root/radiance/ray/src/px/psign.c
Revision: 2.1
Committed: Tue Nov 12 16:04:19 1991 UTC (33 years, 9 months ago) by greg
1 /* Copyright (c) 1991 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * psign.c - produce picture from text.
9 *
10 * 7/1/87
11 */
12
13 #include <stdio.h>
14
15 #include "color.h"
16
17 #define MAXLINE 512 /* longest allowable line */
18
19 char *fontfile = "helvet.fnt"; /* our font file */
20
21 COLR bgcolr = WHTCOLR; /* background color */
22 COLR fgcolr = BLKCOLR; /* foreground color */
23
24 int direct = 'r'; /* direction (right, up, left, down) */
25
26 int cheight = 32; /* character height */
27 double aspect = 1.67; /* height/width character aspect */
28 int cwidth; /* computed character width */
29
30 unsigned char *ourbitmap; /* our output bitmap */
31 int xsiz, ysiz; /* bitmap dimensions */
32 int xdim; /* size of horizontal scan (bytes) */
33
34 #define bitop(x,y,op) (ourbitmap[(y)*xdim+((x)>>3)] op (1<<((x)&7)))
35 #define tstbit(x,y) bitop(x,y,&)
36 #define setbit(x,y) bitop(x,y,|=)
37 #define clrbit(x,y) bitop(x,y,&=~)
38 #define tglbit(x,y) bitop(x,y,^=)
39
40 typedef unsigned char GLYPH;
41
42 GLYPH *ourfont[128]; /* our font */
43
44 typedef struct line {
45 char *s; /* line w/o LF */
46 struct line *next; /* next line up */
47 } LINE;
48
49 LINE *ourtext; /* our text */
50 int nlines, maxline; /* text dimensions */
51
52 extern char *malloc(), *calloc();
53 extern FILE *fropen();
54
55
56 main(argc, argv)
57 int argc;
58 char *argv[];
59 {
60 double atof();
61 int an;
62
63 for (an = 1; an < argc && argv[an][0] == '-'; an++)
64 switch (argv[an][1]) {
65 case 'c': /* color */
66 switch (argv[an][2]) {
67 case 'f': /* foreground */
68 setcolr(fgcolr, atof(argv[an+1]),
69 atof(argv[an+2]),
70 atof(argv[an+3]));
71 an += 3;
72 break;
73 case 'b': /* background */
74 setcolr(bgcolr, atof(argv[an+1]),
75 atof(argv[an+2]),
76 atof(argv[an+3]));
77 an += 3;
78 break;
79 default:
80 goto unkopt;
81 }
82 break;
83 case 'f': /* font */
84 fontfile = argv[++an];
85 break;
86 case 'd': /* direction */
87 switch (argv[an][2]) {
88 case 'r': /* right */
89 case 'u': /* up */
90 case 'l': /* left */
91 case 'd': /* down */
92 direct = argv[an][2];
93 break;
94 default:
95 goto unkopt;
96 }
97 break;
98 case 'h': /* height of characters */
99 cheight = atoi(argv[++an]);
100 break;
101 case 'a': /* aspect ratio */
102 aspect = atof(argv[++an]);
103 break;
104 default:;
105 unkopt:
106 fprintf(stderr, "%s: unknown option: %s\n",
107 argv[0], argv[an]);
108 exit(1);
109 }
110 /* get text */
111 if (an == argc)
112 gettext(stdin);
113 else
114 arg_text(argc-an, argv+an);
115
116 /* create bit map */
117 makemap();
118 /* load font file */
119 loadfont();
120 /* convert text to bitmap */
121 maptext();
122 /* print header */
123 printargs(argc, argv, stdout);
124 fputformat(COLRFMT, stdout);
125 putchar('\n');
126 /* write out bitmap */
127 writemap(stdout);
128
129 exit(0);
130 }
131
132
133 makemap() /* create the bit map */
134 {
135 cwidth = cheight/aspect + 0.5;
136 if (direct == 'r' || direct == 'l') {
137 xsiz = maxline*cwidth;
138 ysiz = nlines*cheight;
139 } else { /* reverse orientation */
140 xsiz = nlines*cheight;
141 ysiz = maxline*cwidth;
142 }
143 xdim = (xsiz+7)/8;
144 ourbitmap = (BYTE *)calloc(ysiz, xdim);
145 if (ourbitmap == NULL) {
146 fprintf(stderr, "out of memory in makemap\n");
147 exit(1);
148 }
149 }
150
151
152 loadfont() /* load the font file */
153 {
154 FILE *fp;
155 char *err;
156 int gn, ngv, gv;
157 register GLYPH *g;
158
159 if ((fp = fropen(fontfile)) == NULL) {
160 fprintf(stderr, "cannot find font file \"%s\"\n",
161 fontfile);
162 exit(1);
163 }
164 while (fscanf(fp, "%d", &gn) == 1) { /* get each glyph */
165 if (gn < 0 || gn > 127) {
166 err = "illegal";
167 goto fonterr;
168 }
169 if (ourfont[gn] != NULL) {
170 err = "duplicate";
171 goto fonterr;
172 }
173 if (fscanf(fp, "%d", &ngv) != 1 ||
174 ngv < 0 || ngv > 255) {
175 err = "bad # vertices for";
176 goto fonterr;
177 }
178 g = (GLYPH *)malloc((2*ngv+1)*sizeof(GLYPH));
179 if (g == NULL)
180 goto memerr;
181 ourfont[gn] = g;
182 *g++ = ngv;
183 ngv *= 2;
184 while (ngv--) {
185 if (fscanf(fp, "%d", &gv) != 1 ||
186 gv < 0 || gv > 255) {
187 err = "bad vertex for";
188 goto fonterr;
189 }
190 *g++ = gv;
191 }
192 }
193 fclose(fp);
194 return;
195 fonterr:
196 fprintf(stderr, "%s character (%d) in font file \"%s\"\n",
197 err, gn, fontfile);
198 exit(1);
199 memerr:
200 fprintf(stderr, "out of memory in loadfont\n");
201 exit(1);
202 }
203
204
205 gettext(fp) /* get text from a file */
206 FILE *fp;
207 {
208 char *fgets();
209 char buf[MAXLINE];
210 register LINE *curl;
211 int len;
212
213 maxline = 0;
214 nlines = 0;
215 while (fgets(buf, MAXLINE, fp) != NULL) {
216 curl = (LINE *)malloc(sizeof(LINE));
217 if (curl == NULL)
218 goto memerr;
219 len = strlen(buf);
220 curl->s = malloc(len--);
221 if (curl->s == NULL)
222 goto memerr;
223 strncpy(curl->s, buf, len);
224 curl->s[len] = '\0';
225 curl->next = ourtext;
226 ourtext = curl;
227 if (len > maxline)
228 maxline = len;
229 nlines++;
230 }
231 return;
232 memerr:
233 fprintf(stderr, "out of memory in gettext\n");
234 exit(1);
235 }
236
237
238 arg_text(ac, av) /* get text from arguments */
239 int ac;
240 char *av[];
241 {
242 register char *cp;
243
244 ourtext = (LINE *)malloc(sizeof(LINE));
245 if (ourtext == NULL)
246 goto memerr;
247 ourtext->s = malloc(MAXLINE);
248 if (ourtext->s == NULL)
249 goto memerr;
250 for (cp = ourtext->s; ac-- > 0; av++) {
251 strcpy(cp, *av);
252 cp += strlen(*av);
253 *cp++ = ' ';
254 }
255 *--cp = '\0';
256 ourtext->next = NULL;
257 maxline = strlen(ourtext->s);
258 nlines = 1;
259 return;
260 memerr:
261 fprintf(stderr, "out of memory in arg_text\n");
262 exit(1);
263 }
264
265
266 maptext() /* map our text */
267 {
268 register LINE *curl;
269 int l;
270 register int c;
271
272 for (l = 0, curl = ourtext; curl != NULL; l++, curl = curl->next)
273 for (c = strlen(curl->s)-1; c >= 0; c--)
274 mapglyph(ourfont[curl->s[c]], c, l);
275 }
276
277
278 mapglyph(gl, tx0, ty0) /* convert a glyph */
279 register GLYPH *gl;
280 int tx0, ty0;
281 {
282 int n;
283 int p0[2], p1[2];
284
285 if (gl == NULL)
286 return;
287
288 tx0 <<= 8; ty0 <<= 8;
289 n = *gl++;
290 mapcoord(p0, gl[2*n-2]+tx0, gl[2*n-1]+ty0);
291 while (n--) {
292 mapcoord(p1, gl[0]+tx0, gl[1]+ty0);
293 mapedge(p0[0], p0[1], p1[0]-p0[0], p1[1]-p0[1]);
294 p0[0] = p1[0]; p0[1] = p1[1];
295 gl += 2;
296 }
297 }
298
299
300 mapcoord(p, tx, ty) /* map text to picture coordinates */
301 int p[2], tx, ty;
302 {
303 tx = (long)tx*cwidth >> 8;
304 ty = (long)ty*cheight >> 8;
305
306 switch (direct) {
307 case 'r': /* right */
308 p[0] = tx;
309 p[1] = ty;
310 return;
311 case 'u': /* up */
312 p[0] = xsiz-1-ty;
313 p[1] = tx;
314 return;
315 case 'l': /* left */
316 p[0] = xsiz-1-tx;
317 p[1] = ysiz-1-ty;
318 return;
319 case 'd': /* down */
320 p[0] = ty;
321 p[1] = ysiz-1-tx;
322 return;
323 }
324 }
325
326
327 mapedge(x, y, run, rise) /* map an edge */
328 register int x, y;
329 int run, rise;
330 {
331 int xstep;
332 int rise2, run2;
333 int n;
334
335 if (rise == 0)
336 return;
337 /* always draw up */
338 if (rise < 0) {
339 x += run;
340 y += rise;
341 rise = -rise;
342 run = -run;
343 }
344 if (run < 0) {
345 xstep = -1;
346 run = -run;
347 } else
348 xstep = 1;
349 n = rise;
350 run2 = rise2 = 0;
351 while (n)
352 if (rise2 >= run2) {
353 tglbit(x, y);
354 n--;
355 y++;
356 run2 += run;
357 } else {
358 x += xstep;
359 rise2 += rise;
360 }
361 }
362
363
364 writemap(fp) /* write out bitmap */
365 FILE *fp;
366 {
367 COLR *scanout;
368 int y;
369 register int x;
370 register int inglyph;
371
372 fprintf(fp, "-Y %d +X %d\n", ysiz, xsiz);
373
374 scanout = (COLR *)malloc(xsiz*sizeof(COLR));
375 if (scanout == NULL) {
376 fprintf(stderr, "out of memory in writemap\n");
377 exit(1);
378 }
379 for (y = ysiz-1; y >= 0; y--) {
380 inglyph = 0;
381 for (x = 0; x < xsiz; x++) {
382 if (tstbit(x, y))
383 inglyph ^= 1;
384 if (inglyph)
385 copycolr(scanout[x], fgcolr);
386 else
387 copycolr(scanout[x], bgcolr);
388 }
389 if (fwritecolrs(scanout, xsiz, fp) < 0) {
390 fprintf(stderr, "write error in writemap\n");
391 exit(1);
392 }
393 }
394 free((char *)scanout);
395 }
