1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: pvalue.c,v 2.42 2022/03/10 03:25:54 greg Exp $"; |
3 |
#endif |
4 |
5 |
* pvalue.c - program to print pixel values. |
6 |
7 |
* 4/23/86 |
8 |
9 |
10 |
#include "platform.h" |
11 |
#include "standard.h" |
12 |
#include "color.h" |
13 |
#include "resolu.h" |
14 |
#include "view.h" |
15 |
16 |
#define min(a,b) ((a)<(b)?(a):(b)) |
17 |
18 |
/* what to put out (also RED, GRN, BLU) */ |
19 |
#define ALL 3 |
20 |
#define BRIGHT 4 |
21 |
22 |
RESOLU picres; /* resolution of picture */ |
23 |
int uniq = 0; /* print only unique values? */ |
24 |
int doexposure = 0; /* exposure change? (>100 to print) */ |
25 |
int dataonly = 0; /* data only format? */ |
26 |
int putprim = ALL; /* what to put out */ |
27 |
int reverse = 0; /* reverse conversion? */ |
28 |
int format = 'a'; /* input/output format */ |
29 |
const char *fmtid = "ascii"; /* format identifier for header */ |
30 |
int header = 1; /* do header? */ |
31 |
long skipbytes = 0; /* skip bytes in input? */ |
32 |
int swapbytes = 0; /* swap bytes? */ |
33 |
int interleave = 1; /* file is interleaved? */ |
34 |
int resolution = 1; /* put/get resolution string? */ |
35 |
int original = 0; /* convert to original values? */ |
36 |
int wrongformat = 0; /* wrong input format? */ |
37 |
double gamcor = 1.0; /* gamma correction */ |
38 |
39 |
RGBPRIMP outprims = stdprims; /* output primaries for reverse conversion */ |
40 |
RGBPRIMS myprims; |
41 |
42 |
int ord[3] = {RED, GRN, BLU}; /* RGB ordering */ |
43 |
int rord[4]; /* reverse ordering */ |
44 |
45 |
COLOR exposure = WHTCOLOR; |
46 |
47 |
char *progname; |
48 |
49 |
FILE *fin; |
50 |
FILE *fin2 = NULL, *fin3 = NULL; /* for other color channels */ |
51 |
52 |
53 |
typedef int getfunc_t(COLOR col); |
54 |
typedef int putfunc_t(COLOR col); |
55 |
typedef double brightfunc_t(COLOR col); |
56 |
57 |
getfunc_t *getval; |
58 |
putfunc_t *putval; |
59 |
brightfunc_t *mybright; |
60 |
61 |
static gethfunc checkhead; |
62 |
static brightfunc_t rgb_bright, xyz_bright; |
63 |
static getfunc_t getbascii, getbint, getbdouble, getbfloat, getbbyte, getbword; |
64 |
static getfunc_t getcascii, getcint, getcdouble, getcfloat, getcbyte, getcword; |
65 |
static putfunc_t putbascii, putbint, putbdouble, putbfloat, putbbyte, putbword; |
66 |
static putfunc_t putcascii, putcint, putcdouble, putcfloat, putcbyte, putcword; |
67 |
static putfunc_t putpascii, putpint, putpdouble, putpfloat, putpbyte, putpword; |
68 |
69 |
static int IDformat(const char *s); |
70 |
static void set_io(void); |
71 |
static void pixtoval(void); |
72 |
static void valtopix(void); |
73 |
74 |
75 |
static double |
76 |
rgb_bright( |
77 |
COLOR clr |
78 |
79 |
80 |
return(bright(clr)); |
81 |
82 |
83 |
static double |
84 |
xyz_bright( |
85 |
COLOR clr |
86 |
87 |
88 |
return(clr[CIEY]); |
89 |
90 |
91 |
int |
92 |
main( |
93 |
int argc, |
94 |
char **argv |
95 |
96 |
97 |
const char *inpmode = "r"; |
98 |
double d, expval = 1.0; |
99 |
int i; |
100 |
101 |
progname = argv[0]; |
102 |
mybright = &rgb_bright; /* default */ |
103 |
picres.rt = PIXSTANDARD; |
104 |
105 |
for (i = 1; i < argc; i++) |
106 |
if (argv[i][0] == '-' || argv[i][0] == '+') |
107 |
switch (argv[i][1]) { |
108 |
case 'h': /* header */ |
109 |
header = argv[i][0] == '+'; |
110 |
break; |
111 |
case 'H': /* resolution string */ |
112 |
resolution = argv[i][0] == '+'; |
113 |
break; |
114 |
case 's': /* skip bytes in header */ |
115 |
skipbytes = atol(argv[++i]); |
116 |
break; |
117 |
case 'u': /* unique values */ |
118 |
uniq = argv[i][0] == '-'; |
119 |
break; |
120 |
case 'o': /* original values */ |
121 |
original = argv[i][0] == '-'; |
122 |
break; |
123 |
case 'O': /* original watts/sr/m^2 */ |
124 |
original = -(argv[i][0] == '-'); |
125 |
break; |
126 |
case 'g': /* gamma correction */ |
127 |
gamcor = atof(argv[i+1]); |
128 |
if (argv[i][0] == '+') |
129 |
gamcor = 1.0/gamcor; |
130 |
i++; |
131 |
break; |
132 |
case 'e': /* exposure correction */ |
133 |
d = atof(argv[i+1]); |
134 |
if (argv[i+1][0] == '-' || argv[i+1][0] == '+') |
135 |
d = pow(2.0, d); |
136 |
if (argv[i][0] == '-') |
137 |
expval *= d; |
138 |
scalecolor(exposure, d); |
139 |
doexposure++; |
140 |
i++; |
141 |
break; |
142 |
case 'R': /* reverse byte sequence */ |
143 |
if (argv[i][0] == '-') { |
144 |
ord[0]=BLU; ord[1]=GRN; ord[2]=RED; |
145 |
} else { |
146 |
ord[0]=RED; ord[1]=GRN; ord[2]=BLU; |
147 |
148 |
break; |
149 |
case 'r': /* reverse conversion */ |
150 |
reverse = argv[i][0] == '-'; |
151 |
break; |
152 |
case 'n': /* non-interleaved RGB */ |
153 |
interleave = argv[i][0] == '+'; |
154 |
break; |
155 |
case 'b': /* brightness values */ |
156 |
putprim = argv[i][0] == '-' ? BRIGHT : ALL; |
157 |
break; |
158 |
case 'p': /* primary controls */ |
159 |
switch (argv[i][2]) { |
160 |
/* these two options affect -r conversion */ |
161 |
case '\0': |
162 |
myprims[RED][CIEX] = atof(argv[++i]); |
163 |
myprims[RED][CIEY] = atof(argv[++i]); |
164 |
myprims[GRN][CIEX] = atof(argv[++i]); |
165 |
myprims[GRN][CIEY] = atof(argv[++i]); |
166 |
myprims[BLU][CIEX] = atof(argv[++i]); |
167 |
myprims[BLU][CIEY] = atof(argv[++i]); |
168 |
myprims[WHT][CIEX] = atof(argv[++i]); |
169 |
myprims[WHT][CIEY] = atof(argv[++i]); |
170 |
outprims = myprims; |
171 |
break; |
172 |
case 'x': case 'X': outprims = NULL; break; |
173 |
/* the following options affect +r only */ |
174 |
case 'r': case 'R': putprim = RED; break; |
175 |
case 'g': case 'G': putprim = GRN; break; |
176 |
case 'b': case 'B': putprim = BLU; break; |
177 |
default: goto unkopt; |
178 |
179 |
break; |
180 |
case 'd': /* data only (no indices) */ |
181 |
dataonly = (argv[i][0] == '-'); |
182 |
183 |
case '\0': |
184 |
case 'a': /* ascii */ |
185 |
format = 'a'; |
186 |
fmtid = "ascii"; |
187 |
break; |
188 |
case 'i': /* integer */ |
189 |
format = 'i'; |
190 |
fmtid = "ascii"; |
191 |
break; |
192 |
case 'b': /* byte */ |
193 |
dataonly = 1; |
194 |
format = 'b'; |
195 |
fmtid = "byte"; |
196 |
break; |
197 |
case 'W': /* 16-bit swapped */ |
198 |
swapbytes = 1; |
199 |
case 'w': /* 16-bit */ |
200 |
dataonly = 1; |
201 |
format = 'w'; |
202 |
fmtid = "16-bit"; |
203 |
break; |
204 |
case 'F': /* swapped floats */ |
205 |
swapbytes = 1; |
206 |
case 'f': /* float */ |
207 |
dataonly = 1; |
208 |
format = 'f'; |
209 |
fmtid = "float"; |
210 |
break; |
211 |
case 'D': /* swapped doubles */ |
212 |
swapbytes = 1; |
213 |
case 'd': /* double */ |
214 |
dataonly = 1; |
215 |
format = 'd'; |
216 |
fmtid = "double"; |
217 |
break; |
218 |
default: |
219 |
goto unkopt; |
220 |
221 |
break; |
222 |
case 'x': /* x resolution */ |
223 |
case 'X': |
224 |
resolution = 0; |
225 |
226 |
picres.rt |= XDECR; |
227 |
else |
228 |
picres.rt &= ~XDECR; |
229 |
if (picres.yr == 0) |
230 |
picres.rt &= ~YMAJOR; |
231 |
picres.xr = atoi(argv[++i]); |
232 |
break; |
233 |
case 'y': /* y resolution */ |
234 |
case 'Y': |
235 |
resolution = 0; |
236 |
237 |
picres.rt |= YDECR; |
238 |
else |
239 |
picres.rt &= ~YDECR; |
240 |
if (picres.xr == 0) |
241 |
picres.rt |= YMAJOR; |
242 |
picres.yr = atoi(argv[++i]); |
243 |
break; |
244 |
default: |
245 |
unkopt: |
246 |
fprintf(stderr, "%s: unknown option: %s\n", |
247 |
progname, argv[i]); |
248 |
quit(1); |
249 |
break; |
250 |
251 |
else |
252 |
break; |
253 |
/* recognize special formats */ |
254 |
if (dataonly & (format == 'b')) { |
255 |
if (putprim == ALL) |
256 |
fmtid = "24-bit_rgb"; |
257 |
else |
258 |
fmtid = "8-bit_grey"; |
259 |
260 |
if (dataonly & (format == 'w')) { |
261 |
262 |
fmtid = "48-bit_rgb"; |
263 |
else |
264 |
fmtid = "16-bit_grey"; |
265 |
266 |
if (!reverse | ((format != 'a') & (format != 'i'))) |
267 |
inpmode = "rb"; |
268 |
/* assign reverse ordering */ |
269 |
rord[ord[0]] = 0; |
270 |
rord[ord[1]] = 1; |
271 |
rord[ord[2]] = 2; |
272 |
/* get input */ |
273 |
if (i == argc) { |
274 |
long n = skipbytes; |
275 |
if (inpmode[1] == 'b') |
276 |
SET_FILE_BINARY(stdin); |
277 |
while (n-- > 0) |
278 |
if (getchar() == EOF) { |
279 |
fprintf(stderr, |
280 |
"%s: cannot skip %ld bytes on standard input\n", |
281 |
progname, skipbytes); |
282 |
quit(1); |
283 |
284 |
fin = stdin; |
285 |
} else if (i < argc) { |
286 |
if ((fin = fopen(argv[i], inpmode)) == NULL) { |
287 |
fprintf(stderr, "%s: can't open file \"%s\"\n", |
288 |
289 |
quit(1); |
290 |
291 |
if (reverse & (putprim != BRIGHT ) & (i == argc-3)) { |
292 |
if ((fin2 = fopen(argv[i+1], inpmode)) == NULL) { |
293 |
294 |
progname, argv[i+1]); |
295 |
quit(1); |
296 |
297 |
if ((fin3 = fopen(argv[i+2], inpmode)) == NULL) { |
298 |
299 |
progname, argv[i+2]); |
300 |
quit(1); |
301 |
302 |
interleave = -1; |
303 |
} else if (i != argc-1) |
304 |
fin = NULL; |
305 |
if (reverse & (putprim != BRIGHT) & !interleave) { |
306 |
fin2 = fopen(argv[i], inpmode); |
307 |
fin3 = fopen(argv[i], inpmode); |
308 |
309 |
if (skipbytes && (fseek(fin, skipbytes, SEEK_SET) || (fin2 != NULL && |
310 |
fseek(fin2, skipbytes, SEEK_SET) | |
311 |
fseek(fin3, skipbytes, SEEK_SET)))) { |
312 |
fprintf(stderr, "%s: cannot skip %ld bytes on input\n", |
313 |
314 |
quit(1); |
315 |
316 |
317 |
if (fin == NULL) { |
318 |
fprintf(stderr, "%s: bad # file arguments\n", progname); |
319 |
quit(1); |
320 |
321 |
if (reverse) { |
322 |
SET_FILE_BINARY(stdout); |
323 |
/* get header */ |
324 |
if (header) { |
325 |
getheader(fin, checkhead, stdout); |
326 |
if (wrongformat) { |
327 |
fprintf(stderr, "%s: wrong input format (expected %s)\n", |
328 |
progname, fmtid); |
329 |
quit(1); |
330 |
331 |
if (fin2 != NULL) { |
332 |
getheader(fin2, NULL, NULL); |
333 |
getheader(fin3, NULL, NULL); |
334 |
335 |
resolution &= (picres.xr <= 0) | (picres.yr <= 0); |
336 |
} else { |
337 |
newheader("RADIANCE", stdout); |
338 |
339 |
/* get resolution */ |
340 |
if ((resolution && !fgetsresolu(&picres, fin)) || |
341 |
(picres.xr <= 0) | (picres.yr <= 0)) { |
342 |
fprintf(stderr, "%s: missing resolution\n", progname); |
343 |
quit(1); |
344 |
345 |
if (resolution && fin2 != NULL) { |
346 |
RESOLU pres2; |
347 |
if (!fgetsresolu(&pres2, fin2) || |
348 |
(pres2.rt != picres.rt) | |
349 |
(pres2.xr != picres.xr) | |
350 |
(pres2.yr != picres.yr) || |
351 |
!fgetsresolu(&pres2, fin3) || |
352 |
353 |
354 |
(pres2.yr != picres.yr)) { |
355 |
fprintf(stderr, "%s: resolution mismatch\n", |
356 |
progname); |
357 |
quit(1); |
358 |
359 |
360 |
/* add to header */ |
361 |
printargs(i, argv, stdout); |
362 |
if ((expval < .99) | (expval > 1.01)) |
363 |
fputexpos(expval, stdout); |
364 |
if (NCSAMP == 1) { |
365 |
366 |
putprim = BRIGHT; |
367 |
} else { |
368 |
if (NCSAMP != 3) { |
369 |
fprintf(stderr, "%s: input NCOMP must be 1 or 3\n", |
370 |
progname); |
371 |
quit(1); |
372 |
373 |
if (putprim != ALL) { |
374 |
fprintf(stderr, "%s: NCOMP mismatch\n", progname); |
375 |
quit(1); |
376 |
377 |
378 |
if (outprims != NULL) { |
379 |
if (outprims != stdprims) |
380 |
fputprims(outprims, stdout); |
381 |
fputformat(COLRFMT, stdout); |
382 |
} else { /* XYZ data */ |
383 |
if (original < 0) { |
384 |
scalecolor(exposure, WHTEFFICACY); |
385 |
doexposure++; |
386 |
387 |
fputformat(CIEFMT, stdout); |
388 |
389 |
putchar('\n'); |
390 |
fputsresolu(&picres, stdout); /* always put resolution */ |
391 |
valtopix(); |
392 |
} else { |
393 |
if ((format != 'a') & (format != 'i')) |
394 |
395 |
/* get header */ |
396 |
397 |
picres.xr = picres.yr = 0; |
398 |
getheader(fin, checkhead, header ? stdout : (FILE *)NULL); |
399 |
400 |
fprintf(stderr, |
401 |
"%s: input not a Radiance RGBE picture\n", |
402 |
progname); |
403 |
quit(1); |
404 |
405 |
if ((picres.xr <= 0) | (picres.yr <= 0) && |
406 |
!fgetsresolu(&picres, fin)) { |
407 |
408 |
quit(1); |
409 |
410 |
if ((original < 0) & (mybright == &xyz_bright)) { |
411 |
scalecolor(exposure, 1./WHTEFFICACY); |
412 |
doexposure++; |
413 |
414 |
if (header) { |
415 |
416 |
printf("%s%c\n", NCOMPSTR, "13"[putprim==ALL]); |
417 |
if (dataonly && !resolution & !uniq) |
418 |
printf("NCOLS=%d\nNROWS=%d\n", scanlen(&picres), |
419 |
numscans(&picres)); |
420 |
421 |
422 |
if (swapbytes) { |
423 |
if (nativebigendian()) |
424 |
puts("BigEndian=0"); |
425 |
else |
426 |
puts("BigEndian=1"); |
427 |
} else if ((format != 'a') & (format != 'i') & |
428 |
(format != 'b')) |
429 |
fputendian(stdout); |
430 |
fputformat(fmtid, stdout); |
431 |
putchar('\n'); |
432 |
433 |
if (resolution) /* put resolution */ |
434 |
fputsresolu(&picres, stdout); |
435 |
pixtoval(); |
436 |
437 |
438 |
quit(0); |
439 |
return 0; /* pro forma return */ |
440 |
441 |
442 |
443 |
static int |
444 |
IDformat(const char *s) |
445 |
446 |
if (!s || !*s) return(0); |
447 |
if (!strcmp(s, "ascii")) return('a'); |
448 |
if (!strcmp(s, "float")) return('f'); |
449 |
if (!strcmp(s, "double")) return('d'); |
450 |
if (!strcmp(s, "byte")) return('b'); |
451 |
if (!strcmp(s, "16-bit")) return('w'); |
452 |
return(0); |
453 |
454 |
455 |
456 |
static int |
457 |
checkhead( /* deal with line from header */ |
458 |
char *line, |
459 |
void *p |
460 |
461 |
462 |
static char fmt[MAXFMTLEN]; |
463 |
FILE *fout = (FILE *)p; |
464 |
double d; |
465 |
COLOR ctmp; |
466 |
int rv; |
467 |
468 |
if (formatval(fmt, line)) { |
469 |
if (reverse) { |
470 |
if (format == 'a') { |
471 |
format = IDformat(fmt); |
472 |
if (format) |
473 |
fmtid = fmt; |
474 |
else |
475 |
wrongformat = 1; |
476 |
} else |
477 |
wrongformat = strcmp(fmt, fmtid); |
478 |
} else if (!strcmp(fmt, CIEFMT)) |
479 |
mybright = &xyz_bright; |
480 |
else if (!strcmp(fmt, COLRFMT) || !strcmp(fmt, SPECFMT)) |
481 |
mybright = &rgb_bright; |
482 |
else |
483 |
wrongformat = 1; |
484 |
return(1); |
485 |
486 |
if (!strncmp(line,"NROWS=",6)) { |
487 |
picres.yr = atoi(line+6); |
488 |
return(1); |
489 |
490 |
if (!strncmp(line,"NCOLS=",6)) { |
491 |
picres.xr = atoi(line+6); |
492 |
return(1); |
493 |
494 |
if (isncomp(line)) { |
495 |
NCSAMP = ncompval(line); |
496 |
dataonly |= reverse; /* pretty safe assumption */ |
497 |
return(1); |
498 |
499 |
if (iswlsplit(line)) { |
500 |
wlsplitval(WLPART, line); |
501 |
return(1); |
502 |
503 |
if (original && isexpos(line)) { |
504 |
d = 1.0/exposval(line); |
505 |
506 |
doexposure++; |
507 |
return(1); |
508 |
509 |
if (original && iscolcor(line)) { |
510 |
colcorval(ctmp, line); |
511 |
setcolor(exposure, colval(exposure,RED)/colval(ctmp,RED), |
512 |
colval(exposure,GRN)/colval(ctmp,GRN), |
513 |
colval(exposure,BLU)/colval(ctmp,BLU)); |
514 |
doexposure++; |
515 |
return(1); |
516 |
517 |
if ((rv = isbigendian(line)) >= 0) { |
518 |
if (reverse) |
519 |
swapbytes = (nativebigendian() != rv); |
520 |
return(1); |
521 |
522 |
if (fout != NULL) |
523 |
fputs(line, fout); |
524 |
return(0); |
525 |
526 |
527 |
528 |
static void |
529 |
pixtoval(void) /* convert picture to values */ |
530 |
531 |
COLOR *scanln; |
532 |
int dogamma; |
533 |
COLOR lastc; |
534 |
RREAL hv[2]; |
535 |
int startprim, endprim; |
536 |
long startpos; |
537 |
int x, y; |
538 |
539 |
scanln = (COLOR *)malloc(scanlen(&picres)*sizeof(COLOR)); |
540 |
if (scanln == NULL) { |
541 |
fprintf(stderr, "%s: out of memory\n", progname); |
542 |
quit(1); |
543 |
544 |
dogamma = gamcor < .95 || gamcor > 1.05; |
545 |
if ((putprim == ALL) & !interleave) { |
546 |
startprim = RED; endprim = BLU; |
547 |
startpos = ftell(fin); |
548 |
} else { |
549 |
startprim = putprim; endprim = putprim; |
550 |
551 |
for (putprim = startprim; putprim <= endprim; putprim++) { |
552 |
if (putprim != startprim && fseek(fin, startpos, SEEK_SET)) { |
553 |
fprintf(stderr, "%s: seek error on input file\n", |
554 |
progname); |
555 |
quit(1); |
556 |
557 |
set_io(); |
558 |
setcolor(lastc, 0.0, 0.0, 0.0); |
559 |
for (y = 0; y < numscans(&picres); y++) { |
560 |
if (fread2scan(scanln, scanlen(&picres), fin, |
561 |
NCSAMP, WLPART) < 0) { |
562 |
fprintf(stderr, "%s: read error\n", progname); |
563 |
quit(1); |
564 |
565 |
for (x = 0; x < scanlen(&picres); x++) { |
566 |
if (uniq) { |
567 |
if ( colval(scanln[x],RED) == |
568 |
colval(lastc,RED) && |
569 |
colval(scanln[x],GRN) == |
570 |
colval(lastc,GRN) && |
571 |
colval(scanln[x],BLU) == |
572 |
colval(lastc,BLU) ) |
573 |
continue; |
574 |
else |
575 |
copycolor(lastc, scanln[x]); |
576 |
577 |
if (doexposure) |
578 |
multcolor(scanln[x], exposure); |
579 |
if (dogamma) |
580 |
setcolor(scanln[x], |
581 |
pow(colval(scanln[x],RED), 1.0/gamcor), |
582 |
pow(colval(scanln[x],GRN), 1.0/gamcor), |
583 |
pow(colval(scanln[x],BLU), 1.0/gamcor)); |
584 |
if (!dataonly) { |
585 |
pix2loc(hv, &picres, x, y); |
586 |
printf("%7d %7d ", |
587 |
(int)(hv[0]*picres.xr), |
588 |
(int)(hv[1]*picres.yr)); |
589 |
590 |
if ((*putval)(scanln[x]) < 0) { |
591 |
fprintf(stderr, "%s: write error\n", |
592 |
progname); |
593 |
quit(1); |
594 |
595 |
596 |
597 |
598 |
free((void *)scanln); |
599 |
600 |
601 |
602 |
static void |
603 |
valtopix(void) /* convert values to a pixel file */ |
604 |
605 |
int dogamma; |
606 |
COLOR *scanln; |
607 |
COLR rgbe; |
608 |
int x, y; |
609 |
610 |
611 |
612 |
613 |
quit(1); |
614 |
615 |
616 |
set_io(); |
617 |
618 |
619 |
if (!dataonly) { |
620 |
fscanf(fin, "%*d %*d"); |
621 |
622 |
fscanf(fin2, "%*d %*d"); |
623 |
fscanf(fin3, "%*d %*d"); |
624 |
625 |
626 |
if ((*getval)(scanln[x]) < 0) { |
627 |
628 |
quit(1); |
629 |
630 |
if (dogamma) |
631 |
632 |
pow(colval(scanln[x],RED), gamcor), |
633 |
pow(colval(scanln[x],GRN), gamcor), |
634 |
pow(colval(scanln[x],BLU), gamcor)); |
635 |
if (doexposure) |
636 |
637 |
if (uniq) { /* uncompressed? */ |
638 |
setcolr(rgbe, scanln[x][RED], |
639 |
scanln[x][GRN], |
640 |
scanln[x][BLU]); |
641 |
if (putbinary(rgbe, sizeof(COLR), 1, stdout) != 1) |
642 |
goto writerr; |
643 |
644 |
645 |
/* write scan if compressed */ |
646 |
if (!uniq && fwritescan(scanln, scanlen(&picres), stdout) < 0) |
647 |
goto writerr; |
648 |
649 |
650 |
return; |
651 |
writerr: |
652 |
fprintf(stderr, "%s: write error\n", progname); |
653 |
quit(1); |
654 |
655 |
656 |
657 |
void |
658 |
quit(code) |
659 |
int code; |
660 |
661 |
exit(code); |
662 |
663 |
664 |
665 |
static int |
666 |
getcascii( /* get an ascii color value from stream(s) */ |
667 |
COLOR col |
668 |
669 |
670 |
double vd[3]; |
671 |
672 |
if (fin2 == NULL) { |
673 |
if (fscanf(fin, "%lf %lf %lf", &vd[0], &vd[1], &vd[2]) != 3) |
674 |
return(-1); |
675 |
} else { |
676 |
if (fscanf(fin, "%lf", &vd[0]) != 1 || |
677 |
fscanf(fin2, "%lf", &vd[1]) != 1 || |
678 |
fscanf(fin3, "%lf", &vd[2]) != 1) |
679 |
return(-1); |
680 |
681 |
setcolor(col, vd[rord[RED]], vd[rord[GRN]], vd[rord[BLU]]); |
682 |
return(0); |
683 |
684 |
685 |
686 |
static int |
687 |
getcdouble( /* get a double color value from stream(s) */ |
688 |
COLOR col |
689 |
690 |
691 |
double vd[3]; |
692 |
693 |
694 |
if (getbinary(vd, sizeof(double), 3, fin) != 3) |
695 |
return(-1); |
696 |
} else { |
697 |
if (getbinary(vd, sizeof(double), 1, fin) != 1 || |
698 |
getbinary(vd+1, sizeof(double), 1, fin2) != 1 || |
699 |
getbinary(vd+2, sizeof(double), 1, fin3) != 1) |
700 |
return(-1); |
701 |
702 |
if (swapbytes) |
703 |
swap64((char *)vd, 3); |
704 |
705 |
return(0); |
706 |
707 |
708 |
709 |
static int |
710 |
getcfloat( /* get a float color value from stream(s) */ |
711 |
COLOR col |
712 |
713 |
714 |
float vf[3]; |
715 |
716 |
717 |
if (getbinary(vf, sizeof(float), 3, fin) != 3) |
718 |
return(-1); |
719 |
} else { |
720 |
if (getbinary(vf, sizeof(float), 1, fin) != 1 || |
721 |
getbinary(vf+1, sizeof(float), 1, fin2) != 1 || |
722 |
getbinary(vf+2, sizeof(float), 1, fin3) != 1) |
723 |
return(-1); |
724 |
725 |
if (swapbytes) |
726 |
swap32((char *)vf, 3); |
727 |
setcolor(col, vf[rord[RED]], vf[rord[GRN]], vf[rord[BLU]]); |
728 |
return(0); |
729 |
730 |
731 |
732 |
static int |
733 |
getcint( /* get an int color value from stream(s) */ |
734 |
COLOR col |
735 |
736 |
737 |
int vi[3]; |
738 |
739 |
740 |
if (fscanf(fin, "%d %d %d", &vi[0], &vi[1], &vi[2]) != 3) |
741 |
return(-1); |
742 |
} else { |
743 |
if (fscanf(fin, "%d", &vi[0]) != 1 || |
744 |
fscanf(fin2, "%d", &vi[1]) != 1 || |
745 |
fscanf(fin3, "%d", &vi[2]) != 1) |
746 |
return(-1); |
747 |
748 |
setcolor(col, (vi[rord[RED]]+.5)/256., |
749 |
(vi[rord[GRN]]+.5)/256., (vi[rord[BLU]]+.5)/256.); |
750 |
return(0); |
751 |
752 |
753 |
754 |
static int |
755 |
getcbyte( /* get a byte color value from stream(s) */ |
756 |
COLOR col |
757 |
758 |
759 |
uby8 vb[3]; |
760 |
761 |
762 |
if (getbinary(vb, sizeof(uby8), 3, fin) != 3) |
763 |
return(-1); |
764 |
} else { |
765 |
if (getbinary(vb, sizeof(uby8), 1, fin) != 1 || |
766 |
getbinary(vb+1, sizeof(uby8), 1, fin2) != 1 || |
767 |
getbinary(vb+2, sizeof(uby8), 1, fin3) != 1) |
768 |
return(-1); |
769 |
770 |
setcolor(col, (vb[rord[RED]]+.5)/256., |
771 |
(vb[rord[GRN]]+.5)/256., (vb[rord[BLU]]+.5)/256.); |
772 |
return(0); |
773 |
774 |
775 |
776 |
static int |
777 |
getcword( /* get a 16-bit color value from stream(s) */ |
778 |
COLOR col |
779 |
780 |
781 |
uint16 vw[3]; |
782 |
783 |
784 |
if (getbinary(vw, sizeof(uint16), 3, fin) != 3) |
785 |
return(-1); |
786 |
} else { |
787 |
if (getbinary(vw, sizeof(uint16), 1, fin) != 1 || |
788 |
getbinary(vw+1, sizeof(uint16), 1, fin2) != 1 || |
789 |
getbinary(vw+2, sizeof(uint16), 1, fin3) != 1) |
790 |
return(-1); |
791 |
792 |
if (swapbytes) |
793 |
swap16((char *)vw, 3); |
794 |
setcolor(col, (vw[rord[RED]]+.5)/65536., |
795 |
(vw[rord[GRN]]+.5)/65536., (vw[rord[BLU]]+.5)/65536.); |
796 |
return(0); |
797 |
798 |
799 |
800 |
static int |
801 |
getbascii( /* get an ascii brightness value from fin */ |
802 |
COLOR col |
803 |
804 |
805 |
double vd; |
806 |
807 |
if (fscanf(fin, "%lf", &vd) != 1) |
808 |
return(-1); |
809 |
setcolor(col, vd, vd, vd); |
810 |
return(0); |
811 |
812 |
813 |
814 |
static int |
815 |
getbdouble( /* get a double brightness value from fin */ |
816 |
COLOR col |
817 |
818 |
819 |
double vd; |
820 |
821 |
if (getbinary(&vd, sizeof(double), 1, fin) != 1) |
822 |
return(-1); |
823 |
if (swapbytes) |
824 |
swap64((char *)&vd, 1); |
825 |
826 |
return(0); |
827 |
828 |
829 |
830 |
static int |
831 |
getbfloat( /* get a float brightness value from fin */ |
832 |
COLOR col |
833 |
834 |
835 |
float vf; |
836 |
837 |
if (getbinary(&vf, sizeof(float), 1, fin) != 1) |
838 |
return(-1); |
839 |
if (swapbytes) |
840 |
swap32((char *)&vf, 1); |
841 |
setcolor(col, vf, vf, vf); |
842 |
return(0); |
843 |
844 |
845 |
846 |
static int |
847 |
getbint( /* get an int brightness value from fin */ |
848 |
COLOR col |
849 |
850 |
851 |
int vi; |
852 |
double d; |
853 |
854 |
if (fscanf(fin, "%d", &vi) != 1) |
855 |
return(-1); |
856 |
d = (vi+.5)/256.; |
857 |
setcolor(col, d, d, d); |
858 |
return(0); |
859 |
860 |
861 |
862 |
static int |
863 |
getbbyte( /* get a byte brightness value from fin */ |
864 |
COLOR col |
865 |
866 |
867 |
uby8 vb; |
868 |
double d; |
869 |
870 |
if (getbinary(&vb, sizeof(uby8), 1, fin) != 1) |
871 |
return(-1); |
872 |
d = (vb+.5)/256.; |
873 |
874 |
return(0); |
875 |
876 |
877 |
878 |
static int |
879 |
getbword( /* get a 16-bit brightness value from fin */ |
880 |
COLOR col |
881 |
882 |
883 |
uint16 vw; |
884 |
double d; |
885 |
886 |
if (getbinary(&vw, sizeof(uint16), 1, fin) != 1) |
887 |
return(-1); |
888 |
if (swapbytes) |
889 |
swap16((char *)&vw, 1); |
890 |
d = (vw+.5)/65536.; |
891 |
892 |
return(0); |
893 |
894 |
895 |
896 |
static int |
897 |
putcascii( /* put an ascii color to stdout */ |
898 |
COLOR col |
899 |
900 |
901 |
fprintf(stdout, "%15.3e %15.3e %15.3e\n", |
902 |
colval(col,ord[0]), |
903 |
colval(col,ord[1]), |
904 |
colval(col,ord[2])); |
905 |
906 |
return(ferror(stdout) ? -1 : 0); |
907 |
908 |
909 |
910 |
static int |
911 |
putcfloat( /* put a float color to stdout */ |
912 |
COLOR col |
913 |
914 |
915 |
float vf[3]; |
916 |
917 |
vf[0] = colval(col,ord[0]); |
918 |
vf[1] = colval(col,ord[1]); |
919 |
vf[2] = colval(col,ord[2]); |
920 |
if (swapbytes) |
921 |
922 |
putbinary(vf, sizeof(float), 3, stdout); |
923 |
924 |
925 |
926 |
927 |
928 |
static int |
929 |
putcdouble( /* put a double color to stdout */ |
930 |
COLOR col |
931 |
932 |
933 |
double vd[3]; |
934 |
935 |
vd[0] = colval(col,ord[0]); |
936 |
vd[1] = colval(col,ord[1]); |
937 |
vd[2] = colval(col,ord[2]); |
938 |
if (swapbytes) |
939 |
940 |
putbinary(vd, sizeof(double), 3, stdout); |
941 |
942 |
943 |
944 |
945 |
946 |
static int |
947 |
putcint( /* put an int color to stdout */ |
948 |
COLOR col |
949 |
950 |
951 |
fprintf(stdout, "%d %d %d\n", |
952 |
(int)(colval(col,ord[0])*256.), |
953 |
(int)(colval(col,ord[1])*256.), |
954 |
(int)(colval(col,ord[2])*256.)); |
955 |
956 |
957 |
958 |
959 |
960 |
static int |
961 |
putcbyte( /* put a byte color to stdout */ |
962 |
COLOR col |
963 |
964 |
965 |
long i; |
966 |
uby8 vb[3]; |
967 |
968 |
i = colval(col,ord[0])*256.; |
969 |
vb[0] = min(i,255); |
970 |
i = colval(col,ord[1])*256.; |
971 |
vb[1] = min(i,255); |
972 |
i = colval(col,ord[2])*256.; |
973 |
vb[2] = min(i,255); |
974 |
putbinary(vb, sizeof(uby8), 3, stdout); |
975 |
976 |
977 |
978 |
979 |
980 |
static int |
981 |
putcword( /* put a 16-bit color to stdout */ |
982 |
COLOR col |
983 |
984 |
985 |
long i; |
986 |
uint16 vw[3]; |
987 |
988 |
i = colval(col,ord[0])*65536.; |
989 |
vw[0] = min(i,65535); |
990 |
i = colval(col,ord[1])*65536.; |
991 |
vw[1] = min(i,65535); |
992 |
i = colval(col,ord[2])*65536.; |
993 |
vw[2] = min(i,65535); |
994 |
if (swapbytes) |
995 |
996 |
putbinary(vw, sizeof(uint16), 3, stdout); |
997 |
998 |
999 |
1000 |
1001 |
1002 |
static int |
1003 |
putbascii( /* put an ascii brightness to stdout */ |
1004 |
COLOR col |
1005 |
1006 |
1007 |
fprintf(stdout, "%15.3e\n", (*mybright)(col)); |
1008 |
1009 |
1010 |
1011 |
1012 |
1013 |
static int |
1014 |
putbfloat( /* put a float brightness to stdout */ |
1015 |
COLOR col |
1016 |
1017 |
1018 |
float vf; |
1019 |
1020 |
vf = (*mybright)(col); |
1021 |
if (swapbytes) |
1022 |
1023 |
putbinary(&vf, sizeof(float), 1, stdout); |
1024 |
1025 |
1026 |
1027 |
1028 |
1029 |
static int |
1030 |
putbdouble( /* put a double brightness to stdout */ |
1031 |
COLOR col |
1032 |
1033 |
1034 |
double vd; |
1035 |
1036 |
vd = (*mybright)(col); |
1037 |
if (swapbytes) |
1038 |
1039 |
putbinary(&vd, sizeof(double), 1, stdout); |
1040 |
1041 |
1042 |
1043 |
1044 |
1045 |
static int |
1046 |
putbint( /* put an int brightness to stdout */ |
1047 |
COLOR col |
1048 |
1049 |
1050 |
fprintf(stdout, "%d\n", (int)((*mybright)(col)*256.)); |
1051 |
1052 |
1053 |
1054 |
1055 |
1056 |
static int |
1057 |
putbbyte( /* put a byte brightness to stdout */ |
1058 |
COLOR col |
1059 |
1060 |
1061 |
int i; |
1062 |
uby8 vb; |
1063 |
1064 |
i = (*mybright)(col)*256.; |
1065 |
vb = min(i,255); |
1066 |
putbinary(&vb, sizeof(uby8), 1, stdout); |
1067 |
1068 |
1069 |
1070 |
1071 |
1072 |
static int |
1073 |
putbword( /* put a 16-bit brightness to stdout */ |
1074 |
COLOR col |
1075 |
1076 |
1077 |
long i; |
1078 |
uint16 vw; |
1079 |
1080 |
i = (*mybright)(col)*65536.; |
1081 |
vw = min(i,65535); |
1082 |
if (swapbytes) |
1083 |
1084 |
putbinary(&vw, sizeof(uint16), 1, stdout); |
1085 |
1086 |
1087 |
1088 |
1089 |
1090 |
static int |
1091 |
putpascii( /* put an ascii primary to stdout */ |
1092 |
COLOR col |
1093 |
1094 |
1095 |
fprintf(stdout, "%15.3e\n", colval(col,putprim)); |
1096 |
1097 |
1098 |
1099 |
1100 |
1101 |
static int |
1102 |
putpfloat( /* put a float primary to stdout */ |
1103 |
COLOR col |
1104 |
1105 |
1106 |
float vf; |
1107 |
1108 |
vf = colval(col,putprim); |
1109 |
if (swapbytes) |
1110 |
1111 |
1112 |
1113 |
1114 |
1115 |
1116 |
1117 |
static int |
1118 |
putpdouble( /* put a double primary to stdout */ |
1119 |
COLOR col |
1120 |
1121 |
1122 |
double vd; |
1123 |
1124 |
vd = colval(col,putprim); |
1125 |
if (swapbytes) |
1126 |
1127 |
1128 |
1129 |
1130 |
1131 |
1132 |
1133 |
static int |
1134 |
putpint( /* put an int primary to stdout */ |
1135 |
COLOR col |
1136 |
1137 |
1138 |
fprintf(stdout, "%d\n", (int)(colval(col,putprim)*256.)); |
1139 |
1140 |
1141 |
1142 |
1143 |
1144 |
static int |
1145 |
putpbyte( /* put a byte primary to stdout */ |
1146 |
COLOR col |
1147 |
1148 |
1149 |
long i; |
1150 |
uby8 vb; |
1151 |
1152 |
i = colval(col,putprim)*256.; |
1153 |
vb = min(i,255); |
1154 |
1155 |
1156 |
1157 |
1158 |
1159 |
1160 |
static int |
1161 |
putpword( /* put a 16-bit primary to stdout */ |
1162 |
COLOR col |
1163 |
1164 |
1165 |
long i; |
1166 |
uint16 vw; |
1167 |
1168 |
i = colval(col,putprim)*65536.; |
1169 |
1170 |
if (swapbytes) |
1171 |
1172 |
1173 |
1174 |
1175 |
1176 |
1177 |
1178 |
static void |
1179 |
set_io(void) /* set put and get functions */ |
1180 |
1181 |
switch (format) { |
1182 |
1183 |
if (putprim == BRIGHT) { |
1184 |
getval = getbascii; |
1185 |
putval = putbascii; |
1186 |
} else if (putprim != ALL) { |
1187 |
1188 |
putval = putpascii; |
1189 |
} else { |
1190 |
getval = getcascii; |
1191 |
putval = putcascii; |
1192 |
if (reverse && !interleave) { |
1193 |
fprintf(stderr, |
1194 |
"%s: ASCII input files must be interleaved\n", |
1195 |
progname); |
1196 |
quit(1); |
1197 |
1198 |
1199 |
return; |
1200 |
case 'f': /* binary float */ |
1201 |
1202 |
getval = getbfloat; |
1203 |
putval = putbfloat; |
1204 |
1205 |
1206 |
putval = putpfloat; |
1207 |
} else { |
1208 |
getval = getcfloat; |
1209 |
putval = putcfloat; |
1210 |
1211 |
if (fin2 == NULL) |
1212 |
goto namerr; |
1213 |
if (fseek(fin2, |
1214 |
(long)sizeof(float)*picres.xr*picres.yr, SEEK_CUR)) |
1215 |
goto seekerr; |
1216 |
if (fseek(fin3, |
1217 |
(long)sizeof(float)*2*picres.xr*picres.yr, SEEK_CUR)) |
1218 |
goto seekerr; |
1219 |
1220 |
1221 |
return; |
1222 |
case 'd': /* binary double */ |
1223 |
1224 |
getval = getbdouble; |
1225 |
putval = putbdouble; |
1226 |
1227 |
1228 |
putval = putpdouble; |
1229 |
} else { |
1230 |
getval = getcdouble; |
1231 |
putval = putcdouble; |
1232 |
1233 |
if (fin2 == NULL) |
1234 |
goto namerr; |
1235 |
if (fseek(fin2, |
1236 |
(long)sizeof(double)*picres.xr*picres.yr, SEEK_CUR)) |
1237 |
goto seekerr; |
1238 |
if (fseek(fin3, |
1239 |
(long)sizeof(double)*2*picres.xr*picres.yr, SEEK_CUR)) |
1240 |
goto seekerr; |
1241 |
1242 |
1243 |
return; |
1244 |
1245 |
1246 |
getval = getbint; |
1247 |
putval = putbint; |
1248 |
1249 |
getval = getbint; |
1250 |
putval = putpint; |
1251 |
} else { |
1252 |
getval = getcint; |
1253 |
putval = putcint; |
1254 |
1255 |
fprintf(stderr, |
1256 |
"%s: integer input files must be interleaved\n", |
1257 |
progname); |
1258 |
quit(1); |
1259 |
1260 |
1261 |
return; |
1262 |
1263 |
1264 |
getval = getbbyte; |
1265 |
putval = putbbyte; |
1266 |
1267 |
1268 |
putval = putpbyte; |
1269 |
} else { |
1270 |
getval = getcbyte; |
1271 |
putval = putcbyte; |
1272 |
1273 |
if (fin2 == NULL) |
1274 |
goto namerr; |
1275 |
if (fseek(fin2, |
1276 |
(long)sizeof(uby8)*picres.xr*picres.yr, SEEK_CUR)) |
1277 |
goto seekerr; |
1278 |
if (fseek(fin3, |
1279 |
(long)sizeof(uby8)*2*picres.xr*picres.yr, SEEK_CUR)) |
1280 |
goto seekerr; |
1281 |
1282 |
1283 |
return; |
1284 |
1285 |
1286 |
getval = getbword; |
1287 |
putval = putbword; |
1288 |
1289 |
1290 |
putval = putpword; |
1291 |
} else { |
1292 |
getval = getcword; |
1293 |
putval = putcword; |
1294 |
1295 |
if (fin2 == NULL) |
1296 |
goto namerr; |
1297 |
if (fseek(fin2, |
1298 |
(long)sizeof(uint16)*picres.xr*picres.yr, SEEK_CUR)) |
1299 |
goto seekerr; |
1300 |
if (fseek(fin3, |
1301 |
(long)sizeof(uint16)*2*picres.xr*picres.yr, SEEK_CUR)) |
1302 |
goto seekerr; |
1303 |
1304 |
1305 |
return; |
1306 |
1307 |
/* badopt: */ /* label not used */ |
1308 |
fprintf(stderr, "%s: botched file type\n", progname); |
1309 |
quit(1); |
1310 |
namerr: |
1311 |
fprintf(stderr, "%s: non-interleaved file(s) must be named\n", |
1312 |
progname); |
1313 |
quit(1); |
1314 |
seekerr: |
1315 |
fprintf(stderr, "%s: cannot seek on interleaved input file\n", |
1316 |
progname); |
1317 |
quit(1); |
1318 |
