1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: pvalue.c,v 2.26 2004/03/28 20:33:14 schorsch Exp $"; |
3 |
#endif |
4 |
5 |
* pvalue.c - program to print pixel values. |
6 |
7 |
* 4/23/86 |
8 |
9 |
10 |
#include "platform.h" |
11 |
#include "standard.h" |
12 |
#include "color.h" |
13 |
#include "resolu.h" |
14 |
#include "view.h" |
15 |
16 |
#define min(a,b) ((a)<(b)?(a):(b)) |
17 |
18 |
/* what to put out (also RED, GRN, BLU) */ |
19 |
#define ALL 3 |
20 |
#define BRIGHT 4 |
21 |
22 |
RESOLU picres; /* resolution of picture */ |
23 |
int uniq = 0; /* print only unique values? */ |
24 |
int doexposure = 0; /* exposure change? (>100 to print) */ |
25 |
int dataonly = 0; /* data only format? */ |
26 |
int putprim = ALL; /* what to put out */ |
27 |
int reverse = 0; /* reverse conversion? */ |
28 |
int format = 'a'; /* input/output format */ |
29 |
char *fmtid = "ascii"; /* format identifier for header */ |
30 |
int header = 1; /* do header? */ |
31 |
long skipbytes = 0; /* skip bytes in input? */ |
32 |
int swapbytes = 0; /* swap bytes? */ |
33 |
int interleave = 1; /* file is interleaved? */ |
34 |
int resolution = 1; /* put/get resolution string? */ |
35 |
int original = 0; /* convert to original values? */ |
36 |
int wrongformat = 0; /* wrong input format? */ |
37 |
double gamcor = 1.0; /* gamma correction */ |
38 |
39 |
int ord[3] = {RED, GRN, BLU}; /* RGB ordering */ |
40 |
int rord[4]; /* reverse ordering */ |
41 |
42 |
COLOR exposure = WHTCOLOR; |
43 |
44 |
char *progname; |
45 |
46 |
FILE *fin; |
47 |
FILE *fin2 = NULL, *fin3 = NULL; /* for other color channels */ |
48 |
49 |
50 |
typedef int getfunc_t(COLOR col); |
51 |
typedef int putfunc_t(COLOR col); |
52 |
typedef double brightfunc_t(COLOR col); |
53 |
54 |
getfunc_t *getval; |
55 |
putfunc_t *putval; |
56 |
brightfunc_t *mybright; |
57 |
58 |
static gethfunc checkhead; |
59 |
static brightfunc_t rgb_bright, xyz_bright; |
60 |
static getfunc_t getbascii, getbint, getbdouble, getbfloat, getbbyte, getbword; |
61 |
static getfunc_t getcascii, getcint, getcdouble, getcfloat, getcbyte, getcword; |
62 |
static putfunc_t putbascii, putbint, putbdouble, putbfloat, putbbyte, putbword; |
63 |
static putfunc_t putcascii, putcint, putcdouble, putcfloat, putcbyte, putcword; |
64 |
static putfunc_t putpascii, putpint, putpdouble, putpfloat, putpbyte, putpword; |
65 |
66 |
static void set_io(void); |
67 |
static void pixtoval(void); |
68 |
static void valtopix(void); |
69 |
static void swap16(uint16 *wp, int n); |
70 |
static void swap32(uint32 *wp, int n); |
71 |
static void swap64(char *wp, int n); |
72 |
73 |
74 |
static double |
75 |
rgb_bright( |
76 |
COLOR clr |
77 |
78 |
79 |
return(bright(clr)); |
80 |
81 |
82 |
static double |
83 |
xyz_bright( |
84 |
COLOR clr |
85 |
86 |
87 |
return(clr[CIEY]); |
88 |
89 |
90 |
int |
91 |
main( |
92 |
int argc, |
93 |
char **argv |
94 |
95 |
96 |
double d, expval = 1.0; |
97 |
int i; |
98 |
99 |
progname = argv[0]; |
100 |
mybright = &rgb_bright; /* default */ |
101 |
102 |
for (i = 1; i < argc; i++) |
103 |
if (argv[i][0] == '-' || argv[i][0] == '+') |
104 |
switch (argv[i][1]) { |
105 |
case 'h': /* header */ |
106 |
header = argv[i][0] == '+'; |
107 |
break; |
108 |
case 'H': /* resolution string */ |
109 |
resolution = argv[i][0] == '+'; |
110 |
break; |
111 |
case 's': /* skip bytes in header */ |
112 |
skipbytes = atol(argv[++i]); |
113 |
break; |
114 |
case 'u': /* unique values */ |
115 |
uniq = argv[i][0] == '-'; |
116 |
break; |
117 |
case 'o': /* original values */ |
118 |
original = argv[i][0] == '-'; |
119 |
break; |
120 |
case 'g': /* gamma correction */ |
121 |
gamcor = atof(argv[i+1]); |
122 |
if (argv[i][0] == '+') |
123 |
gamcor = 1.0/gamcor; |
124 |
i++; |
125 |
break; |
126 |
case 'e': /* exposure correction */ |
127 |
d = atof(argv[i+1]); |
128 |
if (argv[i+1][0] == '-' || argv[i+1][0] == '+') |
129 |
d = pow(2.0, d); |
130 |
if (argv[i][0] == '-') |
131 |
expval *= d; |
132 |
scalecolor(exposure, d); |
133 |
doexposure++; |
134 |
i++; |
135 |
break; |
136 |
case 'R': /* reverse byte sequence */ |
137 |
if (argv[i][0] == '-') { |
138 |
ord[0]=BLU; ord[1]=GRN; ord[2]=RED; |
139 |
} else { |
140 |
ord[0]=RED; ord[1]=GRN; ord[2]=BLU; |
141 |
142 |
break; |
143 |
case 'r': /* reverse conversion */ |
144 |
reverse = argv[i][0] == '-'; |
145 |
break; |
146 |
case 'n': /* non-interleaved RGB */ |
147 |
interleave = argv[i][0] == '+'; |
148 |
break; |
149 |
case 'b': /* brightness values */ |
150 |
putprim = argv[i][0] == '-' ? BRIGHT : ALL; |
151 |
break; |
152 |
case 'p': /* put primary */ |
153 |
switch (argv[i][2]) { |
154 |
case 'r': case 'R': putprim = RED; break; |
155 |
case 'g': case 'G': putprim = GRN; break; |
156 |
case 'b': case 'B': putprim = BLU; break; |
157 |
default: goto unkopt; |
158 |
159 |
break; |
160 |
case 'd': /* data only (no indices) */ |
161 |
dataonly = argv[i][0] == '-'; |
162 |
163 |
case '\0': |
164 |
case 'a': /* ascii */ |
165 |
format = 'a'; |
166 |
fmtid = "ascii"; |
167 |
break; |
168 |
case 'i': /* integer */ |
169 |
format = 'i'; |
170 |
fmtid = "ascii"; |
171 |
break; |
172 |
case 'b': /* byte */ |
173 |
dataonly = 1; |
174 |
format = 'b'; |
175 |
fmtid = "byte"; |
176 |
break; |
177 |
case 'W': /* 16-bit swapped */ |
178 |
swapbytes = 1; |
179 |
case 'w': /* 16-bit */ |
180 |
dataonly = 1; |
181 |
format = 'w'; |
182 |
fmtid = "16-bit"; |
183 |
break; |
184 |
case 'F': /* swapped floats */ |
185 |
swapbytes = 1; |
186 |
case 'f': /* float */ |
187 |
dataonly = 1; |
188 |
format = 'f'; |
189 |
fmtid = "float"; |
190 |
break; |
191 |
case 'D': /* swapped doubles */ |
192 |
swapbytes = 1; |
193 |
case 'd': /* double */ |
194 |
dataonly = 1; |
195 |
format = 'd'; |
196 |
fmtid = "double"; |
197 |
break; |
198 |
default: |
199 |
goto unkopt; |
200 |
201 |
break; |
202 |
case 'x': /* x resolution */ |
203 |
case 'X': /* x resolution */ |
204 |
resolution = 0; |
205 |
206 |
picres.rt |= XDECR; |
207 |
picres.xr = atoi(argv[++i]); |
208 |
break; |
209 |
case 'y': /* y resolution */ |
210 |
case 'Y': /* y resolution */ |
211 |
resolution = 0; |
212 |
213 |
picres.rt |= YDECR; |
214 |
if (picres.xr == 0) |
215 |
picres.rt |= YMAJOR; |
216 |
picres.yr = atoi(argv[++i]); |
217 |
break; |
218 |
default: |
219 |
unkopt: |
220 |
fprintf(stderr, "%s: unknown option: %s\n", |
221 |
progname, argv[i]); |
222 |
quit(1); |
223 |
break; |
224 |
225 |
else |
226 |
break; |
227 |
/* recognize special formats */ |
228 |
if (dataonly && format == 'b') { |
229 |
if (putprim == ALL) |
230 |
fmtid = "24-bit_rgb"; |
231 |
else |
232 |
fmtid = "8-bit_grey"; |
233 |
234 |
if (dataonly && format == 'w') { |
235 |
236 |
fmtid = "48-bit_rgb"; |
237 |
else |
238 |
fmtid = "16-bit_grey"; |
239 |
240 |
/* assign reverse ordering */ |
241 |
rord[ord[0]] = 0; |
242 |
rord[ord[1]] = 1; |
243 |
rord[ord[2]] = 2; |
244 |
/* get input */ |
245 |
if (i == argc) { |
246 |
fin = stdin; |
247 |
} else if (i < argc) { |
248 |
if ((fin = fopen(argv[i], "r")) == NULL) { |
249 |
fprintf(stderr, "%s: can't open file \"%s\"\n", |
250 |
251 |
quit(1); |
252 |
253 |
if (reverse && putprim != BRIGHT && i == argc-3) { |
254 |
if ((fin2 = fopen(argv[i+1], "r")) == NULL) { |
255 |
256 |
progname, argv[i+1]); |
257 |
quit(1); |
258 |
259 |
if ((fin3 = fopen(argv[i+2], "r")) == NULL) { |
260 |
261 |
progname, argv[i+2]); |
262 |
quit(1); |
263 |
264 |
interleave = -1; |
265 |
} else if (i != argc-1) |
266 |
fin = NULL; |
267 |
if (reverse && putprim != BRIGHT && !interleave) { |
268 |
fin2 = fopen(argv[i], "r"); |
269 |
fin3 = fopen(argv[i], "r"); |
270 |
271 |
if (skipbytes && (fseek(fin, skipbytes, 0) || (fin2 != NULL && |
272 |
(fseek(fin2, skipbytes, 0) || |
273 |
fseek(fin3, skipbytes, 0))))) { |
274 |
fprintf(stderr, "%s: cannot skip %ld bytes on input\n", |
275 |
progname, skipbytes); |
276 |
quit(1); |
277 |
278 |
279 |
if (fin == NULL) { |
280 |
fprintf(stderr, "%s: bad # file arguments\n", progname); |
281 |
quit(1); |
282 |
283 |
284 |
if (reverse) { |
285 |
#ifdef _WIN32 |
286 |
SET_FILE_BINARY(stdout); |
287 |
if (format != 'a' && format != 'i') |
288 |
SET_FILE_BINARY(fin); |
289 |
#endif |
290 |
/* get header */ |
291 |
if (header) { |
292 |
if (checkheader(fin, fmtid, stdout) < 0) { |
293 |
fprintf(stderr, "%s: wrong input format\n", |
294 |
progname); |
295 |
quit(1); |
296 |
297 |
if (fin2 != NULL) { |
298 |
getheader(fin2, NULL, NULL); |
299 |
getheader(fin3, NULL, NULL); |
300 |
301 |
} else |
302 |
newheader("RADIANCE", stdout); |
303 |
/* get resolution */ |
304 |
if ((resolution && !fgetsresolu(&picres, fin)) || |
305 |
picres.xr <= 0 || picres.yr <= 0) { |
306 |
fprintf(stderr, "%s: missing resolution\n", progname); |
307 |
quit(1); |
308 |
309 |
if (resolution && fin2 != NULL) { |
310 |
RESOLU pres2; |
311 |
if (!fgetsresolu(&pres2, fin2) || |
312 |
pres2.rt != picres.rt || |
313 |
pres2.xr != picres.xr || |
314 |
pres2.yr != picres.yr || |
315 |
!fgetsresolu(&pres2, fin3) || |
316 |
317 |
318 |
pres2.yr != picres.yr) { |
319 |
fprintf(stderr, "%s: resolution mismatch\n", |
320 |
progname); |
321 |
quit(1); |
322 |
323 |
324 |
/* add to header */ |
325 |
printargs(i, argv, stdout); |
326 |
if (expval < .99 || expval > 1.01) |
327 |
fputexpos(expval, stdout); |
328 |
fputformat(COLRFMT, stdout); |
329 |
putchar('\n'); |
330 |
fputsresolu(&picres, stdout); /* always put resolution */ |
331 |
valtopix(); |
332 |
} else { |
333 |
#ifdef _WIN32 |
334 |
335 |
336 |
337 |
#endif |
338 |
/* get header */ |
339 |
getheader(fin, checkhead, NULL); |
340 |
if (wrongformat) { |
341 |
fprintf(stderr, |
342 |
"%s: input not a Radiance RGBE picture\n", |
343 |
progname); |
344 |
quit(1); |
345 |
346 |
if (!fgetsresolu(&picres, fin)) { |
347 |
348 |
quit(1); |
349 |
350 |
if (header) { |
351 |
352 |
353 |
354 |
fputformat(fmtid, stdout); |
355 |
putchar('\n'); |
356 |
357 |
if (resolution) /* put resolution */ |
358 |
fputsresolu(&picres, stdout); |
359 |
pixtoval(); |
360 |
361 |
362 |
quit(0); |
363 |
return 0; /* pro forma return */ |
364 |
365 |
366 |
367 |
static int |
368 |
checkhead( /* deal with line from header */ |
369 |
char *line, |
370 |
void *p |
371 |
372 |
373 |
char fmt[32]; |
374 |
double d; |
375 |
COLOR ctmp; |
376 |
377 |
if (formatval(fmt, line)) { |
378 |
if (!strcmp(fmt, CIEFMT)) |
379 |
mybright = &xyz_bright; |
380 |
else if (!strcmp(fmt, COLRFMT)) |
381 |
mybright = &rgb_bright; |
382 |
else |
383 |
wrongformat++; |
384 |
} else if (original && isexpos(line)) { |
385 |
d = 1.0/exposval(line); |
386 |
387 |
fprintf(stderr, "scaled exposure by %f, now at %f\n", d, bright(exposure)); |
388 |
doexposure++; |
389 |
} else if (original && iscolcor(line)) { |
390 |
colcorval(ctmp, line); |
391 |
setcolor(exposure, colval(exposure,RED)/colval(ctmp,RED), |
392 |
colval(exposure,GRN)/colval(ctmp,GRN), |
393 |
colval(exposure,BLU)/colval(ctmp,BLU)); |
394 |
doexposure++; |
395 |
} else if (header) |
396 |
fputs(line, stdout); |
397 |
return(0); |
398 |
399 |
400 |
401 |
static void |
402 |
pixtoval(void) /* convert picture to values */ |
403 |
404 |
register COLOR *scanln; |
405 |
int dogamma; |
406 |
COLOR lastc; |
407 |
RREAL hv[2]; |
408 |
int startprim, endprim; |
409 |
long startpos; |
410 |
int y; |
411 |
register int x; |
412 |
413 |
scanln = (COLOR *)malloc(scanlen(&picres)*sizeof(COLOR)); |
414 |
if (scanln == NULL) { |
415 |
fprintf(stderr, "%s: out of memory\n", progname); |
416 |
quit(1); |
417 |
418 |
dogamma = gamcor < .95 || gamcor > 1.05; |
419 |
if (putprim == ALL && !interleave) { |
420 |
startprim = RED; endprim = BLU; |
421 |
startpos = ftell(fin); |
422 |
} else { |
423 |
startprim = putprim; endprim = putprim; |
424 |
425 |
for (putprim = startprim; putprim <= endprim; putprim++) { |
426 |
if (putprim != startprim && fseek(fin, startpos, 0)) { |
427 |
fprintf(stderr, "%s: seek error on input file\n", |
428 |
progname); |
429 |
quit(1); |
430 |
431 |
set_io(); |
432 |
setcolor(lastc, 0.0, 0.0, 0.0); |
433 |
for (y = 0; y < numscans(&picres); y++) { |
434 |
if (freadscan(scanln, scanlen(&picres), fin) < 0) { |
435 |
fprintf(stderr, "%s: read error\n", progname); |
436 |
quit(1); |
437 |
438 |
for (x = 0; x < scanlen(&picres); x++) { |
439 |
if (uniq) { |
440 |
if ( colval(scanln[x],RED) == |
441 |
colval(lastc,RED) && |
442 |
colval(scanln[x],GRN) == |
443 |
colval(lastc,GRN) && |
444 |
colval(scanln[x],BLU) == |
445 |
colval(lastc,BLU) ) |
446 |
continue; |
447 |
else |
448 |
copycolor(lastc, scanln[x]); |
449 |
450 |
if (doexposure) |
451 |
multcolor(scanln[x], exposure); |
452 |
if (dogamma) |
453 |
setcolor(scanln[x], |
454 |
pow(colval(scanln[x],RED), 1.0/gamcor), |
455 |
pow(colval(scanln[x],GRN), 1.0/gamcor), |
456 |
pow(colval(scanln[x],BLU), 1.0/gamcor)); |
457 |
if (!dataonly) { |
458 |
pix2loc(hv, &picres, x, y); |
459 |
printf("%7d %7d ", |
460 |
(int)(hv[0]*picres.xr), |
461 |
(int)(hv[1]*picres.yr)); |
462 |
463 |
if ((*putval)(scanln[x]) < 0) { |
464 |
fprintf(stderr, "%s: write error\n", |
465 |
progname); |
466 |
quit(1); |
467 |
468 |
469 |
470 |
471 |
free((void *)scanln); |
472 |
473 |
474 |
475 |
static void |
476 |
valtopix(void) /* convert values to a pixel file */ |
477 |
478 |
int dogamma; |
479 |
480 |
int y; |
481 |
register int x; |
482 |
483 |
484 |
485 |
486 |
quit(1); |
487 |
488 |
489 |
set_io(); |
490 |
491 |
492 |
if (!dataonly) { |
493 |
fscanf(fin, "%*d %*d"); |
494 |
495 |
fscanf(fin2, "%*d %*d"); |
496 |
fscanf(fin3, "%*d %*d"); |
497 |
498 |
499 |
if ((*getval)(scanln[x]) < 0) { |
500 |
501 |
quit(1); |
502 |
503 |
if (dogamma) |
504 |
505 |
pow(colval(scanln[x],RED), gamcor), |
506 |
pow(colval(scanln[x],GRN), gamcor), |
507 |
pow(colval(scanln[x],BLU), gamcor)); |
508 |
if (doexposure) |
509 |
510 |
511 |
if (fwritescan(scanln, scanlen(&picres), stdout) < 0) { |
512 |
fprintf(stderr, "%s: write error\n", progname); |
513 |
quit(1); |
514 |
515 |
516 |
517 |
518 |
519 |
520 |
void |
521 |
quit(code) |
522 |
int code; |
523 |
524 |
exit(code); |
525 |
526 |
527 |
528 |
static void |
529 |
swap16( /* swap n 16-bit words */ |
530 |
register uint16 *wp, |
531 |
int n |
532 |
533 |
534 |
while (n-- > 0) { |
535 |
*wp = *wp << 8 | ((*wp >> 8) & 0xff); |
536 |
wp++; |
537 |
538 |
539 |
540 |
541 |
static void |
542 |
swap32( /* swap n 32-bit words */ |
543 |
register uint32 *wp, |
544 |
int n |
545 |
546 |
547 |
while (n-- > 0) { |
548 |
*wp = *wp << 24 | ((*wp >> 24) & 0xff) | |
549 |
(*wp & 0xff00) << 8 | (*wp & 0xff0000) >> 8; |
550 |
wp++; |
551 |
552 |
553 |
554 |
555 |
static void |
556 |
swap64( /* swap n 64-bit words */ |
557 |
register char *wp, |
558 |
int n |
559 |
560 |
561 |
register int t; |
562 |
563 |
while (n-- > 0) { |
564 |
t = wp[0]; wp[0] = wp[7]; wp[7] = t; |
565 |
t = wp[1]; wp[1] = wp[6]; wp[6] = t; |
566 |
t = wp[2]; wp[2] = wp[5]; wp[5] = t; |
567 |
t = wp[3]; wp[3] = wp[4]; wp[4] = t; |
568 |
wp += 8; |
569 |
570 |
571 |
572 |
573 |
static int |
574 |
getcascii( /* get an ascii color value from stream(s) */ |
575 |
COLOR col |
576 |
577 |
578 |
double vd[3]; |
579 |
580 |
if (fin2 == NULL) { |
581 |
if (fscanf(fin, "%lf %lf %lf", &vd[0], &vd[1], &vd[2]) != 3) |
582 |
return(-1); |
583 |
} else { |
584 |
if (fscanf(fin, "%lf", &vd[0]) != 1 || |
585 |
fscanf(fin2, "%lf", &vd[1]) != 1 || |
586 |
fscanf(fin3, "%lf", &vd[2]) != 1) |
587 |
return(-1); |
588 |
589 |
setcolor(col, vd[rord[RED]], vd[rord[GRN]], vd[rord[BLU]]); |
590 |
return(0); |
591 |
592 |
593 |
594 |
static int |
595 |
getcdouble( /* get a double color value from stream(s) */ |
596 |
COLOR col |
597 |
598 |
599 |
double vd[3]; |
600 |
601 |
602 |
if (fread((char *)vd, sizeof(double), 3, fin) != 3) |
603 |
return(-1); |
604 |
} else { |
605 |
if (fread((char *)vd, sizeof(double), 1, fin) != 1 || |
606 |
fread((char *)(vd+1), sizeof(double), 1, fin2) != 1 || |
607 |
fread((char *)(vd+2), sizeof(double), 1, fin3) != 1) |
608 |
return(-1); |
609 |
610 |
if (swapbytes) |
611 |
swap64((char *)vd, 3); |
612 |
613 |
return(0); |
614 |
615 |
616 |
617 |
static int |
618 |
getcfloat( /* get a float color value from stream(s) */ |
619 |
COLOR col |
620 |
621 |
622 |
float vf[3]; |
623 |
624 |
625 |
if (fread((char *)vf, sizeof(float), 3, fin) != 3) |
626 |
return(-1); |
627 |
} else { |
628 |
if (fread((char *)vf, sizeof(float), 1, fin) != 1 || |
629 |
fread((char *)(vf+1), sizeof(float), 1, fin2) != 1 || |
630 |
fread((char *)(vf+2), sizeof(float), 1, fin3) != 1) |
631 |
return(-1); |
632 |
633 |
if (swapbytes) |
634 |
swap32((uint32 *)vf, 3); |
635 |
setcolor(col, vf[rord[RED]], vf[rord[GRN]], vf[rord[BLU]]); |
636 |
return(0); |
637 |
638 |
639 |
640 |
static int |
641 |
getcint( /* get an int color value from stream(s) */ |
642 |
COLOR col |
643 |
644 |
645 |
int vi[3]; |
646 |
647 |
648 |
if (fscanf(fin, "%d %d %d", &vi[0], &vi[1], &vi[2]) != 3) |
649 |
return(-1); |
650 |
} else { |
651 |
if (fscanf(fin, "%d", &vi[0]) != 1 || |
652 |
fscanf(fin2, "%d", &vi[1]) != 1 || |
653 |
fscanf(fin3, "%d", &vi[2]) != 1) |
654 |
return(-1); |
655 |
656 |
setcolor(col, (vi[rord[RED]]+.5)/256., |
657 |
(vi[rord[GRN]]+.5)/256., (vi[rord[BLU]]+.5)/256.); |
658 |
return(0); |
659 |
660 |
661 |
662 |
static int |
663 |
getcbyte( /* get a byte color value from stream(s) */ |
664 |
COLOR col |
665 |
666 |
667 |
BYTE vb[3]; |
668 |
669 |
670 |
if (fread((char *)vb, sizeof(BYTE), 3, fin) != 3) |
671 |
return(-1); |
672 |
} else { |
673 |
if (fread((char *)vb, sizeof(BYTE), 1, fin) != 1 || |
674 |
fread((char *)(vb+1), sizeof(BYTE), 1, fin2) != 1 || |
675 |
fread((char *)(vb+2), sizeof(BYTE), 1, fin3) != 1) |
676 |
return(-1); |
677 |
678 |
setcolor(col, (vb[rord[RED]]+.5)/256., |
679 |
(vb[rord[GRN]]+.5)/256., (vb[rord[BLU]]+.5)/256.); |
680 |
return(0); |
681 |
682 |
683 |
684 |
static int |
685 |
getcword( /* get a 16-bit color value from stream(s) */ |
686 |
COLOR col |
687 |
688 |
689 |
uint16 vw[3]; |
690 |
691 |
692 |
if (fread((char *)vw, sizeof(uint16), 3, fin) != 3) |
693 |
return(-1); |
694 |
} else { |
695 |
if (fread((char *)vw, sizeof(uint16), 1, fin) != 1 || |
696 |
fread((char *)(vw+1), sizeof(uint16), 1, fin2) != 1 || |
697 |
fread((char *)(vw+2), sizeof(uint16), 1, fin3) != 1) |
698 |
return(-1); |
699 |
700 |
if (swapbytes) |
701 |
swap16(vw, 3); |
702 |
setcolor(col, (vw[rord[RED]]+.5)/65536., |
703 |
(vw[rord[GRN]]+.5)/65536., (vw[rord[BLU]]+.5)/65536.); |
704 |
return(0); |
705 |
706 |
707 |
708 |
static int |
709 |
getbascii( /* get an ascii brightness value from fin */ |
710 |
COLOR col |
711 |
712 |
713 |
double vd; |
714 |
715 |
if (fscanf(fin, "%lf", &vd) != 1) |
716 |
return(-1); |
717 |
setcolor(col, vd, vd, vd); |
718 |
return(0); |
719 |
720 |
721 |
722 |
static int |
723 |
getbdouble( /* get a double brightness value from fin */ |
724 |
COLOR col |
725 |
726 |
727 |
double vd; |
728 |
729 |
if (fread((char *)&vd, sizeof(double), 1, fin) != 1) |
730 |
return(-1); |
731 |
if (swapbytes) |
732 |
swap64((char *)&vd, 1); |
733 |
734 |
return(0); |
735 |
736 |
737 |
738 |
static int |
739 |
getbfloat( /* get a float brightness value from fin */ |
740 |
COLOR col |
741 |
742 |
743 |
float vf; |
744 |
745 |
if (fread((char *)&vf, sizeof(float), 1, fin) != 1) |
746 |
return(-1); |
747 |
if (swapbytes) |
748 |
swap32((uint32 *)&vf, 1); |
749 |
setcolor(col, vf, vf, vf); |
750 |
return(0); |
751 |
752 |
753 |
754 |
static int |
755 |
getbint( /* get an int brightness value from fin */ |
756 |
COLOR col |
757 |
758 |
759 |
int vi; |
760 |
double d; |
761 |
762 |
if (fscanf(fin, "%d", &vi) != 1) |
763 |
return(-1); |
764 |
d = (vi+.5)/256.; |
765 |
setcolor(col, d, d, d); |
766 |
return(0); |
767 |
768 |
769 |
770 |
static int |
771 |
getbbyte( /* get a byte brightness value from fin */ |
772 |
COLOR col |
773 |
774 |
775 |
BYTE vb; |
776 |
double d; |
777 |
778 |
if (fread((char *)&vb, sizeof(BYTE), 1, fin) != 1) |
779 |
return(-1); |
780 |
d = (vb+.5)/256.; |
781 |
782 |
return(0); |
783 |
784 |
785 |
786 |
static int |
787 |
getbword( /* get a 16-bit brightness value from fin */ |
788 |
COLOR col |
789 |
790 |
791 |
uint16 vw; |
792 |
double d; |
793 |
794 |
if (fread((char *)&vw, sizeof(uint16), 1, fin) != 1) |
795 |
return(-1); |
796 |
if (swapbytes) |
797 |
swap16(&vw, 1); |
798 |
d = (vw+.5)/65536.; |
799 |
800 |
return(0); |
801 |
802 |
803 |
804 |
static int |
805 |
putcascii( /* put an ascii color to stdout */ |
806 |
COLOR col |
807 |
808 |
809 |
fprintf(stdout, "%15.3e %15.3e %15.3e\n", |
810 |
colval(col,ord[0]), |
811 |
colval(col,ord[1]), |
812 |
colval(col,ord[2])); |
813 |
814 |
return(ferror(stdout) ? -1 : 0); |
815 |
816 |
817 |
818 |
static int |
819 |
putcfloat( /* put a float color to stdout */ |
820 |
COLOR col |
821 |
822 |
823 |
float vf[3]; |
824 |
825 |
vf[0] = colval(col,ord[0]); |
826 |
vf[1] = colval(col,ord[1]); |
827 |
vf[2] = colval(col,ord[2]); |
828 |
if (swapbytes) |
829 |
830 |
fwrite((char *)vf, sizeof(float), 3, stdout); |
831 |
832 |
833 |
834 |
835 |
836 |
static int |
837 |
putcdouble( /* put a double color to stdout */ |
838 |
COLOR col |
839 |
840 |
841 |
double vd[3]; |
842 |
843 |
vd[0] = colval(col,ord[0]); |
844 |
vd[1] = colval(col,ord[1]); |
845 |
vd[2] = colval(col,ord[2]); |
846 |
if (swapbytes) |
847 |
848 |
fwrite((char *)vd, sizeof(double), 3, stdout); |
849 |
850 |
851 |
852 |
853 |
854 |
static int |
855 |
putcint( /* put an int color to stdout */ |
856 |
COLOR col |
857 |
858 |
859 |
fprintf(stdout, "%d %d %d\n", |
860 |
(int)(colval(col,ord[0])*256.), |
861 |
(int)(colval(col,ord[1])*256.), |
862 |
(int)(colval(col,ord[2])*256.)); |
863 |
864 |
865 |
866 |
867 |
868 |
static int |
869 |
putcbyte( /* put a byte color to stdout */ |
870 |
COLOR col |
871 |
872 |
873 |
long i; |
874 |
BYTE vb[3]; |
875 |
876 |
i = colval(col,ord[0])*256.; |
877 |
vb[0] = min(i,255); |
878 |
i = colval(col,ord[1])*256.; |
879 |
vb[1] = min(i,255); |
880 |
i = colval(col,ord[2])*256.; |
881 |
vb[2] = min(i,255); |
882 |
fwrite((char *)vb, sizeof(BYTE), 3, stdout); |
883 |
884 |
885 |
886 |
887 |
888 |
static int |
889 |
putcword( /* put a 16-bit color to stdout */ |
890 |
COLOR col |
891 |
892 |
893 |
long i; |
894 |
uint16 vw[3]; |
895 |
896 |
i = colval(col,ord[0])*65536.; |
897 |
vw[0] = min(i,65535); |
898 |
i = colval(col,ord[1])*65536.; |
899 |
vw[1] = min(i,65535); |
900 |
i = colval(col,ord[2])*65536.; |
901 |
vw[2] = min(i,65535); |
902 |
if (swapbytes) |
903 |
swap16(vw, 3); |
904 |
fwrite((char *)vw, sizeof(uint16), 3, stdout); |
905 |
906 |
907 |
908 |
909 |
910 |
static int |
911 |
putbascii( /* put an ascii brightness to stdout */ |
912 |
COLOR col |
913 |
914 |
915 |
fprintf(stdout, "%15.3e\n", (*mybright)(col)); |
916 |
917 |
918 |
919 |
920 |
921 |
static int |
922 |
putbfloat( /* put a float brightness to stdout */ |
923 |
COLOR col |
924 |
925 |
926 |
float vf; |
927 |
928 |
vf = (*mybright)(col); |
929 |
if (swapbytes) |
930 |
931 |
fwrite((char *)&vf, sizeof(float), 1, stdout); |
932 |
933 |
934 |
935 |
936 |
937 |
static int |
938 |
putbdouble( /* put a double brightness to stdout */ |
939 |
COLOR col |
940 |
941 |
942 |
double vd; |
943 |
944 |
vd = (*mybright)(col); |
945 |
if (swapbytes) |
946 |
947 |
fwrite((char *)&vd, sizeof(double), 1, stdout); |
948 |
949 |
950 |
951 |
952 |
953 |
static int |
954 |
putbint( /* put an int brightness to stdout */ |
955 |
COLOR col |
956 |
957 |
958 |
fprintf(stdout, "%d\n", (int)((*mybright)(col)*256.)); |
959 |
960 |
961 |
962 |
963 |
964 |
static int |
965 |
putbbyte( /* put a byte brightness to stdout */ |
966 |
COLOR col |
967 |
968 |
969 |
register int i; |
970 |
BYTE vb; |
971 |
972 |
i = (*mybright)(col)*256.; |
973 |
vb = min(i,255); |
974 |
fwrite((char *)&vb, sizeof(BYTE), 1, stdout); |
975 |
976 |
977 |
978 |
979 |
980 |
static int |
981 |
putbword( /* put a 16-bit brightness to stdout */ |
982 |
COLOR col |
983 |
984 |
985 |
long i; |
986 |
uint16 vw; |
987 |
988 |
i = (*mybright)(col)*65536.; |
989 |
vw = min(i,65535); |
990 |
if (swapbytes) |
991 |
swap16(&vw, 1); |
992 |
fwrite((char *)&vw, sizeof(uint16), 1, stdout); |
993 |
994 |
995 |
996 |
997 |
998 |
static int |
999 |
putpascii( /* put an ascii primary to stdout */ |
1000 |
COLOR col |
1001 |
1002 |
1003 |
fprintf(stdout, "%15.3e\n", colval(col,putprim)); |
1004 |
1005 |
1006 |
1007 |
1008 |
1009 |
static int |
1010 |
putpfloat( /* put a float primary to stdout */ |
1011 |
COLOR col |
1012 |
1013 |
1014 |
float vf; |
1015 |
1016 |
vf = colval(col,putprim); |
1017 |
if (swapbytes) |
1018 |
1019 |
1020 |
1021 |
1022 |
1023 |
1024 |
1025 |
static int |
1026 |
putpdouble( /* put a double primary to stdout */ |
1027 |
COLOR col |
1028 |
1029 |
1030 |
double vd; |
1031 |
1032 |
vd = colval(col,putprim); |
1033 |
if (swapbytes) |
1034 |
1035 |
1036 |
1037 |
1038 |
1039 |
1040 |
1041 |
static int |
1042 |
putpint( /* put an int primary to stdout */ |
1043 |
COLOR col |
1044 |
1045 |
1046 |
fprintf(stdout, "%d\n", (int)(colval(col,putprim)*256.)); |
1047 |
1048 |
1049 |
1050 |
1051 |
1052 |
static int |
1053 |
putpbyte( /* put a byte primary to stdout */ |
1054 |
COLOR col |
1055 |
1056 |
1057 |
long i; |
1058 |
BYTE vb; |
1059 |
1060 |
i = colval(col,putprim)*256.; |
1061 |
vb = min(i,255); |
1062 |
1063 |
1064 |
1065 |
1066 |
1067 |
1068 |
static int |
1069 |
putpword( /* put a 16-bit primary to stdout */ |
1070 |
COLOR col |
1071 |
1072 |
1073 |
long i; |
1074 |
uint16 vw; |
1075 |
1076 |
i = colval(col,putprim)*65536.; |
1077 |
1078 |
if (swapbytes) |
1079 |
swap16(&vw, 1); |
1080 |
1081 |
1082 |
1083 |
1084 |
1085 |
1086 |
static void |
1087 |
set_io(void) /* set put and get functions */ |
1088 |
1089 |
switch (format) { |
1090 |
1091 |
if (putprim == BRIGHT) { |
1092 |
getval = getbascii; |
1093 |
putval = putbascii; |
1094 |
} else if (putprim != ALL) { |
1095 |
1096 |
putval = putpascii; |
1097 |
} else { |
1098 |
getval = getcascii; |
1099 |
putval = putcascii; |
1100 |
if (reverse && !interleave) { |
1101 |
fprintf(stderr, |
1102 |
"%s: ASCII input files must be interleaved\n", |
1103 |
progname); |
1104 |
quit(1); |
1105 |
1106 |
1107 |
return; |
1108 |
case 'f': /* binary float */ |
1109 |
1110 |
getval = getbfloat; |
1111 |
putval = putbfloat; |
1112 |
1113 |
1114 |
putval = putpfloat; |
1115 |
} else { |
1116 |
getval = getcfloat; |
1117 |
putval = putcfloat; |
1118 |
1119 |
if (fin2 == NULL) |
1120 |
goto namerr; |
1121 |
if (fseek(fin2, |
1122 |
(long)sizeof(float)*picres.xr*picres.yr, 1)) |
1123 |
goto seekerr; |
1124 |
if (fseek(fin3, |
1125 |
(long)sizeof(float)*2*picres.xr*picres.yr, 1)) |
1126 |
goto seekerr; |
1127 |
1128 |
1129 |
return; |
1130 |
case 'd': /* binary double */ |
1131 |
1132 |
getval = getbdouble; |
1133 |
putval = putbdouble; |
1134 |
1135 |
1136 |
putval = putpdouble; |
1137 |
} else { |
1138 |
getval = getcdouble; |
1139 |
putval = putcdouble; |
1140 |
1141 |
if (fin2 == NULL) |
1142 |
goto namerr; |
1143 |
if (fseek(fin2, |
1144 |
(long)sizeof(double)*picres.xr*picres.yr, 1)) |
1145 |
goto seekerr; |
1146 |
if (fseek(fin3, |
1147 |
(long)sizeof(double)*2*picres.xr*picres.yr, 1)) |
1148 |
goto seekerr; |
1149 |
1150 |
1151 |
return; |
1152 |
1153 |
1154 |
getval = getbint; |
1155 |
putval = putbint; |
1156 |
1157 |
getval = getbint; |
1158 |
putval = putpint; |
1159 |
} else { |
1160 |
getval = getcint; |
1161 |
putval = putcint; |
1162 |
1163 |
fprintf(stderr, |
1164 |
"%s: integer input files must be interleaved\n", |
1165 |
progname); |
1166 |
quit(1); |
1167 |
1168 |
1169 |
return; |
1170 |
1171 |
1172 |
getval = getbbyte; |
1173 |
putval = putbbyte; |
1174 |
1175 |
1176 |
putval = putpbyte; |
1177 |
} else { |
1178 |
getval = getcbyte; |
1179 |
putval = putcbyte; |
1180 |
1181 |
if (fin2 == NULL) |
1182 |
goto namerr; |
1183 |
if (fseek(fin2, |
1184 |
(long)sizeof(BYTE)*picres.xr*picres.yr, 1)) |
1185 |
goto seekerr; |
1186 |
if (fseek(fin3, |
1187 |
(long)sizeof(BYTE)*2*picres.xr*picres.yr, 1)) |
1188 |
goto seekerr; |
1189 |
1190 |
1191 |
return; |
1192 |
1193 |
1194 |
getval = getbword; |
1195 |
putval = putbword; |
1196 |
1197 |
1198 |
putval = putpword; |
1199 |
} else { |
1200 |
getval = getcword; |
1201 |
putval = putcword; |
1202 |
1203 |
if (fin2 == NULL) |
1204 |
goto namerr; |
1205 |
if (fseek(fin2, |
1206 |
(long)sizeof(uint16)*picres.xr*picres.yr, 1)) |
1207 |
goto seekerr; |
1208 |
if (fseek(fin3, |
1209 |
(long)sizeof(uint16)*2*picres.xr*picres.yr, 1)) |
1210 |
goto seekerr; |
1211 |
1212 |
1213 |
return; |
1214 |
1215 |
/* badopt: */ /* label not used */ |
1216 |
fprintf(stderr, "%s: botched file type\n", progname); |
1217 |
quit(1); |
1218 |
namerr: |
1219 |
fprintf(stderr, "%s: non-interleaved file(s) must be named\n", |
1220 |
progname); |
1221 |
quit(1); |
1222 |
seekerr: |
1223 |
fprintf(stderr, "%s: cannot seek on interleaved input file\n", |
1224 |
progname); |
1225 |
quit(1); |
1226 |
