root/radiance/ray/src/px/pvalue.c
Revision: 2.24
Committed: Wed Oct 22 02:06:35 2003 UTC (21 years, 6 months ago) by greg
2 static const char RCSid[] = "$Id: pvalue.c,v 2.23 2003/09/13 15:24:13 greg Exp $";
5 * pvalue.c - program to print pixel values.
6 *
7 * 4/23/86
8 */
9
10 #include "platform.h"
11 #include "standard.h"
12 #include "color.h"
13 #include "resolu.h"
14
15 #define min(a,b) ((a)<(b)?(a):(b))
16
17 /* what to put out (also RED, GRN, BLU) */
18 #define ALL 3
19 #define BRIGHT 4
20
21 RESOLU picres; /* resolution of picture */
22
23 int uniq = 0; /* print only unique values? */
24
25 int doexposure = 0; /* exposure change? (>100 to print) */
26
27 int dataonly = 0; /* data only format? */
28
29 int putprim = ALL; /* what to put out */
30
31 int reverse = 0; /* reverse conversion? */
32
33 int format = 'a'; /* input/output format */
34 char *fmtid = "ascii"; /* format identifier for header */
35
36 int header = 1; /* do header? */
37
38 long skipbytes = 0; /* skip bytes in input? */
39
40 int swapbytes = 0; /* swap bytes? */
41
42 int interleave = 1; /* file is interleaved? */
43
44 int resolution = 1; /* put/get resolution string? */
45
46 int original = 0; /* convert to original values? */
47
48 int wrongformat = 0; /* wrong input format? */
49
50 double gamcor = 1.0; /* gamma correction */
51
52 int ord[3] = {RED, GRN, BLU}; /* RGB ordering */
53 int rord[4]; /* reverse ordering */
54
55 COLOR exposure = WHTCOLOR;
56
57 char *progname;
58
59 FILE *fin;
60 FILE *fin2 = NULL, *fin3 = NULL; /* for other color channels */
61
62 int (*getval)(), (*putval)();
63
64 double
65 rgb_bright(clr)
66 COLOR clr;
67 {
68 return(bright(clr));
69 }
70
71 double
72 xyz_bright(clr)
73 COLOR clr;
74 {
75 return(clr[CIEY]);
76 }
77
78 double (*mybright)() = &rgb_bright;
79
80
81 main(argc, argv)
82 int argc;
83 char **argv;
84 {
85 extern int checkhead();
86 extern long atol();
87 double d, expval = 1.0;
88 int i;
89
90 progname = argv[0];
91
92 for (i = 1; i < argc; i++)
93 if (argv[i][0] == '-' || argv[i][0] == '+')
94 switch (argv[i][1]) {
95 case 'h': /* header */
96 header = argv[i][0] == '+';
97 break;
98 case 'H': /* resolution string */
99 resolution = argv[i][0] == '+';
100 break;
101 case 's': /* skip bytes in header */
102 skipbytes = atol(argv[++i]);
103 break;
104 case 'u': /* unique values */
105 uniq = argv[i][0] == '-';
106 break;
107 case 'o': /* original values */
108 original = argv[i][0] == '-';
109 break;
110 case 'g': /* gamma correction */
111 gamcor = atof(argv[i+1]);
112 if (argv[i][0] == '+')
113 gamcor = 1.0/gamcor;
114 i++;
115 break;
116 case 'e': /* exposure correction */
117 d = atof(argv[i+1]);
118 if (argv[i+1][0] == '-' || argv[i+1][0] == '+')
119 d = pow(2.0, d);
120 if (argv[i][0] == '-')
121 expval *= d;
122 scalecolor(exposure, d);
123 doexposure++;
124 i++;
125 break;
126 case 'R': /* reverse byte sequence */
127 if (argv[i][0] == '-') {
128 ord[0]=BLU; ord[1]=GRN; ord[2]=RED;
129 } else {
130 ord[0]=RED; ord[1]=GRN; ord[2]=BLU;
131 }
132 break;
133 case 'r': /* reverse conversion */
134 reverse = argv[i][0] == '-';
135 break;
136 case 'n': /* non-interleaved RGB */
137 interleave = argv[i][0] == '+';
138 break;
139 case 'b': /* brightness values */
140 putprim = argv[i][0] == '-' ? BRIGHT : ALL;
141 break;
142 case 'p': /* put primary */
143 switch (argv[i][2]) {
144 case 'r': case 'R': putprim = RED; break;
145 case 'g': case 'G': putprim = GRN; break;
146 case 'b': case 'B': putprim = BLU; break;
147 default: goto unkopt;
148 }
149 break;
150 case 'd': /* data only (no indices) */
151 dataonly = argv[i][0] == '-';
152 switch (argv[i][2]) {
153 case '\0':
154 case 'a': /* ascii */
155 format = 'a';
156 fmtid = "ascii";
157 break;
158 case 'i': /* integer */
159 format = 'i';
160 fmtid = "ascii";
161 break;
162 case 'b': /* byte */
163 dataonly = 1;
164 format = 'b';
165 fmtid = "byte";
166 break;
167 case 'W': /* 16-bit swapped */
168 swapbytes = 1;
169 case 'w': /* 16-bit */
170 dataonly = 1;
171 format = 'w';
172 fmtid = "16-bit";
173 break;
174 case 'F': /* swapped floats */
175 swapbytes = 1;
176 case 'f': /* float */
177 dataonly = 1;
178 format = 'f';
179 fmtid = "float";
180 break;
181 case 'D': /* swapped doubles */
182 swapbytes = 1;
183 case 'd': /* double */
184 dataonly = 1;
185 format = 'd';
186 fmtid = "double";
187 break;
188 default:
189 goto unkopt;
190 }
191 break;
192 case 'x': /* x resolution */
193 case 'X': /* x resolution */
194 resolution = 0;
195 if (argv[i][0] == '-')
196 picres.rt |= XDECR;
197 picres.xr = atoi(argv[++i]);
198 break;
199 case 'y': /* y resolution */
200 case 'Y': /* y resolution */
201 resolution = 0;
202 if (argv[i][0] == '-')
203 picres.rt |= YDECR;
204 if (picres.xr == 0)
205 picres.rt |= YMAJOR;
206 picres.yr = atoi(argv[++i]);
207 break;
208 default:
209 unkopt:
210 fprintf(stderr, "%s: unknown option: %s\n",
211 progname, argv[i]);
212 quit(1);
213 break;
214 }
215 else
216 break;
217 /* recognize special formats */
218 if (dataonly && format == 'b') {
219 if (putprim == ALL)
220 fmtid = "24-bit_rgb";
221 else
222 fmtid = "8-bit_grey";
223 }
224 if (dataonly && format == 'w') {
225 if (putprim == ALL)
226 fmtid = "48-bit_rgb";
227 else
228 fmtid = "16-bit_grey";
229 }
230 /* assign reverse ordering */
231 rord[ord[0]] = 0;
232 rord[ord[1]] = 1;
233 rord[ord[2]] = 2;
234 /* get input */
235 if (i == argc) {
236 fin = stdin;
237 } else if (i < argc) {
238 if ((fin = fopen(argv[i], "r")) == NULL) {
239 fprintf(stderr, "%s: can't open file \"%s\"\n",
240 progname, argv[i]);
241 quit(1);
242 }
243 if (reverse && putprim != BRIGHT && i == argc-3) {
244 if ((fin2 = fopen(argv[i+1], "r")) == NULL) {
245 fprintf(stderr, "%s: can't open file \"%s\"\n",
246 progname, argv[i+1]);
247 quit(1);
248 }
249 if ((fin3 = fopen(argv[i+2], "r")) == NULL) {
250 fprintf(stderr, "%s: can't open file \"%s\"\n",
251 progname, argv[i+2]);
252 quit(1);
253 }
254 interleave = -1;
255 } else if (i != argc-1)
256 fin = NULL;
257 if (reverse && putprim != BRIGHT && !interleave) {
258 fin2 = fopen(argv[i], "r");
259 fin3 = fopen(argv[i], "r");
260 }
261 if (skipbytes && (fseek(fin, skipbytes, 0) || (fin2 != NULL &&
262 (fseek(fin2, skipbytes, 0) ||
263 fseek(fin3, skipbytes, 0))))) {
264 fprintf(stderr, "%s: cannot skip %ld bytes on input\n",
265 progname, skipbytes);
266 quit(1);
267 }
268 }
269 if (fin == NULL) {
270 fprintf(stderr, "%s: bad # file arguments\n", progname);
271 quit(1);
272 }
273
274 if (reverse) {
275 #ifdef _WIN32
276 SET_FILE_BINARY(stdout);
277 if (format != 'a' && format != 'i')
278 SET_FILE_BINARY(fin);
279 #endif
280 /* get header */
281 if (header) {
282 if (checkheader(fin, fmtid, stdout) < 0) {
283 fprintf(stderr, "%s: wrong input format\n",
284 progname);
285 quit(1);
286 }
287 if (fin2 != NULL) {
288 getheader(fin2, NULL, NULL);
289 getheader(fin3, NULL, NULL);
290 }
291 } else
292 newheader("RADIANCE", stdout);
293 /* get resolution */
294 if ((resolution && !fgetsresolu(&picres, fin)) ||
295 picres.xr <= 0 || picres.yr <= 0) {
296 fprintf(stderr, "%s: missing resolution\n", progname);
297 quit(1);
298 }
299 if (resolution && fin2 != NULL) {
300 RESOLU pres2;
301 if (!fgetsresolu(&pres2, fin2) ||
302 pres2.rt != picres.rt ||
303 pres2.xr != picres.xr ||
304 pres2.yr != picres.yr ||
305 !fgetsresolu(&pres2, fin3) ||
306 pres2.rt != picres.rt ||
307 pres2.xr != picres.xr ||
308 pres2.yr != picres.yr) {
309 fprintf(stderr, "%s: resolution mismatch\n",
310 progname);
311 quit(1);
312 }
313 }
314 /* add to header */
315 printargs(i, argv, stdout);
316 if (expval < .99 || expval > 1.01)
317 fputexpos(expval, stdout);
318 fputformat(COLRFMT, stdout);
319 putchar('\n');
320 fputsresolu(&picres, stdout); /* always put resolution */
321 valtopix();
322 } else {
323 #ifdef _WIN32
324 SET_FILE_BINARY(fin);
325 if (format != 'a' && format != 'i')
326 SET_FILE_BINARY(stdout);
327 #endif
328 /* get header */
329 getheader(fin, checkhead, NULL);
330 if (wrongformat) {
331 fprintf(stderr,
332 "%s: input not a Radiance RGBE picture\n",
333 progname);
334 quit(1);
335 }
336 if (!fgetsresolu(&picres, fin)) {
337 fprintf(stderr, "%s: missing resolution\n", progname);
338 quit(1);
339 }
340 if (header) {
341 printargs(i, argv, stdout);
342 if (expval < .99 || expval > 1.01)
343 fputexpos(expval, stdout);
344 fputformat(fmtid, stdout);
345 putchar('\n');
346 }
347 if (resolution) /* put resolution */
348 fputsresolu(&picres, stdout);
349 pixtoval();
350 }
351
352 quit(0);
353 }
354
355
356 int
357 checkhead(line) /* deal with line from header */
358 char *line;
359 {
360 char fmt[32];
361 double d;
362 COLOR ctmp;
363
364 if (formatval(fmt, line)) {
365 if (!strcmp(fmt, CIEFMT)) {
366 mybright = &xyz_bright;
367 if (original) {
368 scalecolor(exposure, 1./WHTEFFICACY);
369 doexposure++;
370 }
371 } else if (!strcmp(fmt, COLRFMT))
372 mybright = &rgb_bright;
373 else
374 wrongformat++;
375 } else if (original && isexpos(line)) {
376 d = 1.0/exposval(line);
377 scalecolor(exposure, d);
378 doexposure++;
379 } else if (original && iscolcor(line)) {
380 colcorval(ctmp, line);
381 setcolor(exposure, colval(exposure,RED)/colval(ctmp,RED),
382 colval(exposure,GRN)/colval(ctmp,GRN),
383 colval(exposure,BLU)/colval(ctmp,BLU));
384 doexposure++;
385 } else if (header)
386 fputs(line, stdout);
387 return(0);
388 }
389
390
391 pixtoval() /* convert picture to values */
392 {
393 register COLOR *scanln;
394 int dogamma;
395 COLOR lastc;
396 RREAL hv[2];
397 int startprim, endprim;
398 long startpos;
399 int y;
400 register int x;
401
402 scanln = (COLOR *)malloc(scanlen(&picres)*sizeof(COLOR));
403 if (scanln == NULL) {
404 fprintf(stderr, "%s: out of memory\n", progname);
405 quit(1);
406 }
407 dogamma = gamcor < .95 || gamcor > 1.05;
408 if (putprim == ALL && !interleave) {
409 startprim = RED; endprim = BLU;
410 startpos = ftell(fin);
411 } else {
412 startprim = putprim; endprim = putprim;
413 }
414 for (putprim = startprim; putprim <= endprim; putprim++) {
415 if (putprim != startprim && fseek(fin, startpos, 0)) {
416 fprintf(stderr, "%s: seek error on input file\n",
417 progname);
418 quit(1);
419 }
420 set_io();
421 setcolor(lastc, 0.0, 0.0, 0.0);
422 for (y = 0; y < numscans(&picres); y++) {
423 if (freadscan(scanln, scanlen(&picres), fin) < 0) {
424 fprintf(stderr, "%s: read error\n", progname);
425 quit(1);
426 }
427 for (x = 0; x < scanlen(&picres); x++) {
428 if (uniq) {
429 if ( colval(scanln[x],RED) ==
430 colval(lastc,RED) &&
431 colval(scanln[x],GRN) ==
432 colval(lastc,GRN) &&
433 colval(scanln[x],BLU) ==
434 colval(lastc,BLU) )
435 continue;
436 else
437 copycolor(lastc, scanln[x]);
438 }
439 if (doexposure)
440 multcolor(scanln[x], exposure);
441 if (dogamma)
442 setcolor(scanln[x],
443 pow(colval(scanln[x],RED), 1.0/gamcor),
444 pow(colval(scanln[x],GRN), 1.0/gamcor),
445 pow(colval(scanln[x],BLU), 1.0/gamcor));
446 if (!dataonly) {
447 pix2loc(hv, &picres, x, y);
448 printf("%7d %7d ",
449 (int)(hv[0]*picres.xr),
450 (int)(hv[1]*picres.yr));
451 }
452 if ((*putval)(scanln[x]) < 0) {
453 fprintf(stderr, "%s: write error\n",
454 progname);
455 quit(1);
456 }
457 }
458 }
459 }
460 free((void *)scanln);
461 }
462
463
464 valtopix() /* convert values to a pixel file */
465 {
466 int dogamma;
467 register COLOR *scanln;
468 int y;
469 register int x;
470
471 scanln = (COLOR *)malloc(scanlen(&picres)*sizeof(COLOR));
472 if (scanln == NULL) {
473 fprintf(stderr, "%s: out of memory\n", progname);
474 quit(1);
475 }
476 dogamma = gamcor < .95 || gamcor > 1.05;
477 set_io();
478 for (y = 0; y < numscans(&picres); y++) {
479 for (x = 0; x < scanlen(&picres); x++) {
480 if (!dataonly) {
481 fscanf(fin, "%*d %*d");
482 if (fin2 != NULL) {
483 fscanf(fin2, "%*d %*d");
484 fscanf(fin3, "%*d %*d");
485 }
486 }
487 if ((*getval)(scanln[x]) < 0) {
488 fprintf(stderr, "%s: read error\n", progname);
489 quit(1);
490 }
491 if (dogamma)
492 setcolor(scanln[x],
493 pow(colval(scanln[x],RED), gamcor),
494 pow(colval(scanln[x],GRN), gamcor),
495 pow(colval(scanln[x],BLU), gamcor));
496 if (doexposure)
497 multcolor(scanln[x], exposure);
498 }
499 if (fwritescan(scanln, scanlen(&picres), stdout) < 0) {
500 fprintf(stderr, "%s: write error\n", progname);
501 quit(1);
502 }
503 }
504 free((void *)scanln);
505 }
506
507
508 void
509 quit(code)
510 int code;
511 {
512 exit(code);
513 }
514
515
516 swap16(wp, n) /* swap n 16-bit words */
517 register uint16 *wp;
518 int n;
519 {
520 while (n-- > 0) {
521 *wp = *wp << 8 | ((*wp >> 8) & 0xff);
522 wp++;
523 }
524 }
525
526
527 swap32(wp, n) /* swap n 32-bit words */
528 register uint32 *wp;
529 int n;
530 {
531 while (n-- > 0) {
532 *wp = *wp << 24 | ((*wp >> 24) & 0xff) |
533 (*wp & 0xff00) << 8 | (*wp & 0xff0000) >> 8;
534 wp++;
535 }
536 }
537
538
539 swap64(wp, n) /* swap n 64-bit words */
540 register char *wp;
541 int n;
542 {
543 register int t;
544
545 while (n-- > 0) {
546 t = wp[0]; wp[0] = wp[7]; wp[7] = t;
547 t = wp[1]; wp[1] = wp[6]; wp[6] = t;
548 t = wp[2]; wp[2] = wp[5]; wp[5] = t;
549 t = wp[3]; wp[3] = wp[4]; wp[4] = t;
550 wp += 8;
551 }
552 }
553
554
555 getcascii(col) /* get an ascii color value from stream(s) */
556 COLOR col;
557 {
558 double vd[3];
559
560 if (fin2 == NULL) {
561 if (fscanf(fin, "%lf %lf %lf", &vd[0], &vd[1], &vd[2]) != 3)
562 return(-1);
563 } else {
564 if (fscanf(fin, "%lf", &vd[0]) != 1 ||
565 fscanf(fin2, "%lf", &vd[1]) != 1 ||
566 fscanf(fin3, "%lf", &vd[2]) != 1)
567 return(-1);
568 }
569 setcolor(col, vd[rord[RED]], vd[rord[GRN]], vd[rord[BLU]]);
570 return(0);
571 }
572
573
574 getcdouble(col) /* get a double color value from stream(s) */
575 COLOR col;
576 {
577 double vd[3];
578
579 if (fin2 == NULL) {
580 if (fread((char *)vd, sizeof(double), 3, fin) != 3)
581 return(-1);
582 } else {
583 if (fread((char *)vd, sizeof(double), 1, fin) != 1 ||
584 fread((char *)(vd+1), sizeof(double), 1, fin2) != 1 ||
585 fread((char *)(vd+2), sizeof(double), 1, fin3) != 1)
586 return(-1);
587 }
588 if (swapbytes)
589 swap64((char *)vd, 3);
590 setcolor(col, vd[rord[RED]], vd[rord[GRN]], vd[rord[BLU]]);
591 return(0);
592 }
593
594
595 getcfloat(col) /* get a float color value from stream(s) */
596 COLOR col;
597 {
598 float vf[3];
599
600 if (fin2 == NULL) {
601 if (fread((char *)vf, sizeof(float), 3, fin) != 3)
602 return(-1);
603 } else {
604 if (fread((char *)vf, sizeof(float), 1, fin) != 1 ||
605 fread((char *)(vf+1), sizeof(float), 1, fin2) != 1 ||
606 fread((char *)(vf+2), sizeof(float), 1, fin3) != 1)
607 return(-1);
608 }
609 if (swapbytes)
610 swap32((uint32 *)vf, 3);
611 setcolor(col, vf[rord[RED]], vf[rord[GRN]], vf[rord[BLU]]);
612 return(0);
613 }
614
615
616 getcint(col) /* get an int color value from stream(s) */
617 COLOR col;
618 {
619 int vi[3];
620
621 if (fin2 == NULL) {
622 if (fscanf(fin, "%d %d %d", &vi[0], &vi[1], &vi[2]) != 3)
623 return(-1);
624 } else {
625 if (fscanf(fin, "%d", &vi[0]) != 1 ||
626 fscanf(fin2, "%d", &vi[1]) != 1 ||
627 fscanf(fin3, "%d", &vi[2]) != 1)
628 return(-1);
629 }
630 setcolor(col, (vi[rord[RED]]+.5)/256.,
631 (vi[rord[GRN]]+.5)/256., (vi[rord[BLU]]+.5)/256.);
632 return(0);
633 }
634
635
636 getcbyte(col) /* get a byte color value from stream(s) */
637 COLOR col;
638 {
639 BYTE vb[3];
640
641 if (fin2 == NULL) {
642 if (fread((char *)vb, sizeof(BYTE), 3, fin) != 3)
643 return(-1);
644 } else {
645 if (fread((char *)vb, sizeof(BYTE), 1, fin) != 1 ||
646 fread((char *)(vb+1), sizeof(BYTE), 1, fin2) != 1 ||
647 fread((char *)(vb+2), sizeof(BYTE), 1, fin3) != 1)
648 return(-1);
649 }
650 setcolor(col, (vb[rord[RED]]+.5)/256.,
651 (vb[rord[GRN]]+.5)/256., (vb[rord[BLU]]+.5)/256.);
652 return(0);
653 }
654
655
656 getcword(col) /* get a 16-bit color value from stream(s) */
657 COLOR col;
658 {
659 uint16 vw[3];
660
661 if (fin2 == NULL) {
662 if (fread((char *)vw, sizeof(uint16), 3, fin) != 3)
663 return(-1);
664 } else {
665 if (fread((char *)vw, sizeof(uint16), 1, fin) != 1 ||
666 fread((char *)(vw+1), sizeof(uint16), 1, fin2) != 1 ||
667 fread((char *)(vw+2), sizeof(uint16), 1, fin3) != 1)
668 return(-1);
669 }
670 if (swapbytes)
671 swap16(vw, 3);
672 setcolor(col, (vw[rord[RED]]+.5)/65536.,
673 (vw[rord[GRN]]+.5)/65536., (vw[rord[BLU]]+.5)/65536.);
674 return(0);
675 }
676
677
678 getbascii(col) /* get an ascii brightness value from fin */
679 COLOR col;
680 {
681 double vd;
682
683 if (fscanf(fin, "%lf", &vd) != 1)
684 return(-1);
685 setcolor(col, vd, vd, vd);
686 return(0);
687 }
688
689
690 getbdouble(col) /* get a double brightness value from fin */
691 COLOR col;
692 {
693 double vd;
694
695 if (fread((char *)&vd, sizeof(double), 1, fin) != 1)
696 return(-1);
697 if (swapbytes)
698 swap64((char *)&vd, 1);
699 setcolor(col, vd, vd, vd);
700 return(0);
701 }
702
703
704 getbfloat(col) /* get a float brightness value from fin */
705 COLOR col;
706 {
707 float vf;
708
709 if (fread((char *)&vf, sizeof(float), 1, fin) != 1)
710 return(-1);
711 if (swapbytes)
712 swap32((uint32 *)&vf, 1);
713 setcolor(col, vf, vf, vf);
714 return(0);
715 }
716
717
718 getbint(col) /* get an int brightness value from fin */
719 COLOR col;
720 {
721 int vi;
722 double d;
723
724 if (fscanf(fin, "%d", &vi) != 1)
725 return(-1);
726 d = (vi+.5)/256.;
727 setcolor(col, d, d, d);
728 return(0);
729 }
730
731
732 getbbyte(col) /* get a byte brightness value from fin */
733 COLOR col;
734 {
735 BYTE vb;
736 double d;
737
738 if (fread((char *)&vb, sizeof(BYTE), 1, fin) != 1)
739 return(-1);
740 d = (vb+.5)/256.;
741 setcolor(col, d, d, d);
742 return(0);
743 }
744
745
746 getbword(col) /* get a 16-bit brightness value from fin */
747 COLOR col;
748 {
749 uint16 vw;
750 double d;
751
752 if (fread((char *)&vw, sizeof(uint16), 1, fin) != 1)
753 return(-1);
754 if (swapbytes)
755 swap16(&vw, 1);
756 d = (vw+.5)/65536.;
757 setcolor(col, d, d, d);
758 return(0);
759 }
760
761
762 putcascii(col) /* put an ascii color to stdout */
763 COLOR col;
764 {
765 fprintf(stdout, "%15.3e %15.3e %15.3e\n",
766 colval(col,ord[0]),
767 colval(col,ord[1]),
768 colval(col,ord[2]));
769
770 return(ferror(stdout) ? -1 : 0);
771 }
772
773
774 putcfloat(col) /* put a float color to stdout */
775 COLOR col;
776 {
777 float vf[3];
778
779 vf[0] = colval(col,ord[0]);
780 vf[1] = colval(col,ord[1]);
781 vf[2] = colval(col,ord[2]);
782 if (swapbytes)
783 swap32((uint32 *)vf, 3);
784 fwrite((char *)vf, sizeof(float), 3, stdout);
785
786 return(ferror(stdout) ? -1 : 0);
787 }
788
789
790 putcdouble(col) /* put a double color to stdout */
791 COLOR col;
792 {
793 double vd[3];
794
795 vd[0] = colval(col,ord[0]);
796 vd[1] = colval(col,ord[1]);
797 vd[2] = colval(col,ord[2]);
798 if (swapbytes)
799 swap64((char *)vd, 3);
800 fwrite((char *)vd, sizeof(double), 3, stdout);
801
802 return(ferror(stdout) ? -1 : 0);
803 }
804
805
806 putcint(col) /* put an int color to stdout */
807 COLOR col;
808 {
809 fprintf(stdout, "%d %d %d\n",
810 (int)(colval(col,ord[0])*256.),
811 (int)(colval(col,ord[1])*256.),
812 (int)(colval(col,ord[2])*256.));
813
814 return(ferror(stdout) ? -1 : 0);
815 }
816
817
818 putcbyte(col) /* put a byte color to stdout */
819 COLOR col;
820 {
821 long i;
822 BYTE vb[3];
823
824 i = colval(col,ord[0])*256.;
825 vb[0] = min(i,255);
826 i = colval(col,ord[1])*256.;
827 vb[1] = min(i,255);
828 i = colval(col,ord[2])*256.;
829 vb[2] = min(i,255);
830 fwrite((char *)vb, sizeof(BYTE), 3, stdout);
831
832 return(ferror(stdout) ? -1 : 0);
833 }
834
835
836 putcword(col) /* put a 16-bit color to stdout */
837 COLOR col;
838 {
839 long i;
840 uint16 vw[3];
841
842 i = colval(col,ord[0])*65536.;
843 vw[0] = min(i,65535);
844 i = colval(col,ord[1])*65536.;
845 vw[1] = min(i,65535);
846 i = colval(col,ord[2])*65536.;
847 vw[2] = min(i,65535);
848 if (swapbytes)
849 swap16(vw, 3);
850 fwrite((char *)vw, sizeof(uint16), 3, stdout);
851
852 return(ferror(stdout) ? -1 : 0);
853 }
854
855
856 putbascii(col) /* put an ascii brightness to stdout */
857 COLOR col;
858 {
859 fprintf(stdout, "%15.3e\n", (*mybright)(col));
860
861 return(ferror(stdout) ? -1 : 0);
862 }
863
864
865 putbfloat(col) /* put a float brightness to stdout */
866 COLOR col;
867 {
868 float vf;
869
870 vf = (*mybright)(col);
871 if (swapbytes)
872 swap32((uint32 *)&vf, 1);
873 fwrite((char *)&vf, sizeof(float), 1, stdout);
874
875 return(ferror(stdout) ? -1 : 0);
876 }
877
878
879 putbdouble(col) /* put a double brightness to stdout */
880 COLOR col;
881 {
882 double vd;
883
884 vd = (*mybright)(col);
885 if (swapbytes)
886 swap64((char *)&vd, 1);
887 fwrite((char *)&vd, sizeof(double), 1, stdout);
888
889 return(ferror(stdout) ? -1 : 0);
890 }
891
892
893 putbint(col) /* put an int brightness to stdout */
894 COLOR col;
895 {
896 fprintf(stdout, "%d\n", (int)((*mybright)(col)*256.));
897
898 return(ferror(stdout) ? -1 : 0);
899 }
900
901
902 putbbyte(col) /* put a byte brightness to stdout */
903 COLOR col;
904 {
905 register int i;
906 BYTE vb;
907
908 i = (*mybright)(col)*256.;
909 vb = min(i,255);
910 fwrite((char *)&vb, sizeof(BYTE), 1, stdout);
911
912 return(ferror(stdout) ? -1 : 0);
913 }
914
915
916 putbword(col) /* put a 16-bit brightness to stdout */
917 COLOR col;
918 {
919 long i;
920 uint16 vw;
921
922 i = (*mybright)(col)*65536.;
923 vw = min(i,65535);
924 if (swapbytes)
925 swap16(&vw, 1);
926 fwrite((char *)&vw, sizeof(uint16), 1, stdout);
927
928 return(ferror(stdout) ? -1 : 0);
929 }
930
931
932 putpascii(col) /* put an ascii primary to stdout */
933 COLOR col;
934 {
935 fprintf(stdout, "%15.3e\n", colval(col,putprim));
936
937 return(ferror(stdout) ? -1 : 0);
938 }
939
940
941 putpfloat(col) /* put a float primary to stdout */
942 COLOR col;
943 {
944 float vf;
945
946 vf = colval(col,putprim);
947 if (swapbytes)
948 swap32((uint32 *)&vf, 1);
949 fwrite((char *)&vf, sizeof(float), 1, stdout);
950
951 return(ferror(stdout) ? -1 : 0);
952 }
953
954
955 putpdouble(col) /* put a double primary to stdout */
956 COLOR col;
957 {
958 double vd;
959
960 vd = colval(col,putprim);
961 if (swapbytes)
962 swap64((char *)&vd, 1);
963 fwrite((char *)&vd, sizeof(double), 1, stdout);
964
965 return(ferror(stdout) ? -1 : 0);
966 }
967
968
969 putpint(col) /* put an int primary to stdout */
970 COLOR col;
971 {
972 fprintf(stdout, "%d\n", (int)(colval(col,putprim)*256.));
973
974 return(ferror(stdout) ? -1 : 0);
975 }
976
977
978 putpbyte(col) /* put a byte primary to stdout */
979 COLOR col;
980 {
981 long i;
982 BYTE vb;
983
984 i = colval(col,putprim)*256.;
985 vb = min(i,255);
986 fwrite((char *)&vb, sizeof(BYTE), 1, stdout);
987
988 return(ferror(stdout) ? -1 : 0);
989 }
990
991
992 putpword(col) /* put a 16-bit primary to stdout */
993 COLOR col;
994 {
995 long i;
996 uint16 vw;
997
998 i = colval(col,putprim)*65536.;
999 vw = min(i,65535);
1000 if (swapbytes)
1001 swap16(&vw, 1);
1002 fwrite((char *)&vw, sizeof(uint16), 1, stdout);
1003
1004 return(ferror(stdout) ? -1 : 0);
1005 }
1006
1007
1008 set_io() /* set put and get functions */
1009 {
1010 switch (format) {
1011 case 'a': /* ascii */
1012 if (putprim == BRIGHT) {
1013 getval = getbascii;
1014 putval = putbascii;
1015 } else if (putprim != ALL) {
1016 getval = getbascii;
1017 putval = putpascii;
1018 } else {
1019 getval = getcascii;
1020 putval = putcascii;
1021 if (reverse && !interleave) {
1022 fprintf(stderr,
1023 "%s: ASCII input files must be interleaved\n",
1024 progname);
1025 quit(1);
1026 }
1027 }
1028 return;
1029 case 'f': /* binary float */
1030 if (putprim == BRIGHT) {
1031 getval = getbfloat;
1032 putval = putbfloat;
1033 } else if (putprim != ALL) {
1034 getval = getbfloat;
1035 putval = putpfloat;
1036 } else {
1037 getval = getcfloat;
1038 putval = putcfloat;
1039 if (reverse && !interleave) {
1040 if (fin2 == NULL)
1041 goto namerr;
1042 if (fseek(fin2,
1043 (long)sizeof(float)*picres.xr*picres.yr, 1))
1044 goto seekerr;
1045 if (fseek(fin3,
1046 (long)sizeof(float)*2*picres.xr*picres.yr, 1))
1047 goto seekerr;
1048 }
1049 }
1050 return;
1051 case 'd': /* binary double */
1052 if (putprim == BRIGHT) {
1053 getval = getbdouble;
1054 putval = putbdouble;
1055 } else if (putprim != ALL) {
1056 getval = getbdouble;
1057 putval = putpdouble;
1058 } else {
1059 getval = getcdouble;
1060 putval = putcdouble;
1061 if (reverse && !interleave) {
1062 if (fin2 == NULL)
1063 goto namerr;
1064 if (fseek(fin2,
1065 (long)sizeof(double)*picres.xr*picres.yr, 1))
1066 goto seekerr;
1067 if (fseek(fin3,
1068 (long)sizeof(double)*2*picres.xr*picres.yr, 1))
1069 goto seekerr;
1070 }
1071 }
1072 return;
1073 case 'i': /* integer */
1074 if (putprim == BRIGHT) {
1075 getval = getbint;
1076 putval = putbint;
1077 } else if (putprim != ALL) {
1078 getval = getbint;
1079 putval = putpint;
1080 } else {
1081 getval = getcint;
1082 putval = putcint;
1083 if (reverse && !interleave) {
1084 fprintf(stderr,
1085 "%s: integer input files must be interleaved\n",
1086 progname);
1087 quit(1);
1088 }
1089 }
1090 return;
1091 case 'b': /* byte */
1092 if (putprim == BRIGHT) {
1093 getval = getbbyte;
1094 putval = putbbyte;
1095 } else if (putprim != ALL) {
1096 getval = getbbyte;
1097 putval = putpbyte;
1098 } else {
1099 getval = getcbyte;
1100 putval = putcbyte;
1101 if (reverse && !interleave) {
1102 if (fin2 == NULL)
1103 goto namerr;
1104 if (fseek(fin2,
1105 (long)sizeof(BYTE)*picres.xr*picres.yr, 1))
1106 goto seekerr;
1107 if (fseek(fin3,
1108 (long)sizeof(BYTE)*2*picres.xr*picres.yr, 1))
1109 goto seekerr;
1110 }
1111 }
1112 return;
1113 case 'w': /* 16-bit */
1114 if (putprim == BRIGHT) {
1115 getval = getbword;
1116 putval = putbword;
1117 } else if (putprim != ALL) {
1118 getval = getbword;
1119 putval = putpword;
1120 } else {
1121 getval = getcword;
1122 putval = putcword;
1123 if (reverse && !interleave) {
1124 if (fin2 == NULL)
1125 goto namerr;
1126 if (fseek(fin2,
1127 (long)sizeof(uint16)*picres.xr*picres.yr, 1))
1128 goto seekerr;
1129 if (fseek(fin3,
1130 (long)sizeof(uint16)*2*picres.xr*picres.yr, 1))
1131 goto seekerr;
1132 }
1133 }
1134 return;
1135 }
1136 badopt:
1137 fprintf(stderr, "%s: botched file type\n", progname);
1138 quit(1);
1139 namerr:
1140 fprintf(stderr, "%s: non-interleaved file(s) must be named\n",
1141 progname);
1142 quit(1);
1143 seekerr:
1144 fprintf(stderr, "%s: cannot seek on interleaved input file\n",
1145 progname);
1146 quit(1);
1147 }
