root/radiance/ray/src/px/pvalue.c
Revision: 2.12
Committed: Wed Jan 8 08:51:43 1997 UTC (28 years, 6 months ago) by greg
Changes since 2.11: +118 -40 lines
added -n option for non-interleaved RGB input and output
1 /* Copyright (c) 1992 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * pvalue.c - program to print pixel values.
9 *
10 * 4/23/86
11 */
12
13 #include "standard.h"
14
15 #include "color.h"
16
17 #include "resolu.h"
18
19 #define min(a,b) ((a)<(b)?(a):(b))
20
21 /* what to put out (also RED, GRN, BLU) */
22 #define ALL 3
23 #define BRIGHT 4
24
25 #define brightonly (putprim==BRIGHT)
26
27 RESOLU picres; /* resolution of picture */
28
29 int uniq = 0; /* print only unique values? */
30
31 int doexposure = 0; /* exposure change? (>100 to print) */
32
33 int dataonly = 0; /* data only format? */
34
35 int putprim = ALL; /* what to put out */
36
37 int reverse = 0; /* reverse conversion? */
38
39 int format = 'a'; /* input/output format */
40 char *fmtid = "ascii"; /* format identifier for header */
41
42 int header = 1; /* do header? */
43
44 long skipbytes = 0; /* skip bytes in input? */
45
46 int interleave = 1; /* file is interleaved? */
47
48 int resolution = 1; /* put/get resolution string? */
49
50 int original = 0; /* convert to original values? */
51
52 int wrongformat = 0; /* wrong input format? */
53
54 double gamcor = 1.0; /* gamma correction */
55
56 int ord[3] = {RED, GRN, BLU}; /* RGB ordering */
57 int rord[4]; /* reverse ordering */
58
59 COLOR exposure = WHTCOLOR;
60
61 char *progname;
62
63 FILE *fin;
64 FILE *fin2 = NULL, *fin3 = NULL; /* for other color channels */
65
66 int (*getval)(), (*putval)();
67
68
69 main(argc, argv)
70 int argc;
71 char **argv;
72 {
73 extern int checkhead();
74 extern long atol();
75 double d, expval = 1.0;
76 int i;
77
78 progname = argv[0];
79
80 for (i = 1; i < argc; i++)
81 if (argv[i][0] == '-' || argv[i][0] == '+')
82 switch (argv[i][1]) {
83 case 'h': /* header */
84 header = argv[i][0] == '+';
85 break;
86 case 'H': /* resolution string */
87 resolution = argv[i][0] == '+';
88 break;
89 case 's': /* skip bytes in header */
90 skipbytes = atol(argv[++i]);
91 break;
92 case 'u': /* unique values */
93 uniq = argv[i][0] == '-';
94 break;
95 case 'o': /* original values */
96 original = argv[i][0] == '-';
97 break;
98 case 'g': /* gamma correction */
99 gamcor = atof(argv[i+1]);
100 if (argv[i][0] == '+')
101 gamcor = 1.0/gamcor;
102 i++;
103 break;
104 case 'e': /* exposure correction */
105 d = atof(argv[i+1]);
106 if (argv[i+1][0] == '-' || argv[i+1][0] == '+')
107 d = pow(2.0, d);
108 if (argv[i][0] == '-')
109 expval *= d;
110 scalecolor(exposure, d);
111 doexposure++;
112 i++;
113 break;
114 case 'R': /* reverse byte sequence */
115 if (argv[i][0] == '-') {
116 ord[0]=BLU; ord[1]=GRN; ord[2]=RED;
117 } else {
118 ord[0]=RED; ord[1]=GRN; ord[2]=BLU;
119 }
120 break;
121 case 'r': /* reverse conversion */
122 reverse = argv[i][0] == '-';
123 break;
124 case 'n': /* non-interleaved RGB */
125 interleave = argv[i][0] == '+';
126 break;
127 case 'b': /* brightness values */
128 putprim = argv[i][0] == '-' ? BRIGHT : ALL;
129 break;
130 case 'p': /* put primary */
131 switch (argv[i][2]) {
132 case 'r': case 'R': putprim = RED; break;
133 case 'g': case 'G': putprim = GRN; break;
134 case 'b': case 'B': putprim = BLU; break;
135 default: goto unkopt;
136 }
137 break;
138 case 'd': /* data only (no indices) */
139 dataonly = argv[i][0] == '-';
140 switch (argv[i][2]) {
141 case '\0':
142 case 'a': /* ascii */
143 format = 'a';
144 fmtid = "ascii";
145 break;
146 case 'i': /* integer */
147 format = 'i';
148 fmtid = "ascii";
149 break;
150 case 'b': /* byte */
151 dataonly = 1;
152 format = 'b';
153 fmtid = "byte";
154 break;
155 case 'f': /* float */
156 dataonly = 1;
157 format = 'f';
158 fmtid = "float";
159 break;
160 case 'd': /* double */
161 dataonly = 1;
162 format = 'd';
163 fmtid = "double";
164 break;
165 default:
166 goto unkopt;
167 }
168 break;
169 case 'x': /* x resolution */
170 case 'X': /* x resolution */
171 resolution = 0;
172 if (argv[i][0] == '-')
173 picres.or |= XDECR;
174 picres.xr = atoi(argv[++i]);
175 break;
176 case 'y': /* y resolution */
177 case 'Y': /* y resolution */
178 resolution = 0;
179 if (argv[i][0] == '-')
180 picres.or |= YDECR;
181 if (picres.xr == 0)
182 picres.or |= YMAJOR;
183 picres.yr = atoi(argv[++i]);
184 break;
185 default:
186 unkopt:
187 fprintf(stderr, "%s: unknown option: %s\n",
188 progname, argv[i]);
189 quit(1);
190 break;
191 }
192 else
193 break;
194 /* recognize special formats */
195 if (dataonly && format == 'b')
196 if (brightonly)
197 fmtid = "8-bit_grey";
198 else
199 fmtid = "24-bit_rgb";
200 /* assign reverse ordering */
201 rord[ord[0]] = 0;
202 rord[ord[1]] = 1;
203 rord[ord[2]] = 2;
204 /* get input */
205 if (i == argc) {
206 fin = stdin;
207 } else if (i < argc) {
208 if ((fin = fopen(argv[i], "r")) == NULL) {
209 fprintf(stderr, "%s: can't open file \"%s\"\n",
210 progname, argv[i]);
211 quit(1);
212 }
213 if (reverse && !brightonly && i == argc-3) {
214 if ((fin2 = fopen(argv[i+1], "r")) == NULL) {
215 fprintf(stderr, "%s: can't open file \"%s\"\n",
216 progname, argv[i+1]);
217 quit(1);
218 }
219 if ((fin3 = fopen(argv[i+2], "r")) == NULL) {
220 fprintf(stderr, "%s: can't open file \"%s\"\n",
221 progname, argv[i+2]);
222 quit(1);
223 }
224 interleave = -1;
225 } else if (i != argc-1)
226 fin = NULL;
227 if (reverse && !brightonly && !interleave) {
228 fin2 = fopen(argv[i], "r");
229 fin3 = fopen(argv[i], "r");
230 }
231 if (skipbytes && (fseek(fin, skipbytes, 0) || (fin2 != NULL &&
232 (fseek(fin2, skipbytes, 0) ||
233 fseek(fin3, skipbytes, 0))))) {
234 fprintf(stderr, "%s: cannot skip %ld bytes on input\n",
235 progname, skipbytes);
236 quit(1);
237 }
238 }
239 if (fin == NULL) {
240 fprintf(stderr, "%s: bad # file arguments\n", progname);
241 quit(1);
242 }
243
244 if (reverse) {
245 #ifdef MSDOS
246 setmode(fileno(stdout), O_BINARY);
247 if (format != 'a' && format != 'i')
248 setmode(fileno(fin), O_BINARY);
249 #endif
250 /* get header */
251 if (header) {
252 if (checkheader(fin, fmtid, stdout) < 0) {
253 fprintf(stderr, "%s: wrong input format\n",
254 progname);
255 quit(1);
256 }
257 if (fin2 != NULL) {
258 getheader(fin2, NULL, NULL);
259 getheader(fin3, NULL, NULL);
260 }
261 } else
262 newheader("RADIANCE", stdout);
263 /* get resolution */
264 if ((resolution && !fgetsresolu(&picres, fin)) ||
265 picres.xr <= 0 || picres.yr <= 0) {
266 fprintf(stderr, "%s: missing resolution\n", progname);
267 quit(1);
268 }
269 if (resolution && fin2 != NULL) {
270 RESOLU pres2;
271 if (!fgetsresolu(&pres2, fin2) ||
272 pres2.or != picres.or ||
273 pres2.xr != picres.xr ||
274 pres2.yr != picres.yr ||
275 !fgetsresolu(&pres2, fin3) ||
276 pres2.or != picres.or ||
277 pres2.xr != picres.xr ||
278 pres2.yr != picres.yr) {
279 fprintf(stderr, "%s: resolution mismatch\n",
280 progname);
281 quit(1);
282 }
283 }
284 /* add to header */
285 printargs(i, argv, stdout);
286 if (expval < .99 || expval > 1.01)
287 fputexpos(expval, stdout);
288 fputformat(COLRFMT, stdout);
289 putchar('\n');
290 fputsresolu(&picres, stdout); /* always put resolution */
291 valtopix();
292 } else {
293 #ifdef MSDOS
294 setmode(fileno(fin), O_BINARY);
295 if (format != 'a' && format != 'i')
296 setmode(fileno(stdout), O_BINARY);
297 #endif
298 /* get header */
299 getheader(fin, checkhead, NULL);
300 if (wrongformat) {
301 fprintf(stderr, "%s: input not a Radiance picture\n",
302 progname);
303 quit(1);
304 }
305 if (!fgetsresolu(&picres, fin)) {
306 fprintf(stderr, "%s: missing resolution\n", progname);
307 quit(1);
308 }
309 if (header) {
310 printargs(i, argv, stdout);
311 if (expval < .99 || expval > 1.01)
312 fputexpos(expval, stdout);
313 fputformat(fmtid, stdout);
314 putchar('\n');
315 }
316 if (resolution) /* put resolution */
317 fputsresolu(&picres, stdout);
318 pixtoval();
319 }
320
321 quit(0);
322 }
323
324
325 checkhead(line) /* deal with line from header */
326 char *line;
327 {
328 char fmt[32];
329 double d;
330 COLOR ctmp;
331
332 if (formatval(fmt, line))
333 wrongformat = strcmp(fmt, COLRFMT);
334 else if (original && isexpos(line)) {
335 d = 1.0/exposval(line);
336 scalecolor(exposure, d);
337 doexposure++;
338 } else if (original && iscolcor(line)) {
339 colcorval(ctmp, line);
340 setcolor(exposure, colval(exposure,RED)/colval(ctmp,RED),
341 colval(exposure,GRN)/colval(ctmp,GRN),
342 colval(exposure,BLU)/colval(ctmp,BLU));
343 doexposure++;
344 } else if (header)
345 fputs(line, stdout);
346 }
347
348
349 pixtoval() /* convert picture to values */
350 {
351 register COLOR *scanln;
352 int dogamma;
353 COLOR lastc;
354 FLOAT hv[2];
355 int startprim, endprim;
356 long startpos;
357 int y;
358 register int x;
359
360 scanln = (COLOR *)malloc(scanlen(&picres)*sizeof(COLOR));
361 if (scanln == NULL) {
362 fprintf(stderr, "%s: out of memory\n", progname);
363 quit(1);
364 }
365 dogamma = gamcor < .95 || gamcor > 1.05;
366 if (putprim == ALL && !interleave) {
367 startprim = RED; endprim = BLU;
368 startpos = ftell(fin);
369 } else {
370 startprim = putprim; endprim = putprim;
371 }
372 for (putprim = startprim; putprim <= endprim; putprim++) {
373 if (putprim != startprim && fseek(fin, startpos, 0)) {
374 fprintf(stderr, "%s: seek error on input file\n",
375 progname);
376 quit(1);
377 }
378 set_io();
379 setcolor(lastc, 0.0, 0.0, 0.0);
380 for (y = 0; y < numscans(&picres); y++) {
381 if (freadscan(scanln, scanlen(&picres), fin) < 0) {
382 fprintf(stderr, "%s: read error\n", progname);
383 quit(1);
384 }
385 for (x = 0; x < scanlen(&picres); x++) {
386 if (uniq)
387 if ( colval(scanln[x],RED) ==
388 colval(lastc,RED) &&
389 colval(scanln[x],GRN) ==
390 colval(lastc,GRN) &&
391 colval(scanln[x],BLU) ==
392 colval(lastc,BLU) )
393 continue;
394 else
395 copycolor(lastc, scanln[x]);
396 if (doexposure)
397 multcolor(scanln[x], exposure);
398 if (dogamma)
399 setcolor(scanln[x],
400 pow(colval(scanln[x],RED), 1.0/gamcor),
401 pow(colval(scanln[x],GRN), 1.0/gamcor),
402 pow(colval(scanln[x],BLU), 1.0/gamcor));
403 if (!dataonly) {
404 pix2loc(hv, &picres, x, y);
405 printf("%7d %7d ",
406 (int)(hv[0]*picres.xr),
407 (int)(hv[1]*picres.yr));
408 }
409 if ((*putval)(scanln[x]) < 0) {
410 fprintf(stderr, "%s: write error\n",
411 progname);
412 quit(1);
413 }
414 }
415 }
416 }
417 free((char *)scanln);
418 }
419
420
421 valtopix() /* convert values to a pixel file */
422 {
423 int dogamma;
424 register COLOR *scanln;
425 int y;
426 register int x;
427
428 scanln = (COLOR *)malloc(scanlen(&picres)*sizeof(COLOR));
429 if (scanln == NULL) {
430 fprintf(stderr, "%s: out of memory\n", progname);
431 quit(1);
432 }
433 dogamma = gamcor < .95 || gamcor > 1.05;
434 set_io();
435 for (y = 0; y < numscans(&picres); y++) {
436 for (x = 0; x < scanlen(&picres); x++) {
437 if (!dataonly) {
438 fscanf(fin, "%*d %*d");
439 if (fin2 != NULL) {
440 fscanf(fin2, "%*d %*d");
441 fscanf(fin3, "%*d %*d");
442 }
443 }
444 if ((*getval)(scanln[x]) < 0) {
445 fprintf(stderr, "%s: read error\n", progname);
446 quit(1);
447 }
448 if (dogamma)
449 setcolor(scanln[x],
450 pow(colval(scanln[x],RED), gamcor),
451 pow(colval(scanln[x],GRN), gamcor),
452 pow(colval(scanln[x],BLU), gamcor));
453 if (doexposure)
454 multcolor(scanln[x], exposure);
455 }
456 if (fwritescan(scanln, scanlen(&picres), stdout) < 0) {
457 fprintf(stderr, "%s: write error\n", progname);
458 quit(1);
459 }
460 }
461 free((char *)scanln);
462 }
463
464
465 quit(code)
466 int code;
467 {
468 exit(code);
469 }
470
471
472 getcascii(col) /* get an ascii color value from stream(s) */
473 COLOR col;
474 {
475 double vd[3];
476
477 if (fin2 == NULL) {
478 if (fscanf(fin, "%lf %lf %lf", &vd[0], &vd[1], &vd[2]) != 3)
479 return(-1);
480 } else {
481 if (fscanf(fin, "%lf", &vd[0]) != 1 ||
482 fscanf(fin2, "%lf", &vd[1]) != 1 ||
483 fscanf(fin3, "%lf", &vd[2]) != 1)
484 return(-1);
485 }
486 setcolor(col, vd[rord[RED]], vd[rord[GRN]], vd[rord[BLU]]);
487 return(0);
488 }
489
490
491 getcdouble(col) /* get a double color value from stream(s) */
492 COLOR col;
493 {
494 double vd[3];
495
496 if (fin2 == NULL) {
497 if (fread((char *)vd, sizeof(double), 3, fin) != 3)
498 return(-1);
499 } else {
500 if (fread((char *)vd, sizeof(double), 1, fin) != 1 ||
501 fread((char *)(vd+1), sizeof(double), 1, fin2) != 1 ||
502 fread((char *)(vd+2), sizeof(double), 1, fin3) != 1)
503 return(-1);
504 }
505 setcolor(col, vd[rord[RED]], vd[rord[GRN]], vd[rord[BLU]]);
506 return(0);
507 }
508
509
510 getcfloat(col) /* get a float color value from stream(s) */
511 COLOR col;
512 {
513 float vf[3];
514
515 if (fin2 == NULL) {
516 if (fread((char *)vf, sizeof(float), 3, fin) != 3)
517 return(-1);
518 } else {
519 if (fread((char *)vf, sizeof(float), 1, fin) != 1 ||
520 fread((char *)(vf+1), sizeof(float), 1, fin2) != 1 ||
521 fread((char *)(vf+2), sizeof(float), 1, fin3) != 1)
522 return(-1);
523 }
524 setcolor(col, vf[rord[RED]], vf[rord[GRN]], vf[rord[BLU]]);
525 return(0);
526 }
527
528
529 getcint(col) /* get an int color value from stream(s) */
530 COLOR col;
531 {
532 int vi[3];
533
534 if (fin2 == NULL) {
535 if (fscanf(fin, "%d %d %d", &vi[0], &vi[1], &vi[2]) != 3)
536 return(-1);
537 } else {
538 if (fscanf(fin, "%d", &vi[0]) != 1 ||
539 fscanf(fin2, "%d", &vi[1]) != 1 ||
540 fscanf(fin3, "%d", &vi[2]) != 1)
541 return(-1);
542 }
543 setcolor(col, (vi[rord[RED]]+.5)/256.,
544 (vi[rord[GRN]]+.5)/256., (vi[rord[BLU]]+.5)/256.);
545 return(0);
546 }
547
548
549 getcbyte(col) /* get a byte color value from stream(s) */
550 COLOR col;
551 {
552 BYTE vb[3];
553
554 if (fin2 == NULL) {
555 if (fread((char *)vb, sizeof(BYTE), 3, fin) != 3)
556 return(-1);
557 } else {
558 if (fread((char *)vb, sizeof(BYTE), 1, fin) != 1 ||
559 fread((char *)(vb+1), sizeof(BYTE), 1, fin2) != 1 ||
560 fread((char *)(vb+2), sizeof(BYTE), 1, fin3) != 1)
561 return(-1);
562 }
563 setcolor(col, (vb[rord[RED]]+.5)/256.,
564 (vb[rord[GRN]]+.5)/256., (vb[rord[BLU]]+.5)/256.);
565 return(0);
566 }
567
568
569 getbascii(col) /* get an ascii brightness value from fin */
570 COLOR col;
571 {
572 double vd;
573
574 if (fscanf(fin, "%lf", &vd) != 1)
575 return(-1);
576 setcolor(col, vd, vd, vd);
577 return(0);
578 }
579
580
581 getbdouble(col) /* get a double brightness value from fin */
582 COLOR col;
583 {
584 double vd;
585
586 if (fread((char *)&vd, sizeof(double), 1, fin) != 1)
587 return(-1);
588 setcolor(col, vd, vd, vd);
589 return(0);
590 }
591
592
593 getbfloat(col) /* get a float brightness value from fin */
594 COLOR col;
595 {
596 float vf;
597
598 if (fread((char *)&vf, sizeof(float), 1, fin) != 1)
599 return(-1);
600 setcolor(col, vf, vf, vf);
601 return(0);
602 }
603
604
605 getbint(col) /* get an int brightness value from fin */
606 COLOR col;
607 {
608 int vi;
609 double d;
610
611 if (fscanf(fin, "%d", &vi) != 1)
612 return(-1);
613 d = (vi+.5)/256.;
614 setcolor(col, d, d, d);
615 return(0);
616 }
617
618
619 getbbyte(col) /* get a byte brightness value from fin */
620 COLOR col;
621 {
622 BYTE vb;
623 double d;
624
625 if (fread((char *)&vb, sizeof(BYTE), 1, fin) != 1)
626 return(-1);
627 d = (vb+.5)/256.;
628 setcolor(col, d, d, d);
629 return(0);
630 }
631
632
633 putcascii(col) /* put an ascii color to stdout */
634 COLOR col;
635 {
636 fprintf(stdout, "%15.3e %15.3e %15.3e\n",
637 colval(col,ord[0]),
638 colval(col,ord[1]),
639 colval(col,ord[2]));
640
641 return(ferror(stdout) ? -1 : 0);
642 }
643
644
645 putcfloat(col) /* put a float color to stdout */
646 COLOR col;
647 {
648 float vf[3];
649
650 vf[0] = colval(col,ord[0]);
651 vf[1] = colval(col,ord[1]);
652 vf[2] = colval(col,ord[2]);
653 fwrite((char *)vf, sizeof(float), 3, stdout);
654
655 return(ferror(stdout) ? -1 : 0);
656 }
657
658
659 putcdouble(col) /* put a double color to stdout */
660 COLOR col;
661 {
662 double vd[3];
663
664 vd[0] = colval(col,ord[0]);
665 vd[1] = colval(col,ord[1]);
666 vd[2] = colval(col,ord[2]);
667 fwrite((char *)vd, sizeof(double), 3, stdout);
668
669 return(ferror(stdout) ? -1 : 0);
670 }
671
672
673 putcint(col) /* put an int color to stdout */
674 COLOR col;
675 {
676 fprintf(stdout, "%d %d %d\n",
677 (int)(colval(col,ord[0])*256.),
678 (int)(colval(col,ord[1])*256.),
679 (int)(colval(col,ord[2])*256.));
680
681 return(ferror(stdout) ? -1 : 0);
682 }
683
684
685 putcbyte(col) /* put a byte color to stdout */
686 COLOR col;
687 {
688 register int i;
689 BYTE vb[3];
690
691 i = colval(col,ord[0])*256.;
692 vb[0] = min(i,255);
693 i = colval(col,ord[1])*256.;
694 vb[1] = min(i,255);
695 i = colval(col,ord[2])*256.;
696 vb[2] = min(i,255);
697 fwrite((char *)vb, sizeof(BYTE), 3, stdout);
698
699 return(ferror(stdout) ? -1 : 0);
700 }
701
702
703 putbascii(col) /* put an ascii brightness to stdout */
704 COLOR col;
705 {
706 fprintf(stdout, "%15.3e\n", bright(col));
707
708 return(ferror(stdout) ? -1 : 0);
709 }
710
711
712 putbfloat(col) /* put a float brightness to stdout */
713 COLOR col;
714 {
715 float vf;
716
717 vf = bright(col);
718 fwrite((char *)&vf, sizeof(float), 1, stdout);
719
720 return(ferror(stdout) ? -1 : 0);
721 }
722
723
724 putbdouble(col) /* put a double brightness to stdout */
725 COLOR col;
726 {
727 double vd;
728
729 vd = bright(col);
730 fwrite((char *)&vd, sizeof(double), 1, stdout);
731
732 return(ferror(stdout) ? -1 : 0);
733 }
734
735
736 putbint(col) /* put an int brightness to stdout */
737 COLOR col;
738 {
739 fprintf(stdout, "%d\n", (int)(bright(col)*256.));
740
741 return(ferror(stdout) ? -1 : 0);
742 }
743
744
745 putbbyte(col) /* put a byte brightness to stdout */
746 COLOR col;
747 {
748 register int i;
749 BYTE vb;
750
751 i = bright(col)*256.;
752 vb = min(i,255);
753 fwrite((char *)&vb, sizeof(BYTE), 1, stdout);
754
755 return(ferror(stdout) ? -1 : 0);
756 }
757
758
759 putpascii(col) /* put an ascii primary to stdout */
760 COLOR col;
761 {
762 fprintf(stdout, "%15.3e\n", colval(col,putprim));
763
764 return(ferror(stdout) ? -1 : 0);
765 }
766
767
768 putpfloat(col) /* put a float primary to stdout */
769 COLOR col;
770 {
771 float vf;
772
773 vf = colval(col,putprim);
774 fwrite((char *)&vf, sizeof(float), 1, stdout);
775
776 return(ferror(stdout) ? -1 : 0);
777 }
778
779
780 putpdouble(col) /* put a double primary to stdout */
781 COLOR col;
782 {
783 double vd;
784
785 vd = colval(col,putprim);
786 fwrite((char *)&vd, sizeof(double), 1, stdout);
787
788 return(ferror(stdout) ? -1 : 0);
789 }
790
791
792 putpint(col) /* put an int primary to stdout */
793 COLOR col;
794 {
795 fprintf(stdout, "%d\n", (int)(colval(col,putprim)*256.));
796
797 return(ferror(stdout) ? -1 : 0);
798 }
799
800
801 putpbyte(col) /* put a byte primary to stdout */
802 COLOR col;
803 {
804 register int i;
805 BYTE vb;
806
807 i = colval(col,putprim)*256.;
808 vb = min(i,255);
809 fwrite((char *)&vb, sizeof(BYTE), 1, stdout);
810
811 return(ferror(stdout) ? -1 : 0);
812 }
813
814
815 set_io() /* set put and get functions */
816 {
817 switch (format) {
818 case 'a': /* ascii */
819 if (putprim == BRIGHT) {
820 getval = getbascii;
821 putval = putbascii;
822 } else if (putprim != ALL) {
823 getval = getbascii;
824 putval = putpascii;
825 } else {
826 getval = getcascii;
827 putval = putcascii;
828 if (reverse && !interleave) {
829 fprintf(stderr,
830 "%s: ASCII input files must be interleaved\n",
831 progname);
832 quit(1);
833 }
834 }
835 return;
836 case 'f': /* binary float */
837 if (putprim == BRIGHT) {
838 getval = getbfloat;
839 putval = putbfloat;
840 } else if (putprim != ALL) {
841 getval = getbfloat;
842 putval = putpfloat;
843 } else {
844 getval = getcfloat;
845 putval = putcfloat;
846 if (reverse && !interleave) {
847 if (fin2 == NULL)
848 goto namerr;
849 if (fseek(fin2,
850 (long)sizeof(float)*picres.xr*picres.yr, 1))
851 goto seekerr;
852 if (fseek(fin3,
853 (long)sizeof(float)*2*picres.xr*picres.yr, 1))
854 goto seekerr;
855 }
856 }
857 return;
858 case 'd': /* binary double */
859 if (putprim == BRIGHT) {
860 getval = getbdouble;
861 putval = putbdouble;
862 } else if (putprim != ALL) {
863 getval = getbdouble;
864 putval = putpdouble;
865 } else {
866 getval = getcdouble;
867 putval = putcdouble;
868 if (reverse && !interleave) {
869 if (fin2 == NULL)
870 goto namerr;
871 if (fseek(fin2,
872 (long)sizeof(double)*picres.xr*picres.yr, 1))
873 goto seekerr;
874 if (fseek(fin3,
875 (long)sizeof(double)*2*picres.xr*picres.yr, 1))
876 goto seekerr;
877 }
878 }
879 return;
880 case 'i': /* integer */
881 if (putprim == BRIGHT) {
882 getval = getbint;
883 putval = putbint;
884 } else if (putprim != ALL) {
885 getval = getbint;
886 putval = putpint;
887 } else {
888 getval = getcint;
889 putval = putcint;
890 if (reverse && !interleave) {
891 fprintf(stderr,
892 "%s: integer input files must be interleaved\n",
893 progname);
894 quit(1);
895 }
896 }
897 return;
898 case 'b': /* byte */
899 if (putprim == BRIGHT) {
900 getval = getbbyte;
901 putval = putbbyte;
902 } else if (putprim != ALL) {
903 getval = getbbyte;
904 putval = putpbyte;
905 } else {
906 getval = getcbyte;
907 putval = putcbyte;
908 if (reverse && !interleave) {
909 if (fin2 == NULL)
910 goto namerr;
911 if (fseek(fin2,
912 (long)sizeof(BYTE)*picres.xr*picres.yr, 1))
913 goto seekerr;
914 if (fseek(fin3,
915 (long)sizeof(BYTE)*2*picres.xr*picres.yr, 1))
916 goto seekerr;
917 }
918 }
919 return;
920 }
921 badopt:
922 fprintf(stderr, "%s: botched file type\n", progname);
923 quit(1);
924 namerr:
925 fprintf(stderr, "%s: non-interleaved file(s) must be named\n",
926 progname);
927 quit(1);
928 seekerr:
929 fprintf(stderr, "%s: cannot seek on interleaved input file\n",
930 progname);
931 quit(1);
932 }
