof(double), 1, fin) != 1) return(-1); setcolor(col, vd, vd, vd); return(0); } -getbfloat(col, fp) /* get a float brightness value from fp */ +getbfloat(col) /* get a float brightness value from fin */ COLOR col; -FILE *fp; { float vf; - if (fread((char *)&vf, sizeof(float), 1, fp) != 1) + if (fread((char *)&vf, sizeof(float), 1, fin) != 1) return(-1); setcolor(col, vf, vf, vf); return(0); } -getbint(col, fp) /* get an int brightness value from fp */ +getbint(col) /* get an int brightness value from fin */ COLOR col; -FILE *fp; { int vi; double d; - if (fscanf(fp, "%d", &vi) != 1) + if (fscanf(fin, "%d", &vi) != 1) return(-1); d = (vi+.5)/256.; setcolor(col, d, d, d); @@ -600,14 +689,13 @@ FILE *fp; } -getbbyte(col, fp) /* get a byte brightness value from fp */ +getbbyte(col) /* get a byte brightness value from fin */ COLOR col; -FILE *fp; { BYTE vb; double d; - if (fread((char *)&vb, sizeof(BYTE), 1, fp) != 1) + if (fread((char *)&vb, sizeof(BYTE), 1, fin) != 1) return(-1); d = (vb+.5)/256.; setcolor(col, d, d, d); @@ -615,67 +703,78 @@ FILE *fp; } -putcascii(col, fp) /* put an ascii color to fp */ +getbword(col) /* get a 16-bit brightness value from fin */ COLOR col; -FILE *fp; { - fprintf(fp, "%15.3e %15.3e %15.3e\n", + uint16 vw; + double d; + + if (fread((char *)&vw, sizeof(uint16), 1, fin) != 1) + return(-1); + if (swapbytes) + swap16(&vw, 1); + d = (vw+.5)/65536.; + setcolor(col, d, d, d); + return(0); +} + + +putcascii(col) /* put an ascii color to stdout */ +COLOR col; +{ + fprintf(stdout, "%15.3e %15.3e %15.3e\n", colval(col,ord[0]), colval(col,ord[1]), colval(col,ord[2])); - return(ferror(fp) ? -1 : 0); + return(ferror(stdout) ? -1 : 0); } -putcfloat(col, fp) /* put a float color to fp */ +putcfloat(col) /* put a float color to stdout */ COLOR col; -FILE *fp; { float vf[3]; vf[0] = colval(col,ord[0]); vf[1] = colval(col,ord[1]); vf[2] = colval(col,ord[2]); - fwrite((char *)vf, sizeof(float), 3, fp); + fwrite((char *)vf, sizeof(float), 3, stdout); - return(ferror(fp) ? -1 : 0); + return(ferror(stdout) ? -1 : 0); } -putcdouble(col, fp) /* put a double color to fp */ +putcdouble(col) /* put a double color to stdout */ COLOR col; -FILE *fp; { double vd[3]; vd[0] = colval(col,ord[0]); vd[1] = colval(col,ord[1]); vd[2] = colval(col,ord[2]); - fwrite((char *)vd, sizeof(double), 3, fp); + fwrite((char *)vd, sizeof(double), 3, stdout); - return(ferror(fp) ? -1 : 0); + return(ferror(stdout) ? -1 : 0); } -putcint(col, fp) /* put an int color to fp */ +putcint(col) /* put an int color to stdout */ COLOR col; -FILE *fp; { - fprintf(fp, "%d %d %d\n", + fprintf(stdout, "%d %d %d\n", (int)(colval(col,ord[0])*256.), (int)(colval(col,ord[1])*256.), (int)(colval(col,ord[2])*256.)); - return(ferror(fp) ? -1 : 0); + return(ferror(stdout) ? -1 : 0); } -putcbyte(col, fp) /* put a byte color to fp */ +putcbyte(col) /* put a byte color to stdout */ COLOR col; -FILE *fp; { - register int i; + long i; BYTE vb[3]; i = colval(col,ord[0])*256.; @@ -684,134 +783,176 @@ FILE *fp; vb[1] = min(i,255); i = colval(col,ord[2])*256.; vb[2] = min(i,255); - fwrite((char *)vb, sizeof(BYTE), 3, fp); + fwrite((char *)vb, sizeof(BYTE), 3, stdout); - return(ferror(fp) ? -1 : 0); + return(ferror(stdout) ? -1 : 0); } -putbascii(col, fp) /* put an ascii brightness to fp */ +putcword(col) /* put a 16-bit color to stdout */ COLOR col; -FILE *fp; { - fprintf(fp, "%15.3e\n", bright(col)); + long i; + uint16 vw[3]; - return(ferror(fp) ? -1 : 0); + i = colval(col,ord[0])*65536.; + vw[0] = min(i,65535); + i = colval(col,ord[1])*65536.; + vw[1] = min(i,65535); + i = colval(col,ord[2])*65536.; + vw[2] = min(i,65535); + if (swapbytes) + swap16(vw, 3); + fwrite((char *)vw, sizeof(uint16), 3, stdout); + + return(ferror(stdout) ? -1 : 0); } -putbfloat(col, fp) /* put a float brightness to fp */ +putbascii(col) /* put an ascii brightness to stdout */ COLOR col; -FILE *fp; { + fprintf(stdout, "%15.3e\n", (*mybright)(col)); + + return(ferror(stdout) ? -1 : 0); +} + + +putbfloat(col) /* put a float brightness to stdout */ +COLOR col; +{ float vf; - vf = bright(col); - fwrite((char *)&vf, sizeof(float), 1, fp); + vf = (*mybright)(col); + fwrite((char *)&vf, sizeof(float), 1, stdout); - return(ferror(fp) ? -1 : 0); + return(ferror(stdout) ? -1 : 0); } -putbdouble(col, fp) /* put a double brightness to fp */ +putbdouble(col) /* put a double brightness to stdout */ COLOR col; -FILE *fp; { double vd; - vd = bright(col); - fwrite((char *)&vd, sizeof(double), 1, fp); + vd = (*mybright)(col); + fwrite((char *)&vd, sizeof(double), 1, stdout); - return(ferror(fp) ? -1 : 0); + return(ferror(stdout) ? -1 : 0); } -putbint(col, fp) /* put an int brightness to fp */ +putbint(col) /* put an int brightness to stdout */ COLOR col; -FILE *fp; { - fprintf(fp, "%d\n", (int)(bright(col)*256.)); + fprintf(stdout, "%d\n", (int)((*mybright)(col)*256.)); - return(ferror(fp) ? -1 : 0); + return(ferror(stdout) ? -1 : 0); } -putbbyte(col, fp) /* put a byte brightness to fp */ +putbbyte(col) /* put a byte brightness to stdout */ COLOR col; -FILE *fp; { register int i; BYTE vb; - i = bright(col)*256.; + i = (*mybright)(col)*256.; vb = min(i,255); - fwrite((char *)&vb, sizeof(BYTE), 1, fp); + fwrite((char *)&vb, sizeof(BYTE), 1, stdout); - return(ferror(fp) ? -1 : 0); + return(ferror(stdout) ? -1 : 0); } -putpascii(col, fp) /* put an ascii primary to fp */ +putbword(col) /* put a 16-bit brightness to stdout */ COLOR col; -FILE *fp; { - fprintf(fp, "%15.3e\n", colval(col,putprim)); + long i; + uint16 vw; - return(ferror(fp) ? -1 : 0); + i = (*mybright)(col)*65536.; + vw = min(i,65535); + if (swapbytes) + swap16(&vw, 1); + fwrite((char *)&vw, sizeof(uint16), 1, stdout); + + return(ferror(stdout) ? -1 : 0); } -putpfloat(col, fp) /* put a float primary to fp */ +putpascii(col) /* put an ascii primary to stdout */ COLOR col; -FILE *fp; { + fprintf(stdout, "%15.3e\n", colval(col,putprim)); + + return(ferror(stdout) ? -1 : 0); +} + + +putpfloat(col) /* put a float primary to stdout */ +COLOR col; +{ float vf; vf = colval(col,putprim); - fwrite((char *)&vf, sizeof(float), 1, fp); + fwrite((char *)&vf, sizeof(float), 1, stdout); - return(ferror(fp) ? -1 : 0); + return(ferror(stdout) ? -1 : 0); } -putpdouble(col, fp) /* put a double primary to fp */ +putpdouble(col) /* put a double primary to stdout */ COLOR col; -FILE *fp; { double vd; vd = colval(col,putprim); - fwrite((char *)&vd, sizeof(double), 1, fp); + fwrite((char *)&vd, sizeof(double), 1, stdout); - return(ferror(fp) ? -1 : 0); + return(ferror(stdout) ? -1 : 0); } -putpint(col, fp) /* put an int primary to fp */ +putpint(col) /* put an int primary to stdout */ COLOR col; -FILE *fp; { - fprintf(fp, "%d\n", (int)(colval(col,putprim)*256.)); + fprintf(stdout, "%d\n", (int)(colval(col,putprim)*256.)); - return(ferror(fp) ? -1 : 0); + return(ferror(stdout) ? -1 : 0); } -putpbyte(col, fp) /* put a byte primary to fp */ +putpbyte(col) /* put a byte primary to stdout */ COLOR col; -FILE *fp; { - register int i; + long i; BYTE vb; i = colval(col,putprim)*256.; vb = min(i,255); - fwrite((char *)&vb, sizeof(BYTE), 1, fp); + fwrite((char *)&vb, sizeof(BYTE), 1, stdout); - return(ferror(fp) ? -1 : 0); + return(ferror(stdout) ? -1 : 0); } +putpword(col) /* put a 16-bit primary to stdout */ +COLOR col; +{ + long i; + uint16 vw; + + i = colval(col,putprim)*65536.; + vw = min(i,65535); + if (swapbytes) + swap16(&vw, 1); + fwrite((char *)&vw, sizeof(uint16), 1, stdout); + + return(ferror(stdout) ? -1 : 0); +} + + set_io() /* set put and get functions */ { switch (format) { @@ -825,6 +966,12 @@ set_io() /* set put and get functions */ } else { getval = getcascii; putval = putcascii; + if (reverse && !interleave) { + fprintf(stderr, + "%s: ASCII input files must be interleaved\n", + progname); + quit(1); + } } return; case 'f': /* binary float */ @@ -837,6 +984,16 @@ set_io() /* set put and get functions */ } else { getval = getcfloat; putval = putcfloat; + if (reverse && !interleave) { + if (fin2 == NULL) + goto namerr; + if (fseek(fin2, + (long)sizeof(float)*picres.xr*picres.yr, 1)) + goto seekerr; + if (fseek(fin3, + (long)sizeof(float)*2*picres.xr*picres.yr, 1)) + goto seekerr; + } } return; case 'd': /* binary double */ @@ -849,6 +1006,16 @@ set_io() /* set put and get functions */ } else { getval = getcdouble; putval = putcdouble; + if (reverse && !interleave) { + if (fin2 == NULL) + goto namerr; + if (fseek(fin2, + (long)sizeof(double)*picres.xr*picres.yr, 1)) + goto seekerr; + if (fseek(fin3, + (long)sizeof(double)*2*picres.xr*picres.yr, 1)) + goto seekerr; + } } return; case 'i': /* integer */ @@ -861,6 +1028,12 @@ set_io() /* set put and get functions */ } else { getval = getcint; putval = putcint; + if (reverse && !interleave) { + fprintf(stderr, + "%s: integer input files must be interleaved\n", + progname); + quit(1); + } } return; case 'b': /* byte */ @@ -873,7 +1046,50 @@ set_io() /* set put and get functions */ } else { getval = getcbyte; putval = putcbyte; + if (reverse && !interleave) { + if (fin2 == NULL) + goto namerr; + if (fseek(fin2, + (long)sizeof(BYTE)*picres.xr*picres.yr, 1)) + goto seekerr; + if (fseek(fin3, + (long)sizeof(BYTE)*2*picres.xr*picres.yr, 1)) + goto seekerr; + } } return; + case 'w': /* 16-bit */ + if (putprim == BRIGHT) { + getval = getbword; + putval = putbword; + } else if (putprim != ALL) { + getval = getbword; + putval = putpword; + } else { + getval = getcword; + putval = putcword; + if (reverse && !interleave) { + if (fin2 == NULL) + goto namerr; + if (fseek(fin2, + (long)sizeof(uint16)*picres.xr*picres.yr, 1)) + goto seekerr; + if (fseek(fin3, + (long)sizeof(uint16)*2*picres.xr*picres.yr, 1)) + goto seekerr; + } + } + return; } +badopt: + fprintf(stderr, "%s: botched file type\n", progname); + quit(1); +namerr: + fprintf(stderr, "%s: non-interleaved file(s) must be named\n", + progname); + quit(1); +seekerr: + fprintf(stderr, "%s: cannot seek on interleaved input file\n", + progname); + quit(1); }
