--- ray/src/px/pvalue.c 2016/03/06 01:13:17 2.32 +++ ray/src/px/pvalue.c 2016/08/18 00:52:48 2.33 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: pvalue.c,v 2.32 2016/03/06 01:13:17 schorsch Exp $"; +static const char RCSid[] = "$Id: pvalue.c,v 2.33 2016/08/18 00:52:48 greg Exp $"; #endif /* * pvalue.c - program to print pixel values. @@ -572,12 +572,12 @@ getcdouble( /* get a double color value from stream(s double vd[3]; if (fin2 == NULL) { - if (fread((char *)vd, sizeof(double), 3, fin) != 3) + if (getbinary(vd, sizeof(double), 3, fin) != 3) return(-1); } else { - if (fread((char *)vd, sizeof(double), 1, fin) != 1 || - fread((char *)(vd+1), sizeof(double), 1, fin2) != 1 || - fread((char *)(vd+2), sizeof(double), 1, fin3) != 1) + if (getbinary(vd, sizeof(double), 1, fin) != 1 || + getbinary(vd+1, sizeof(double), 1, fin2) != 1 || + getbinary(vd+2, sizeof(double), 1, fin3) != 1) return(-1); } if (swapbytes) @@ -595,12 +595,12 @@ getcfloat( /* get a float color value from stream(s) float vf[3]; if (fin2 == NULL) { - if (fread((char *)vf, sizeof(float), 3, fin) != 3) + if (getbinary(vf, sizeof(float), 3, fin) != 3) return(-1); } else { - if (fread((char *)vf, sizeof(float), 1, fin) != 1 || - fread((char *)(vf+1), sizeof(float), 1, fin2) != 1 || - fread((char *)(vf+2), sizeof(float), 1, fin3) != 1) + if (getbinary(vf, sizeof(float), 1, fin) != 1 || + getbinary(vf+1, sizeof(float), 1, fin2) != 1 || + getbinary(vf+2, sizeof(float), 1, fin3) != 1) return(-1); } if (swapbytes) @@ -640,12 +640,12 @@ getcbyte( /* get a byte color value from stream(s) */ uby8 vb[3]; if (fin2 == NULL) { - if (fread((char *)vb, sizeof(uby8), 3, fin) != 3) + if (getbinary(vb, sizeof(uby8), 3, fin) != 3) return(-1); } else { - if (fread((char *)vb, sizeof(uby8), 1, fin) != 1 || - fread((char *)(vb+1), sizeof(uby8), 1, fin2) != 1 || - fread((char *)(vb+2), sizeof(uby8), 1, fin3) != 1) + if (getbinary(vb, sizeof(uby8), 1, fin) != 1 || + getbinary(vb+1, sizeof(uby8), 1, fin2) != 1 || + getbinary(vb+2, sizeof(uby8), 1, fin3) != 1) return(-1); } setcolor(col, (vb[rord[RED]]+.5)/256., @@ -662,12 +662,12 @@ getcword( /* get a 16-bit color value from stream(s) uint16 vw[3]; if (fin2 == NULL) { - if (fread((char *)vw, sizeof(uint16), 3, fin) != 3) + if (getbinary(vw, sizeof(uint16), 3, fin) != 3) return(-1); } else { - if (fread((char *)vw, sizeof(uint16), 1, fin) != 1 || - fread((char *)(vw+1), sizeof(uint16), 1, fin2) != 1 || - fread((char *)(vw+2), sizeof(uint16), 1, fin3) != 1) + if (getbinary(vw, sizeof(uint16), 1, fin) != 1 || + getbinary(vw+1, sizeof(uint16), 1, fin2) != 1 || + getbinary(vw+2, sizeof(uint16), 1, fin3) != 1) return(-1); } if (swapbytes) @@ -699,7 +699,7 @@ getbdouble( /* get a double brightness value from fin { double vd; - if (fread((char *)&vd, sizeof(double), 1, fin) != 1) + if (getbinary(&vd, sizeof(double), 1, fin) != 1) return(-1); if (swapbytes) swap64((char *)&vd, 1); @@ -715,7 +715,7 @@ getbfloat( /* get a float brightness value from fin * { float vf; - if (fread((char *)&vf, sizeof(float), 1, fin) != 1) + if (getbinary(&vf, sizeof(float), 1, fin) != 1) return(-1); if (swapbytes) swap32((char *)&vf, 1); @@ -748,7 +748,7 @@ getbbyte( /* get a byte brightness value from fin */ uby8 vb; double d; - if (fread((char *)&vb, sizeof(uby8), 1, fin) != 1) + if (getbinary(&vb, sizeof(uby8), 1, fin) != 1) return(-1); d = (vb+.5)/256.; setcolor(col, d, d, d); @@ -764,7 +764,7 @@ getbword( /* get a 16-bit brightness value from fin * uint16 vw; double d; - if (fread((char *)&vw, sizeof(uint16), 1, fin) != 1) + if (getbinary(&vw, sizeof(uint16), 1, fin) != 1) return(-1); if (swapbytes) swap16((char *)&vw, 1); @@ -800,7 +800,7 @@ putcfloat( /* put a float color to stdout */ vf[2] = colval(col,ord[2]); if (swapbytes) swap32((char *)vf, 3); - fwrite((char *)vf, sizeof(float), 3, stdout); + putbinary(vf, sizeof(float), 3, stdout); return(ferror(stdout) ? -1 : 0); } @@ -818,7 +818,7 @@ putcdouble( /* put a double color to stdout */ vd[2] = colval(col,ord[2]); if (swapbytes) swap64((char *)vd, 3); - fwrite((char *)vd, sizeof(double), 3, stdout); + putbinary(vd, sizeof(double), 3, stdout); return(ferror(stdout) ? -1 : 0); } @@ -852,7 +852,7 @@ putcbyte( /* put a byte color to stdout */ vb[1] = min(i,255); i = colval(col,ord[2])*256.; vb[2] = min(i,255); - fwrite((char *)vb, sizeof(uby8), 3, stdout); + putbinary(vb, sizeof(uby8), 3, stdout); return(ferror(stdout) ? -1 : 0); } @@ -874,7 +874,7 @@ putcword( /* put a 16-bit color to stdout */ vw[2] = min(i,65535); if (swapbytes) swap16((char *)vw, 3); - fwrite((char *)vw, sizeof(uint16), 3, stdout); + putbinary(vw, sizeof(uint16), 3, stdout); return(ferror(stdout) ? -1 : 0); } @@ -901,7 +901,7 @@ putbfloat( /* put a float brightness to stdout */ vf = (*mybright)(col); if (swapbytes) swap32((char *)&vf, 1); - fwrite((char *)&vf, sizeof(float), 1, stdout); + putbinary(&vf, sizeof(float), 1, stdout); return(ferror(stdout) ? -1 : 0); } @@ -917,7 +917,7 @@ putbdouble( /* put a double brightness to stdout */ vd = (*mybright)(col); if (swapbytes) swap64((char *)&vd, 1); - fwrite((char *)&vd, sizeof(double), 1, stdout); + putbinary(&vd, sizeof(double), 1, stdout); return(ferror(stdout) ? -1 : 0); } @@ -944,7 +944,7 @@ putbbyte( /* put a byte brightness to stdout */ i = (*mybright)(col)*256.; vb = min(i,255); - fwrite((char *)&vb, sizeof(uby8), 1, stdout); + putbinary(&vb, sizeof(uby8), 1, stdout); return(ferror(stdout) ? -1 : 0); } @@ -962,7 +962,7 @@ putbword( /* put a 16-bit brightness to stdout */ vw = min(i,65535); if (swapbytes) swap16((char *)&vw, 1); - fwrite((char *)&vw, sizeof(uint16), 1, stdout); + putbinary(&vw, sizeof(uint16), 1, stdout); return(ferror(stdout) ? -1 : 0); } @@ -989,7 +989,7 @@ putpfloat( /* put a float primary to stdout */ vf = colval(col,putprim); if (swapbytes) swap32((char *)&vf, 1); - fwrite((char *)&vf, sizeof(float), 1, stdout); + putbinary(&vf, sizeof(float), 1, stdout); return(ferror(stdout) ? -1 : 0); } @@ -1005,7 +1005,7 @@ putpdouble( /* put a double primary to stdout */ vd = colval(col,putprim); if (swapbytes) swap64((char *)&vd, 1); - fwrite((char *)&vd, sizeof(double), 1, stdout); + putbinary(&vd, sizeof(double), 1, stdout); return(ferror(stdout) ? -1 : 0); } @@ -1032,7 +1032,7 @@ putpbyte( /* put a byte primary to stdout */ i = colval(col,putprim)*256.; vb = min(i,255); - fwrite((char *)&vb, sizeof(uby8), 1, stdout); + putbinary(&vb, sizeof(uby8), 1, stdout); return(ferror(stdout) ? -1 : 0); } @@ -1050,7 +1050,7 @@ putpword( /* put a 16-bit primary to stdout */ vw = min(i,65535); if (swapbytes) swap16((char *)&vw, 1); - fwrite((char *)&vw, sizeof(uint16), 1, stdout); + putbinary(&vw, sizeof(uint16), 1, stdout); return(ferror(stdout) ? -1 : 0); }
