1 |
#!/bin/csh -f |
2 |
# RCSid: $Id: psquish.csh,v 3.4 2005/02/16 05:40:11 greg Exp $ |
3 |
set Lmin=.0001 # minimum visible world luminance |
4 |
set Ldmin=1 # minimum display luminance |
5 |
set Ldmax=100 # maximum display luminance |
6 |
set nsteps=100 # number of steps in perceptual histogram |
7 |
set cvratio=0.05 # fraction of pixels to ignore in envelope clipping |
8 |
set td=/tmp |
9 |
set tf0=$td/tf$$ |
10 |
set tf1=$td/hist$$ |
11 |
set tf1b=$td/hist$$.diff |
12 |
set tf2=$td/cumt$$ |
13 |
set tf3=$td/histeq$$.cal |
14 |
set tf4=$td/cf$$.cal |
15 |
set tf=($tf0 $tf1 $tf1b $tf2 $tf3 $tf4) |
16 |
if ( "$argv[1]" == "-a" ) then |
17 |
set adaptive |
18 |
shift argv |
19 |
endif |
20 |
if ( $#argv != 1 ) then |
21 |
echo "Usage: $0 [-a] input.hdr > output.hdr" |
22 |
exit 1 |
23 |
endif |
24 |
set ifile=$1 |
25 |
set ibase=$ifile:t |
26 |
if ( "$ibase" =~ *.hdr ) set ibase=$ibase:r |
27 |
set ibase=$ibase:t |
28 |
onintr quit |
29 |
pextrem -o $ifile > $tf0 |
30 |
set Lmin=`rcalc -e 'L=179*(.265*$3+.67*$4+.065*$5)' -e 'cond=1.5-recno;$1=if('L-$Lmin,L,$Lmin')' $tf0` |
31 |
set Lmax=`rcalc -e 'L=179*(.265*$3+.67*$4+.065*$5)' -e 'cond=recno-1.5;$1=if('$Ldmax-L,$Ldmax,L')' $tf0` |
32 |
cat > $tf3 << _EOF_ |
33 |
min(a,b) : if(a-b, b, a); |
34 |
WE : 179; { Radiance white luminous efficacy } |
35 |
Lmin : $Lmin ; { minimum visible luminance } |
36 |
Lmax : $Lmax ; { maximum picture luminance } |
37 |
Ldmin : $Ldmin ; { minimum output luminance } |
38 |
Ldmax : $Ldmax ; { maximum output luminance } |
39 |
Stepsiz : (Bl(Lmax)-Bl(Lmin))/ $nsteps ; { brightness step size } |
40 |
{ Logarithmic brightness function } |
41 |
Bl(L) : log(L); |
42 |
Lb(B) : exp(B); |
43 |
BLw(Lw) : Bl(Ldmin) + (Bl(Ldmax)-Bl(Ldmin))*cf(Bl(Lw)); |
44 |
{ first derivative functions } |
45 |
Bl1(L) : 1/L; |
46 |
Lb1(B) : exp(B); |
47 |
{ histogram equalization function } |
48 |
lin = li(1); |
49 |
Lw = WE/le(1) * lin; |
50 |
Lout = Lb(BLw(Lw)); |
51 |
mult = if(Lw-Lmin, (Lout-Ldmin)/(Ldmax-Ldmin)/lin, 0) ; |
52 |
_EOF_ |
53 |
if ( $?adaptive ) then |
54 |
cat >> $tf3 << _EOF_ |
55 |
{ Ferwerda contrast sensitivity function } |
56 |
{ log10 of cone threshold luminance } |
57 |
ltp(lLa) : if(-2.6 - lLa, -.72, if(lLa - 1.9, lLa - 1.255, |
58 |
(.249*lLa + .65)^2.7 - .72)); |
59 |
{ log10 of rod threshold luminance } |
60 |
lts(lLa) : if(-3.94 - lLa, -2.86, if(lLa - -1.44, lLa - .395, |
61 |
(.405*lLa + 1.6)^2.18 - 2.86)); |
62 |
{ threshold is minimum of rods and cones } |
63 |
ldL2(lLa) : min(ltp(lLa),lts(lLa)); |
64 |
dL(La) : 10^ldL2(log10(La)); |
65 |
{ derivative clamping function } |
66 |
clamp2(L, bLw) : dL(Lb(bLw))/dL(L)/Lb1(bLw)/(Bl(Ldmax)-Bl(Ldmin))/Bl1(L); |
67 |
clamp(L) : clamp2(L, BLw(L)); |
68 |
{ shift direction for histogram } |
69 |
shiftdir(B) : if(cf(B) - (B - Bl(Lmin))/(Bl(Ldmax) - Bl(Lmin)), 1, -1); |
70 |
{ Scotopic/Photopic color adjustment } |
71 |
sL(r,g,b) : .062*r + .608*g + .330*b; { approx. scotopic brightness } |
72 |
BotMesopic : 10^-2.25; { top of scotopic range } |
73 |
TopMesopic : 10^0.75; { bottom of photopic range } |
74 |
incolor = if(Lw-TopMesopic, 1, if(BotMesopic-Lw, 0, |
75 |
(Lw-BotMesopic)/(TopMesopic-BotMesopic))); |
76 |
slf = (1 - incolor)*sL(ri(1),gi(1),bi(1)); |
77 |
ro = mult*(incolor*ri(1) + slf); |
78 |
go = mult*(incolor*gi(1) + slf); |
79 |
bo = mult*(incolor*bi(1) + slf); |
80 |
_EOF_ |
81 |
else |
82 |
83 |
84 |
clamp2(L, bLw) : Lb(bLw)/L/Lb1(bLw)/(Bl(Ldmax)-Bl(Ldmin))/Bl1(L); |
85 |
86 |
87 |
shiftdir(B) : -1; |
88 |
ro = mult*ri(1); |
89 |
go = mult*gi(1); |
90 |
bo = mult*bi(1); |
91 |
_EOF_ |
92 |
endif |
93 |
# Compute brightness histogram |
94 |
pfilt -1 -p 1 -x 128 -y 128 $ifile | pvalue -o -b -d -h -H \ |
95 |
| rcalc -f $tf3 -e 'Lw=WE*$1;$1=if(Lw-Lmin,Bl(Lw),-1)' \ |
96 |
| histo `ev "log($Lmin)" "log($Lmax)"` $nsteps > $tf1 |
97 |
# Clamp frequency distribution |
98 |
set totcount=`sed 's/^.*[ ]//' $tf1 | total` |
99 |
set margin=`ev "floor($totcount*$cvratio+.5)"` |
100 |
while ( 1 ) |
101 |
# Compute mapping function |
102 |
sed 's/^.*[ ]//' $tf1 | total -1 -r \ |
103 |
| rcalc -e '$1=$1/'$totcount | rlam $tf1 - \ |
104 |
| tabfunc -i 0 cf > $tf4 |
105 |
# Compute difference with visible envelope |
106 |
rcalc -f $tf4 -f $tf3 -e "T:$totcount*Stepsiz" \ |
107 |
-e 'clfq=floor(T*clamp(Lb($1))+.5)' \ |
108 |
-e '$1=$2-clfq;$2=shiftdir($1)' $tf1 > $tf1b |
109 |
if (`sed 's/[ ].*$//' $tf1b | total` >= 0) then |
110 |
# Nothing visible? -- just normalize |
111 |
pfilt -1 -e `pextrem $ifile | rcalc -e 'cond=recno-1.5;$1=1/(.265*$3+.67*$4+.065*$5)'` $ifile |
112 |
goto quit |
113 |
endif |
114 |
# Check to see if we're close enough |
115 |
if (`rcalc -e '$1=if($1,$1,0)' $tf1b | total` <= $margin) break |
116 |
# Squash frequency distribution |
117 |
set diffs=(`sed 's/[ ].*$//' $tf1b`) |
118 |
set shftd=(`sed 's/^.*[ ]//' $tf1b`) |
119 |
while ( 1 ) |
120 |
set maxi=0 |
121 |
set maxd=0 |
122 |
set i=$nsteps |
123 |
while ( $i > 0 ) |
124 |
if ( $diffs[$i] > $maxd ) then |
125 |
set maxd=$diffs[$i] |
126 |
set maxi=$i |
127 |
endif |
128 |
@ i-- |
129 |
end |
130 |
if ( $maxd == 0 ) break |
131 |
set i=0 |
132 |
tryagain: |
133 |
set r=$shftd[$maxi] |
134 |
while ( $i == 0 ) |
135 |
@ t= $maxi + $r |
136 |
if ( $t < 1 || $t > $nsteps ) then |
137 |
@ shftd[$maxi]= -($shftd[$maxi]) |
138 |
goto tryagain |
139 |
endif |
140 |
if ( $diffs[$t] < 0 ) set i=$t |
141 |
@ r+= $shftd[$maxi] |
142 |
end |
143 |
if ( $diffs[$i] <= -$diffs[$maxi] ) then |
144 |
@ diffs[$i]+= $diffs[$maxi] |
145 |
set diffs[$maxi]=0 |
146 |
else |
147 |
@ diffs[$maxi]+= $diffs[$i] |
148 |
set diffs[$i]=0 |
149 |
endif |
150 |
end |
151 |
# Mung histogram |
152 |
echo $diffs | tr ' ' '\012' | rlam $tf1 - \ |
153 |
154 |
155 |
-e '$1=$1;$2=$3+clfq' > $tf1b |
156 |
mv -f $tf1b $tf1 |
157 |
end |
158 |
# Plot the mapping function if we are in debug mode |
159 |
if ( $?DEBUG ) then |
160 |
cat > ${ibase}_histo.plt << _EOF_ |
161 |
include=curve.plt |
162 |
title="Brightness Frequency Distribution" |
163 |
subtitle= $ibase |
164 |
ymin=0 |
165 |
xlabel="Perceptual Brightness B(Lw)" |
166 |
ylabel="Frequency Count" |
167 |
Alabel="Histogram" |
168 |
Alintype=0 |
169 |
Blabel="Envelope" |
170 |
Bsymsize=0 |
171 |
Adata= |
172 |
_EOF_ |
173 |
(cat $tf1; echo \;; echo Bdata=) >> ${ibase}_histo.plt |
174 |
175 |
-e '$1=$1;$2=T*clamp(Lb($1))' $tf1 \ |
176 |
177 |
cat > ${ibase}_brmap.plt << _EOF_ |
178 |
include=line.plt |
179 |
title="Brightness Mapping Function" |
180 |
subtitle= $ibase |
181 |
xlabel="World Luminance (log cd/m^2)" |
182 |
ylabel="Display Luminance (cd/m^2)" |
183 |
ymax= $Ldmax |
184 |
Adata= |
185 |
_EOF_ |
186 |
cnt 100 | rcalc -f $tf4 -f $tf3 -e '$1=lx;$2=Lb(BLw(10^lx))' \ |
187 |
-e 'lx=$1/99*(log10(Lmax)-log10(Lmin))+log10(Lmin)' \ |
188 |
>> ${ibase}_brmap.plt |
189 |
if ( $?DISPLAY ) then |
190 |
bgraph ${ibase}_histo.plt ${ibase}_brmap.plt | x11meta & |
191 |
endif |
192 |
endif |
193 |
# Map our picture |
194 |
getinfo < $ifile | egrep '^((VIEW|PIXASPECT|PRIMARIES)=|[^ ]*(rpict|rview|pinterp) )' |
195 |
pcomb -f $tf4 -f $tf3 $ifile |
196 |
quit: |
197 |
rm -f $tf |
