1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: psketch.c,v 2.4 2018/08/02 18:33:46 greg Exp $"; |
3 |
#endif |
4 |
5 |
* psketch.c - modify picture to sketch objects with named modifiers |
6 |
7 |
* 9/23/2017 |
8 |
9 |
10 |
#include "copyright.h" |
11 |
12 |
#include <string.h> |
13 |
14 |
#include "standard.h" |
15 |
#include "platform.h" |
16 |
#include "resolu.h" |
17 |
#include "color.h" |
18 |
19 |
#define MAXMOD 2048 /* maximum number of modifiers */ |
20 |
#define USESORT 12 /* switch to sorted search */ |
21 |
22 |
double smoothing = 0.8; /* weight for moving average filter */ |
23 |
double mixfact = 0.3; /* amount to mix above/below */ |
24 |
25 |
char *modlist[MAXMOD]; /* (sorted) modifier list */ |
26 |
int nmods = 0; /* number of modifiers */ |
27 |
28 |
unsigned char *hasmod; /* scanline bitmap */ |
29 |
unsigned char *hasmod1; |
30 |
COLOR *scan[2]; /* i/o scanlines */ |
31 |
RESOLU pres; /* input resolution */ |
32 |
int bmwidth; /* bytes per bitmap */ |
33 |
34 |
#undef tstbit /* conflicting def's in param.h */ |
35 |
#undef setbit |
36 |
#undef clrbit |
37 |
#undef tglbit |
38 |
39 |
#define bitop(bm,x,op) ((bm)[(x)>>3] op (1<<((x)&7))) |
40 |
#define tstbit(bm,x) bitop(bm,x,&) |
41 |
#define setbit(bm,x) bitop(bm,x,|=) |
42 |
#define clrbit(bm,x) bitop(bm,x,&=~) |
43 |
#define tglbit(bm,x) bitop(bm,x,^=) |
44 |
45 |
const char *octree, *infname; /* input octree and picture names */ |
46 |
FILE *infp; /* picture input stream */ |
47 |
FILE *mafp; /* pipe from rtrace with modifiers */ |
48 |
int linesread = 0; /* scanlines read so far */ |
49 |
50 |
static int |
51 |
find_mod(const char *s) |
52 |
53 |
int ilower, iupper; |
54 |
int c, i; |
55 |
56 |
if (nmods < USESORT) { /* linear search */ |
57 |
for (i = nmods; i-- > 0; ) |
58 |
if (!strcmp(s, modlist[i])) |
59 |
return(i); |
60 |
return(-1); |
61 |
62 |
ilower = 0; iupper = nmods; |
63 |
c = iupper; /* binary search */ |
64 |
while ((i = (iupper + ilower) >> 1) != c) { |
65 |
c = strcmp(s, modlist[i]); |
66 |
if (c > 0) |
67 |
ilower = i; |
68 |
else if (c < 0) |
69 |
iupper = i; |
70 |
else |
71 |
return(i); |
72 |
c = i; |
73 |
74 |
return(-1); |
75 |
76 |
77 |
static int |
78 |
read_scan(void) |
79 |
80 |
const int spread = (int)(smoothing*10); |
81 |
int x, width = scanlen(&pres); |
82 |
unsigned char *tbmp; |
83 |
COLOR *tscn; |
84 |
char modbuf[516]; |
85 |
/* advance buffer */ |
86 |
tscn = scan[0]; |
87 |
scan[0] = scan[1]; |
88 |
scan[1] = tscn; |
89 |
/* check if we are at the end */ |
90 |
if (linesread >= numscans(&pres)) |
91 |
return(0); |
92 |
/* set scanline bitmap */ |
93 |
if (linesread) { |
94 |
/* load & check materials */ |
95 |
memset(hasmod1, 0, bmwidth); |
96 |
for (x = 0; x < width; x++) { |
97 |
int len; |
98 |
if (fgets(modbuf, sizeof(modbuf), mafp) == NULL) { |
99 |
fprintf(stderr, "Error reading from rtrace!\n"); |
100 |
return(-1); |
101 |
102 |
len = strlen(modbuf); |
103 |
if (len < 3 || (modbuf[len-1] != '\n') | |
104 |
(modbuf[len-2] != '\t')) { |
105 |
fprintf(stderr, "Garbled rtrace output: %s", modbuf); |
106 |
return(-1); |
107 |
108 |
modbuf[len-2] = '\0'; |
109 |
if (find_mod(modbuf) >= 0) |
110 |
setbit(hasmod1, x); |
111 |
112 |
/* smear to cover around object */ |
113 |
memset(hasmod, 0, bmwidth); |
114 |
for (x = spread; x < width-spread; x++) { |
115 |
int ox; |
116 |
if (!tstbit(hasmod1,x)) continue; |
117 |
for (ox = -spread; ox <= spread; ox++) |
118 |
setbit(hasmod,x+ox); |
119 |
120 |
121 |
/* read next picture scanline */ |
122 |
if (freadscan(scan[1], width, infp) < 0) { |
123 |
fprintf(stderr, "%s: error reading scanline %d\n", |
124 |
infname, linesread); |
125 |
return(-1); |
126 |
127 |
return(++linesread); |
128 |
129 |
130 |
static int |
131 |
spcmp(const void *p1, const void *p2) |
132 |
133 |
return strcmp(*(const char **)p1, *(const char **)p2); |
134 |
135 |
136 |
static int |
137 |
get_started(void) |
138 |
139 |
char combuf[1024]; |
140 |
141 |
if (nmods >= USESORT) /* need to sort for search? */ |
142 |
qsort(modlist, nmods, sizeof(char *), &spcmp); |
143 |
/* open pipe from rtrace */ |
144 |
sprintf(combuf, "vwrays -fd %s | rtrace -h -fda -om %s", |
145 |
infname, octree); |
146 |
mafp = popen(combuf, "r"); |
147 |
if (mafp == NULL) { |
148 |
perror("popen"); |
149 |
return(0); |
150 |
151 |
/* allocate bitmaps & buffers */ |
152 |
bmwidth = (scanlen(&pres)+7) >> 3; |
153 |
hasmod = (unsigned char *)malloc(bmwidth); |
154 |
hasmod1 = (unsigned char *)malloc(bmwidth); |
155 |
scan[0] = (COLOR *)malloc(scanlen(&pres)*sizeof(COLOR)); |
156 |
scan[1] = (COLOR *)malloc(scanlen(&pres)*sizeof(COLOR)); |
157 |
if (!hasmod | !hasmod1 | !scan[0] | !scan[1]) { |
158 |
perror("malloc"); |
159 |
return(0); |
160 |
161 |
if (!read_scan()) /* read first scanline */ |
162 |
return(0); |
163 |
return(1); |
164 |
165 |
166 |
static int |
167 |
advance_scanline(void) |
168 |
169 |
static int alldone = 0; |
170 |
int width = scanlen(&pres); |
171 |
int height = numscans(&pres); |
172 |
int x, xstart = 0, xstop = width, xstep = 1; |
173 |
COLOR cmavg; |
174 |
175 |
if (alldone) /* finished last scanline? */ |
176 |
return(0); |
177 |
alldone = (linesread >= height); |
178 |
/* advance scanline */ |
179 |
if (read_scan() < !alldone) |
180 |
return(-1); |
181 |
if (linesread & 1) { /* process in horizontal zig-zag */ |
182 |
xstart = width-1; |
183 |
xstop = -1; |
184 |
xstep = -1; |
185 |
186 |
setcolor(cmavg, .0f, .0f, .0f); /* process this scanline */ |
187 |
for (x = xstart; x != xstop; x += xstep) { |
188 |
COLOR cmix; |
189 |
if (!tstbit(hasmod,x)) continue; |
190 |
/* apply moving average */ |
191 |
scalecolor(scan[0][x], 1.-smoothing); |
192 |
scalecolor(cmavg, smoothing); |
193 |
addcolor(cmavg, scan[0][x]); |
194 |
copycolor(scan[0][x], cmavg); |
195 |
/* mix pixel into next scanline */ |
196 |
copycolor(cmix, scan[0][x]); |
197 |
scalecolor(cmix, mixfact); |
198 |
scalecolor(scan[1][x], 1.-mixfact); |
199 |
addcolor(scan[1][x], cmix); |
200 |
201 |
/* write out result */ |
202 |
if (fwritescan(scan[0], width, stdout) < 0) { |
203 |
perror("write error"); |
204 |
return(-1); |
205 |
206 |
return(1); |
207 |
208 |
209 |
static int |
210 |
clean_up(void) |
211 |
212 |
char linebuf[128]; |
213 |
/* read unused materials */ |
214 |
while (fgets(linebuf, sizeof(linebuf), mafp) != NULL) |
215 |
216 |
if (pclose(mafp) != 0) { |
217 |
fprintf(stderr, "Error running rtrace!\n"); |
218 |
return(0); |
219 |
220 |
fclose(infp); |
221 |
free(hasmod); |
222 |
free(hasmod1); |
223 |
free(scan[0]); |
224 |
free(scan[1]); |
225 |
return(1); |
226 |
227 |
228 |
int |
229 |
main(int argc, char *argv[]) |
230 |
231 |
int i, rval; |
232 |
char pfmt[MAXFMTLEN]; |
233 |
/* process options */ |
234 |
for (i = 1; i < argc && argv[i][0] == '-'; i++) |
235 |
switch (argv[i][1]) { |
236 |
case 'm': /* new modifier name */ |
237 |
if (nmods >= MAXMOD) { |
238 |
fprintf(stderr, "%s: too many modifiers\n", argv[0]); |
239 |
return(1); |
240 |
241 |
modlist[nmods++] = argv[++i]; |
242 |
break; |
243 |
case 'M': /* modifier file */ |
244 |
rval = wordfile(modlist, MAXMOD-nmods, argv[++i]); |
245 |
if (rval < 0) { |
246 |
fprintf(stderr, "%s: cannot open modifier file '%s'\n", |
247 |
argv[0], argv[i]); |
248 |
return(1); |
249 |
250 |
nmods += rval; |
251 |
break; |
252 |
case 's': /* filter smoothing amount */ |
253 |
smoothing = atof(argv[++i]); |
254 |
if ((smoothing <= FTINY) | (smoothing >= 1.-FTINY)) { |
255 |
fprintf(stderr, "%s: smoothing factor must be in (0,1) range\n", |
256 |
argv[0]); |
257 |
return(1); |
258 |
259 |
break; |
260 |
default: |
261 |
fprintf(stderr, "%s: unknown option '%s'\n", |
262 |
263 |
return(1); |
264 |
265 |
if ((argc-i < 2) | (argc-i > 3)) { |
266 |
fprintf(stderr, "Usage: %s [-m modname][-M modfile][-s smoothing] octree input.hdr [output.hdr]\n", |
267 |
argv[0]); |
268 |
return(1); |
269 |
270 |
if (!nmods) { |
271 |
fprintf(stderr, "%s: at least one '-m' or '-M' option needed\n", |
272 |
argv[0]); |
273 |
return(1); |
274 |
275 |
octree = argv[i]; |
276 |
infname = argv[i+1]; /* open input picture */ |
277 |
infp = fopen(infname, "rb"); |
278 |
if (infp == NULL) { |
279 |
fprintf(stderr, "%s: cannot open input '%s' for reading\n", |
280 |
argv[0], argv[i+1]); |
281 |
return(1); |
282 |
283 |
if (i+2 < argc && /* open output picture */ |
284 |
freopen(argv[i+2], "w", stdout) == NULL) { |
285 |
fprintf(stderr, "%s: cannot open output '%s' for writing\n", |
286 |
argv[0], argv[i+2]); |
287 |
return(1); |
288 |
289 |
SET_FILE_BINARY(stdout); |
290 |
strcpy(pfmt, PICFMT); /* copy format/resolution */ |
291 |
if (checkheader(infp, pfmt, stdout) < 0 || !fgetsresolu(&pres, infp)) { |
292 |
fprintf(stderr, "%s: bad format for input picture\n", |
293 |
argv[0]); |
294 |
return(1); |
295 |
296 |
printargs(argc, argv, stdout); /* complete header */ |
297 |
fputformat(pfmt, stdout); |
298 |
fputc('\n', stdout); |
299 |
fputsresolu(&pres, stdout); /* resolution does not change */ |
300 |
if (!get_started()) |
301 |
return(1); |
302 |
while ((rval = advance_scanline())) |
303 |
if (rval < 0) |
304 |
return(1); |
305 |
if (!clean_up()) |
306 |
return(1); |
307 |
return(0); |
308 |
