Forgot to remove debug statement on last check-in
Eliminated copystruct() macro, which is unnecessary in ANSI. Reduced ambiguity warnings for nested if/if/else clauses.
Abstracted process and path handling for Windows. Renamed FLOAT to RREAL because of conflict on Windows. Added conditional compiles for some signal handlers.
Corrected format string for -pP option
Added -dW option for 16-bit byte-swapped words
Added -dw option for 16-bit i/o
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
added -n option for non-interleaved RGB input and output
took out file arguments from get and put value routines
added routines for reading and writing separate RGB files added -pP (where P is one of 'R', 'G' or 'B' upper or lower case) added -s option to skip specified number of bytes on header
made it so -e and +e work well together
added +/-e option to correct/adjust exposure
made pvalue accept upper case X and Y for resolution spec. also
Changes for PC port
added -R option for color order reversal
added +/-H option for no/yes to resolution string
added -g (gamma correction) option
added format info to header
added use of COLORCORR header i/o
changed EXPOSURE information interface
