root/radiance/ray/src/px/pvalue.c
Revision: 2.13
Committed: Tue Oct 27 09:08:27 1998 UTC (26 years, 8 months ago) by gwlarson
Changes since 2.12: +2 -0 lines
1 /* Copyright (c) 1992 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * pvalue.c - program to print pixel values.
9 *
10 * 4/23/86
11 */
12
13 #include "standard.h"
14
15 #include "color.h"
16
17 #include "resolu.h"
18
19 #define min(a,b) ((a)<(b)?(a):(b))
20
21 /* what to put out (also RED, GRN, BLU) */
22 #define ALL 3
23 #define BRIGHT 4
24
25 #define brightonly (putprim==BRIGHT)
26
27 RESOLU picres; /* resolution of picture */
28
29 int uniq = 0; /* print only unique values? */
30
31 int doexposure = 0; /* exposure change? (>100 to print) */
32
33 int dataonly = 0; /* data only format? */
34
35 int putprim = ALL; /* what to put out */
36
37 int reverse = 0; /* reverse conversion? */
38
39 int format = 'a'; /* input/output format */
40 char *fmtid = "ascii"; /* format identifier for header */
41
42 int header = 1; /* do header? */
43
44 long skipbytes = 0; /* skip bytes in input? */
45
46 int interleave = 1; /* file is interleaved? */
47
48 int resolution = 1; /* put/get resolution string? */
49
50 int original = 0; /* convert to original values? */
51
52 int wrongformat = 0; /* wrong input format? */
53
54 double gamcor = 1.0; /* gamma correction */
55
56 int ord[3] = {RED, GRN, BLU}; /* RGB ordering */
57 int rord[4]; /* reverse ordering */
58
59 COLOR exposure = WHTCOLOR;
60
61 char *progname;
62
63 FILE *fin;
64 FILE *fin2 = NULL, *fin3 = NULL; /* for other color channels */
65
66 int (*getval)(), (*putval)();
67
68
69 main(argc, argv)
70 int argc;
71 char **argv;
72 {
73 extern int checkhead();
74 extern long atol();
75 double d, expval = 1.0;
76 int i;
77
78 progname = argv[0];
79
80 for (i = 1; i < argc; i++)
81 if (argv[i][0] == '-' || argv[i][0] == '+')
82 switch (argv[i][1]) {
83 case 'h': /* header */
84 header = argv[i][0] == '+';
85 break;
86 case 'H': /* resolution string */
87 resolution = argv[i][0] == '+';
88 break;
89 case 's': /* skip bytes in header */
90 skipbytes = atol(argv[++i]);
91 break;
92 case 'u': /* unique values */
93 uniq = argv[i][0] == '-';
94 break;
95 case 'o': /* original values */
96 original = argv[i][0] == '-';
97 break;
98 case 'g': /* gamma correction */
99 gamcor = atof(argv[i+1]);
100 if (argv[i][0] == '+')
101 gamcor = 1.0/gamcor;
102 i++;
103 break;
104 case 'e': /* exposure correction */
105 d = atof(argv[i+1]);
106 if (argv[i+1][0] == '-' || argv[i+1][0] == '+')
107 d = pow(2.0, d);
108 if (argv[i][0] == '-')
109 expval *= d;
110 scalecolor(exposure, d);
111 doexposure++;
112 i++;
113 break;
114 case 'R': /* reverse byte sequence */
115 if (argv[i][0] == '-') {
116 ord[0]=BLU; ord[1]=GRN; ord[2]=RED;
117 } else {
118 ord[0]=RED; ord[1]=GRN; ord[2]=BLU;
119 }
120 break;
121 case 'r': /* reverse conversion */
122 reverse = argv[i][0] == '-';
123 break;
124 case 'n': /* non-interleaved RGB */
125 interleave = argv[i][0] == '+';
126 break;
127 case 'b': /* brightness values */
128 putprim = argv[i][0] == '-' ? BRIGHT : ALL;
129 break;
130 case 'p': /* put primary */
131 switch (argv[i][2]) {
132 case 'r': case 'R': putprim = RED; break;
133 case 'g': case 'G': putprim = GRN; break;
134 case 'b': case 'B': putprim = BLU; break;
135 default: goto unkopt;
136 }
137 break;
138 case 'd': /* data only (no indices) */
139 dataonly = argv[i][0] == '-';
140 switch (argv[i][2]) {
141 case '\0':
142 case 'a': /* ascii */
143 format = 'a';
144 fmtid = "ascii";
145 break;
146 case 'i': /* integer */
147 format = 'i';
148 fmtid = "ascii";
149 break;
150 case 'b': /* byte */
151 dataonly = 1;
152 format = 'b';
153 fmtid = "byte";
154 break;
155 case 'f': /* float */
156 dataonly = 1;
157 format = 'f';
158 fmtid = "float";
159 break;
160 case 'd': /* double */
161 dataonly = 1;
162 format = 'd';
163 fmtid = "double";
164 break;
165 default:
166 goto unkopt;
167 }
168 break;
169 case 'x': /* x resolution */
170 case 'X': /* x resolution */
171 resolution = 0;
172 if (argv[i][0] == '-')
173 picres.or |= XDECR;
174 picres.xr = atoi(argv[++i]);
175 break;
176 case 'y': /* y resolution */
177 case 'Y': /* y resolution */
178 resolution = 0;
179 if (argv[i][0] == '-')
180 picres.or |= YDECR;
181 if (picres.xr == 0)
182 picres.or |= YMAJOR;
183 picres.yr = atoi(argv[++i]);
184 break;
185 default:
186 unkopt:
187 fprintf(stderr, "%s: unknown option: %s\n",
188 progname, argv[i]);
189 quit(1);
190 break;
191 }
192 else
193 break;
194 /* recognize special formats */
195 if (dataonly && format == 'b')
196 if (brightonly)
197 fmtid = "8-bit_grey";
198 else
199 fmtid = "24-bit_rgb";
200 /* assign reverse ordering */
201 rord[ord[0]] = 0;
202 rord[ord[1]] = 1;
203 rord[ord[2]] = 2;
204 /* get input */
205 if (i == argc) {
206 fin = stdin;
207 } else if (i < argc) {
208 if ((fin = fopen(argv[i], "r")) == NULL) {
209 fprintf(stderr, "%s: can't open file \"%s\"\n",
210 progname, argv[i]);
211 quit(1);
212 }
213 if (reverse && !brightonly && i == argc-3) {
214 if ((fin2 = fopen(argv[i+1], "r")) == NULL) {
215 fprintf(stderr, "%s: can't open file \"%s\"\n",
216 progname, argv[i+1]);
217 quit(1);
218 }
219 if ((fin3 = fopen(argv[i+2], "r")) == NULL) {
220 fprintf(stderr, "%s: can't open file \"%s\"\n",
221 progname, argv[i+2]);
222 quit(1);
223 }
224 interleave = -1;
225 } else if (i != argc-1)
226 fin = NULL;
227 if (reverse && !brightonly && !interleave) {
228 fin2 = fopen(argv[i], "r");
229 fin3 = fopen(argv[i], "r");
230 }
231 if (skipbytes && (fseek(fin, skipbytes, 0) || (fin2 != NULL &&
232 (fseek(fin2, skipbytes, 0) ||
233 fseek(fin3, skipbytes, 0))))) {
234 fprintf(stderr, "%s: cannot skip %ld bytes on input\n",
235 progname, skipbytes);
236 quit(1);
237 }
238 }
239 if (fin == NULL) {
240 fprintf(stderr, "%s: bad # file arguments\n", progname);
241 quit(1);
242 }
243
244 if (reverse) {
245 #ifdef MSDOS
246 setmode(fileno(stdout), O_BINARY);
247 if (format != 'a' && format != 'i')
248 setmode(fileno(fin), O_BINARY);
249 #endif
250 /* get header */
251 if (header) {
252 if (checkheader(fin, fmtid, stdout) < 0) {
253 fprintf(stderr, "%s: wrong input format\n",
254 progname);
255 quit(1);
256 }
257 if (fin2 != NULL) {
258 getheader(fin2, NULL, NULL);
259 getheader(fin3, NULL, NULL);
260 }
261 } else
262 newheader("RADIANCE", stdout);
263 /* get resolution */
264 if ((resolution && !fgetsresolu(&picres, fin)) ||
265 picres.xr <= 0 || picres.yr <= 0) {
266 fprintf(stderr, "%s: missing resolution\n", progname);
267 quit(1);
268 }
269 if (resolution && fin2 != NULL) {
270 RESOLU pres2;
271 if (!fgetsresolu(&pres2, fin2) ||
272 pres2.or != picres.or ||
273 pres2.xr != picres.xr ||
274 pres2.yr != picres.yr ||
275 !fgetsresolu(&pres2, fin3) ||
276 pres2.or != picres.or ||
277 pres2.xr != picres.xr ||
278 pres2.yr != picres.yr) {
279 fprintf(stderr, "%s: resolution mismatch\n",
280 progname);
281 quit(1);
282 }
283 }
284 /* add to header */
285 printargs(i, argv, stdout);
286 if (expval < .99 || expval > 1.01)
287 fputexpos(expval, stdout);
288 fputformat(COLRFMT, stdout);
289 putchar('\n');
290 fputsresolu(&picres, stdout); /* always put resolution */
291 valtopix();
292 } else {
293 #ifdef MSDOS
294 setmode(fileno(fin), O_BINARY);
295 if (format != 'a' && format != 'i')
296 setmode(fileno(stdout), O_BINARY);
297 #endif
298 /* get header */
299 getheader(fin, checkhead, NULL);
300 if (wrongformat) {
301 fprintf(stderr, "%s: input not a Radiance picture\n",
302 progname);
303 quit(1);
304 }
305 if (!fgetsresolu(&picres, fin)) {
306 fprintf(stderr, "%s: missing resolution\n", progname);
307 quit(1);
308 }
309 if (header) {
310 printargs(i, argv, stdout);
311 if (expval < .99 || expval > 1.01)
312 fputexpos(expval, stdout);
313 fputformat(fmtid, stdout);
314 putchar('\n');
315 }
316 if (resolution) /* put resolution */
317 fputsresolu(&picres, stdout);
318 pixtoval();
319 }
320
321 quit(0);
322 }
323
324
325 int
326 checkhead(line) /* deal with line from header */
327 char *line;
328 {
329 char fmt[32];
330 double d;
331 COLOR ctmp;
332
333 if (formatval(fmt, line))
334 wrongformat = strcmp(fmt, COLRFMT);
335 else if (original && isexpos(line)) {
336 d = 1.0/exposval(line);
337 scalecolor(exposure, d);
338 doexposure++;
339 } else if (original && iscolcor(line)) {
340 colcorval(ctmp, line);
341 setcolor(exposure, colval(exposure,RED)/colval(ctmp,RED),
342 colval(exposure,GRN)/colval(ctmp,GRN),
343 colval(exposure,BLU)/colval(ctmp,BLU));
344 doexposure++;
345 } else if (header)
346 fputs(line, stdout);
347 return(0);
348 }
349
350
351 pixtoval() /* convert picture to values */
352 {
353 register COLOR *scanln;
354 int dogamma;
355 COLOR lastc;
356 FLOAT hv[2];
357 int startprim, endprim;
358 long startpos;
359 int y;
360 register int x;
361
362 scanln = (COLOR *)malloc(scanlen(&picres)*sizeof(COLOR));
363 if (scanln == NULL) {
364 fprintf(stderr, "%s: out of memory\n", progname);
365 quit(1);
366 }
367 dogamma = gamcor < .95 || gamcor > 1.05;
368 if (putprim == ALL && !interleave) {
369 startprim = RED; endprim = BLU;
370 startpos = ftell(fin);
371 } else {
372 startprim = putprim; endprim = putprim;
373 }
374 for (putprim = startprim; putprim <= endprim; putprim++) {
375 if (putprim != startprim && fseek(fin, startpos, 0)) {
376 fprintf(stderr, "%s: seek error on input file\n",
377 progname);
378 quit(1);
379 }
380 set_io();
381 setcolor(lastc, 0.0, 0.0, 0.0);
382 for (y = 0; y < numscans(&picres); y++) {
383 if (freadscan(scanln, scanlen(&picres), fin) < 0) {
384 fprintf(stderr, "%s: read error\n", progname);
385 quit(1);
386 }
387 for (x = 0; x < scanlen(&picres); x++) {
388 if (uniq)
389 if ( colval(scanln[x],RED) ==
390 colval(lastc,RED) &&
391 colval(scanln[x],GRN) ==
392 colval(lastc,GRN) &&
393 colval(scanln[x],BLU) ==
394 colval(lastc,BLU) )
395 continue;
396 else
397 copycolor(lastc, scanln[x]);
398 if (doexposure)
399 multcolor(scanln[x], exposure);
400 if (dogamma)
401 setcolor(scanln[x],
402 pow(colval(scanln[x],RED), 1.0/gamcor),
403 pow(colval(scanln[x],GRN), 1.0/gamcor),
404 pow(colval(scanln[x],BLU), 1.0/gamcor));
405 if (!dataonly) {
406 pix2loc(hv, &picres, x, y);
407 printf("%7d %7d ",
408 (int)(hv[0]*picres.xr),
409 (int)(hv[1]*picres.yr));
410 }
411 if ((*putval)(scanln[x]) < 0) {
412 fprintf(stderr, "%s: write error\n",
413 progname);
414 quit(1);
415 }
416 }
417 }
418 }
419 free((char *)scanln);
420 }
421
422
423 valtopix() /* convert values to a pixel file */
424 {
425 int dogamma;
426 register COLOR *scanln;
427 int y;
428 register int x;
429
430 scanln = (COLOR *)malloc(scanlen(&picres)*sizeof(COLOR));
431 if (scanln == NULL) {
432 fprintf(stderr, "%s: out of memory\n", progname);
433 quit(1);
434 }
435 dogamma = gamcor < .95 || gamcor > 1.05;
436 set_io();
437 for (y = 0; y < numscans(&picres); y++) {
438 for (x = 0; x < scanlen(&picres); x++) {
439 if (!dataonly) {
440 fscanf(fin, "%*d %*d");
441 if (fin2 != NULL) {
442 fscanf(fin2, "%*d %*d");
443 fscanf(fin3, "%*d %*d");
444 }
445 }
446 if ((*getval)(scanln[x]) < 0) {
447 fprintf(stderr, "%s: read error\n", progname);
448 quit(1);
449 }
450 if (dogamma)
451 setcolor(scanln[x],
452 pow(colval(scanln[x],RED), gamcor),
453 pow(colval(scanln[x],GRN), gamcor),
454 pow(colval(scanln[x],BLU), gamcor));
455 if (doexposure)
456 multcolor(scanln[x], exposure);
457 }
458 if (fwritescan(scanln, scanlen(&picres), stdout) < 0) {
459 fprintf(stderr, "%s: write error\n", progname);
460 quit(1);
461 }
462 }
463 free((char *)scanln);
464 }
465
466
467 quit(code)
468 int code;
469 {
470 exit(code);
471 }
472
473
474 getcascii(col) /* get an ascii color value from stream(s) */
475 COLOR col;
476 {
477 double vd[3];
478
479 if (fin2 == NULL) {
480 if (fscanf(fin, "%lf %lf %lf", &vd[0], &vd[1], &vd[2]) != 3)
481 return(-1);
482 } else {
483 if (fscanf(fin, "%lf", &vd[0]) != 1 ||
484 fscanf(fin2, "%lf", &vd[1]) != 1 ||
485 fscanf(fin3, "%lf", &vd[2]) != 1)
486 return(-1);
487 }
488 setcolor(col, vd[rord[RED]], vd[rord[GRN]], vd[rord[BLU]]);
489 return(0);
490 }
491
492
493 getcdouble(col) /* get a double color value from stream(s) */
494 COLOR col;
495 {
496 double vd[3];
497
498 if (fin2 == NULL) {
499 if (fread((char *)vd, sizeof(double), 3, fin) != 3)
500 return(-1);
501 } else {
502 if (fread((char *)vd, sizeof(double), 1, fin) != 1 ||
503 fread((char *)(vd+1), sizeof(double), 1, fin2) != 1 ||
504 fread((char *)(vd+2), sizeof(double), 1, fin3) != 1)
505 return(-1);
506 }
507 setcolor(col, vd[rord[RED]], vd[rord[GRN]], vd[rord[BLU]]);
508 return(0);
509 }
510
511
512 getcfloat(col) /* get a float color value from stream(s) */
513 COLOR col;
514 {
515 float vf[3];
516
517 if (fin2 == NULL) {
518 if (fread((char *)vf, sizeof(float), 3, fin) != 3)
519 return(-1);
520 } else {
521 if (fread((char *)vf, sizeof(float), 1, fin) != 1 ||
522 fread((char *)(vf+1), sizeof(float), 1, fin2) != 1 ||
523 fread((char *)(vf+2), sizeof(float), 1, fin3) != 1)
524 return(-1);
525 }
526 setcolor(col, vf[rord[RED]], vf[rord[GRN]], vf[rord[BLU]]);
527 return(0);
528 }
529
530
531 getcint(col) /* get an int color value from stream(s) */
532 COLOR col;
533 {
534 int vi[3];
535
536 if (fin2 == NULL) {
537 if (fscanf(fin, "%d %d %d", &vi[0], &vi[1], &vi[2]) != 3)
538 return(-1);
539 } else {
540 if (fscanf(fin, "%d", &vi[0]) != 1 ||
541 fscanf(fin2, "%d", &vi[1]) != 1 ||
542 fscanf(fin3, "%d", &vi[2]) != 1)
543 return(-1);
544 }
545 setcolor(col, (vi[rord[RED]]+.5)/256.,
546 (vi[rord[GRN]]+.5)/256., (vi[rord[BLU]]+.5)/256.);
547 return(0);
548 }
549
550
551 getcbyte(col) /* get a byte color value from stream(s) */
552 COLOR col;
553 {
554 BYTE vb[3];
555
556 if (fin2 == NULL) {
557 if (fread((char *)vb, sizeof(BYTE), 3, fin) != 3)
558 return(-1);
559 } else {
560 if (fread((char *)vb, sizeof(BYTE), 1, fin) != 1 ||
561 fread((char *)(vb+1), sizeof(BYTE), 1, fin2) != 1 ||
562 fread((char *)(vb+2), sizeof(BYTE), 1, fin3) != 1)
563 return(-1);
564 }
565 setcolor(col, (vb[rord[RED]]+.5)/256.,
566 (vb[rord[GRN]]+.5)/256., (vb[rord[BLU]]+.5)/256.);
567 return(0);
568 }
569
570
571 getbascii(col) /* get an ascii brightness value from fin */
572 COLOR col;
573 {
574 double vd;
575
576 if (fscanf(fin, "%lf", &vd) != 1)
577 return(-1);
578 setcolor(col, vd, vd, vd);
579 return(0);
580 }
581
582
583 getbdouble(col) /* get a double brightness value from fin */
584 COLOR col;
585 {
586 double vd;
587
588 if (fread((char *)&vd, sizeof(double), 1, fin) != 1)
589 return(-1);
590 setcolor(col, vd, vd, vd);
591 return(0);
592 }
593
594
595 getbfloat(col) /* get a float brightness value from fin */
596 COLOR col;
597 {
598 float vf;
599
600 if (fread((char *)&vf, sizeof(float), 1, fin) != 1)
601 return(-1);
602 setcolor(col, vf, vf, vf);
603 return(0);
604 }
605
606
607 getbint(col) /* get an int brightness value from fin */
608 COLOR col;
609 {
610 int vi;
611 double d;
612
613 if (fscanf(fin, "%d", &vi) != 1)
614 return(-1);
615 d = (vi+.5)/256.;
616 setcolor(col, d, d, d);
617 return(0);
618 }
619
620
621 getbbyte(col) /* get a byte brightness value from fin */
622 COLOR col;
623 {
624 BYTE vb;
625 double d;
626
627 if (fread((char *)&vb, sizeof(BYTE), 1, fin) != 1)
628 return(-1);
629 d = (vb+.5)/256.;
630 setcolor(col, d, d, d);
631 return(0);
632 }
633
634
635 putcascii(col) /* put an ascii color to stdout */
636 COLOR col;
637 {
638 fprintf(stdout, "%15.3e %15.3e %15.3e\n",
639 colval(col,ord[0]),
640 colval(col,ord[1]),
641 colval(col,ord[2]));
642
643 return(ferror(stdout) ? -1 : 0);
644 }
645
646
647 putcfloat(col) /* put a float color to stdout */
648 COLOR col;
649 {
650 float vf[3];
651
652 vf[0] = colval(col,ord[0]);
653 vf[1] = colval(col,ord[1]);
654 vf[2] = colval(col,ord[2]);
655 fwrite((char *)vf, sizeof(float), 3, stdout);
656
657 return(ferror(stdout) ? -1 : 0);
658 }
659
660
661 putcdouble(col) /* put a double color to stdout */
662 COLOR col;
663 {
664 double vd[3];
665
666 vd[0] = colval(col,ord[0]);
667 vd[1] = colval(col,ord[1]);
668 vd[2] = colval(col,ord[2]);
669 fwrite((char *)vd, sizeof(double), 3, stdout);
670
671 return(ferror(stdout) ? -1 : 0);
672 }
673
674
675 putcint(col) /* put an int color to stdout */
676 COLOR col;
677 {
678 fprintf(stdout, "%d %d %d\n",
679 (int)(colval(col,ord[0])*256.),
680 (int)(colval(col,ord[1])*256.),
681 (int)(colval(col,ord[2])*256.));
682
683 return(ferror(stdout) ? -1 : 0);
684 }
685
686
687 putcbyte(col) /* put a byte color to stdout */
688 COLOR col;
689 {
690 register int i;
691 BYTE vb[3];
692
693 i = colval(col,ord[0])*256.;
694 vb[0] = min(i,255);
695 i = colval(col,ord[1])*256.;
696 vb[1] = min(i,255);
697 i = colval(col,ord[2])*256.;
698 vb[2] = min(i,255);
699 fwrite((char *)vb, sizeof(BYTE), 3, stdout);
700
701 return(ferror(stdout) ? -1 : 0);
702 }
703
704
705 putbascii(col) /* put an ascii brightness to stdout */
706 COLOR col;
707 {
708 fprintf(stdout, "%15.3e\n", bright(col));
709
710 return(ferror(stdout) ? -1 : 0);
711 }
712
713
714 putbfloat(col) /* put a float brightness to stdout */
715 COLOR col;
716 {
717 float vf;
718
719 vf = bright(col);
720 fwrite((char *)&vf, sizeof(float), 1, stdout);
721
722 return(ferror(stdout) ? -1 : 0);
723 }
724
725
726 putbdouble(col) /* put a double brightness to stdout */
727 COLOR col;
728 {
729 double vd;
730
731 vd = bright(col);
732 fwrite((char *)&vd, sizeof(double), 1, stdout);
733
734 return(ferror(stdout) ? -1 : 0);
735 }
736
737
738 putbint(col) /* put an int brightness to stdout */
739 COLOR col;
740 {
741 fprintf(stdout, "%d\n", (int)(bright(col)*256.));
742
743 return(ferror(stdout) ? -1 : 0);
744 }
745
746
747 putbbyte(col) /* put a byte brightness to stdout */
748 COLOR col;
749 {
750 register int i;
751 BYTE vb;
752
753 i = bright(col)*256.;
754 vb = min(i,255);
755 fwrite((char *)&vb, sizeof(BYTE), 1, stdout);
756
757 return(ferror(stdout) ? -1 : 0);
758 }
759
760
761 putpascii(col) /* put an ascii primary to stdout */
762 COLOR col;
763 {
764 fprintf(stdout, "%15.3e\n", colval(col,putprim));
765
766 return(ferror(stdout) ? -1 : 0);
767 }
768
769
770 putpfloat(col) /* put a float primary to stdout */
771 COLOR col;
772 {
773 float vf;
774
775 vf = colval(col,putprim);
776 fwrite((char *)&vf, sizeof(float), 1, stdout);
777
778 return(ferror(stdout) ? -1 : 0);
779 }
780
781
782 putpdouble(col) /* put a double primary to stdout */
783 COLOR col;
784 {
785 double vd;
786
787 vd = colval(col,putprim);
788 fwrite((char *)&vd, sizeof(double), 1, stdout);
789
790 return(ferror(stdout) ? -1 : 0);
791 }
792
793
794 putpint(col) /* put an int primary to stdout */
795 COLOR col;
796 {
797 fprintf(stdout, "%d\n", (int)(colval(col,putprim)*256.));
798
799 return(ferror(stdout) ? -1 : 0);
800 }
801
802
803 putpbyte(col) /* put a byte primary to stdout */
804 COLOR col;
805 {
806 register int i;
807 BYTE vb;
808
809 i = colval(col,putprim)*256.;
810 vb = min(i,255);
811 fwrite((char *)&vb, sizeof(BYTE), 1, stdout);
812
813 return(ferror(stdout) ? -1 : 0);
814 }
815
816
817 set_io() /* set put and get functions */
818 {
819 switch (format) {
820 case 'a': /* ascii */
821 if (putprim == BRIGHT) {
822 getval = getbascii;
823 putval = putbascii;
824 } else if (putprim != ALL) {
825 getval = getbascii;
826 putval = putpascii;
827 } else {
828 getval = getcascii;
829 putval = putcascii;
830 if (reverse && !interleave) {
831 fprintf(stderr,
832 "%s: ASCII input files must be interleaved\n",
833 progname);
834 quit(1);
835 }
836 }
837 return;
838 case 'f': /* binary float */
839 if (putprim == BRIGHT) {
840 getval = getbfloat;
841 putval = putbfloat;
842 } else if (putprim != ALL) {
843 getval = getbfloat;
844 putval = putpfloat;
845 } else {
846 getval = getcfloat;
847 putval = putcfloat;
848 if (reverse && !interleave) {
849 if (fin2 == NULL)
850 goto namerr;
851 if (fseek(fin2,
852 (long)sizeof(float)*picres.xr*picres.yr, 1))
853 goto seekerr;
854 if (fseek(fin3,
855 (long)sizeof(float)*2*picres.xr*picres.yr, 1))
856 goto seekerr;
857 }
858 }
859 return;
860 case 'd': /* binary double */
861 if (putprim == BRIGHT) {
862 getval = getbdouble;
863 putval = putbdouble;
864 } else if (putprim != ALL) {
865 getval = getbdouble;
866 putval = putpdouble;
867 } else {
868 getval = getcdouble;
869 putval = putcdouble;
870 if (reverse && !interleave) {
871 if (fin2 == NULL)
872 goto namerr;
873 if (fseek(fin2,
874 (long)sizeof(double)*picres.xr*picres.yr, 1))
875 goto seekerr;
876 if (fseek(fin3,
877 (long)sizeof(double)*2*picres.xr*picres.yr, 1))
878 goto seekerr;
879 }
880 }
881 return;
882 case 'i': /* integer */
883 if (putprim == BRIGHT) {
884 getval = getbint;
885 putval = putbint;
886 } else if (putprim != ALL) {
887 getval = getbint;
888 putval = putpint;
889 } else {
890 getval = getcint;
891 putval = putcint;
892 if (reverse && !interleave) {
893 fprintf(stderr,
894 "%s: integer input files must be interleaved\n",
895 progname);
896 quit(1);
897 }
898 }
899 return;
900 case 'b': /* byte */
901 if (putprim == BRIGHT) {
902 getval = getbbyte;
903 putval = putbbyte;
904 } else if (putprim != ALL) {
905 getval = getbbyte;
906 putval = putpbyte;
907 } else {
908 getval = getcbyte;
909 putval = putcbyte;
910 if (reverse && !interleave) {
911 if (fin2 == NULL)
912 goto namerr;
913 if (fseek(fin2,
914 (long)sizeof(BYTE)*picres.xr*picres.yr, 1))
915 goto seekerr;
916 if (fseek(fin3,
917 (long)sizeof(BYTE)*2*picres.xr*picres.yr, 1))
918 goto seekerr;
919 }
920 }
921 return;
922 }
923 badopt:
924 fprintf(stderr, "%s: botched file type\n", progname);
925 quit(1);
926 namerr:
927 fprintf(stderr, "%s: non-interleaved file(s) must be named\n",
928 progname);
929 quit(1);
930 seekerr:
931 fprintf(stderr, "%s: cannot seek on interleaved input file\n",
932 progname);
933 quit(1);
934 }
