--- ray/src/px/pvalue.c 1991/11/11 14:01:37 1.8 +++ ray/src/px/pvalue.c 1992/05/08 11:55:42 2.4 @@ -33,20 +33,23 @@ int reverse = 0; /* reverse conversion? */ int format = 'a'; /* input/output format */ char *fmtid = "ascii"; /* format identifier for header */ -int header = 1; /* do header */ +int header = 1; /* do header? */ +int resolution = 1; /* put/get resolution string? */ + int wrongformat = 0; /* wrong input format? */ double gamcor = 1.0; /* gamma correction */ +int ord[3] = {RED, GRN, BLU}; /* RGB ordering */ +int rord[4]; /* reverse ordering */ + COLOR exposure = WHTCOLOR; char *progname; FILE *fin; -extern double atof(), pow(); - int (*getval)(), (*putval)(); @@ -65,6 +68,9 @@ char **argv; case 'h': /* header */ header = argv[i][0] == '+'; break; + case 'H': /* resolution string */ + resolution = argv[i][0] == '+'; + break; case 'u': /* unique values */ uniq = argv[i][0] == '-'; break; @@ -76,6 +82,13 @@ char **argv; if (argv[i][0] == '+') gamcor = 1.0/gamcor; break; + case 'R': /* reverse byte sequence */ + if (argv[i][0] == '-') { + ord[0]=BLU; ord[1]=GRN; ord[2]=RED; + } else { + ord[0]=RED; ord[1]=GRN; ord[2]=BLU; + } + break; case 'r': /* reverse conversion */ reverse = argv[i][0] == '-'; break; @@ -114,11 +127,13 @@ char **argv; } break; case 'x': /* x resolution */ + resolution = 0; if (argv[i][0] == '-') picres.or |= XDECR; picres.xr = atoi(argv[++i]); break; case 'y': /* y resolution */ + resolution = 0; if (argv[i][0] == '-') picres.or |= YDECR; if (picres.xr == 0) @@ -140,7 +155,11 @@ unkopt: fmtid = "8-bit_grey"; else fmtid = "24-bit_rgb"; - + /* assign reverse ordering */ + rord[ord[0]] = 0; + rord[ord[1]] = 1; + rord[ord[2]] = 2; + /* get input */ if (i == argc) { fin = stdin; } else if (i == argc-1) { @@ -162,17 +181,17 @@ unkopt: fprintf(stderr, "%s: wrong input format\n", progname); quit(1); } - if (picres.xr <= 0 || picres.yr <= 0) /* get resolution */ - if (!fgetsresolu(&picres, fin)) { - fprintf(stderr, "%s: missing resolution\n", - progname); - quit(1); - } + /* get resolution */ + if ((resolution && !fgetsresolu(&picres, fin)) || + picres.xr <= 0 || picres.yr <= 0) { + fprintf(stderr, "%s: missing resolution\n", progname); + quit(1); + } /* add to header */ printargs(i, argv, stdout); fputformat(COLRFMT, stdout); putchar('\n'); - fputsresolu(&picres, stdout); + fputsresolu(&picres, stdout); /* always put resolution */ valtopix(); } else { /* get header */ @@ -182,18 +201,17 @@ unkopt: progname); quit(1); } - - if (picres.xr <= 0 || picres.yr <= 0) /* get picture size */ - if (!fgetsresolu(&picres, fin)) { - fprintf(stderr, "%s: missing resolution\n", - progname); - quit(1); - } + if (!fgetsresolu(&picres, fin)) { + fprintf(stderr, "%s: missing resolution\n", progname); + quit(1); + } if (header) { printargs(i, argv, stdout); fputformat(fmtid, stdout); putchar('\n'); } + if (resolution) /* put resolution */ + fputsresolu(&picres, stdout); pixtoval(); } @@ -329,7 +347,7 @@ FILE *fp; if (fscanf(fp, "%lf %lf %lf", &vd[0], &vd[1], &vd[2]) != 3) return(-1); - setcolor(col, vd[0], vd[1], vd[2]); + setcolor(col, vd[rord[RED]], vd[rord[GRN]], vd[rord[BLU]]); return(0); } @@ -342,7 +360,7 @@ FILE *fp; if (fread((char *)vd, sizeof(double), 3, fp) != 3) return(-1); - setcolor(col, vd[0], vd[1], vd[2]); + setcolor(col, vd[rord[RED]], vd[rord[GRN]], vd[rord[BLU]]); return(0); } @@ -355,7 +373,7 @@ FILE *fp; if (fread((char *)vf, sizeof(float), 3, fp) != 3) return(-1); - setcolor(col, vf[0], vf[1], vf[2]); + setcolor(col, vf[rord[RED]], vf[rord[GRN]], vf[rord[BLU]]); return(0); } @@ -368,7 +386,8 @@ FILE *fp; if (fscanf(fp, "%d %d %d", &vi[0], &vi[1], &vi[2]) != 3) return(-1); - setcolor(col,(vi[0]+.5)/256.,(vi[1]+.5)/256.,(vi[2]+.5)/256.); + setcolor(col, (vi[rord[RED]]+.5)/256., + (vi[rord[GRN]]+.5)/256., (vi[rord[BLU]]+.5)/256.); return(0); } @@ -381,7 +400,8 @@ FILE *fp; if (fread((char *)vb, sizeof(BYTE), 3, fp) != 3) return(-1); - setcolor(col,(vb[0]+.5)/256.,(vb[1]+.5)/256.,(vb[2]+.5)/256.); + setcolor(col, (vb[rord[RED]]+.5)/256., + (vb[rord[GRN]]+.5)/256., (vb[rord[BLU]]+.5)/256.); return(0); } @@ -460,9 +480,9 @@ COLOR col; FILE *fp; { fprintf(fp, "%15.3e %15.3e %15.3e\n", - colval(col,RED), - colval(col,GRN), - colval(col,BLU)); + colval(col,ord[0]), + colval(col,ord[1]), + colval(col,ord[2])); return(ferror(fp) ? -1 : 0); } @@ -474,9 +494,9 @@ FILE *fp; { float vf[3]; - vf[0] = colval(col,RED); - vf[1] = colval(col,GRN); - vf[2] = colval(col,BLU); + vf[0] = colval(col,ord[0]); + vf[1] = colval(col,ord[1]); + vf[2] = colval(col,ord[2]); fwrite((char *)vf, sizeof(float), 3, fp); return(ferror(fp) ? -1 : 0); @@ -489,9 +509,9 @@ FILE *fp; { double vd[3]; - vd[0] = colval(col,RED); - vd[1] = colval(col,GRN); - vd[2] = colval(col,BLU); + vd[0] = colval(col,ord[0]); + vd[1] = colval(col,ord[1]); + vd[2] = colval(col,ord[2]); fwrite((char *)vd, sizeof(double), 3, fp); return(ferror(fp) ? -1 : 0); @@ -503,9 +523,9 @@ COLOR col; FILE *fp; { fprintf(fp, "%d %d %d\n", - (int)(colval(col,RED)*256.), - (int)(colval(col,GRN)*256.), - (int)(colval(col,BLU)*256.)); + (int)(colval(col,ord[0])*256.), + (int)(colval(col,ord[1])*256.), + (int)(colval(col,ord[2])*256.)); return(ferror(fp) ? -1 : 0); } @@ -518,11 +538,11 @@ FILE *fp; register int i; BYTE vb[3]; - i = colval(col,RED)*256.; + i = colval(col,ord[0])*256.; vb[0] = min(i,255); - i = colval(col,GRN)*256.; + i = colval(col,ord[1])*256.; vb[1] = min(i,255); - i = colval(col,BLU)*256.; + i = colval(col,ord[2])*256.; vb[2] = min(i,255); fwrite((char *)vb, sizeof(BYTE), 3, fp);
