root/radiance/ray/src/px/pvalue.c
Revision: 2.16
Committed: Tue Feb 25 16:47:23 2003 UTC (22 years, 2 months ago) by greg
Changes since 2.15: +25 -1 lines
Added -dW option for 16-bit byte-swapped words
5 * pvalue.c - program to print pixel values.
6 *
7 * 4/23/86
8 */
9
10 #include "standard.h"
11
12 #include "color.h"
13
14 #include <time.h>
15
16 #include "resolu.h"
17
18 typedef unsigned short uint16; /* sizeof (uint16) must == 2 */
19
20 #define min(a,b) ((a)<(b)?(a):(b))
21
22 /* what to put out (also RED, GRN, BLU) */
23 #define ALL 3
24 #define BRIGHT 4
25
26 #define brightonly (putprim==BRIGHT)
27
28 RESOLU picres; /* resolution of picture */
29
30 int uniq = 0; /* print only unique values? */
31
32 int doexposure = 0; /* exposure change? (>100 to print) */
33
34 int dataonly = 0; /* data only format? */
35
36 int putprim = ALL; /* what to put out */
37
38 int reverse = 0; /* reverse conversion? */
39
40 int format = 'a'; /* input/output format */
41 char *fmtid = "ascii"; /* format identifier for header */
42
43 int header = 1; /* do header? */
44
45 long skipbytes = 0; /* skip bytes in input? */
46
47 int swapbytes = 0; /* swap bytes in 16-bit words? */
48
49 int interleave = 1; /* file is interleaved? */
50
51 int resolution = 1; /* put/get resolution string? */
52
53 int original = 0; /* convert to original values? */
54
55 int wrongformat = 0; /* wrong input format? */
56
57 double gamcor = 1.0; /* gamma correction */
58
59 int ord[3] = {RED, GRN, BLU}; /* RGB ordering */
60 int rord[4]; /* reverse ordering */
61
62 COLOR exposure = WHTCOLOR;
63
64 char *progname;
65
66 FILE *fin;
67 FILE *fin2 = NULL, *fin3 = NULL; /* for other color channels */
68
69 int (*getval)(), (*putval)();
70
71 double
72 rgb_bright(clr)
73 COLOR clr;
74 {
75 return(bright(clr));
76 }
77
78 double
79 xyz_bright(clr)
80 COLOR clr;
81 {
82 return(clr[CIEY]);
83 }
84
85 double (*mybright)() = &rgb_bright;
86
87
88 main(argc, argv)
89 int argc;
90 char **argv;
91 {
92 extern int checkhead();
93 extern long atol();
94 double d, expval = 1.0;
95 int i;
96
97 progname = argv[0];
98
99 for (i = 1; i < argc; i++)
100 if (argv[i][0] == '-' || argv[i][0] == '+')
101 switch (argv[i][1]) {
102 case 'h': /* header */
103 header = argv[i][0] == '+';
104 break;
105 case 'H': /* resolution string */
106 resolution = argv[i][0] == '+';
107 break;
108 case 's': /* skip bytes in header */
109 skipbytes = atol(argv[++i]);
110 break;
111 case 'u': /* unique values */
112 uniq = argv[i][0] == '-';
113 break;
114 case 'o': /* original values */
115 original = argv[i][0] == '-';
116 break;
117 case 'g': /* gamma correction */
118 gamcor = atof(argv[i+1]);
119 if (argv[i][0] == '+')
120 gamcor = 1.0/gamcor;
121 i++;
122 break;
123 case 'e': /* exposure correction */
124 d = atof(argv[i+1]);
125 if (argv[i+1][0] == '-' || argv[i+1][0] == '+')
126 d = pow(2.0, d);
127 if (argv[i][0] == '-')
128 expval *= d;
129 scalecolor(exposure, d);
130 doexposure++;
131 i++;
132 break;
133 case 'R': /* reverse byte sequence */
134 if (argv[i][0] == '-') {
135 ord[0]=BLU; ord[1]=GRN; ord[2]=RED;
136 } else {
137 ord[0]=RED; ord[1]=GRN; ord[2]=BLU;
138 }
139 break;
140 case 'r': /* reverse conversion */
141 reverse = argv[i][0] == '-';
142 break;
143 case 'n': /* non-interleaved RGB */
144 interleave = argv[i][0] == '+';
145 break;
146 case 'b': /* brightness values */
147 putprim = argv[i][0] == '-' ? BRIGHT : ALL;
148 break;
149 case 'p': /* put primary */
150 switch (argv[i][2]) {
151 case 'r': case 'R': putprim = RED; break;
152 case 'g': case 'G': putprim = GRN; break;
153 case 'b': case 'B': putprim = BLU; break;
154 default: goto unkopt;
155 }
156 break;
157 case 'd': /* data only (no indices) */
158 dataonly = argv[i][0] == '-';
159 switch (argv[i][2]) {
160 case '\0':
161 case 'a': /* ascii */
162 format = 'a';
163 fmtid = "ascii";
164 break;
165 case 'i': /* integer */
166 format = 'i';
167 fmtid = "ascii";
168 break;
169 case 'b': /* byte */
170 dataonly = 1;
171 format = 'b';
172 fmtid = "byte";
173 break;
174 case 'W': /* 16-bit swapped */
175 swapbytes = 1;
176 case 'w': /* 16-bit */
177 dataonly = 1;
178 format = 'w';
179 fmtid = "16-bit";
180 break;
181 case 'f': /* float */
182 dataonly = 1;
183 format = 'f';
184 fmtid = "float";
185 break;
186 case 'd': /* double */
187 dataonly = 1;
188 format = 'd';
189 fmtid = "double";
190 break;
191 default:
192 goto unkopt;
193 }
194 break;
195 case 'x': /* x resolution */
196 case 'X': /* x resolution */
197 resolution = 0;
198 if (argv[i][0] == '-')
199 picres.rt |= XDECR;
200 picres.xr = atoi(argv[++i]);
201 break;
202 case 'y': /* y resolution */
203 case 'Y': /* y resolution */
204 resolution = 0;
205 if (argv[i][0] == '-')
206 picres.rt |= YDECR;
207 if (picres.xr == 0)
208 picres.rt |= YMAJOR;
209 picres.yr = atoi(argv[++i]);
210 break;
211 default:
212 unkopt:
213 fprintf(stderr, "%s: unknown option: %s\n",
214 progname, argv[i]);
215 quit(1);
216 break;
217 }
218 else
219 break;
220 /* recognize special formats */
221 if (dataonly && format == 'b')
222 if (brightonly)
223 fmtid = "8-bit_grey";
224 else
225 fmtid = "24-bit_rgb";
226 if (dataonly && format == 'w')
227 if (brightonly)
228 fmtid = "16-bit_grey";
229 else
230 fmtid = "48-bit_rgb";
231 /* assign reverse ordering */
232 rord[ord[0]] = 0;
233 rord[ord[1]] = 1;
234 rord[ord[2]] = 2;
235 /* get input */
236 if (i == argc) {
237 fin = stdin;
238 } else if (i < argc) {
239 if ((fin = fopen(argv[i], "r")) == NULL) {
240 fprintf(stderr, "%s: can't open file \"%s\"\n",
241 progname, argv[i]);
242 quit(1);
243 }
244 if (reverse && !brightonly && i == argc-3) {
245 if ((fin2 = fopen(argv[i+1], "r")) == NULL) {
246 fprintf(stderr, "%s: can't open file \"%s\"\n",
247 progname, argv[i+1]);
248 quit(1);
249 }
250 if ((fin3 = fopen(argv[i+2], "r")) == NULL) {
251 fprintf(stderr, "%s: can't open file \"%s\"\n",
252 progname, argv[i+2]);
253 quit(1);
254 }
255 interleave = -1;
256 } else if (i != argc-1)
257 fin = NULL;
258 if (reverse && !brightonly && !interleave) {
259 fin2 = fopen(argv[i], "r");
260 fin3 = fopen(argv[i], "r");
261 }
262 if (skipbytes && (fseek(fin, skipbytes, 0) || (fin2 != NULL &&
263 (fseek(fin2, skipbytes, 0) ||
264 fseek(fin3, skipbytes, 0))))) {
265 fprintf(stderr, "%s: cannot skip %ld bytes on input\n",
266 progname, skipbytes);
267 quit(1);
268 }
269 }
270 if (fin == NULL) {
271 fprintf(stderr, "%s: bad # file arguments\n", progname);
272 quit(1);
273 }
274
275 if (reverse) {
276 #ifdef MSDOS
277 setmode(fileno(stdout), O_BINARY);
278 if (format != 'a' && format != 'i')
279 setmode(fileno(fin), O_BINARY);
280 #endif
281 /* get header */
282 if (header) {
283 if (checkheader(fin, fmtid, stdout) < 0) {
284 fprintf(stderr, "%s: wrong input format\n",
285 progname);
286 quit(1);
287 }
288 if (fin2 != NULL) {
289 getheader(fin2, NULL, NULL);
290 getheader(fin3, NULL, NULL);
291 }
292 } else
293 newheader("RADIANCE", stdout);
294 /* get resolution */
295 if ((resolution && !fgetsresolu(&picres, fin)) ||
296 picres.xr <= 0 || picres.yr <= 0) {
297 fprintf(stderr, "%s: missing resolution\n", progname);
298 quit(1);
299 }
300 if (resolution && fin2 != NULL) {
301 RESOLU pres2;
302 if (!fgetsresolu(&pres2, fin2) ||
303 pres2.rt != picres.rt ||
304 pres2.xr != picres.xr ||
305 pres2.yr != picres.yr ||
306 !fgetsresolu(&pres2, fin3) ||
307 pres2.rt != picres.rt ||
308 pres2.xr != picres.xr ||
309 pres2.yr != picres.yr) {
310 fprintf(stderr, "%s: resolution mismatch\n",
311 progname);
312 quit(1);
313 }
314 }
315 /* add to header */
316 printargs(i, argv, stdout);
317 if (expval < .99 || expval > 1.01)
318 fputexpos(expval, stdout);
319 fputformat(COLRFMT, stdout);
320 putchar('\n');
321 fputsresolu(&picres, stdout); /* always put resolution */
322 valtopix();
323 } else {
324 #ifdef MSDOS
325 setmode(fileno(fin), O_BINARY);
326 if (format != 'a' && format != 'i')
327 setmode(fileno(stdout), O_BINARY);
328 #endif
329 /* get header */
330 getheader(fin, checkhead, NULL);
331 if (wrongformat) {
332 fprintf(stderr,
333 "%s: input not a Radiance RGBE picture\n",
334 progname);
335 quit(1);
336 }
337 if (!fgetsresolu(&picres, fin)) {
338 fprintf(stderr, "%s: missing resolution\n", progname);
339 quit(1);
340 }
341 if (header) {
342 printargs(i, argv, stdout);
343 if (expval < .99 || expval > 1.01)
344 fputexpos(expval, stdout);
345 fputformat(fmtid, stdout);
346 putchar('\n');
347 }
348 if (resolution) /* put resolution */
349 fputsresolu(&picres, stdout);
350 pixtoval();
351 }
352
353 quit(0);
354 }
355
356
357 int
358 checkhead(line) /* deal with line from header */
359 char *line;
360 {
361 char fmt[32];
362 double d;
363 COLOR ctmp;
364
365 if (formatval(fmt, line)) {
366 if (!strcmp(fmt, CIEFMT)) {
367 mybright = &xyz_bright;
368 if (original) {
369 scalecolor(exposure, 1./WHTEFFICACY);
370 doexposure++;
371 }
372 } else if (!strcmp(fmt, COLRFMT))
373 mybright = &rgb_bright;
374 else
375 wrongformat++;
376 } else if (original && isexpos(line)) {
377 d = 1.0/exposval(line);
378 scalecolor(exposure, d);
379 doexposure++;
380 } else if (original && iscolcor(line)) {
381 colcorval(ctmp, line);
382 setcolor(exposure, colval(exposure,RED)/colval(ctmp,RED),
383 colval(exposure,GRN)/colval(ctmp,GRN),
384 colval(exposure,BLU)/colval(ctmp,BLU));
385 doexposure++;
386 } else if (header)
387 fputs(line, stdout);
388 return(0);
389 }
390
391
392 pixtoval() /* convert picture to values */
393 {
394 register COLOR *scanln;
395 int dogamma;
396 COLOR lastc;
397 FLOAT hv[2];
398 int startprim, endprim;
399 long startpos;
400 int y;
401 register int x;
402
403 scanln = (COLOR *)malloc(scanlen(&picres)*sizeof(COLOR));
404 if (scanln == NULL) {
405 fprintf(stderr, "%s: out of memory\n", progname);
406 quit(1);
407 }
408 dogamma = gamcor < .95 || gamcor > 1.05;
409 if (putprim == ALL && !interleave) {
410 startprim = RED; endprim = BLU;
411 startpos = ftell(fin);
412 } else {
413 startprim = putprim; endprim = putprim;
414 }
415 for (putprim = startprim; putprim <= endprim; putprim++) {
416 if (putprim != startprim && fseek(fin, startpos, 0)) {
417 fprintf(stderr, "%s: seek error on input file\n",
418 progname);
419 quit(1);
420 }
421 set_io();
422 setcolor(lastc, 0.0, 0.0, 0.0);
423 for (y = 0; y < numscans(&picres); y++) {
424 if (freadscan(scanln, scanlen(&picres), fin) < 0) {
425 fprintf(stderr, "%s: read error\n", progname);
426 quit(1);
427 }
428 for (x = 0; x < scanlen(&picres); x++) {
429 if (uniq)
430 if ( colval(scanln[x],RED) ==
431 colval(lastc,RED) &&
432 colval(scanln[x],GRN) ==
433 colval(lastc,GRN) &&
434 colval(scanln[x],BLU) ==
435 colval(lastc,BLU) )
436 continue;
437 else
438 copycolor(lastc, scanln[x]);
439 if (doexposure)
440 multcolor(scanln[x], exposure);
441 if (dogamma)
442 setcolor(scanln[x],
443 pow(colval(scanln[x],RED), 1.0/gamcor),
444 pow(colval(scanln[x],GRN), 1.0/gamcor),
445 pow(colval(scanln[x],BLU), 1.0/gamcor));
446 if (!dataonly) {
447 pix2loc(hv, &picres, x, y);
448 printf("%7d %7d ",
449 (int)(hv[0]*picres.xr),
450 (int)(hv[1]*picres.yr));
451 }
452 if ((*putval)(scanln[x]) < 0) {
453 fprintf(stderr, "%s: write error\n",
454 progname);
455 quit(1);
456 }
457 }
458 }
459 }
460 free((void *)scanln);
461 }
462
463
464 valtopix() /* convert values to a pixel file */
465 {
466 int dogamma;
467 register COLOR *scanln;
468 int y;
469 register int x;
470
471 scanln = (COLOR *)malloc(scanlen(&picres)*sizeof(COLOR));
472 if (scanln == NULL) {
473 fprintf(stderr, "%s: out of memory\n", progname);
474 quit(1);
475 }
476 dogamma = gamcor < .95 || gamcor > 1.05;
477 set_io();
478 for (y = 0; y < numscans(&picres); y++) {
479 for (x = 0; x < scanlen(&picres); x++) {
480 if (!dataonly) {
481 fscanf(fin, "%*d %*d");
482 if (fin2 != NULL) {
483 fscanf(fin2, "%*d %*d");
484 fscanf(fin3, "%*d %*d");
485 }
486 }
487 if ((*getval)(scanln[x]) < 0) {
488 fprintf(stderr, "%s: read error\n", progname);
489 quit(1);
490 }
491 if (dogamma)
492 setcolor(scanln[x],
493 pow(colval(scanln[x],RED), gamcor),
494 pow(colval(scanln[x],GRN), gamcor),
495 pow(colval(scanln[x],BLU), gamcor));
496 if (doexposure)
497 multcolor(scanln[x], exposure);
498 }
499 if (fwritescan(scanln, scanlen(&picres), stdout) < 0) {
500 fprintf(stderr, "%s: write error\n", progname);
501 quit(1);
502 }
503 }
504 free((void *)scanln);
505 }
506
507
508 void
509 quit(code)
510 int code;
511 {
512 exit(code);
513 }
514
515
516 swap16(wp, n) /* swap n 16-bit words */
517 register uint16 *wp;
518 int n;
519 {
520 while (n-- > 0) {
521 *wp = *wp << 8 | ((*wp >> 8) & 0xff);
522 wp++;
523 }
524 }
525
526 getcascii(col) /* get an ascii color value from stream(s) */
527 COLOR col;
528 {
529 double vd[3];
530
531 if (fin2 == NULL) {
532 if (fscanf(fin, "%lf %lf %lf", &vd[0], &vd[1], &vd[2]) != 3)
533 return(-1);
534 } else {
535 if (fscanf(fin, "%lf", &vd[0]) != 1 ||
536 fscanf(fin2, "%lf", &vd[1]) != 1 ||
537 fscanf(fin3, "%lf", &vd[2]) != 1)
538 return(-1);
539 }
540 setcolor(col, vd[rord[RED]], vd[rord[GRN]], vd[rord[BLU]]);
541 return(0);
542 }
543
544
545 getcdouble(col) /* get a double color value from stream(s) */
546 COLOR col;
547 {
548 double vd[3];
549
550 if (fin2 == NULL) {
551 if (fread((char *)vd, sizeof(double), 3, fin) != 3)
552 return(-1);
553 } else {
554 if (fread((char *)vd, sizeof(double), 1, fin) != 1 ||
555 fread((char *)(vd+1), sizeof(double), 1, fin2) != 1 ||
556 fread((char *)(vd+2), sizeof(double), 1, fin3) != 1)
557 return(-1);
558 }
559 setcolor(col, vd[rord[RED]], vd[rord[GRN]], vd[rord[BLU]]);
560 return(0);
561 }
562
563
564 getcfloat(col) /* get a float color value from stream(s) */
565 COLOR col;
566 {
567 float vf[3];
568
569 if (fin2 == NULL) {
570 if (fread((char *)vf, sizeof(float), 3, fin) != 3)
571 return(-1);
572 } else {
573 if (fread((char *)vf, sizeof(float), 1, fin) != 1 ||
574 fread((char *)(vf+1), sizeof(float), 1, fin2) != 1 ||
575 fread((char *)(vf+2), sizeof(float), 1, fin3) != 1)
576 return(-1);
577 }
578 setcolor(col, vf[rord[RED]], vf[rord[GRN]], vf[rord[BLU]]);
579 return(0);
580 }
581
582
583 getcint(col) /* get an int color value from stream(s) */
584 COLOR col;
585 {
586 int vi[3];
587
588 if (fin2 == NULL) {
589 if (fscanf(fin, "%d %d %d", &vi[0], &vi[1], &vi[2]) != 3)
590 return(-1);
591 } else {
592 if (fscanf(fin, "%d", &vi[0]) != 1 ||
593 fscanf(fin2, "%d", &vi[1]) != 1 ||
594 fscanf(fin3, "%d", &vi[2]) != 1)
595 return(-1);
596 }
597 setcolor(col, (vi[rord[RED]]+.5)/256.,
598 (vi[rord[GRN]]+.5)/256., (vi[rord[BLU]]+.5)/256.);
599 return(0);
600 }
601
602
603 getcbyte(col) /* get a byte color value from stream(s) */
604 COLOR col;
605 {
606 BYTE vb[3];
607
608 if (fin2 == NULL) {
609 if (fread((char *)vb, sizeof(BYTE), 3, fin) != 3)
610 return(-1);
611 } else {
612 if (fread((char *)vb, sizeof(BYTE), 1, fin) != 1 ||
613 fread((char *)(vb+1), sizeof(BYTE), 1, fin2) != 1 ||
614 fread((char *)(vb+2), sizeof(BYTE), 1, fin3) != 1)
615 return(-1);
616 }
617 setcolor(col, (vb[rord[RED]]+.5)/256.,
618 (vb[rord[GRN]]+.5)/256., (vb[rord[BLU]]+.5)/256.);
619 return(0);
620 }
621
622
623 getcword(col) /* get a 16-bit color value from stream(s) */
624 COLOR col;
625 {
626 uint16 vw[3];
627
628 if (fin2 == NULL) {
629 if (fread((char *)vw, sizeof(uint16), 3, fin) != 3)
630 return(-1);
631 } else {
632 if (fread((char *)vw, sizeof(uint16), 1, fin) != 1 ||
633 fread((char *)(vw+1), sizeof(uint16), 1, fin2) != 1 ||
634 fread((char *)(vw+2), sizeof(uint16), 1, fin3) != 1)
635 return(-1);
636 }
637 if (swapbytes)
638 swap16(vw, 3);
639 setcolor(col, (vw[rord[RED]]+.5)/65536.,
640 (vw[rord[GRN]]+.5)/65536., (vw[rord[BLU]]+.5)/65536.);
641 return(0);
642 }
643
644
645 getbascii(col) /* get an ascii brightness value from fin */
646 COLOR col;
647 {
648 double vd;
649
650 if (fscanf(fin, "%lf", &vd) != 1)
651 return(-1);
652 setcolor(col, vd, vd, vd);
653 return(0);
654 }
655
656
657 getbdouble(col) /* get a double brightness value from fin */
658 COLOR col;
659 {
660 double vd;
661
662 if (fread((char *)&vd, sizeof(double), 1, fin) != 1)
663 return(-1);
664 setcolor(col, vd, vd, vd);
665 return(0);
666 }
667
668
669 getbfloat(col) /* get a float brightness value from fin */
670 COLOR col;
671 {
672 float vf;
673
674 if (fread((char *)&vf, sizeof(float), 1, fin) != 1)
675 return(-1);
676 setcolor(col, vf, vf, vf);
677 return(0);
678 }
679
680
681 getbint(col) /* get an int brightness value from fin */
682 COLOR col;
683 {
684 int vi;
685 double d;
686
687 if (fscanf(fin, "%d", &vi) != 1)
688 return(-1);
689 d = (vi+.5)/256.;
690 setcolor(col, d, d, d);
691 return(0);
692 }
693
694
695 getbbyte(col) /* get a byte brightness value from fin */
696 COLOR col;
697 {
698 BYTE vb;
699 double d;
700
701 if (fread((char *)&vb, sizeof(BYTE), 1, fin) != 1)
702 return(-1);
703 d = (vb+.5)/256.;
704 setcolor(col, d, d, d);
705 return(0);
706 }
707
708
709 getbword(col) /* get a 16-bit brightness value from fin */
710 COLOR col;
711 {
712 uint16 vw;
713 double d;
714
715 if (fread((char *)&vw, sizeof(uint16), 1, fin) != 1)
716 return(-1);
717 if (swapbytes)
718 swap16(&vw, 1);
719 d = (vw+.5)/65536.;
720 setcolor(col, d, d, d);
721 return(0);
722 }
723
724
725 putcascii(col) /* put an ascii color to stdout */
726 COLOR col;
727 {
728 fprintf(stdout, "%15.3e %15.3e %15.3e\n",
729 colval(col,ord[0]),
730 colval(col,ord[1]),
731 colval(col,ord[2]));
732
733 return(ferror(stdout) ? -1 : 0);
734 }
735
736
737 putcfloat(col) /* put a float color to stdout */
738 COLOR col;
739 {
740 float vf[3];
741
742 vf[0] = colval(col,ord[0]);
743 vf[1] = colval(col,ord[1]);
744 vf[2] = colval(col,ord[2]);
745 fwrite((char *)vf, sizeof(float), 3, stdout);
746
747 return(ferror(stdout) ? -1 : 0);
748 }
749
750
751 putcdouble(col) /* put a double color to stdout */
752 COLOR col;
753 {
754 double vd[3];
755
756 vd[0] = colval(col,ord[0]);
757 vd[1] = colval(col,ord[1]);
758 vd[2] = colval(col,ord[2]);
759 fwrite((char *)vd, sizeof(double), 3, stdout);
760
761 return(ferror(stdout) ? -1 : 0);
762 }
763
764
765 putcint(col) /* put an int color to stdout */
766 COLOR col;
767 {
768 fprintf(stdout, "%d %d %d\n",
769 (int)(colval(col,ord[0])*256.),
770 (int)(colval(col,ord[1])*256.),
771 (int)(colval(col,ord[2])*256.));
772
773 return(ferror(stdout) ? -1 : 0);
774 }
775
776
777 putcbyte(col) /* put a byte color to stdout */
778 COLOR col;
779 {
780 long i;
781 BYTE vb[3];
782
783 i = colval(col,ord[0])*256.;
784 vb[0] = min(i,255);
785 i = colval(col,ord[1])*256.;
786 vb[1] = min(i,255);
787 i = colval(col,ord[2])*256.;
788 vb[2] = min(i,255);
789 fwrite((char *)vb, sizeof(BYTE), 3, stdout);
790
791 return(ferror(stdout) ? -1 : 0);
792 }
793
794
795 putcword(col) /* put a 16-bit color to stdout */
796 COLOR col;
797 {
798 long i;
799 uint16 vw[3];
800
801 i = colval(col,ord[0])*65536.;
802 vw[0] = min(i,65535);
803 i = colval(col,ord[1])*65536.;
804 vw[1] = min(i,65535);
805 i = colval(col,ord[2])*65536.;
806 vw[2] = min(i,65535);
807 if (swapbytes)
808 swap16(vw, 3);
809 fwrite((char *)vw, sizeof(uint16), 3, stdout);
810
811 return(ferror(stdout) ? -1 : 0);
812 }
813
814
815 putbascii(col) /* put an ascii brightness to stdout */
816 COLOR col;
817 {
818 fprintf(stdout, "%15.3e\n", (*mybright)(col));
819
820 return(ferror(stdout) ? -1 : 0);
821 }
822
823
824 putbfloat(col) /* put a float brightness to stdout */
825 COLOR col;
826 {
827 float vf;
828
829 vf = (*mybright)(col);
830 fwrite((char *)&vf, sizeof(float), 1, stdout);
831
832 return(ferror(stdout) ? -1 : 0);
833 }
834
835
836 putbdouble(col) /* put a double brightness to stdout */
837 COLOR col;
838 {
839 double vd;
840
841 vd = (*mybright)(col);
842 fwrite((char *)&vd, sizeof(double), 1, stdout);
843
844 return(ferror(stdout) ? -1 : 0);
845 }
846
847
848 putbint(col) /* put an int brightness to stdout */
849 COLOR col;
850 {
851 fprintf(stdout, "%d\n", (int)((*mybright)(col)*256.));
852
853 return(ferror(stdout) ? -1 : 0);
854 }
855
856
857 putbbyte(col) /* put a byte brightness to stdout */
858 COLOR col;
859 {
860 register int i;
861 BYTE vb;
862
863 i = (*mybright)(col)*256.;
864 vb = min(i,255);
865 fwrite((char *)&vb, sizeof(BYTE), 1, stdout);
866
867 return(ferror(stdout) ? -1 : 0);
868 }
869
870
871 putbword(col) /* put a 16-bit brightness to stdout */
872 COLOR col;
873 {
874 long i;
875 uint16 vw;
876
877 i = (*mybright)(col)*65536.;
878 vw = min(i,65535);
879 if (swapbytes)
880 swap16(&vw, 1);
881 fwrite((char *)&vw, sizeof(uint16), 1, stdout);
882
883 return(ferror(stdout) ? -1 : 0);
884 }
885
886
887 putpascii(col) /* put an ascii primary to stdout */
888 COLOR col;
889 {
890 fprintf(stdout, "%15.3e\n", colval(col,putprim));
891
892 return(ferror(stdout) ? -1 : 0);
893 }
894
895
896 putpfloat(col) /* put a float primary to stdout */
897 COLOR col;
898 {
899 float vf;
900
901 vf = colval(col,putprim);
902 fwrite((char *)&vf, sizeof(float), 1, stdout);
903
904 return(ferror(stdout) ? -1 : 0);
905 }
906
907
908 putpdouble(col) /* put a double primary to stdout */
909 COLOR col;
910 {
911 double vd;
912
913 vd = colval(col,putprim);
914 fwrite((char *)&vd, sizeof(double), 1, stdout);
915
916 return(ferror(stdout) ? -1 : 0);
917 }
918
919
920 putpint(col) /* put an int primary to stdout */
921 COLOR col;
922 {
923 fprintf(stdout, "%d\n", (int)(colval(col,putprim)*256.));
924
925 return(ferror(stdout) ? -1 : 0);
926 }
927
928
929 putpbyte(col) /* put a byte primary to stdout */
930 COLOR col;
931 {
932 long i;
933 BYTE vb;
934
935 i = colval(col,putprim)*256.;
936 vb = min(i,255);
937 fwrite((char *)&vb, sizeof(BYTE), 1, stdout);
938
939 return(ferror(stdout) ? -1 : 0);
940 }
941
942
943 putpword(col) /* put a 16-bit primary to stdout */
944 COLOR col;
945 {
946 long i;
947 uint16 vw;
948
949 i = colval(col,putprim)*65536.;
950 vw = min(i,65535);
951 if (swapbytes)
952 swap16(&vw, 1);
953 fwrite((char *)&vw, sizeof(uint16), 1, stdout);
954
955 return(ferror(stdout) ? -1 : 0);
956 }
957
958
959 set_io() /* set put and get functions */
960 {
961 switch (format) {
962 case 'a': /* ascii */
963 if (putprim == BRIGHT) {
964 getval = getbascii;
965 putval = putbascii;
966 } else if (putprim != ALL) {
967 getval = getbascii;
968 putval = putpascii;
969 } else {
970 getval = getcascii;
971 putval = putcascii;
972 if (reverse && !interleave) {
973 fprintf(stderr,
974 "%s: ASCII input files must be interleaved\n",
975 progname);
976 quit(1);
977 }
978 }
979 return;
980 case 'f': /* binary float */
981 if (putprim == BRIGHT) {
982 getval = getbfloat;
983 putval = putbfloat;
984 } else if (putprim != ALL) {
985 getval = getbfloat;
986 putval = putpfloat;
987 } else {
988 getval = getcfloat;
989 putval = putcfloat;
990 if (reverse && !interleave) {
991 if (fin2 == NULL)
992 goto namerr;
993 if (fseek(fin2,
994 (long)sizeof(float)*picres.xr*picres.yr, 1))
995 goto seekerr;
996 if (fseek(fin3,
997 (long)sizeof(float)*2*picres.xr*picres.yr, 1))
998 goto seekerr;
999 }
1000 }
1001 return;
1002 case 'd': /* binary double */
1003 if (putprim == BRIGHT) {
1004 getval = getbdouble;
1005 putval = putbdouble;
1006 } else if (putprim != ALL) {
1007 getval = getbdouble;
1008 putval = putpdouble;
1009 } else {
1010 getval = getcdouble;
1011 putval = putcdouble;
1012 if (reverse && !interleave) {
1013 if (fin2 == NULL)
1014 goto namerr;
1015 if (fseek(fin2,
1016 (long)sizeof(double)*picres.xr*picres.yr, 1))
1017 goto seekerr;
1018 if (fseek(fin3,
1019 (long)sizeof(double)*2*picres.xr*picres.yr, 1))
1020 goto seekerr;
1021 }
1022 }
1023 return;
1024 case 'i': /* integer */
1025 if (putprim == BRIGHT) {
1026 getval = getbint;
1027 putval = putbint;
1028 } else if (putprim != ALL) {
1029 getval = getbint;
1030 putval = putpint;
1031 } else {
1032 getval = getcint;
1033 putval = putcint;
1034 if (reverse && !interleave) {
1035 fprintf(stderr,
1036 "%s: integer input files must be interleaved\n",
1037 progname);
1038 quit(1);
1039 }
1040 }
1041 return;
1042 case 'b': /* byte */
1043 if (putprim == BRIGHT) {
1044 getval = getbbyte;
1045 putval = putbbyte;
1046 } else if (putprim != ALL) {
1047 getval = getbbyte;
1048 putval = putpbyte;
1049 } else {
1050 getval = getcbyte;
1051 putval = putcbyte;
1052 if (reverse && !interleave) {
1053 if (fin2 == NULL)
1054 goto namerr;
1055 if (fseek(fin2,
1056 (long)sizeof(BYTE)*picres.xr*picres.yr, 1))
1057 goto seekerr;
1058 if (fseek(fin3,
1059 (long)sizeof(BYTE)*2*picres.xr*picres.yr, 1))
1060 goto seekerr;
1061 }
1062 }
1063 return;
1064 case 'w': /* 16-bit */
1065 if (putprim == BRIGHT) {
1066 getval = getbword;
1067 putval = putbword;
1068 } else if (putprim != ALL) {
1069 getval = getbword;
1070 putval = putpword;
1071 } else {
1072 getval = getcword;
1073 putval = putcword;
1074 if (reverse && !interleave) {
1075 if (fin2 == NULL)
1076 goto namerr;
1077 if (fseek(fin2,
1078 (long)sizeof(uint16)*picres.xr*picres.yr, 1))
1079 goto seekerr;
1080 if (fseek(fin3,
1081 (long)sizeof(uint16)*2*picres.xr*picres.yr, 1))
1082 goto seekerr;
1083 }
1084 }
1085 return;
1086 }
1087 badopt:
1088 fprintf(stderr, "%s: botched file type\n", progname);
1089 quit(1);
1090 namerr:
1091 fprintf(stderr, "%s: non-interleaved file(s) must be named\n",
1092 progname);
1093 quit(1);
1094 seekerr:
1095 fprintf(stderr, "%s: cannot seek on interleaved input file\n",
1096 progname);
1097 quit(1);
1098 }
